  17-Year-Old Trailer: What To Check
Author Topic:   17-Year-Old Trailer: What To Check
Jgstewart8 posted 02-13-2005 09:53 PM ET (US)   Profile for Jgstewart8   Send Email to Jgstewart8
I bought my boat a few months back - trailered it home just fine 5 hours. Have used it a few times since as well. It is an older trailer, 1988 - but was not used too much - just sat around. It did have some rust spots I have tried to clean up. I mainly concerned about the bearings and such - what precautions can I take to make sure I will not have problems? thanks.
ryanwhaler posted 02-13-2005 09:55 PM ET (US)     Profile for ryanwhaler  Send Email to ryanwhaler
Have you pulled the hubs to inspect/pack the bearings?
DWE posted 02-13-2005 10:17 PM ET (US)     Profile for DWE
If the bearings have not been regularly packed, there is likely to be some, if not total degradation of the bearings to a dangerous extent. Since new trailer bearings are quite cheap, I would simply replace the old, existing bearings (of one-inch size on your trailer?) with new ones. The procedure is fairly straightforward, and I am sure many members will be of assistance to answer any questions you have.
Jgstewart8 posted 02-13-2005 10:31 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
I have no experience with trailer hubs - but i am sure i can figure it out pretty quick... how do i go about checking/repacking the bearings - any sites to help out?
jimh posted 02-13-2005 11:08 PM ET (US)     Profile for jimh  Send Email to jimh
Watch out for some very sharp, unfinished edges on the inside of those hubs. You can get a nasty cut. I am speaking from experience.
jimh posted 02-13-2005 11:12 PM ET (US)     Profile for jimh  Send Email to jimh
Also check:
--tire pressure, including spare tire;
--brakes, if the trailer has them;
--all lights and markers;
--winch strap integrity;
--all fasteners;
--corrosion in structural members, also in springs.
Chuck Tribolet posted 02-13-2005 11:33 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Is it a saltwater or freshwater trailer?
Painted or galvanized?
I agree with what's been said, and:
Check tongue weight (just so you know what it is).
Check integrity of any bunks.
Check integrity and easy of rolling of any rollers.
Check the hitch (the bit that goes over the ball on your
truck). Make sure it isn't worn thin.
Get spare hub kit (hub, studs/bolts, bearings, seals, grease,
and all the tools to do the change). It goes everywhere the
trailer goes.
Somebody posted a link a while back (I think in response to
a question from Ryan) to a page that had good instructions
on how to do the bearings.
Chuck Tribolet posted 02-13-2005 11:35 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Wheel balance.
Jgstewart8 posted 02-13-2005 11:42 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
Thanks so far guys - i have actually done a lot of that - it is galvanized/salt water trailer.
how long/consuming is redoing the hubs --
where is that thread with instructions? thank you.
DanT posted 02-14-2005 07:55 AM ET (US)     Profile for DanT  Send Email to DanT
Here are instructions.
http://www.championtrailers.com/techsup.html#packhubs
DWE posted 02-14-2005 09:29 AM ET (US)     Profile for DWE
Some more information:
[urlhttp://www.rverscorner.com/articles/bearing1.html9[/url]
DWE posted 02-14-2005 09:30 AM ET (US)     Profile for DWE
Jgstewart8 posted 02-14-2005 01:49 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
Thanks so far guys - how time consuming is this project usually?
Jgstewart8 posted 02-14-2005 01:58 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
Would replacement bearings from walmart be ok?
what grease should we use?
Buckda posted 02-14-2005 02:14 PM ET (US)     Profile for Buckda  Send Email to Buckda
JG-
Should not take too long, but I always add in time for "key learnings" when I've never done it before.
Expect this to be a very messy job. A full roll of paper towel and a tub of GoJo should be at your side.
I'd expect under normal operations 20-30 minutes per wheel to check and re-pack the bearings....but for a beginner, allow an hour for the first one and a half hour or 45 minutes for the other one. You'll get faster as you get familiar with how to do it.
Bearings from Wal-Mart should be fine if they're the correct size....most important thing is to make sure they are greased properly and completely.
Dave
DWE posted 02-14-2005 03:00 PM ET (US)     Profile for DWE
J.G.—
I agree with Dave on the times provided to complete the job, especially for a first attempt. On our trailer I never greased the bearings in the past five years we owned it, and not knowing when the previous owner last serviced them, I just decided to replace them last fall. (This was my first time servicing a trailer, albeit with my father’s assistance.) The only complication during the procedure occurred when trying to dislodge the race from the hub. One hour’s worth of whacks with a hammer and punch finally removed it; after that, it was trouble-free. The specific grease should be “trailer wheel bearing grease,” and is usually found at the same place where you buy the bearing kit. I suggest wearing latex gloves, too, because the process is awfully messy.
Good Luck,
DWE
Jgstewart8 posted 02-20-2005 11:12 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
Guys,
I am heading home this wkd to do some stuff to the boat in order for the Key's trip in March -- I was thinking, since I am not sure of the age of the hubs (quite possibly the age of the trailer) would it be a wise investment to go ahead and install new hubs instead? How time consuming is this?
Jgstewart8 posted 02-21-2005 11:29 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
any opinions on that?
Morro Bay Whaler posted 02-24-2005 12:30 AM ET (US)     Profile for Morro Bay Whaler  Send Email to Morro Bay Whaler
If the tires are original, it is time for new tires. Even if the tread wear is fine, the sidewalls start to degrade. I had one blow out and the treads looked new! Check the sidewalls on the inside.
nFL_Bosn69 posted 02-24-2005 09:03 AM ET (US)     Profile for nFL_Bosn69  Send Email to nFL_Bosn69
Unless you've had some sort of catastrophic failure, like melting/grinding out a hub with a frozen bearing, or show excessive wear, your existing hubs should be ok, they're fairly static(no moving parts), but I would replace the bearings, if needed, and the grease, even if not needed. You've got a long trip no need to chance it. I agree with MBW, unless you absolutely know the tires are new, replace them. Also, make sure you have extra fuses for the tow vehicles lighting circuit.
Ryan
Jgstewart8 posted 02-25-2005 08:54 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
Ok,
I took my my wheel tonight - and have no idea how to get into the hub - or take it off... all there is a zirk fitting on the end of the hub... any help?
Jgstewart8 posted 02-26-2005 01:38 AM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
I got the dust cap off - there is a LOT of blue grease in there--- should i be removing all of it prior to repacking?
FISHNFF posted 02-26-2005 02:38 AM ET (US)     Profile for FISHNFF  Send Email to FISHNFF
How does one know what size hub to get for a replacement?
Some hubs have different size inner and outer bearings. Do you need to measure these?
Where do you measure these at?
My trailer is the original one sold with the Whaler, a 1968 Shoreline with rollers, bunks, and 12" wheels, 5 lug. It has those plastic end caps bearing protectors with a zerk fitting.
I want to replace them, as I am redoing the entire boat and trailer.
FISHNFF
DWE posted 02-26-2005 08:42 AM ET (US)     Profile for DWE
Yes, JG, remove all the existing grease and clean the area with a solvent (I prefer 3M General Purpose Adhesive Cleaner) before repacking the new bearings with, of course, new grease. The entire purpose of repacking is to remove the older, contaminated grease with fresh grease to ensure proper lubrication of the wheel bearings.
Jgstewart8 posted 02-26-2005 11:39 AM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
How do I know what size the bearings are?
Jgstewart8 posted 02-27-2005 12:58 AM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
I decided to just go ahead and get new springs and hubs (both rusty)
my question is - the new hubs come preloaded with grease - do I need to have marine grease in them, or get special marine hubs, or what?
Jgstewart8 posted 02-27-2005 08:56 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
I mainly just need to know if there marine "hubS" i should be buying, or it any ole hubs will do.
Jgstewart8 posted 03-01-2005 01:27 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
do I need to get marine friendly hubs, or will any greased hub do? I am going out to buy tomorrow...
jxs226 posted 03-01-2005 02:35 PM ET (US)     Profile for jxs226  Send Email to jxs226
I'd strongly suggest you get galvanized hubs as they'll stand up to saltwater immersion much better over the years than painted hubs.
Jgstewart8 posted 03-01-2005 04:36 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
Thanks - to be honest, this trailer will see saltwater 2x a year max. Are there special hubs to get since they will be submerged in water?
DWE posted 03-01-2005 05:29 PM ET (US)     Profile for DWE
To answer your question, I do not think there is such a thing as special “marine” trailer hubs. Unless your hubs and springs are severely deteriorated (cracked and rusted-through), as opposed to having just surface rust, I would not go through the hassle of replacing them. Just concentrate on greasing the bearings because if not done properly, your Florida Keys trip will terminate in a rather abrupt and possibly unsafe fashion.
Jgstewart8 posted 03-01-2005 07:02 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
DWE - the hub itself is pretty rusty on the outside, and I am already replacing the springs. I think I will be replacing the hub as well. Should I repack the new hubs?
DWE posted 03-01-2005 07:55 PM ET (US)     Profile for DWE
If the new hubs come preloaded with grease, then I do not think there is any need to repack them. Just make sure to grease the wheel bearings and everything will be fine.
DWE posted 03-01-2005 09:12 PM ET (US)     Profile for DWE
Also, JG, how about updating your profile to include the webpage of your beautifully restored 15-Striper?
Jgstewart8 posted 03-01-2005 10:05 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
DWE - ok thanks... even if the grease is not the "blue marine" grease? How can you know how much grease needs to be in the hub?
i will put the site on my profile.. i had to remove a few pics and add a few others for a CPSC project at school, but I will change it back in a few weeks.
Rastuscrab posted 03-01-2005 10:24 PM ET (US)     Profile for Rastuscrab  Send Email to Rastuscrab
JG: Great comments by everyone! Some other things to consider (Time, Knowledge & Safety). (Time)I had a profesional trailer company install new hubs on my Montauk's trailer last year. It took them about 45 minutes and cost me under $100 including the bearings. It would of cost me more to buy extra tools and get everything done. (Knowledge)I then installed my old bearing buddies on and use marine grease only. Regular grease breaks down a lot faster! I check the bearing buddies before every trip and add grease if I have too.(Safety) make sure you have a safety strape on the bow that goes strait down to the trailer. This will help keep your boat snug to the trailer when transporting. Believe me if you are going a long distance it will relieve the bouncing of the boat that causes you fatigue.
Also, I wash my trailer and boat down after every use. This helps get salt and other junk off your boat trialer.
I run my boat (12) months a year and fish heavy in the ocean during the spring and early summer for Salmon. In the fall I fish in brackish water for stripers and run about 5-10M miles year on the trailer and (knock on wood) never had an issue!
Just some more ideas to think about!
Matt
Gene in NC posted 03-01-2005 10:36 PM ET (US)     Profile for Gene in NC  Send Email to Gene in NC
Hubs can't be done too well. Consider oil bath hubs. Never need to touch again and you can see the oil through the clear dust caps.
