Topic: Suzuki DT225: Check Engine Light
Hans Jacobs |
posted 04-07-2005 05:34 PM ET (US)
After I collected my Revenge from the winter storage I am having a problem with my Suzuki DT225. I never had any problem, so far the engine has been very reliable. I had the boat stored inside and serviced by a Suzuki dealer. (The engine is from 1998, I bought it 2 years ago with 50 hours on the meter and currently it has 200 hours)From the moment my Revenge is in the water again I have the problem. The light "Check Engine" goes on and the rpm's fall back to idle now and then (appearently the engine has a safety mechanism that limits the RPM in case of a problem) . My first thought was that it had to do with old fuel, so I filled the tank up 100% (it has been 25% during the winter) but after filling it still has the same problem. It starts without problem and when running idle it sounds ok (but the "Check Engine light lights up now and then) If I let the motor run a little bit more revs then now and then the light goes on, rpm falls back to idle and after a few seconds it picks up the rpm again. The dealer claimed they added fuel stabilizor to the fuel but on the bill I can see they used something against humidity and not stabilizor. I checked the manual and it seems that the "Check engine" light has to do with the electronic fuel injection system. I called the dealer, but before can they can do anything they have to order a book from Japan (which will take 2,5 weeks) and their comment was, everything breaks down at one moment in time. (They are willing to do a quick check to see if there is a simple from like a loose wire) I find it quite a coincidence that just after service (and winter storage) I am getting this kind of problems. Further, when I looked at the fuel tank indicator (when I just collected the boat with fuel thank filled up 25%) I also noticed that at the moment the motor stalls the fuel indicatior goes down to 0, and, coincidence or not, my Navman 3100 fuelflow meter is not working anymore. (I tried it also without the Navman sensor, which made no difference) I went to an other dealer which services my other boat (but isn't a Suzuki dealer) and he suggested that the fuel injectors might be fouled and advised to use "Fuel System Cleaner" from Evinrude Johnson. The idea that it has to do with the fuel seems logical to me. I want to try to run the engine with the cleaner from a portable fuel tank. Is this a good thing to try? Any other suggestions?
LHG
posted 04-07-2005 05:50 PM ET (US)
EFI 2-strokes are very suseptible to water in the fuel, and with your tank filled only 25% during storage, you could have that problem. I would check to see if there is a smaller water separating fuel filter on the engine, like the Merc EFI's have. If that is full of water, it might give the signal you are getting. |
jbarrow4124
posted 04-07-2005 10:09 PM ET (US)
I vote that you have water in your fuel like LHG suggests. I had the same problem years ago with my 150. Ran great standing still or on the trailer. In the water, it ran terrible. Try a six gallon portable tank with fresh gas first to see if the problem goes away. If it does, invest in a fuel/water separator. If you still have the problem, at least you have eliminated one potential problem. I never had the problem again after installing my Racor separator. |
Hans Jacobs
posted 04-09-2005 04:21 PM ET (US)
Thanks for the responses, today I tried it with a portable tank. I had the machine running idle for around 10 minutes. At first the problem seemed to be worse then before but after a few minutes I guess it was the same. Is there anything I can try next or am I now totally depended on the dealer? Will it be usesfull to try it again from the portable tank with the "Fuel System Cleaner" added? Or is there a risk that I am making things worse? |
posted 04-10-2005 10:53 AM ET (US)
Usually the Owner's Manual will describe what is indicated when a particular warning gauge is illuminated, although sometimes the pidgeon-English translation of documents composed in foreign languages often muddles the meaning.Suzuki must have someone who could tell you over the telephone or via email what precise condition is indicated when the CHECK ENGINE warning lamp is illuminated--or at least you would think they could. It seems absurd that you have to wait weeks to find out this information. Has not SUZUKI heard of the internet or email? They make a nice engine, but, come on, this is not 1800's and the telegraph hasn't been invented yet! It is always a good idea to have a SERVICE MANUAl for your engine, too, even if you don't plan on doing extensive repair work on it yourself. A service manual will have an electrical schematic diagram, and you could probably deduce which sensor was illuminating the alarm light. It will also help you understand more about the engine, if just from browsing through it. You better order that volume well in advance, though, as it sounds like it might take a while to get one! |
Hans Jacobs
posted 04-12-2005 02:35 PM ET (US)
After some research I found a dealer that has the computer with the required interface to read out the computer of the engine. An advantage of being in The Netherlands: everything is relatively close. Still it would be a good idea to order the Service Manual. The importer told me that the the flashing of the Check Engine light is not at random but indicates an error code. You need the Service Manual to find out the meaning of the code. Thanks for the responses. |
posted 04-13-2005 08:46 AM ET (US)
It sounds like the controller in the Suzuki engine is similar to ones used in automobile engines. They will wink the CHECK ENGINE light on/off in a pattern. By counting the flashes in a long sequence, you could deduce the error indication by consulting a reference chart. I tried this once with the EEC-IV controller on my Ford automobile--it was a tedious process! Much simpler to use the computer interface to read the code.Good luck with the motor. What was the error being indicated? |
Hans Jacobs
posted 04-17-2005 04:44 PM ET (US)
The error being indicated was: Throttle system sensor. The dealer found the error using the service manual. He explained that there are only 4 different error codes so there is no real need to use the computer.The dealer advised first to clean the air inlet (spray stuff into the inlet while the motor is running and leave it for one night) and use the fuel system cleaner in a 6 gallon tank. If that was not going to work the sensor needs to be replaced. So I did the cleaning stuff, today I tried again and there was definitely an improvement. In the beginning it seemed to be worse, the motor stopped something that never happend before. After a while it became better. At the end, after 1 hour, the CHECK ENGINE flashes occasionaly (last week it flashed several times during a minute, now it didn't flash for several minutes). So the problem is not gone but it looks like the situation is better now. Ordering the sensor takes 3 weeks in the worst case. I will have to take a descision soon Whether or not I want to order the sensor because there are some good events (With the Dutch Boston Whaler club) coming up. I will try the inlet cleaning again today and see if it improves further tomorrow. |
Vince
posted 04-17-2005 08:05 PM ET (US)
We had a similar problem with that same engine. There are not a lot of Suzuki products out here, but I did a lot of research. Troubleshooting that outboard was suprisingly similar to our Mercs and Yamahas. Anyway, we rectified that same problem by replacing the T.P.S.(throttle position sensor.) Also, we had to perform a module reset, because some of these Suzukis, when a problem is detected, will go into a "limp home" mode, where they may not run great, but at least you'll get back to the dock. |
Hans Jacobs
posted 04-18-2005 04:08 PM ET (US)
I decided to order the sensor, the reaction of Vince was the last push I needed. I did try the engine for a few moments today but the CHECK ENGINE light was still going on now and then. Vince: How did you perform the module reset? Is just taking the power away not enough? How did you find out the cause of the problem? Also using the service manual? How did the fact that troubleshooting Mercs and Yamahas is similar help you finding the problem? |
Vince
posted 04-18-2005 06:20 PM ET (US)
Hey Hans, after replacing the T.P.S., there was a procedure we used to clear the fault code. It required grounding out a certain lead BEFORE the 12V power disconnect. This clears any trouble codes. It's a lot cheaper than buying the Suzuki Only laptop. If you like, I'll look through the service records tomorrow and email you the exact procedure. |
fno
posted 04-18-2005 06:27 PM ET (US)
Hans, is the vent on your tank closed or plugged? If so you will be drawing against a vacuum and not get any fuel to flow. It's a common enough problem and often overlooked. |
Hans Jacobs
posted 04-19-2005 04:45 PM ET (US)
Vince: It would be great if you can email me the procedure!Fno: I checked that, in the beginning I had the idea that it could have something today with ventilation of the tank. Everytime when the problem occured the tank meter gauge moved. Later I realized that at the moment the engine goes back to idle, all the petrol in the tank moves and so it is not strange that the fuel gauge moves...
Vince
posted 04-24-2005 05:26 PM ET (US)
Sorry Hans, Busy time of year for us, completely forgot. Get home at night and realize when I get on the site that I have to get back to a couple of you guys. Did everyone except you. Call me or e-mail me and I'll get you the info. Sorry again,.....Vince |
posted 04-24-2005 11:46 PM ET (US)
On an electronic fuel injection engine, the throttle position sensor (TPS) is really crucial to the engine's smooth operation. This component informs the engine control module (ECM) of the throttle position, and this determines many other elements of the combustion process and its timing. Typically the TPS signal is a voltage that varies from 0 to 5 volts and is produced by a potentiometer which is linked to the actual throttle plate in the engine's air intake path.There are many potential problems with the TPS and its electronic signal. First, if there is any mechanical problem with the linkage between the TPS and the actual throttle plate, the indicated position can be false, causing problems. It is now seen on modern engine designs like the Bombardier Evinrude E-TEC that the TPS is mounted directly to the actual shaft of the throttle plate without any interconnecting mechanical linkage. This is the best arrangement. Other designs have link arms, cams, or other devices to actuate the TPS remotely from the throttle plate shaft. Misadjustment, play, or binding in these linkages can cause problems which result in false indication on the TPS signal. Second, the TPS can develop electrical problems. The potentiometer can fail, become noisy, intermittent, or short out. Also any connections between the TPS and the ECM can be sources of problems. Loose connections, broken wires, and poor shielding which admits electrical noise are all typical problems. High temperatures can also cause failures. Water or oil can also create problems for the electrical circuit. Typically the TPS consists of nothing more than a potentiometer built into a special housing with appropriate mechanical link and electrical connector. There typically are no active electrical components in the TPS. The potentiometer portion probably costs about $5. When sold as a marine replacement part with an OEM brand and packaging, I am certain the cost will be far greater. I would be interested to know the price of a new TPS for your Suzuki engine. |
Hans Jacobs
posted 04-30-2005 03:30 PM ET (US)
Thanks for the interesting information about a part of my engine I was never aware of before. Since I have the problem with my engine I am forced to find out how the different components of the engine work together and that is very interesting. I am sure I can enjoy it even more when the problem is solved.I removed the TPS and you are absolutely right, it is a very simple device. I ordered the TPS; hopefully I will get it this week. They charge me 150 euro (around $200). It is a lot of money for a very simple device but I don¥¥¥t have a choice. I am not 100% sure if a new TPS will solve the problem because the CHECK ENIGE light is not always flashing the TPS error code, also because it looks like the problem is less after running the engine for some time at high speed. Since I have the problem I didn¥¥¥t use the engine for long periods of time or under heavy loads because I was afraid to do damage to the engine but tomorrow I will try it for a longer period of time to see what happens.
posted 05-01-2005 08:48 AM ET (US)
Ouch! $200 for the Throttle Position Sensor is quite expensive. In contrast, a typical automotive engine OEM replacement part would be about $50.I think the Suzuki is a fine motor, but those parts are certainly sold at a premium! I hope this cures your problem. Keep us posted, please. |
Hans Jacobs
posted 05-02-2006 12:28 PM ET (US)
[One Year Later...]At last the problem with the Suzuki on my Revenge has been solved. After visiting 3 dealers, execute every test from the repair manual that I could do myself; the solution was a lot easier then expected. I am almost ashamed to tell¥¥¥.. I noticed already that the sparkplugs (that had been replaced during winter maintenance) were not exactly according to the specifications in the manual. I pointed this out to 2 of the dealers and they both said that it was impossible that this could have something to do with the problem. This winter I asked the third dealer look at the problem and after 1 day he called already that it was most probable was caused by interference of the bogies with the 2 computers in the engine. Last weekend was the first opportunity to do a test run and¥¥¥ the problem was gone. The engine was performing excellent, as it always did before. During the process I learned a lot about the engine, what was very interesting, but the most important lesson: trust my own ideas.
Tom W Clark
posted 05-02-2006 12:37 PM ET (US)
Hans,This saga and its resolution illustrate a couple lessons I have learned over the years: - The solution to a problem is VERY OFTEN quite simple. - It is wise to FOLLOW YOUR INTUITION. |
jumpjet231
posted 05-03-2006 05:53 PM ET (US)
[The author began his article with a direct quotation of something previously posted in this discussion, but failed in include quotation marks or attribution, which was quite confusing.]$194 to replace my TPS and repack the bearings on the trailer. Luckily with Suzuki's you rarely have to do anything, unlike Mercs. |
posted 05-03-2006 08:31 PM ET (US)
Hans--thanks for the follow-up. It is always interesting to hear the resolution of a problem like this.Engines with fancy computer controllers will be susceptible to Radio-Frequency-Interference (RFI) from spark plugs. These engines almost always require special RFI-suppressor spark plugs. Jump---If you want to quote something, include the quotation marks and give attribution so we can figure out what you are talking about. |
Xavier
posted 08-27-2008 12:40 PM ET (US)
hello, I am not really having a trouble (yet) I just acquired a well used 2001 DT 225 and I am figuring out the workings ( I have the seloc manual) I installed the engine on a motor stand and already started it (it was frozen due to lack of use) I just rigged all the wiring harnesses, and started it a couple questions now: after opening the ignition all the lights on the warning gauge light up, with exception of the bottom (red) one on the oil gauge (under the green lights) and the oil light itself (to the right of the gauge, under the check engine one) ..is this normal? during rigging, I removed the oil tank, and there are six hose conections ahead of the inyectors, connected to nothing..according to the seloc manual, this is where the oil was injected on older DT225s, this engine has the oil injection conected direct into the high pressure pump, before the injectors, should the inlets be capped (shut) or left open (there is a slight vacumm there)Outboard will be installed on a 26 foot bayliner rendezvous catamaran, (right now it has a 120 HP force of 1992 vintage) and is used year round at an altitude of 2000 meters over sea level, what fuel consumption should I expect? (the force is a gas guzzler, but is only 120hp) more questions later best regards from, of all places, Mexico... Xavier |
Xavier
posted 08-28-2008 04:06 PM ET (US)
more info: this is how the message gauge looks when the ignition is turned on: http://www.youtube.com/watch?v=LfT7yhzUR8w also, if anyone needs the flashing codes for the DT225, just ask Xavier |
Xavier
posted 10-09-2008 10:06 AM ET (US)
*bump* anyone, at least on the oil conections next to the fuel injectors...? Xavier |
watersm
posted 10-01-2009 01:10 AM ET (US)
I also have the Suzuki DT225 and on my last outing, power significantly reduced. Full throttle results in very slow acceleration to 3000 rpm and about 28 mph. Can't get it up to 4000 rpm. Prop is OK. Thoughts: Gas gummed up. Bad cylinder(s).Someone said powerhead needs replacing at $9800... is that another term for engine itself? Parts lists have crankcase, cylinders, heads, etc., all at less than $1K Nothing is $9800. |
Tohsgib
posted 10-01-2009 10:10 AM ET (US)
Do a compression test. |
bksnow
posted 05-21-2012 04:15 PM ET (US)
I need the engine codes for DT225 Suzuki 2001. Thanks |
