posted 04-13-2005 09:18 AM ET (US)
To replace the water pump impeller on most all outboard motors you have to remove the lower leg of the outboard. The size and weight of the lower leg is proportionate to the horsepower, so with a 90-HP engine you are about at the limit of the weight that an average guy can handle by himself.To remove the lower leg you have to remove about 4-6 fasteners. You also have to disconnect any linkages between the shift shaft and the shift actuator in the power head area. This linkage is a bit more difficult to disconnect on OMC motors than on Mercury motors.
Once you have the lower leg removed from the engine, the water pump housing has to be removed, the old impeller removed, and any associated wear plates or gaskets removed, too.
On paper all of this goes smoothly, but in the real world there can be corrosion which prevents the many fasteners or parts from separating. There can be more time spent taking things apart than anticipated. It depends on the condition of the motor and how long it has been since these components were serviced. Also, if there is corrosion on mating surfaces, this may need to be cleaned up so that a proper fit is obtained.
The new impeller is installed, the new gaskets and other components installed, and the lower leg reassembled. Then the lower leg must be returned to the engine. This can be awkward to accomplish.
When the lower leg is installed on the engine, there are several components which must align, typically:
--the drive shaft
--the water pump outlet hose
--the exhaust passage
--the shift shaft
If you are good (and lucky), all of these components align and slip effortlessly together on the first try. You will be holding the lower unit (which has considerable weight) with one hand, and trying to align all of these components with the other hand. Once you finally get everything aligned, you continue to hold it together with one hand while you quickly install a fastener or two with the other hand.
When the engine has been reassembled, you have to re-connect the shift linkage and verify it is still operating properly. Then you have to start and test the engine to verify the new water pump is working properly.
I suppose if everything goes well and the mechanic knows what he is doing, he can accomplish all of this in an hour.
At one of my local dealers they usually offer a fall or spring special where they will replace the water pump impeller for a flat fee. I have seen the mechanic line up about 5-6 boats (on trailers) and work on them all at once. He is quite efficient and can get them all done in good time.
The parts used in the overhaul of the water pump can vary. If you just replace the impeller with a discount or aftermarket impeller it can cost as little as $15. If you replace the impeller with an OEM part, it can easily be double that. Also, sometimes a replacement "kit" is used which contains a number of gaskets, seals, and wear plates for the pump. The kit usually costs about $30-$50. Finally, the actual housing of the water pump may need replacement, and this part can be another $15 or more. As you can see, the part cost can vary quite a bit, say from $15 to $75 or more.
