| Author | Topic: Letting an Engine Die with Dignity? |
| Buckda |
I’m having a bit of frustration with the motor on my 18’ Outrage this spring, and quite frankly, am posting for a bit of encouragement…and perhaps some words of wisdom/experience, if you have them. Here’s the problem that’s causing my frustration. Over the winter, I implemented some major improvements and modifications on my 18. Most noticeable, is that I added an arch, but there was a lot of other work that was done that is not as noticeable. I added a power distribution panel and re-wired nearly everything in the console, among other projects, including cleaning the decking under the console and fixing what appears to have been a long-standing oil leak from the remote oil tank that is located there. When I had everything re-connected early this spring, I tested all electrical systems, lights, instruments, electronics, accessory outlets, etc. Everything worked. I then turned the key to “on”. The familiar Beeeep, Bip Bip! Of the oil warning system sounded. I turned the key off, and turned off the battery selector switch while I installed the VHF radio into the console. When I re-ran the tests, everything worked EXCEPT for the oil warning horn. Because the original horn was pretty badly corroded (made of metal, unlike the plastic replacement) I simply ordered the replacement horn and installed it. Still no sound, and following the Service manual for my 1986 Mercury 150 HP motor, determined that it was a faulty warning module. This was confirmed by the presence of PLENTY of blue smoke and a continuously full engine-mounted oil tank. Two weekends ago, I installed the replacement Oil Injection Warning module ($195), but was unable to test the motor due to the snow falling outside. Last weekend, I got up early and ran to Michigan to tow the boat to Grand Rapids to have the trailer tires replaced. On the way back the day cleared off with beautiful sunshine and 50 degrees. I decided to put the boat in the water and test the module. When I splashed the boat, the warning horn sounded the familiar three tone pattern, and then, after warming the motor up for awhile as I parked my rig, backed out of the ramp and headed down the river. Slowly a continuous tone began sounding from the console. I turned around and headed back to the ramp (I had only traveled perhaps ¼ mile downriver) and pulled the service manual which indicated that this continuous tone was an overheat warning. I pulled the cowl and placed my fingers on the powerhead (right where the sparkplugs are) and while the motor was warm to the touch, it certainly was not overheating. Smoke continued to come out as normal, and I checked the oil tank on the powerhead, and it was still full. At this point I turn the motor back on, still sounding the horn, so I switch it off, only the starter motor, while not engaged, is still spinning. I switch the battery selector switch to “off” and turn the key off and the motor quits. (This might be a separate problem!?). I then go back to the motor to take a look at the black wire that is supposed to be running to the overheat sensor. When I unscrew the screw that holds this wire, it literally crumbles in my hand, and the ugly tarnished green color of rotting wire strands are exposed. I decide that the day of boating is over for me, and I tilt the motor up to recover the boat. I go back to look at the engine one final time before re-installing the cowling, and notice big, ugly blobs of oil surfacing from the exhaust hub of the propeller (released when I tilted the motor up?). I pull the boat and the lower unit continues to hemorrhage black oil (thank god it wasn’t milky) onto a towel I’ve placed on the pavement underneath it. I’m thinking failed shaft seal, but haven’t heard the diagnosis from the mechanic yet, since I simply left it at his business Saturday afternoon and called him this morning on the drive in to work to let him know what was wrong and to take a look at it. I’m frustrated, because I literally spent more than 1,000 on truck and trailer improvements or maintenance last week (My computer chip on my truck died on Monday, and it needed transmission service anyway), so I figure I’ve pretty much already blown my boating budget for May and even part of June before I even undertake these repairs. I’m thinking that I definitely have to “sit out” the month of May. I hope the fish are biting near the pier. Here’s the thing that’s just not sitting well with me right now: The compression on the powerhead was good at last check – about 130 PSI on all cylinders. Additionally last fall, I spend around $650 on maintenance items such as replacing corroded thermostats, replacing the water pump, etc. I’m thinking that now, I need to replace maybe 50 percent or more of the wiring, which is easy enough to do, just time consuming, on top of concerns about doing it correctly, will have to have a professional replace/repair the prop shaft seal, and probably troubleshoot the oil-injection warning system. I figure at least $300 more dollars, perhaps as much as $500 will be spent this week…I guess I’m wondering when to stop and just sit out a season to work on the repowering equation? Thanks for listening/reading. Dave |
| bsmotril |
It is obvious to me what happened here. After you spent all that time and money improving the boat, the motor is now jealous. Being temperamental is just a ploy to get some attention. When I got a new rig some 8 years ago, one of the first things I did was seal all the crimp connectors under the cowl, and around the batteries/bilge, with liquid electrical tape. After 8 years of saltwater use, everything is still in good shape wire wise. You may be able to buy a complete wire harness for the motor which would make the job go quicker. BillS |
| Buckda |
Thanks Bill. At least we've solved the question about why boats are referred to as "she"! ..and irrational jealousy at that. I spent time and money on this motor all last year, with that $650 winterizing special to tuck her in for the winter. I even bought her a new shiny SS propeller, and replaced her corroding trim-tab anode! |
| bsmotril |
You've done all the right things. One can only assume you have a gold-digger there. Perhaps you could justify replacement on those grounds ;-) BillS |
| Buckda |
Divorce?!! But it's so expensive! |
| MyOutrage |
You're living the fear that all of us with old motors have. Perhaps it's time to bite the bullet on a re-power (yeah I know... easier said than done) Best of luck. Hope you get a pleasant surprise from the mechanic. '89 Outrage |
| LHG |
Dave - I think you've done the right thing, to get the opinion of a Mercury technician who knows these engines, rather than trying to work on it yourself. Afterall, that engine, from outward appearance, was not all that well taken care of in the first place by previous owner, and has already been re-built with some used parts, correct? My feeling is that engines that are cosmetically beautiful, like the 150 that came on my 21, are worth keeping up, but those that don't look so hot, are not. Even if they are in perfect mechanical shape, they won't have much value if they look bad. It sounds to me like your problems are mostly with the wiring. I would have them go over it, checking all systems. If they tell you it needs a lot of work, I would check the "outboards for sale" listing on Scream and Fly.com. Lots of good used engines, mostly Mercs, show up there. Someone in Livonia Mich has a mint 1992 200 EFI for sale for $3900, but it would need a 5" extension for your use. A new 2.5 liter 25" Merc 150 XR6 (carbed) is about $7500, while they last. A modern 135 Optimax puts out the same actual performance as these older 2.0 liter 150's from what I can tell |
| Buckda |
Larry - That's the direction that I think I'm headed (used merc that can synch up with my current guages and controls). For $2-$4K, I think I can get back on the boat with power that will buy me 4-5 more years of use, and then I will repower again with new technology. I'm thinking. But that's why I posted. I wanted to get some thoughts/advice from folks who are somewhat removed from the situation and not commenting from an emotional perspective. Of course, I'd have to explain to the bank why the motor they helped me buy is no longer on the transom.... Dave |
| kgregg |
>Divorce?!! But it's so expensive! Why are divorces so expensive? Because they are worth it!! Dave- Let the Merc mechanic give you an estimate of what it would cost to repair the motor. Don't make any decisions until you have that number. I bet you could repair your current motor several times for what you'd spend on a repower with a used outboard (that may have its own problems). Good luck. Kevin (owner of aged 1991 Merc 135) |
| andygere |
Dave, I was there not too long ago when I had to shell out $700 to have my tilt ram replaced. I did talk with my mechanic about new and used motors, and he told me that as much as he'd like to sell me a new Opti, that the rest of the thing (it's an '89) was in pristine shape and had a lot of hours left in her. In the end, it's just economics. Figure out how much more life you expect if you do the repairs (be conservative), and compare that annual cost to that of a new motor (amortized over its expected life), and even a good used one as Larry suggests. It may be easier estimate in terms of running hours instead of years, which makes more sense anyway. Then, convert hours to seasonal use to figure out the net present value of the alternatives. In the end, short term cash flow may dictate what you do, and that's an important consideration. My gut feeling is that if the powerhead and lower unit are sound, and there's not too much corrosion, she's worth saving, at least this time around. |
| andygere |
One more thing, sunk costs, the money you have already spent on this engine, are not relevant in the decision. What you really want to decide is how to spend your money going forward, and get the most value per dollar spent starting now. All of this assumes that you will get a satisfactory level of performance and reliability if you repair, buy new or buy used. |
| Vince |
Hey Dave, I feel for you. Other than the shaft seal, there are ways you can continue to motor around until the dreaded re-power financial issue comes around. I believe Sierra makes a aftermarket engine harness that you can replace semi easily, for your alarm issue. Also, if you're concerned about oil injection issues, why not bypass it and go back to mixing 50:1. This is just a suggestion, by no means assume I'm telling this is the remedy. By the way, winter, when it comes again, we're hearing through the grapevine that all the major manufactuers will be offering super low interest rates on new engines.(maybe because of gas prices?)Anyway, good luck to you and I hope you get there next may. |
| LHG |
Regarding Vince's comment, even in conventional 2-strokes' last days, they are still 35% of the new engine market. I think that the manufacturers are afraid that once they are banned, they will need sales incentives ot move the cleaner, more expensive engines. Many will simply put off buying and stay with what they have, or get it repaired. |
| Buckda |
Gentlemen - thank you for your levelheaded and thoughtful comments. I hope to hear from my mechanic tomorrow, however this is a very busy time for him as the weather just turned nice and everyone wants their boats put in the water. I'll let you know when I do. Vince - I am intrigued by your gossip. Would it be unprecedented for manufacturers of outboard motors to offer financing? How will this be done, given that some states do not title the motor separately from the boat? I've asked about this before (last fall) and the reply was that you generally need to go through a bank and take a lein on both the boat and the motor. Dave |
| MyOutrage |
Now that the topic of re-powering w/ "used" has come up, I'll tell you that's exactly what I did last year. I bought the boat in the beginning of the season with a blown engine and opted to repower with used from a local dealer. While I wasn't in a big hurry to drop the dollars for a new engine, the real reason (or the reason I've convinced myself of) that I went with "used" is because I was waiting for the optimax / 4stroke / E-TEC battle to prove out. Now, is repowering w/ "used" care free... nope. I've had it in for some work (missed a day of boating). But I've heard the same or worse from those buying brand new. Good luck with your decision. |
To re-seal the propeller shaft on a lower unit is probably about $300. The wire to the heat sensor is probably running in the hottest part of the engine. That's why they put the heat sensor there. The other wires may not be as bad. And wires are relatively inexpensive if you replace them yourself. If the fundamental parts of the engine--pistons, block, rods, crankshaft, lower unit--are still OK, I would not give up on it yet. If you have a mechanic you have some faith in, that is another asset. Sometimes a series of little things conspire to make you think the time has come to give up on the engine. It just might take one more $50 investment and you could be back in good shape! |
| rtk |
www.yamaha-motor.com/finance/finance.html I did not see anything on the Mercury and Evinrude sites. Some dealers have relationships with companies or can refer you to companies that offer personal loans to pay for repower. I wonder why a company can offer no payments/interest for 12 to 24 months on furniture and not outboard motors. Marine financing sources are finally becoming more available and the terms alot more flexible. If they can offer easy financing I would think they would sell alot more product. Rich |
| Bulldog |
Dave, I think that you would do better to fix what you have if the price is resonable, and save up for the brand new super-duper-techno-weenie engine in a couple years! You said you did a lot to the motor last year, and compression is good, so wait and see what the mechcanic says. The motor industry is changing so fast and becoming so much more efficent that I think I would rather spend my money on a new motor that will last 16-20 years then buying a used motor that you would hope will last a couple years. Remember boats are a hole in the water surrounded by fiberglass into which we all throw money!...Jack |
| jechura |
Dave Possibly a good, fast talking son could use or own a 22 Guardian. Jerry |
| Gep |
Dave, I went through something similar last year. I think that you should just spend (within reason)the money to fix what you have. That engine ran fine for 635 miles on the Georgian Bay trip last year. If it was a crummy engine, it would have died then.
| Plotman |
I spent a few weeks being really frustrated with my engines when I bought my new boat. I felt exactly the same way you did. I tore into the carbs myself, and ended up also having to have a remote oil pump replaced. It took a little effort and experimentation (and the help of a gear-head friend) to get the carbs adjusted properly after I rebulit them, but since them my engines have been bullet proof. I would go with the advice that as long as the powerhead and major mechanical componants are sound, it is worth fixing the little things. We are still using a 1964 evinrude at our fishing camp. It needs to be fed parts every so often, but even so, there is no way we can justify the cost of a new engine as long as this one keeps on working... |
| Cicada |
Dave, I think it's also too late for an anullment. I can relate to the trusting your propulsion and that sinking feeling that comes with major repairs and investment. Not an easy decision. There are compromises involved unless you have an unlimited budget. I went through all of this with the rebuild of the Johnson. I look at it like I'm biding my time until the technology issues level out. I considered purchasing used but thought I'd probably be faced with the same issue of trusting the motor. At least with the rebuild I'm beginning to know the motor inside and out. I agree with LHG about the mechanic whether it's new, used or repaired. Get a good one that's willing to take some time with you showing and explaining what's going on with the motor. Somehow I can't see you sitting out the season and not taking Gambler out. Now, that's an emotional issue. Paul |
| Buckda |
Thanks to everyone for the advice and encouragement. I want to be able to clarify here too, but I do know that some of you already understand this, and your advice was already provided coming from a similar standpoint: When I say I say that because I’m thinking ahead to my planned boat trips this year. Isle Royale on Lake Superior in particular. Isle Royale is not somewhere that I want to be left with a troublesome motor problem. I had already arranged to borrow a kicker for that trip, which buys me some additional level of comfort. The point is, to use the boat how I want to, requires more than just a telephone number for Sea Tow in my pocket and a working VHF. If I’m not comfortable with the motor, I am going to be relegated to inland lakes and rivers because I won’t be comfortable going out into the big Lake, where conditions can change and get dangerous quickly. Jerry – Your point is well made, and I believe you’re right, but my tow vehicle won’t pull the 22 Guardian other than just around town anyway. Re: the financing offers made by Suzuki and Yamaha – could this be because these corporations already have financing arms for their automobile (Suzuki) and ATV/Motorcycle arms? I still think it boils down to how different states title boats and motors (separate or together). Paul – It’s so funny that last year, I was still just getting to know this motor, and even though, as Larry said, she ain’t pretty, she performed well and ran like a top nearly all year. When I had her checked out, the mechanic said he could tell that it had been in saltwater, but I basically asked him to replace/repair what needed it. Besides the thermostats (corroded), water pump/impeller (old), trim tab/anode (badly corroded), and some hoses, the only other things that had been repaired by me was the faulty rectifier (bolt-on part), a trim/tilt relay had shorted out and I replaced the fuel pump diaphragm. Other than that it was routine maintenance all the way – replaced spark plugs, changed lower unit oil, etc. Compression was good and even in all 6 cylinders. I called the mechanic on my lunch break and the boat hasn’t yet been looked at, but I’ll let you know when I know more. |
| Vince |
Dave, Yamaha and Honda and Suzuki offer financing. To respond, Mercury and Bombadier(is Bombadier still running Johnson & Evinrude? I heard a rumor that it may have changed hands again.)have financing plans in the works. A few of my customers have went with the Yamaha financing, especially on twin engine set ups. As far as I know, the only issue was about insurance. Seemed to me to be a lot like taking out a car loan. |
| Vince |
Sorry for the misspelling of Bombardier! |
| Sheila |
"You’re right. I’d rather eat mac and cheese, PB&J and cereal and toast for the next year than go without boating…and I’m serious. (I know you married guys just don’t have that option!)." Don't lay too much money on that bet, Dave! And sending good thoughts your way for an economical, reliable fix for your motor. |
| Teak Oil |
Dave dump that thing. As Larry said, you can tell a lot about the history of an engine by its outward appearance. My Evinrude is a year older than your Merc but it looks and runs like its 5 years newer. Besides that 150 lives up to the "Black Max" on the cowl by leaving a black cloud behind it every time you hit idle speed. You can fix whats wrong and sell it for $1500, throw in 1500 of your own and get an early to mid 90's 200 (50+ baby!) carb or a 150 EFI and not have to worry about what the next thing to go wrong on that engine is. Plus you wont need bungee cords on board to hold the cowling on, LOL. |
| Buckda |
Teak - Agreed that she ain't pretty. The cowl latch failure comes from 18 years in a saltwater and salty-air environment coupled with extremely high humidity - too much rust on one of the screws (replacement latches are $24 each!). I think your motor might also show her years had she not been babied up there in MN where the summers are short and the winters cold and long. I would guess that your motor has fewer than half the hours that are on mine. Unfortunately, the previous owner did not install an hour-meter to make that position defendable...but it's likely. All that said, I don't think this motor was mis-treated. I just think she's old and seen better days. I still haven't heard back from the boatyard, but I plan to call tomorrow morning to see where they are and if they've had a chance to even look at the motor. Vince - thanks for the additional background on the financing front. Man is that tempting to just hold off and see what Evinrude comes up with. I'm guessing that I'd be lucky to get cash or trade for the old motor if I decided to repower...the dealer would probably offer to try to sell it on consignment on my behalf, rather than take that risk on himself. (I wonder where outboards go to die? The junkyard? - the parts bin?) Twin E-Tecs back there would be pretty darn cool, but best to be done over the winter since I'd have to patch the transom and add jackplates. Gotta' get a few more Cabela's points.... Shiela - I was speaking in broad, sweeping stereotypes...is it any wonder I'm a bachelor? ;) Thanks all. Dave |
| Teak Oil |
Dave I am not knocking your motor just stating the facts that you just confirmed. It probably does have a ton more hours, all the more reason to look for a nice, northern Merc V6 from the mid 90's. If you go from a 1986 to a 1994, its only 8 years newer, but probably has 16 years worth of fewer hours if that makes any sense. Bite the bullet now, and you can still have everything installed and have a fun, relaxing summer. Wait and you will spend all summer worrying and taking the cowl on and off. |
| Sheila |
Well, Dave, I guess now you'll know when you've found the "one" (woman, I mean, not motor). She'll be the one who's willing to cut back on groceries to help support the boat. :) |
| Eagleman |
Dave, I personally think that to many people think that an outboard motor is overly complex, and most engines will last a long time. Have a "Good Tech" evaluate the engine and move forward from there. Outboards are built tough and I bet your problem will be something simple. Keep the faith we'll see you in Lake Superior! Eagleman |
| Buckda |
Well, good news: The prop shaft seal was intact. Apparently the oil/goo that was literally oozing out of the exhaust hub on the prop was unburned oil/gas mixture. The Overheat sensor and wire lead were replaced. The engine was "decarboned" and they did some kind of adjustment for the unburned oil/gas mixture. (wonder if this will clear up the smokiness??) I only spoke with the woman at the front desk on my lunchbreak, so I haven't yet spoken directly to the mechanic - will get to do that on Saturday morning. Compression is still good. Cost: $275 bucks There is joy in mudville once again, although it is cautious. Thank you for the emotional roller-coaster ride, but I'd like to get off the train now, thank you. I'm still going to be very watchful for financing offers from the engine-makers (Evinrude and Mercury) this fall/winter, but hopes are high and confidence is rising (slowly) about making it through another season with the old girl. I think I'm going to get a wiring harness in the interim too to just be sure abou these electrical components. Thanks everyone for your opinions, thoughts and advice. I know that there are quite a few other folks out there who are in similar situations with similar questions/concerns about their motors and about when to say 'when'. Regards, Dave |
| Buckda |
Well, I got the boat on Saturday and took her out to the big lake. She ran like a top all afternoon, but I did find a voltage regulator problem (see another thread I started in this forum) that's going to cost about $150 just for the part. I guess I can't complain too loudly since I had a great day on the water with an absolutely stunning sunset that dropped all fiery-orange into the lake perfectly placed between both piers as I headed back into port facing pink topped clouds with dark blue bottoms as the front from earlier in the day scudded eastward. I'm happy to say that the arch completely solved the navigation light nuisances. With the perko glare guard up there, just the very front of the bow rail is exposed to direct light from the all-around white light, leaving the cockpit instruments as the only lightsources in the cabin and eliminating all glare from the Mills Canvas windshield (which used to have to be taken down at night for clear vision). I can tell that this summer's evening boating will be greatly improved, and the spreader lights make final clean up and canvas stowing at the ramp much faster than doing it in the dark. I do have another question that perhaps should be in a new thread: I'm getting engine feedback through the radio. As the RPM's increase, the pitch of the feedback increases, so I know it's probably a shielding thing. Should I check the power cable for the radio and make sure it is separated out from the cable running to the motor, or is it more likely an interference from the antenna cable that should be separated from the power cable bundle...OR is it likely tied to my voltage regulation problem on the motor, and may be resolved once I fix that? Thanks! Dave |
| Yiddil |
Buckda, I had a Proline 85 CC 20 footer.. with an 85 VRO 90 thats scared me to dealth to go more than a few miles...it ate at me as I rebuilt the lower unit, the tilt trim, and when the I wasn't sure about my oil mixture, I disconnected and added oil to the gas by hand....smoked a lot but I never blew her up! After 10 years...I bought that boat for 5 grand, and finally decided I couldn't stand not trusting her to get me home...sold her for 5 grand.... and bought the Nantucket package with the 115-2 I have today...Its a great feeling not having to worry bout that engine anymore!!! PS I just saw her on the road the other day...owner says she needed a starter and a few other things...but she still runnning!!! NO way Im sorry I sold her...could have repowered her for way less than the nantucket, but.............I have no such worries anymore !!!!that piece of mind is worth everything! You will know when you have had enough...and repower...I just decided hells bells, why not just get a WHaler with the repower hehehhe Good Luck.......... |
