  Why Bottom Paint a Trailered Boat?
Author Topic:   Why Bottom Paint a Trailered Boat?
caddis posted 05-03-2005 06:40 PM ET (US)   Profile for caddis   Send Email to caddis
I've seen quite a few boats lately with bottom paint, even though they are kept on a trailer. What is the reason for this? I would think for the hassle one could just clean the hull once on the trailer instead of having to deal with the paint issue year after year. Can someone please enlighten me as to why this is necessary?
Phil Tyson posted 05-03-2005 06:43 PM ET (US)     Profile for Phil Tyson  Send Email to Phil Tyson
They may have been moored at one time or another.
My Montauk has bottom paint from a prior owner who had it at a slip or mooring.
CapeMayMike posted 05-03-2005 06:59 PM ET (US)     Profile for CapeMayMike  Send Email to CapeMayMike
Some keep their boat on a trailer and then slip it while on vacation, sometimes up to 4 weeks in warm water. I did that with my previous boat.
caddis posted 05-03-2005 09:09 PM ET (US)     Profile for caddis  Send Email to caddis
Wouldn't it be cheaper to just have the hull cleaned after four weeks in the water? From what I understand, that shouldn't cause problems being in the water that length of time.
The reason I ask is that, being in the market for a boat, I really don't need bottom paint but a lot of the ones I am looking at have it. I have to decide if it is worth it keeping the paint or having it removed. I know removing is a chore, but if that is short pain for long gain it might be my choice.
Anyone got an idea of what it costs to have a boat bottom painted that is left on a trailer, and how often?
where2 posted 05-03-2005 09:55 PM ET (US)     Profile for where2  Send Email to where2
4 weeks in the warm water in the Florida Keys will get you some nice barncles... 4 weeks on a nice freshwater lake somewhere in the midwest might get you only algae...
The brown scum I get running up my brackish canal is generally invisible if you have bottom paint. Since neither of my boats has bottom paint, I have to scrub the scum off the boat, and will get a noticeable tint to the gelocat from the tannin in the water if I leave my boat in the water for a week. (that's why I keep my boats on a floating lift, rather than in the water...)
If the bottom paint was properly applied, then the bottom is likely scratched gelcoat which is difficult to get back to a presentable finish after removing the bottom paint. Soda Blasting might work better than other methods, but I doubt that it would ever look like my boat that hasn't had bottom paint.
MantyMonty posted 05-03-2005 09:58 PM ET (US)     Profile for MantyMonty  Send Email to MantyMonty
There is never ending discussion on this subject. I talked to Mr. Bennett at Boston Whaler last fall, and osmotic blistering can occur on the gel coat hull after one day or one week or three weeks or all summer or never. It is a virtual crap shoot and see if you are lucky situation if this blistering attacks your hull or the next guys. It was stated by BW that a barrier coat and bottom paint be applied if the boat is going to remain in the water. I keep mine in cold fresh Lake Michigan water, and they still told me it is recommended to do this coating. I have an estimate of 1150.00 plus a boot stripe for my 170. The recoat is every two to three years at 240.00 per coating. This coating is with VC17 teflon applied with sanding between all coats and final finish is a racing finish, as the local marina applies to racing sailboats. I am going to do the coating this spring as soon as it gets above 30 degrees at night here.
Calder posted 05-04-2005 10:28 AM ET (US)     Profile for Calder  Send Email to Calder
Be careful, alot of people will bottom paint a hull to cover up fiberglass repair that doesn't look so good. I t is easy to say that she sat in a slip. If you are looking for used boats make sure the hull is dry and clean so that you can look for tell tale patch work.
pglein posted 05-04-2005 07:07 PM ET (US)     Profile for pglein  Send Email to pglein
There are many reasons a person would do this. First off being the most obvious: that you are incorrect that it is always trailered. For example, my boat may appear to some to be a trailer queen, but she spends a good three months straight in the water in summer. The rest of the year, she is back in and out. And here in the northwest, all it takes is for your boat to be in the water on the one day of the year that the barnacles spawn for you to wish you had bottom paint.
Another reason is that once you apply bottom paint, you pretty much have to continue to do so. A previous owner may have had a good reason to paint the hull and now, because the gel coat is scuffed from the preperation and maintenance of the old paint, it's necessary to keep it painted for appearance now.
I wouldn't ever assume that just because a boat has bottom paint it means that there is shoddy or poor repair work lurking beneath. Any patch or repair should be visible through the paint. If it isn't, that means it was done right and shouldn't be a concern. It's pretty much impossible to use a boat for more than a few years without eventually needing to do a repair of some sort.
Also, it can really depend on what kind of paint is being used. Sloughing paint (what we use here in the northwest on trailered boats) can be pretty easily removed through the use of a pressure washer and some paitence. A more permanent paint (Such as Interlux Mircon CSC) cannot be removed without a lot of sanding and hard work.
Obviously the issue of blistering was already mentioned.
Personally, I will always keep bottom paint on my boats. It looks nice, and protects my investment. Leaving your bottom unpainted is like leaving your car without a wax finish. Sure, lots of people do it, but over time, the lack of proper mainenance becomes obvious.
Some of the figures you guys are tossing out there seem outrageous. I spent $100 on a 1 gallon can of Interlux Bottomkote and no more than 4 hours of my time over several days painting my hull. The paint on the hull will last two to three years and the can has enough left in it to last four or five more applications. So for $100, I'm covered for the next decade.
stefan posted 05-05-2005 10:27 AM ET (US)     Profile for stefan  Send Email to stefan
I live on a canal in Fl, but not allowed a lift, so I drop my boat in usually for about a week max and then pull it out-ramp is only a mile away- I had to leave boat in for almost 3 weeks, when I had my roof redone- and when I pulled it out I wanted too cry- brown, nasty bottom-LOL- I spent all sunday cleaning it off w/ Mary Kate's - a few stains but nothing major- my question is my neigbor said he had his boat bottom painted several years ago, then decided to get it removed and he said it looked as good as new, as if the yard just took a preasure washer and sprayed it off- would that be the Sloughing paint you mention?- any negative to doing that- if it's easy to get off what's the disadvantage?
erik selis posted 05-05-2005 10:41 AM ET (US)     Profile for erik selis  Send Email to erik selis
I trailer my boat all the time but every summer I leave my boat for 2 to 3 weeks in the warm salt water of the Spanish Med. I don't have any bottom paint on her but I always have a heck of a job cleaning the small barnacles off when my holidays are over. Before I leave her in the water I always wax the hull with Starbrite's Marine Wax with Teflon. If not for this I'm pretty sure I would never get her cleaned up the way I should. I am now seriously considering getting bottom paint on my hull as I would rather spend my valuable time on the water than cleaning the barnacles and brown stains off of my hull.
Erik
BOB KEMMLER JR posted 05-06-2005 10:07 PM ET (US)     Profile for BOB KEMMLER JR
I am running into the same situation in my quest for a Mischeif.I was under the impression years ago that all boats should have bottom paint.Of course i was educated by someone who knew what the heck they were talking about.I think that has a lot to do with it,or maybe they buy the boat with faded bottom paint and figure it looks better with fresh bottom paint(even if they trailer it) etc???? A red Mischief with black bottom paint is just UGLY IMO.I hear they have a "racing" bottom paint,that is supposed to be slicker going through the water than standard paints,but not possitive on that.and the search continues
Sheila posted 05-07-2005 01:01 AM ET (US)     Profile for Sheila  Send Email to Sheila
Bob, have you seen the presumed Mischief that just popped up in Marketplace? The subject is something about "ski boat."
