  How To Determine Mix Ratio of Marine-Tex?
Author Topic:   How To Determine Mix Ratio of Marine-Tex?
Speedo66 posted 05-12-2005 07:47 AM ET (US)   Profile for Speedo66   Send Email to Speedo66
While I think Marine-Tex is great stuff (aside from the cost, but we won't go there), I'm always unsure of the ratio when I'm mixing it.
They call for a 5:1 ratio of paste to hardener, but because of it's thickness I don't have an accurate method to determine the ratio other than eyeball. They say too much hardener and it won't harden properly. Go figure!
Anybody have a better method? I'd love to hear about it.
Thanks, Steve
LHG posted 05-12-2005 01:23 PM ET (US)     Profile for LHG
I use a plastic throw-away spoon to get my quantities approximate, which is really all you need to do. Depending on how much you want to mix up, just take the same proportion in each spoon dip (half a spoon, full spoon, etc), 5 of paste, and 1 of catalyst. Kind of like dropping cookie dough on the cookie sheet!
I also use spoons to get liquid gelcoat out of the can, and avoid a pouring mess. Then eye-drop in the hardener. If it sets too quickly, next time, use same spoon quantity, and fewer drops. Eventually you will get it just perfect.
I mix gelcoat in Jello 6-pack cups. Their plastic is heavy, and won't disintegrate in your hand, and the quantity is just about right for pot life/working time. I use Chop-Sticks as mixers!
Or you can get really fancy any buy some cooking measuring spoon sets
JMARTIN posted 05-12-2005 01:45 PM ET (US)     Profile for JMARTIN  Send Email to JMARTIN
I buy the smallest container possible and mix up the whole kit and kaboodle. Then I use the leftover to patch holes in my 30 year old John Deere tractor's mowing deck. It is slowing turning from yellow to white. John
kingfish posted 05-12-2005 02:02 PM ET (US)     Profile for kingfish  Send Email to kingfish
I love it...
JOHN W MAYO posted 05-12-2005 02:16 PM ET (US)     Profile for JOHN W MAYO  Send Email to JOHN W MAYO
I use a cheap set of measuring spoon for cooking. In the past I have gone on the side of maybe not enought hardner. I relazed this when I had some left over and the next time I used the product I used more than I normally do. It seemed to mix much easier and somewhat better flow as I spread it.
You can get cheap plastic spreaders at auto parts stores.
Robob2003 posted 05-12-2005 04:43 PM ET (US)     Profile for Robob2003  Send Email to Robob2003
JMARTIN is right. <I buy the smallest container possible and mix up the whole kit and kaboodle.>
It doesn't go too far so I have never had a repair so small that there was much left over.
Bob on Tampa Bay
Legobusier posted 05-12-2005 04:50 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
This is sort of an aside, but does anyone know if JB Weld is the same formula?
I mixed up some Marine-Tex last year and a few weeks later some of the JB Weld....I could swear it's the same.
I would also venture to guess the JB weld is much cheaper.
Just curious if anyone else has observed this or if I'm losing my mind.
Chris
kingfish posted 05-12-2005 04:54 PM ET (US)     Profile for kingfish  Send Email to kingfish
Option B...
Speedo66 posted 05-12-2005 08:08 PM ET (US)     Profile for Speedo66  Send Email to Speedo66
All great ideas and I thank you all!
Steve
Speedo66 posted 05-12-2005 08:18 PM ET (US)     Profile for Speedo66  Send Email to Speedo66
Legobusier- A few years ago I poked a hole in my BMW's gas tank going over a raised manhole cover. They were doing roadwork and had scraped away the surface, which raised the cover. In traffic, I didn't see it.
Anyway, I tried a two part gas tank sealing putty by Permatex-no good, wouldn't hold. Next tried J-B Weld, unfortunately same result.
The only thing that worked was gray Marine-Tex, and it's STILL holding after several years.
Also used the same stuff to seal a waste pipe that sprung a leak.
Gotta' love that stuff! ;>)
Legobusier posted 05-12-2005 08:41 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
I guess that settles it..I am crazy. I was beginning to suspect so.
LHG posted 05-13-2005 04:11 PM ET (US)     Profile for LHG
Has anyone tried restoring an engine skeg to original shape using grey Marine-Tex? I have an engine where the skeg has been "rounded off" and chipped a little from being dragged around, and would like to build it back out to the sharp lined, original shape.
Otherwise, I'm looking at having a new one welded on and lower unit repainted, about a $275 expense.
And please don't tell me to just slap on a Skeg-Guard. Those things offend me!
jimh posted 05-14-2005 11:21 AM ET (US)     Profile for jimh  Send Email to jimh
Getting the mix ratio correct is very important for making epoxy that will have the proper strength of material in the final cured state. The conversion of epoxy resin and hardener into a cured state is a chemical reaction between two reagents, and you need to supply each reagent in the proper amount. If one reagent is supplied in excess, then this material does not enter into the chemical reaction and remains suspended in the mixture.
For example, if you use an excess of resin, only the resin which chemically reacts with the hardener will form the epoxy. The rest of the uncured resin remains in the final mix where it tends to dilute the material and reduce its strength.
This is one of the very nice features of using WEST System products. In the small batches the reagents are packaged in foil packets (like catsup or mustard at a take-out restaurant) in the precisely correct ratio for making the epoxy.
The final strength of material for an epoxy is also affected by the filler material. You can purchase a number of different filler products. For surface coats a micro-balloon filler is usually used. This makes fairing and sanding much easier. To add strength and thickening, a high-density filler can be used. I think you can also buy powdered aluminum (but I don't know where).
To repair a broken skeg tip (a topic of personal concern to me as well), I was thinking of getting some modeling clay and making an impression of an intact skeg. Then using the mold, it might be possible to cast a replacement section using an epoxy paste mixture.
I agree with LHG that the bolt-on skeg guard does not represent an acceptable solution. They are not up to the mark by esthetic or hydrodynamic standards.
Sheila posted 05-14-2005 11:47 AM ET (US)     Profile for Sheila  Send Email to Sheila
Larry, it seems that you have little to lose by attempting to mold the new piece.
Hopefully you and/or Jim will try the methods you're envisioning and let us know how it works.
DaveS posted 05-14-2005 11:51 PM ET (US)     Profile for DaveS  Send Email to DaveS
jimh...
You just described how my wifes brownies come out of the oven!
Some day I'm sure she'll take a cooking class...but there are seven days to a week and someday is not one of them! Thank God for takeout!
DaveS
Charleston Revenge posted 05-17-2005 09:42 AM ET (US)     Profile for Charleston Revenge  Send Email to Charleston Revenge
The directions for mixing the epoxy are to spread out a 'puddle' of epoxy, then put a 'ribbon' of cream hardener across the entire diameter. I think that the measuring cups and/or spoons are a great idea, but I've always had decent results just making a circular puddle and squeezing a solid line of hardener across the whole diameter. The larger the puddle, the more hardener it takes. Hey, it works for me!
Buckda posted 05-17-2005 03:57 PM ET (US)     Profile for Buckda  Send Email to Buckda
Early last summer, I had my first experience with marine-Tex. On the whole it was positive, as I was following LHG's directions for shoring up the screw-holes for my bow railing. I ended up using a kit and a half worth of the stuff. The half is what killed me (but I didn't know it at the time). That final half I tried to mix the hardener and the putty in the appropriate amount through 'guesstimation' for one final bow rail mounting point.
Last fall, I noticed that this railing was coming loose again at the mounting point. Since the weather has just now climbed into the acceptable range for working with epoxy, I have been waiting to work on this.
On Sunday, I had to cut off the rail base because one final, stubborn screw would not come out of the hole and was instead adhered to the epoxy plug in the hole. After cutting the base off, I drilled out the hole and was able to remove the final screw. I then used needle nose pliers to pull soft, pliable plugs of partially-cured Marine-Tex out of the holes. No wonder this fix wasn't holding!
Well, I drilled out quite a bit of wet material and plugged the holes with paper towel to absorb and wick out moisture, and pointed a heat gun down into the hole to accellerate the drying process. Then late on Sunday evening, I simply combined the contents of an entire Marine-Tex kit together as the instructions recommend and used WEST SYSTEM plastic injection needles to fill the holes with epoxy. I went ahead and filled a few extra holes around the boat that had been "plugged" with a screw beaded with silicone caulk last year, and just threw out the rest. I realize that it's somewhat expensive (I paid $8.95), but the peace of mind from knowing that it will cure properly is worth 10 bucks, to my way of thinking.
