Topic: Lower Unit: Re-Seal
ryland |
posted 06-06-2005 05:13 PM ET (US)
When I bought my 1979 Evinrude 35-HP (on a 13-foot 1979 Boston Whaler boat), the gear oil was thin, brown and milky. Less than two months later, it is again milky. I will buy a gear housing seal kit and a water pump kit and go to work. I have never done this before. Any advice? It would be helpful. I do know that I should do a pressure test first. This is the greatest website ever!
Binkie
posted 06-06-2005 05:22 PM ET (US)
Do the pressure test last to make sure its no longer leaking.
ryland
posted 06-06-2005 05:40 PM ET (US)
thanks for the reply. can anyone think of anything else i should replace while i do this job, and of course what will make me swear the most? |
Taylor
posted 06-06-2005 05:47 PM ET (US)
If there are o-rings on the fill and vent screws for the gearcase, those should be replaced also. |
Sal DiMercurio
posted 06-06-2005 06:12 PM ET (US)
Not to be a smart a$$ but I don't think you should do it if you have never seen it done. There are phillips screws that you absolutly do not touch because they are adjustment screws not hold in screws. Once you take those gears loose there's no way your going to get them back as they should be. There are 2 seals in that lower unit & if you don't have a manual forget it. Sal |
JBCornwell
posted 06-06-2005 07:16 PM ET (US)
I think you should do it, ryland, but that doesn't mean I disagree with Sal.Attempting to work on any outboard without a manual that has been read and studied is an amatuer trick that makes a lot of pro wrenches lots of bux. Get a manual. Do not mess with your engine until you have it and have read it. Taylor shines a light on your most likely cause. The O-rings or gaskets that go under the drain and vent plugs are "crush-once and discard" items. Failure to replace them every time the plugs are removed is the most common cause of gearcase water contamination. Red sky at night. . . JB |
ryland
posted 06-06-2005 09:09 PM ET (US)
Thanks guys. I have replaced the O-rings each time I changed the gear oil. I do have two manuals, one original and one generic. I will study carefully and will consider a mechanic. One thing I am worried about: I removed the wrong screw while changing the gear oil--you know, the one the manual says do no remove by mistake. It is the screw next to the drain screw. Is this bad? Again, thank you. |
posted 06-06-2005 10:40 PM ET (US)
I, myself, have not replaced the propeller shaft seals on my engines. I always had the shop do it. The charge was fairly modest, about $250, compared to the value of the engines, which I judge to be at least ten times that cost. In your situation, working on a 24-year-old 35-HP classic two-stroke may be about the best time and place to learn how to do this sort of thing.The only proviso I would offer is the possible necessity of special tools to remove the propeller shaft nut. If this nut has not been removed in the past ten years, there is a good chance it will not come out without a fight. The combination of corrosion and lack of the exactly right tool might make getting that nut off to be the hardest part of the repair. When I had my 1987 engine re-sealed, the shaft nut would not budge. The shop mechanic had to break the nut into pieces and pry it out. That was in c.2002, when it was only about 15 years old. The motor had been used almost exclusively in fresh water, too. A new nut was an expensive part, too. All of this repair is predicated on the notion that there is a shaft seal leak. I would double check the fill and vent screws and their seals. Be sure they are not the source of the water ingress. Be sure the seat for the seal (the O-ring or gasket) is clean, and it does not have any old seal residue. Re-build the water pump next. That is much easier, I believe. If you still are getting contaminated oil, then go for the propeller shaft seal. |
PeteB88
posted 06-07-2005 12:00 AM ET (US)
Here's a good one for you - - I got an older Johnson 25 last summer for my small Whaler. Being into preventive maintenance and having found lower unit lube in the same shape as yours - milky, I replaced the drain and fill plug white/slightly opague seals with rubber o-rings. I figured o-rings would be better seals and newer technology. Two weeks later - same issue' milky gear lube. I went to a GREAT motor shop with old school mechanics who are always totally cool about do it yourselfers like me. They told me to use the OEM sort of clear, plastic gasket/ seals that are indicated for those plugs because THEY WERE DESIGNED FOR THOSE PLUGS. And yes those seals go bad and need to be replaced (from subsequent checking, refilling and torquing). I got the real things, replaced, no milky gear lube. I also bought a proper filler pump and follow the directions. best of luck Take on the job - what the hell! There ain't much you can "shade tree" any more. That's one reason I like older motors. 88 |
bsmotril
posted 06-07-2005 09:00 AM ET (US)
If your going through the trouble of changing the prop shaft seal, don't forget to also change the seal around the shifter shaft, and the drive shaft underneath the water pump. Do them all, and you good for another 10 years. It is possible to do this all yourself with moderate mechanical talent, AND THE OEM SERVICE MANUAL !! I would not attempt is without a good service manual unless you've done the same task several times before on that same model motor. Snap-On tools makes an adjustable spanner wrench that will fit 95% of the hub carrier nuts out there. BillS |
ryland
posted 06-07-2005 10:45 AM ET (US)
all great advice that i will heed. with respect to the o rings on the filler and drain plugs, on the last change 2 days ago i replaced the rubber o rings with the plastic, so i think i will run it again and then check the gear oil, maybe it as a simple as using the plastic instead of rubber o rings. |
Sal DiMercurio
posted 06-07-2005 10:49 AM ET (US)
Ryland, thats the screw I told you is an adjustment & not to touch, now you "BETTER" read that manual or take the engine in to get it right. You do "NOT" touch any screw on the lower unit that is phillips head. Sal |
ryland
posted 06-08-2005 12:33 AM ET (US)
thanks sal, i removed it a few days ago, i knew better, just a dumb mistake, the manual calls it a pivot pin and only tells you not to remove it but fails to explain what to do if you do. if anyone knows about this let me know. |
RDAD
posted 06-10-2005 12:34 AM ET (US)
Call your dad, he would be happy to help!! Pokey!!! |
bsmotril
posted 06-10-2005 10:34 AM ET (US)
I think that pin sets the travel range for the clutch dogs to move. The impact of not having it set right is that ou get excessive wear of the clutch dogs in the lower unit. BillS |
