posted 07-11-2005 07:52 AM ET (US)
Sand it as smooth as possible with 100-grit paper and a palm sander.Roll on a quart of the two-part Interlux 404/414 Epoxy Barrior Coat.
Fill any remaining hairline cracks with 3M Marine Putty.
Sand it again.
Roll on another quart of the 404/414. Sand it again.
Flip the boat back over, put some 40-pound bags of sand inside the boat to give you an idea of how it will sit with motor, battery, fuel and seats. Put it in some dirty, calm water to get a waterliine mark.
Take it out of the water, remove the sand, and flip it back over. Put tape on the waterline.
Using a foam roller that is designed for all paints, roll two or three coats of bottom paint on the area that is going to be below the water line. Trilux makes a white bottom paint that looks very good if you want to de-emphasize that the bottom has been painted.
Remove the tape and put new tape on the edge of the botttom paint line.
Using the same type of foam rollers (Home Depot sells them by the six-pack), put on two or three coats of off-white Interlux Easy Poxy on the areas of the hull that will not be below the waterline. Sand lightly between coats.
It will look great and it is easy to do. If it gets scuffed up later on, you can always touch up those spots with leftover paint.
Best of luck with your project.
