| Author | Topic: RAGE 15 Engine Replacement |
| klspanos |
I just bought a 1995 RAGE 15. It needs a new engine. What I should expect to pay to have [the engine] replaced? Thanks for your help. |
The labor rate at marine repair facilities varies depending on location and season, so it is hard to predict the going rate in your area. A major job like replacing an engine will probably be quite a few hours of labor. Have you located a replacement engine? What engine is in your boat? Is it the OMC 115-HP Turbo Jet? Considering that OMC is no longer in business, I wonder how available a complete replacement engine is going to be. |
| BOB KEMMLER JR |
a few years back when my rage 115 let loose,i got a estimate of $3500 to replace the powerhead. |
| where2 |
A "short block" alone for that Rage will run around $2k presuming you have a rebuildable core. Find a reputable mechanic. My mechanic did a tear down, had his favorite local machine shop overbore one of the cylinders, mechanic reassembled everything including an overbore piston and handed me back the engine to reinstall for under $2k. This was the problem: http://www.tfn.net/~wendtm/damaged_piston.jpg |
