  27' fuel tanks 'Whaler 27' or Full Cabin
Author Topic:   27' fuel tanks 'Whaler 27' or Full Cabin
JMR posted 09-22-2005 11:21 AM ET (US)   Profile for JMR   Send Email to JMR
I had a 22 revenge cuddy with 70 gallon tank in the 90s when the kids were young. Now I am bitten by the bug of wanting to buy a 27' and restoring/repowering over time. The site has been very helpful in much of the discussion about engines and props etc etc. I have already looked at some 'Whaler 27' models with outboards - all so far seem to have 300+ gallons fuel capacity in three tanks which I believe are 70+170+70. I have yet to look at at a Full Cabin with outboards but the ones that have caught my attention seem to have single, 170-180 gallon tanks only. Is a retro-fit of e.g. the two 70 gallon tanks out of the question (technically or costwise), relatively routine, or somewhere in between, or, is there a better solution nowadays given that original tanks may not last forever in any case? I realize that an inboard diesel model may be a better solution with today's gas prices but I am not there yet.
WHALER27CC posted 09-23-2005 07:45 AM ET (US)     Profile for WHALER27CC  Send Email to WHALER27CC
My 1986 27'with T/outboards, had a SINGLE 240 Gallon fuel tank that ran stright up in the centerline. Im not sure how many were made with that sized tank, but I have never really seen to much merit in having the 70 saddles , given that they eat up alot of in-deck space and add another 400lbs to the stern area. In the case of inboards, you may have to just stick with the 70s, cost-wise and logistic-wise and upgrade them, as the room under deck is substantially cut down by the trannys,exhausts and shafts .
Captain Billy posted 09-23-2005 10:40 AM ET (US)     Profile for Captain Billy  Send Email to Captain Billy
My 92 27WA has a 150 and a 75. Both on the centerline of the boat. When going offshore, you will need all you can carry.
Billy
jeffs22outrage posted 09-23-2005 02:41 PM ET (US)     Profile for jeffs22outrage  Send Email to jeffs22outrage
[ur]http://www.classicseacraft.com/offshore27.htm[/url]
It should one tank. Follow the article and you will see pictures of the cockpit with the fuel cover removed.
jeffs22outrage posted 09-23-2005 02:42 PM ET (US)     Profile for jeffs22outrage  Send Email to jeffs22outrage
One more time
JMR posted 09-24-2005 01:14 PM ET (US)     Profile for JMR  Send Email to JMR
I guess my question is whether or not I should look at a 27 foot boat with only a 170 tank, because I don't know how much of a problem it would be to increase the fuel tank capacity?
WHALER27CC posted 09-24-2005 06:50 PM ET (US)     Profile for WHALER27CC  Send Email to WHALER27CC
Depends . Are you planning long trips? Do you plan to go far offshore, or are you just doing coastal cruising??What kind of engine setups are you looking at?
Twin 2 strokes will be somewhat limited .4 strokes or inboards will give you much more range with 170 gal tank.
Retrofitting and adding saddle tanks can be done,physically there is plenty of room in the indeck boxes, but you will give up almost all in-deck storage. The cost may be substantial though, because I think you would have to acces the main tank area to add the necessary hardware The cost of the tanks and fuel valves would be pretty pricey too.
If it were me , I think I would try to stay away from retrofit situation, it will be a very costly PIA .
JMR posted 10-04-2005 11:30 AM ET (US)     Profile for JMR  Send Email to JMR
Thank you all for your very helpful responses. This a great site. I have decided to go with a Whaler 27 with 300+ tanks and forget about retrofitting saddle tanks. It happens that I looked over my first Full Cabin this last weekend and decided that the extra height versus the extra weight didn't add up, for me, to much more than a day boat with a full head instead of a porta-potty; if I saw one with 300+ tanks I might think again but I think that I have found a Whaler 27 which works for me. If I wanted to have some real cabin comfort and seriously spend time inside, I would buy a bigger boat. I am now on to the carbs v. the newer 2- & 4- stuff and when the hype dies down I will try to figure out what the best re-power is going to be.
LHG posted 10-04-2005 01:46 PM ET (US)     Profile for LHG
With the cost of fuel, and the 40% better mileage from the new 3 star engines, I think it would be a HUGE mistake to re-power a 27 with old 2-strokes, if you can even find them. Without going really old, only the Merc 225 or 250 EFI's would be a choice, since they were the only convnetional 2-stroke engines made through 2005. First decide if you want DFI 2-stroke such as E-tec or Optimax (stay away from troublesome 250/300 Yamaha HPDI's) or 4-stroke. In 4-stroke you will have to consider the 250HP range, either Yamaha, Suzuki or Mercury Verado. Avoid the 225 Yamaha and Hondas, as they are a little short on HP/acceleration for a hull that size
Peter posted 10-04-2005 03:23 PM ET (US)     Profile for Peter  Send Email to Peter
JMR, I have a 27 Whaler WD with the 310 gallon capacity powered by a pair of Evinrude Ficht 225s. At the time I bought it I didn't care about the fuel capacity but in hindsight I'm glad my 27 came with the 310 gallon capacity. I can typically go on an extended cruise without ever having to worry about stopping for fuel.
The 40 percent better mileage between a 2 or 3-Star motor and a 0-Star motor is typically at idle speed. The differences narrow as engine speed increases. The difference between the naturally aspirated 2 or 3-Star motors and the 0-Star motor may only be on the order of 10 to 15 percent or less at WOT. At cruise speed, the difference is typically going to be in the 20 to 25 percent range.
With either a 4-stroke or a DFI 2-stroke, you can expect to get about 1.4 MPG at cruise out of the 27 Whaler WD hull. With a carbureted or EFI 2-stroke, you are likely not to see better than 1.1 to 1.2 MPG at cruise. Thus, using the rule of 1/3s, with a 170 gallon capacity and a 0-Star motor, your offshore range is going to be approximately 60 miles leaving about 50 gallons of gas in reserve. With a fuel efficient 2 or 3-Star motor, your offshore range is likely to be increased to about 80 miles. With a 310 gallon capacity, the offshore range will be increased to about 110 and 140 miles with the two motor types, respectively.
The big advantage of the 2 or 3-Star motor will be trolling. I can troll at 2 to 3 MPH on one motor burning just a measly 0.3 GPH which equals 10+ MPG. That will be true for any of the 3-Star motors. A single 0-Star motor is going to burn 1 to 1.5 GPH on the same troll.
If the conditions are very rough such that you can manage to run only at minimum planing speed, expect to see fuel economy drop down into the 1 to 1.1 MPG range. It is these conditions where the extra capacity really helps out.
If you enjoy minimal camping effort, you'll have no problem doing multiple overnights on the 27.
JMR posted 10-05-2005 10:49 AM ET (US)     Profile for JMR  Send Email to JMR
LHG, Peter thanks for the suggestions. I am buying a real working 27 WD with late 1990s carbs but that goes to price. I held back from buying an 27 WD hull only (with the 310 tanks) which had spent its summer life without much covering, precisely because the solution offered by the dealer (he repowered my revenge cuddy) was 225 Hondas at about $40,000 (+ sales tax) installed after necessary replacements of this and that. That plus complete canvas and the upholstery, fixes of some known defects, electronics & arch, and a contingency factor for unknowns, easily made it a $70,000+ boat registered and all taxes paid. As to engines I would like to wait a while at 1 mile per gallon and figure out what works best. In theory the E-TEC and intelligent design sounds better than an SUV engine but I am wary that BRP is a new entity not making any money and I have an abiding suspicion that what W. Edwards Deming taught has been forgotten here but not in Japan. Ironically, the toughest issue, inevitably a purely local one, is to find a slip on Peconic Bay where the town and the environmental authorities have restricted growth of docking space.
