  Bottom paint dilemma (probably a really stupid question)
Author Topic:   Bottom paint dilemma (probably a really stupid question)
Sheila posted 10-03-2005 10:00 PM ET (US)   Profile for Sheila   Send Email to Sheila
Our dive service guy has advised us that Tohora Iti, our 1985 Revenge Hardtop, is due for new bottom paint. When we bought the boat last fall, the seller advised us that the paint would need to be redone this year, so we're not surprised.
We keep her in a slip and do not own a trailer for her. At first look, it appears our only option is to have her hauled out and professionally painted.
Here are my really stupid questions:
Is there a viable alternative I'm overlooking? I know a few other forum members in our area with the same boat and trailers, but could she be painted on a borrowed trailer? How does one paint a bottom on a trailer without having unpainted spots where she rests on the trailer? If such a loan (or rental) were feasable, what are the benefits and downsides to a DIY bottom paint job?
What else should we inspect/replace while she's out of the water? I know it's time for new lower unit oil, and we should take a look at the through-hulls. What else should we check out?
Thanks.
Binkie posted 10-03-2005 10:13 PM ET (US)     Profile for Binkie  Send Email to Binkie
If you can find a do it yourself yard, they will hang the boat on a sling or put it on blocks for you to paint it. You can`t do a good job from a trailer.
BobL posted 10-03-2005 10:41 PM ET (US)     Profile for BobL  Send Email to BobL
Sheila,
Many boatyards will power-wash any slime or growth off of the hull as part of the haul-out price. They can set the boat on stands so you can paint the bottom and inspect the hull. The stands will be repositioned after the new hull paint is dry so the spots under the stands can be painted. The painting is easy enough but is a smelly and messy job. You may want to use an ablative paint to avoid the yearly build-up of antifouling paint. Applying the paint with a roller is easier but I feel I can get a smoother, thinner coat with a brush.
andygere posted 10-04-2005 01:50 AM ET (US)     Profile for andygere  Send Email to andygere
The yards that cater to commercial fisherman are more likely to allow do it yourself bottom painting. Shop around, and ask what's included in the haul out price. Be sure you know how much time you have in the yard, and what the charge for extra days is. I did mine at a yard in a harbor 12 miles away by water because the total costs were less than half of what the yard in my harbor wanted. My local yard caters more to the yachting crowd, and is priced accordingly. Also, ask if you can supply your own paint, or if the yard requires you to purchase from them. If so, what are the prices (sit down before asking).
It takes a bit of planning to do a good bottom job, but anyone can do it. I suggest the best quality ablative paint you can afford (I like Interlux Micron Extra) and plan on putting on 3 coats, more along the waterlines. This will extend the time before recoating significantly. Make sure you have a good quality respirator, since the prep solvents and paints are pretty toxic. Also get a roll of 3M fine line tape (1/2 inch wide) to tape off the waterlines. Get a roll of blue masking to tape above the fine line to prevent errant roller or brush marks. You must buy fine nap foam roller covers that are made for marine paints. Get plenty. The home center roller covers will fall apart and make a mess of your job. Have plenty of rags (more than you think), several rolls of paper towels, and a pair of chemical resistant gloves. The disposable gloves also tend to fall apart, and there is no keeping the paint off of them. Bring a mechanic's creeper or an old camping cushion to sit/lay on while you work. I put all my stuff in a big plastic tote to make it easier to carry, and the tote is a nice surface for pouring paint into roller trays.
In addition to checking the through-hulls and clamshells, replace the anodes on your outboards, and inspect and clean your trim tabs if you have them. I also coat my sonar transducer with a special antifouling paint made just for plastic parts.
Here's a few pics for inspiration. http://photobucket.com/albums/v408/andygere/Bottom%20Painting/?sc=1&multi=3
starlight marine posted 10-04-2005 06:27 AM ET (US)     Profile for starlight marine  Send Email to starlight marine
Sheila, Hey hope all is well. All these guys are correct for sure. You don't want to attempt on a trailer. It won't be done correctly, it's a mess and I don't think the owner of the trailer would appreciate it. The only additional advice I can give you is what I sometimes have to beat (figurtively) into my guys. Wear ALL of the protective gear that I have for them. What the bottom paint companies admit to is only a small part of what this stuff can do. I've seen the painters here in Fla. come an go way too early in life, and they weren't old ! Wear a headsock, full facemask with air, Disposable coverall's, sealed disp. gloves, booties. Take all precautions. Better yet, have one of the yard guys do it for you. It's bad stuff. Good luck whatever you do, Capt. T Oh, one last thing. If you get it on your skin, do NOT use ACETONE for clean up. This speeds it into your bloodstream. Use a slower solvent, be it mineral spirits or just try to scrub off as soon as you get it on you.
rtk posted 10-04-2005 07:40 AM ET (US)     Profile for rtk  Send Email to rtk
Starlight is right, it is very nasty stuff. The new bottom paint and the old dry stuff. He is not exagerating the hazzards of working with this stuff. Doing it on a trailer will be the most miserable thing you will ever experience in your life, you will wish you were never born :)
The going rate around here (New Jersey) for a single coat of single season antifouling paint is around $10.00/ per foot. Three coats of a good multiseason ablative more, but it turns the bottom painting ritual into an every other year event. You should still haul out once a year to clean the bottom and do maintemance though.
A good powerwash, zincs, lower unit oil change, waterpump?, grease all zerks, remove prop and grease driveshaft, prop reconditioned if necessary while it is out, wax boat.
It is not a difficult job to do, but it is one of those tasks you have to weigh the cost savings of paying a yard a few hours of labor or doing a dirty job yourself. By the time you buy all the tape, rollers, paint and do it yourself you may save $200?
As far as a good paint to use, check around and see what the yard uses and yout friends around you in other slips. A bottom paint should be chosen that works well for your geographic area, paints are designed for different degrees of salinity, temperature and types of marine growth.
Rich
tarbaby posted 10-04-2005 07:40 AM ET (US)     Profile for tarbaby  Send Email to tarbaby
Sheila,
I agree with Starlight. Get the yard to do it. Go do something fun with your family and leave all that mess to a bunch of guys that do it all day. You will not save any money doing the job yourself. Most yards charge one ammount to haul a boat for a DIY bottom job and they charge a different ammount if they haul it to perform the work for you. The yards here charge even more to haul you out if you buy your paint somewhere else. The cost of buying the propper equipment outweighs the cost savings. This is dangerous stuff that is better left to the professionals.
Have the yard look for blisters when the boat is hauled.
Shay
andygere posted 10-04-2005 12:18 PM ET (US)     Profile for andygere  Send Email to andygere
I respectfully disagree about the cost of DIY vs. the yard. While it is a lot of money, some of the yards in my area have a "minimum charge", and the per foot charge is a lot higher than $10. Does the $10/foot include materials? That's a bargain, but not even close to going rate in my area. The yard in my harbor also adds junk fees, such as haz mat disposal ($100!) and clean up, and charges more than 2x the West Marine price for paint. Finally, if you do have a yard do the work, check with other customers to see if they have done it right. My dock neighbor paid $1,500 for a bottom paint job on a new boat, and the yard had it in the slings for relaunch when he came by to check on the work. They hadn't moved the stands, and there were 2 big squares with no paint at all. This is not to say that a yard job won't be done right, but be cautious and do your homework.
In California, there are not nearly as many boatyards and harbors as in the Northeast, and the lack of competition leaves the consumer with high prices and in some cases shoddy work.
pglein posted 10-04-2005 12:30 PM ET (US)     Profile for pglein  Send Email to pglein
With regard to bottom paint, it kind of depends on what kind of paint you're using. Since your boat is in the water all the time, you are probably going to want to use something like Micron CSC or similar. If you use ablative paint (better for trailer boats), the job is really quite easy. Obviously, you want to wear protective gear, and if you're doing the boat on stands, this will include overalls, since you'll likely drip on yourself. But other than that, the actual paint application process is quite easy. I did my 13' upside down in my garage and was able to whip out each coat in a matter of minutes. I would then let it dry for a few hours and come back and apply another coat. It stunk up the house something fierce, but I never spilled a drop on my hands, clothes, or even my drop cloth. USE A ROLLER, it will save you time.
The difference between what I did, and what you'll be doing, is that for me, a simple pressure washing was all that was required for prep work (aside from some gel coat repair). For you, you'll likely need to have it sanded before painting. This is the messy part. Good luck.
LHG posted 10-04-2005 01:29 PM ET (US)     Profile for LHG
Although I have "zero" experience with bottom paint, it would seem that with an older hull, and from some of the horrible jobs I have seen, that the hull is probably in need of total stripping first. Soda Blasting seems to be the way to do this, or at the minimum, the hull must be REALLY SANDED WELL AND SMOOTH. At the same time, I'm betting the brass through-hulls need to be replaced and checked for water in the hull.
Bottom paint build up really affects performance and economy, so a smooth bottom painted hull is important.
I am beginning to think that an unpainted hull and a good trailer pays for itself real fast with the expense of continual bottom painting work
Sheila posted 10-04-2005 02:56 PM ET (US)     Profile for Sheila  Send Email to Sheila
Thanks, everyone, for your thoughtful replies.
Pglein, if I could flip my 25' hardtop and do it in my garage, I suppose it would be a simple task.
17 bodega posted 10-04-2005 05:34 PM ET (US)     Profile for 17 bodega  Send Email to 17 bodega
I was blown away by the high price of an epoxy style bottom paint... Andy is right... the major expense is the labor. The DIY yards are around and they usually have jacks and stands handy. Borrow the trailer to get the boat to a yard and then you or Jeff could take your time and use whatever product you wanted. You don't even need a yard, just a place where you could keep the boat on stands for a while.
Speedo66 posted 10-04-2005 09:10 PM ET (US)     Profile for Speedo66  Send Email to Speedo66
Hey Sheila, I did mine this past spring. The major problem was removing the old paint, may not be required for yours if the current paint is ablative.
One other thing which has not been mentioned: if your boat is constantly in the water, is there a sealing coat under the bottom paint? I put three coats of that on before I put the two coats of bottom paint on. Bottom paint alone will not stop possible water intrusion.
I did it all on a trailer, not a lot of fun but it worked. I jacked each side of the boat up with a wide support under an auto floor jack on supports to get to the portions resting on bunks. After the first 3 or 4 times it was easy. :(
I hope not to look at another paint can for at least another year. After dealing with all that (strippers, sealing paint, bottom paint), I'm just glad my reproductive days are over. I'm sure my DNA took a hit.
Best of luck, Steve
starlight marine posted 10-05-2005 08:04 AM ET (US)     Profile for starlight marine  Send Email to starlight marine
Sheila, after all the emails we've had back and forth I'm going to say this once more. For the little money you save, it's NOT worth it ! Go to a yard and find the "bottom guy" have a good look at him or her. I'd like to see you stay healthy. I see these guys every day. The more they do it , the more they become lax at it. It's a very unhealthy skill to have. What you can do is acid wash the hull sides before the bottom job and polish. The acid wash will remove all hardwater stains and make the polishing procedure a lot easier. Good luck and take care, Capt. T
Prflyer1 posted 10-05-2005 08:13 AM ET (US)     Profile for Prflyer1  Send Email to Prflyer1
I have to agree with Starlight, My father owns a Chemical supply factory and some of the stuff is VERY nasty on your health, not at all what it says on the label. Save a little more money and have someone do it, and then you save on your health for many more years of Boating :)
Many Blessings,
Dan
rtk posted 10-05-2005 09:32 AM ET (US)     Profile for rtk  Send Email to rtk
Once again, I will agree 100% with Capt T and others comments on working with any marine paint. He is by no means exaggerating the health risk associated with these products.
My experience with these products is not limited to use on boats I have owned. I used to work for a boat yard that specialized in Awlgip application and bottom blister repair, barrier coat and multi-season bottom paint applications.
When I was hired, the Marina owner was the wife of the former owner. Her husband died of lukemia I believe, way before anyone plans on departing this earth. The yard foreman, late 30's/early 40's in age, already had a lung condition from working with these materials.
The work is highly satisfying, taking a boat in poor condition and making it look like new. But the shop did not feel they needed to invest in the recommended safety equipment to do the work. Most don't- why spend $5000 for a positive air feed protective suit when some poor slob will do the work without it? Many in the business do not even using a simple mask respirator. Those little dust masks from the hardware store do nothing.
Not only lung damage, but the stuff will chew up and spit out brain cells, internal organs and your central nervous system. That is a fact, not a paranoid over reaction.
After working with the stuff for thousands of hours, I am not aware of any immediate health problems associated with the material. When I am in my sixties I anticipate some problems.
Somebody was looking out for me when the boating industry collapsed in 1990. Unemployed, I found work in another field. I truly enjoyed working on boats, but it is probably one of the worst industries with regard to occupational safety.
Even at $25 dollars a foot, that is $625 to have someone do the bottom, basic job. Gallon of paint $150, tape, rollers, pan $25. Savings around $400? Burn the check and use the time to detail the boat, it is sound advice.
Rich
gcl posted 10-05-2005 09:50 AM ET (US)     Profile for gcl  Send Email to gcl
I bottom paint my 16'17" Whaler myself,on the trailer, every year. The following is an outline of the process, which is based upon a few assumptions, including: you don't mind getting some bottom paint on the trailer, the boat is sitting on a bunk trailer, on relatively level ground, and the boat has been previously properly bottom painted, however there is not a build-up of many layers of bottom paint:
Drag a sharp standard long-handled draw-type paint scraper across every square inch of the painted bottom to remove any loose paint. Any paint strong enough to stay on the hull earns its right to stay there. No sanding. Jack the boat at the stern with a simple bottle jack, (with a piece of board between the jack and the hull to protect the hull), until there is enough room between the bunks and the hull to insert 4" sections of 2"X4"s as spacers. Leave enough room between the spacers to fit a thin paint roller. Lower the jack so the boat settles on the spacers. Paint the area between the bunks and the hull with a very thin roller. Tape the existing edge of the bottom paint hull interface. Spot paint the areas where loose paint had been scraped off. Paint the taped edge, the waterline, and the sponson edges. Let these painted areas dry, allowing the time specified by the manufacturer of the paint. Rejack the boat, as described above. Reposition the 2"X4" spacers to the areas that already have been painted. Paint entire bottom paint area. Rejack and remove 2"X4" spacers. Done.
The process describe above takes me approximately three hours to accomplish. Remember, you are not "painting" in a traditional sense. You are simply periodically applying a temporary coating of biocide. My two-cents - which is most likely what it is worth.
gcl posted 10-05-2005 10:05 AM ET (US)     Profile for gcl  Send Email to gcl
I must add - the process discribed above would be more difficult with Shelia's larger boat.
starlight marine posted 10-05-2005 10:07 AM ET (US)     Profile for starlight marine  Send Email to starlight marine
Amen Rich, We'd like to keep Sheila around for MANY more "WHALER YEARS" !!
quickfarms posted 10-05-2005 10:56 AM ET (US)     Profile for quickfarms  Send Email to quickfarms
It has been my experiance that it is very common for yards to paint the boat on the stands and then put it in the slings and touch up the spots where the stands were located.
Do you know how many layers of paint are on the bottom?
It may be time to strip it and do it again.
My outrage will be soda blasted in several weeks. Due to the AQMD regulations it will be done inside of a booth. The boat will be covered with the mooring cover and then plastic. The boat will also be left on the trailer, but raised up 6" to allow clearance on the bunks.
If you want to come up to LA you can see what the bottom looks like after blasting.
If you want to paint the bottom yourself do it jacks or blocks and not on a trailer. The trailer just makes it harder.
By the way the blasting will cost me 450 for a 19'
I have recieved quotes of 40 a foot for sanding and 20 a foot for painting.
Good luck
mitch13 posted 10-05-2005 11:43 AM ET (US)     Profile for mitch13  Send Email to mitch13
Sheila,
Sanding the bottom while the boat is in the water is far less hazardous than breathing that stuff after it dries out. While my 36' trawler was at Dana Point I would sand it in the water , then run down to the yard at Oceanside, have them lift her out and I would rinse with fresh water, tape off the waterline, check the thru hulls, and roll on the bottom paint. When they lifted it with slings I would paint the spots that were missed when on jacks and they would put it in the water with those spots still wet. Two days, one overnight. Of course it helps if you SCUBA, otherwise you have to depend on your bottom cleaner to do a decent job.
mitch
RMS posted 10-05-2005 01:47 PM ET (US)     Profile for RMS  Send Email to RMS
Pettit Trinidad is good for 3 seasons in NJ. After 3 six-month seasons, it's worn away, no need to remove. Merely powerwash (on trailer) when removed for season, no sanding, no scraping.
Sheila posted 10-05-2005 03:12 PM ET (US)     Profile for Sheila  Send Email to Sheila
Thanks, everyone, for the information, and for your concern for my well being. I think I'll start by calling the guys at Oceanside, since we're slipped there.
Binkie posted 10-05-2005 09:03 PM ET (US)     Profile for Binkie  Send Email to Binkie
I never heard of sanding the bottom while the boat is in the water. It sounds like a great idea. I guess thats what they really call wet sanding. I might try it after I get a longer dropcord. My electric outlet is 200 feet from the boat. Do you think there would be to much voltage drop?
swist posted 10-06-2005 08:21 AM ET (US)     Profile for swist  Send Email to swist
Don't even think about doing this - I tried it once myself. It was the worst DIY job I ever undertook. There is not room under a trailer to do it right. You lie on your back with toxic goop inches from your face. The stuff was all over me and my clothes. The yard stunk for days. My wife was ready for divorce court.
I enjoy working on my boat and do everything myself I possibly can - but as far as I am concerned, paying someone else to do it is part of the cost of ownership.
Sheila posted 10-10-2005 09:07 PM ET (US)     Profile for Sheila  Send Email to Sheila
Update:
I called our diver today to ask his advice. I reasoned since that he's the one doing the monthly cleaning on boats all over town, he's seen good, and poor, jobs. He recommended two local yards. I emailed for quotes. Here is the reply I got from the first yard:
"The price for a complete bottom job on your 25' whaler would be $28.00 per foot (or $700.00) plus tax on materials. This price includes hauling the boat out of the water, hydrowashing the bottom, painting the bottom (two coats at the waterline, one on the bottom) and launching the boat back into the water. Hopefully this answers your questions. If you wish to schedule
a Haulout, please call Joe Driscoll at 619-221-8456.
Thank you for your interest."
Per their website, an extra coat will cost $13/foot. Their website also notes that DIY is welcome at their yard, so I'm thinking this would be a good time to change the lower unit oil and impeller, inspect the through-hulls, and change a clamshell that's beginning to deteriorate.
My diver also told me that our paint isn't completely gone yet (it's ablative) and so we can wait a few more months. He also told me that all the local yards run winter specials for these services and that we could put the job off until those specials are offered.
David Jenkins posted 10-10-2005 10:22 PM ET (US)     Profile for David Jenkins  Send Email to David Jenkins
Sheila, I am reluctant to disagree with guys who have owned boatyards or who have worked in boatyards all of their lives. But I think that you might want to learn how to do this yourself. It is not difficult. Don't try to do the work with the boat on a trailer. If the existing paint needs more than cleaning, wear a disposable body suit and nose and eye protection. Take your time taping the waterline. Use small rollers that are designed for marine paint. Wear rubber gloves. You can do it.
Sheila posted 10-11-2005 12:18 AM ET (US)     Profile for Sheila  Send Email to Sheila
David,
Thanks for your confidence in my ability to learn this skill.
A few miscellaneous factors:
This same yard will charge me $20/foot to haul my boat out and block her on stands, then relaunch her when I'm done working on her. The per day charge is, I think, $1.50/foot. The charge for them to complete the entire job is $28/foot. I'm reasonably certain that I can't buy the paint and protective gear for the $200 difference, before adding in the day charges.
Also, I'm pretty chemically sensitive. Perfumes and household cleaners can give me big respiratory problems. I'm not sure I want to mess with this stuff. I also have a "touchy" disc in my c-spine that tends to complain when I work overhead for any length of time.
I think I may leave this job to the pros.
andygere posted 10-11-2005 02:35 AM ET (US)     Profile for andygere  Send Email to andygere
Sheila,
Bargain a bit with your boat yard. Tell them you will pay them to do the bottom job if they give you a few free days of yard time to do your other maintenance tasks. For price perspective, the expensive yard in my area wanted $25 per foot for a bottom job, using cheapo epoxy based paint. The upcharge for good quality ablative was another $100. They also had a bunch of junk fees for clean up and haz-mat disposal. The working yard where I did it myself charged me a flat $200 for a haul, powerwash and a week in the yard.
starlight marine posted 10-11-2005 05:55 AM ET (US)     Profile for starlight marine  Send Email to starlight marine
Wow, and I thought Florida yards gouged people ! Those yards are making some dough$$. I'm glad you've decided to let someone else do it Sheila whatever the cost. When you factor in chiropractor,and a host of potential health problems you'll be way ahead on this one. You are more than qualified to do the job, that's definitely not the issue. It's what they don't tell you on the can that can kill you. Take care,Capt.T
gcl posted 10-11-2005 11:29 AM ET (US)     Profile for gcl  Send Email to gcl
Despite my attempt at describing how easy it is to bottom paint, seeing there are health/safety issues, my advice is to find the best deal and hire the job out. Best wishes.
Sheila posted 10-11-2005 12:56 PM ET (US)     Profile for Sheila  Send Email to Sheila
GCL,
I am grateful for your comments and will likely try your method when we redo the bottoms on our 16'7" hulls. But since we don't own a trailer for the 25 foot hull, and for all the other reasons mentioned, I think we'll let the pros do the big boat.
Capt. T, that's kind of funny--those of us out west tend to think of Florida boat-related pricing as lower than ours.
Also, all the yards offer winter specials. Our diver has advised that we can wait for those specials. The current price quote doesn't account for the winter deals.
Andy, thanks for the tip. I'll try that.
gcl posted 10-11-2005 03:37 PM ET (US)     Profile for gcl  Send Email to gcl
Shelia,
Thanks for the comment. If you do decide to tackle your smaller boat, one additonal item to help with the bottom paint prep - wash the bottom as soon as possible after the boat is hauled. I use a standard garden hose to rinse the bottom. While it is still wet, I apply concentrated "Simple Green" onto the bottom with a spray bottle, then scrub with a stiff brush, followed with a good rinse. It is amazing how clean the bottom ends up. At this point, I follow the steps outlined earlier. Good luck and best wishes.
macfam posted 10-11-2005 05:48 PM ET (US)     Profile for macfam  Send Email to macfam
Wow!
I guess I've been getting a great deal for my 25' Revenge WT.
For bottom painting, my local boat yard charges me $10/ft ($250) and suppies another $20, and I supply the paint. Pettit/Woolsey water-based "Hydrocoat" ablative anti-fouling ($89/gal)
They don't stock the paint, so I buy it. The yard likes it so much I'm sure they'll stock it next year.
The water-based "Hydrocoat" anti-fouling paint has worked very well on both my Whalers. At the end of each season, May through early November, no growth, just a slight slime that easily powerwashes away.
I paint the 13' Super Sport myself. The water-based paint is very easy to use and super-easy clean-up with soap and water.
I'll never go back to solvent based paints again!
Sheila posted 10-11-2005 09:00 PM ET (US)     Profile for Sheila  Send Email to Sheila
Thanks for those added tips, GCL.
Macfam, that's it, rub it in! Do they haul your boat, or do you bring it to them? Just curious...Thanks for the suggestion on paint type.
Since I have a bit of time, my diver is going to talk to his clients whose bottom paint seems best to find out what brands they've used and where the job was done. The second yard that he initially recommended to me doesn't haul out boats less than 30 feet in LOA.
