  27-foot Re-power
Author Topic:   27-foot Re-power
LID15 posted 11-12-2005 10:07 AM ET (US)   Profile for LID15   Send Email to LID15
I have a 1988 Boston Whaler 27-foot boat with a cuddy cabin and a 10' beam [possibly an OUTRAGE 27 CUDDY?]. The boat is in very good condition. The [boat was powered by twin] 225-HP OMC Sea Drives, but the engines have been removed.
Does it make good sense from both performance and cost standpoints to re-power this boat with new engines, as opposed to buying a newer boat? The estimated cost to re-power with new 225-HP outboard motors would be $35,000 to $40,000. I'm not sure yet what I could get for the hull alone.
Who should I be looking for to do this work?
Is an Armstrong bracket the best way to go?
Thanks to anyone who can help.
crazy4salmon posted 11-12-2005 12:16 PM ET (US)     Profile for crazy4salmon  Send Email to crazy4salmon
Go to the Cetacea collection and look at Cetacea Page 79. That owner put a bracket on a 27 that had Sea Drives on it. How much would you spend on a boat of the same quality with new power? I think in the Cetacea article the cost of the bracket work is mentioned. Good luck
Dan
Steve Leone posted 11-12-2005 01:41 PM ET (US)     Profile for Steve Leone  Send Email to Steve Leone
You could get away with twin 150-HP E-TEC outboard motors. I just rigged two 90-HP motors on a 21-foot Trophy. The base price on each outboard was $7,400. $35,000 to $40.000 is a bit steep for a re-power, but I guess it depends on where you take it to have the job done. If you like the boat, then do it. If you are doing it just to sell the boat you may be better off to sell just the hull, minus the power, and let the new owner decide how they want it. Good luck, Steve.
Revenge 25 posted 11-12-2005 02:12 PM ET (US)     Profile for Revenge 25  Send Email to Revenge 25
I would take the boat or have it transported to Armstrong Marine in Florida and have them fabricate and install the bracket. It will probably cost you:
1) $1,500 transom fiberglass repair
2) $2,500 bracket
3) $500 bracket installation
You can pick up a pair of Johnson 225-HP outboards at Ed's Marine Superstore for the following price:
1) PAIR 225 HP 4-STROKE EFI JOHNSONS $18,999
You will probably have additional rigging costs of around $1,500.00 (i.e. new Teleflex hydraulic steering, ignition switch) Hopefully the guages and binnacle shifter will be reuseable.
In short, you can probably do it for $25,000.00 If the boat is in good condition, it is worth doing. A 27 Whaler is a great boat!
Good Luck.
jimh posted 11-12-2005 04:44 PM ET (US)     Profile for jimh  Send Email to jimh
Replacement of Sea Drive power with a transom bracket and conventional outboard motors is a complex project. As others have mentioned, you must first decide if the large investment will be worth it for the hull.
If the hull is in good condition--and there is no reason why an 1988 Boston Whaler hull cannot be in nearly new condition if well cared for--the cost of re-powering will only be about $5,000 more than in the case of a boat with a conventional transom. The added performance and beautiful appearance of the full transom Boston Whaler boats makes this added premium worth the effort for many owners.
On the other hand, it might be time for a new boat. In that case, I think you will be able to find a buyer for the hull, although at somewhat of a discount. Boats sold without working motors always seem to suffer in value compared to a boat in good running condition.
JMR posted 11-21-2005 10:53 PM ET (US)     Profile for JMR  Send Email to JMR
To: LID15
I looked long and hard this summer at a 1989 Whaler 27 with about 300 hours on original twin 275 Johnsons which were said to be non-working and effectively zero value - but it was otherwise a local boat with a history and seemed to be in good shape. The asking price was $16,900 and I bid $14,000. The response was $15,500 and I bid $14,500.
The hull eventually went to someone who traded a smaller Whaler. I was just not ready to buy a hull and pay $40,000 for Honda 225s plus all the extras in sales taxes, canvas, cushioning and electonics (as estimated by a known & reputable broker/dealer).
Subsequently, in early Fall,I found a Whaler 27 with 1999 Johnson 200s in good shape and am now ready to haul and fix up various things related to gel-coat and canvas/upholstery (the latter is easy since Mills is very close). I don't know whether the 2-stroke v. 4-stroke debate will be decided soon but I am happy to wait it out at 1 mpg instead of maybe 1.25 mpg, depending on various assumptions about rpm. I hope the 2-stroke wins but it will not be much cheaper. So, I would suggest 15K for a good hull.
Peter posted 11-22-2005 09:12 AM ET (US)     Profile for Peter  Send Email to Peter
I think a value of $15k for a good 27 hull is in the ball park. Repower with a pair of 225s and a bracket and labor will probably be in the neighborhood of $30k to $35k. One way or another you will be losing money by putting brand new power on any vessel new or old.
A pair of 150 HP outboards is not enough power for the broad beam 27!
ratherwhalering posted 11-22-2005 10:15 AM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
I recently converted an Outrage-18 from a 2.6L Sea Drive to a Jackplate and a 1991 Johnson 150. I researched Armstrong and Stainless Marine brackets before deciding on a jackplate, and Revenge 25's cost estimate is right on the money. You will want to call Armstrong first, as they has a 3-4 month backlog last time I checked (this early spring).
Any competent boatyard can prep the transom, and install the bracket, and rig the engines. The folks at Armsrtong can fabricate and ship your custom bracket to the yard, if needed, but all the better if you can bring the hull to them.
jeffs22outrage posted 11-22-2005 11:32 AM ET (US)     Profile for jeffs22outrage  Send Email to jeffs22outrage
This article should be of interest to you
http://www.continuouswave.com/whaler/cetacea/cetaceaPage79.html
I would go the route shown here in the article. Remove the seadrives have a platform style setback bracket mounted to the transom. Then look for a set of slighty used outboards. You should be able to find a nice set of used 200 - 250hp outboards for 10,000 - 20,000 not including controls and rigging.
alkar posted 11-26-2005 06:36 AM ET (US)     Profile for alkar  Send Email to alkar
If you decide to repower, don't plan to skimp on the horsepower. You'd have a barge/dog if you only hung twin 150s on that 27'. (Max horsepower is 600 on that boat, and it's never a good idea to halve max power.)
My 27' had twin Yamaha 200s which I planned to replace with twin CR Honda 225s. The cost of new Honda 225s, rigged, with stainless props, all new gauges & controls, and a new hydraulic steering cylinder was $32,000. The Hondas would have been much more expensive if I had not been able to find a pair of new 2003 "non-currents". (The out-the-door price for new Suzuki 200 four-strokes was about $27K similarly equipped and installed.)
I still wish I had been in a position to finish that boat, as it would have been a delight to own/run. However, as potential buyers regularly reminded me, there are newer Conquests and Gradys on the market with low-hour, big, twin Yamaha four-strokes in the $40,000 to $50,000 range, so I would have been burried in that boat if I had restored her as planned.
A good repower is still worth it if you are confident you will keep the boat long enough to run the value out of the motors. You will never get your money back.
Boston Blackie posted 11-26-2005 02:14 PM ET (US)     Profile for Boston Blackie
It always amazes me to the extent of those offering advice without any idea what they are talking about. A 27 with 300 HP will be grossly underpowered. After purchasing my second 27',I would never put anything less than 400 total HP.
The twin 200HP Yamaha's on Alex' boat needed work but they will get me thru another 200 hours. I will then re-power with 2 strokes but will increase to either 225's or 250's. Pairs can be acquired for $12,000 - $15,000. As many people with more money than common sense re-power, more of the older engines (in very good condition) become available. Just last week a boat owner bought new 4 stroke Yamaha's and told the marina to get rid of his 2000 225HP's or "just keep them". He offered them to me for $12,000.00. I passed, but someone got a good deal.
ARG Marine in Florida always has pairs of this size.
To see the boat now is unrecognizable. Photos will be posted in the next weeks.
alkar posted 11-27-2005 07:59 PM ET (US)     Profile for alkar  Send Email to alkar
I can't wait to see the pictures, Joel. I bet just getting the gelcoat polished out and applying the graphics made a big difference. Please send them on as soon as you can.
WHALER27CC posted 11-27-2005 09:54 PM ET (US)     Profile for WHALER27CC  Send Email to WHALER27CC
A 27 that had sea drives will need a bracket on the back. Assuming that this transom can handle the new distribution that will come from the bracket, and the overall integirty is still there, you will be looking at spending a minumum of 7k for bracket and installation. If you go for the older 2 strokes that are ofetn for sale with reasonable hours then you are going to be looking at another 15-20k RIGGED.If you are looking to put new 4 strokes on , then plan on 30k rigged.
This hull in great condition is worth maybe 15k. Any way you look at it, you are going to be sitting on a 45-60k boat that you will NEVER get your money back on. I would pass on this one, and look for a 27 with newer engines , or one that wouldnt need a bracket put on to facilitate a repower, you will be in a better position that way.
Good luck
Peter
