  Why New Throttle Control For New Engine??
Author Topic:   Why New Throttle Control For New Engine??
BigDeal posted 12-04-2005 11:11 PM ET (US)   Profile for BigDeal   Send Email to BigDeal
Sorry For My Ignorance (Yes I did a search)
I don't quite understand why you need to change the controls when changing the motor. Instead of just the cables themselves. Also are they more likely to work with existing control/cables if you stick with same manufacterer (i.e. OMC,Merc,Honda)
This Baby Wants a Re-Power
http://photobucket.com/albums/d90/BigDeal27/Whaler%2017ft/?action=view& current=ba3b3f50.jpg
-Steve
tarbaby posted 12-04-2005 11:33 PM ET (US)     Profile for tarbaby  Send Email to tarbaby
You have a Morse shifter. Either an MT2 or MT3. There are thousands of Whalers with them. There is no reason to change the shifter if you like that one. It will work with any engine you could put on your boat. If you wanted the trim button on the handle you would get a shifter that matches the engine you put on. There isn't a more classic shifter available.
Nice boat you have there. The shifter fits.... The wheel needs to go! A stainless destroyer wheel would match the shifter. Let us know what you do.
BigDeal posted 12-05-2005 12:07 AM ET (US)     Profile for BigDeal  Send Email to BigDeal
Steering wheel already gone!! Whats this Destroyer you speak of?? (Link??) So would the cables work with any motor or does it depend on the motor. Same with the trim button and ignition (OMC Key) are they typically matched to engine brand??
-Steve
tarbaby posted 12-05-2005 06:20 AM ET (US)     Profile for tarbaby  Send Email to tarbaby
It is a good idea to change out the cables. They will feel much smoother. You want the whole package to be right with a new engine. The cable ends are different on the engine side depending on which engine you buy. If you were to get another Johnson or Evinrude there is a possibility they would be a direct fit from the ones you have now. More than likely you will have to replace the cables.
Do you know what engine you want? Tell the people on this forum what kind of boating you do with how many people, how far etc. and they can steer you in the right direction.
The destroyer wheel is the 5 or 6 spoke stainless steel wheel that most Whalers came with. Do an E-bay search and you will see many. The trim switch should work with any brand of engine. You will have to find the wire in the harness and splice into it. The ignition switch could cause you problems because you will more than likely have to cut the end off of your new harness and wire it to your ignition switch.
The reason most people change out the shifter is that it is a plug in installation with the new wiring harness. Ever seen a Deutch connector? There are available ignition switches from most engine manufacturers that allow you to use the Morse shifter.
Buckda posted 12-05-2005 06:46 PM ET (US)     Profile for Buckda  Send Email to Buckda
Cables are about $20 each, so it's not a big investment. Ditto the advice above - if that control box is in working condition, keep it. You can also buy them new from Teleflex/Morse.
Great looking boat! That baby is begging for a new Evinrude E-TEC 90 HP motor, Saltwater Series (white).
Did you buy the boat painted like that, or did you have it done?
BigDeal posted 12-05-2005 11:35 PM ET (US)     Profile for BigDeal  Send Email to BigDeal
I bought it that way. They did a great job! I would love to start with a bare-bones 19-22 foot project. Something a little more stable in the Chesapeake Bay. But I would go with a yellow paint: ) I was thinking maybe a 115hp Evinrude/Johnson. Thats why I wanted some additional info to weigh out a rebuild if it would've cost an extra 1K for contorls and what not.
-Steve
Revenge 25 posted 12-06-2005 12:00 AM ET (US)     Profile for Revenge 25  Send Email to Revenge 25
I repowered with a 115 Evinrude, about 8 years ago, and the OMC controls had an integrated ignition switch and trim/tilt switch that the motor just plugged into. I cannot imagine cutting off the new harness connector to use an old controller and then re-wiring it all. My new controller with ignition switch was $265.00 I sold the old Morse Controller on Ebay for $75.00. For $190.00 I had a bulletproof and simple installation.
Also, if you decide to switch over to Yamaha, it is a pretty substantial expense for the new rigging. This year I went from an OMC to Yamaha and none of the OMC stuff was easy interchangeable. I ended up spending $1,000 in additional rigging costs.
Good luck!
