  A piece of my Evinrude 175 outboard powerhead is missing
Author Topic:   A piece of my Evinrude 175 outboard powerhead is missing
Mike Brantley posted 12-15-2005 11:21 PM ET (US)   Profile for Mike Brantley   Send Email to Mike Brantley
My outboard mechanic called me this afternoon with good news and bad news. Don't you just hate those kind of calls? The good news was that my tilt was working again on my 1998 Evinrude Ocean Pro 175, which powers my 1980 V-22 Revenge.
Since I've owned this boat for the past year, shifting has been very hard, and I was convinced the problem was that my control cables were too short and were making too sharp a bend here and there. I was wrong. The problem, my mechanic informed me in the bad news part of his call, is that a piece of my powerhead has broken off. It was a protrusion on the front with a hole in it that, together with its twin that is still in place, holds the shift cable or some portion of the shift mechanism against the powerhead. It's on the lower front part of the case inside the cowling, toward the starboard side. I believe it was aluminum. There is no sign of it. With the shift cable only half supported, it tries to jump out and/or break the other “protrusion” when I shift. I wish I knew the correct nomenclature, but maybe my description means something to someone.
Besides being difficult to shift, which has been annoying, I do not feel this is safe. I could lose the ability to shift into forward, neutral or reverse, which could be a dangerous problem while operating the boat I think.
My mechanic doesn't think this will be easy to fix short of a new powerhead, which to me doesn't seem like a financially viable option. He was talking $3,000 and advised me I'd be better off looking for another motor. Does this sound right?
I hate to think my outboard has been taken out by such a seemingly low-tech problem, and I keep thinking that surely there must be some way to reliably hold the shift cable or mechanism or whatever it is in place. But I am stumped.
I fear my description may be inadequate. Does anybody know what I am talking about? Any advice about how to proceed?
New power means I will definitely have to sell my other boat, which is a 1982 15 Sport with a fabulous 2004 Evinrude E-Tec 50. I recently listed this for sale in Marketplace but had since reconsidered and decided to keep both boats. But I won't be able to keep them both if the Revenge needs a new power plant.
2manyboats posted 12-15-2005 11:53 PM ET (US)     Profile for 2manyboats  Send Email to 2manyboats
A picture might help and if you had an old power head you could look at you may could drill and tap for a new bracket.
Sal DiMercurio posted 12-15-2005 11:57 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
Surely you jest.
What needs to be done here is, tell the tech where to head off.
First off, that piece thats missing has nothing to do with the power head, it only holds the cable.
Second, a new power head for that engine isn't going to cost $3,000....A re-build is about $500 a hole or cylinder which comes to 3 grand.
Unless your talking about something totally different than what I think your talking about on your engine, the only thing that will be out of whack will be your sinc & link & that can be adjusted.
Sal
mtbadfish posted 12-16-2005 12:21 AM ET (US)     Profile for mtbadfish  Send Email to mtbadfish
Mike,
Couldn't you have someone make a mount that would position a connection point for the cable, where the missing one was, and would be secured to a couple of nearby bolts? From the descrition you give it shouldn't require a new powerhead. Just a thought.
Mike
lorin posted 12-16-2005 01:27 AM ET (US)     Profile for lorin  Send Email to lorin
Unfortunately (if i understand you correctly) that piece you're talking about does have something to do with the powerhead. You said it is broken off the powerhead so it is part of the powerhead. If it were a separate part it would have a name and it would be simple to replace it by ordering another one. I think that with some creative ingenuity you can overcome the problem, but it will not be as easy as some might think. This is because the really diificult challenge is finding some way to secure the cable extremely tightly, because when you shift, any movement in this outside sheathed part of the cable will create "slop" in the cable and interfere with the shifting. You need to find a way to hold the cable so tightly that there is absolutley no movement, probably not an impossible task, but also not such an easy one.
daddydo posted 12-16-2005 01:52 AM ET (US)     Profile for daddydo  Send Email to daddydo
Mike, give me a call tomorrow. You can come over and see if my 150 has the part you need (I'm going to repower the 21' in the spring).
RJG posted 12-16-2005 08:02 AM ET (US)     Profile for RJG  Send Email to RJG
I would go to a machine shop and ask if something can be fabricated and welded on. Or try a welding shop. Anything to avoid selling that 15. The piece can't be very big right? I wonder how this piece could have broken off and where it went. The load on it is very small. It should have fallen straight down. Good luck.
Mike Brantley posted 12-16-2005 11:01 AM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Lorin, you understand the situation exactly. Integrated bracket might be better nomenclature than protrusion, but it was the end of a long day when I was trying to describe it. Yours is the most pessimistic of the replies, but I think it's the most accurate to this confounding problem.
This isn't a case of taking a part off another motor or ordering a small part and bolting it on. This bracket really is an external piece of the powerhead that has broken off as a chunk. I can't imagine how this happened, but I'm convinced now it has been like this since I've owned the motor. The controls have always been stiff and difficult to engage, and now I know why. The broken off piece is nowhere to be found, so I don't know what happened to it.
It does sound frustratingly low-tech, doesn't it? I simply need some way to hold the cable in place, and the problem is solved. I will investigate fabricating something. I wonder if it's possible to engineer this in reverse. In other words, have something attached to the inside lower cabin and push against the shift cable to hold it in place against the powerhead rather than try to bolt something or weld something onto the powerhead itself. I'm just thinking out loud here. Could I make something out of wood or some material like King Starboard?
That may be a terrible idea, but I don't know. Perhaps I should be talking to a machinist about something out of metal.
Jeff, I will see what I can do about taking a picture. It's difficult to see because of its position. My mechanic showed me what the piece looks like on a V4 powerhead (mine is a V6), and I have found it on a diagram in my Clymer shop manual. Stay tuned for some type of graphic presentation. :)
David, I'll give you a shout. Love to hear about what you're going to hang on the transom of that 21!
derf posted 12-16-2005 11:53 AM ET (US)     Profile for derf  Send Email to derf
I told you that you should have given that motor to me when the trim/tilt was broken.
But, seriously, I'm sure that something can be fabricated to hold that cable until you are ready to re-power. I've had several similar problems. Lately, on my Mariner 115, one of the studs that mounts the block that holds the cable bases was broken. The PO had used nylon zip ties to hold the cables in place. It worked fine but I just had to fix the problem. I ended up removing the cowling and drilling and tapping for a new stud. On the Mariner, the cable bracket was part of the carb air box, I think. It sounds like your mechanic wants you to buy a new motor. I'll bet if it was his motor he could rig a fix. Please post a pic. I think a bracket could be made from SS or Al and mounted to something nearby.
The bad news: you're right, it is something you want to fix right away.
The good news: it can probably be fixed.
Where are you located? If you are nearby, I would be happy to have a look and see if I can come up with something.
Also, I'm in the market for a 150 for my Outrage, I could probably use a 175. So, don't let anyone rip you on the value of that motor because of the problem.
derf posted 12-16-2005 11:55 AM ET (US)     Profile for derf  Send Email to derf
I see you are in Mobile. I'm not too far away.
daddydo, LMK if you want to sell that 150, especially if Mike needs some part and it is project afterwards.
Sonic posted 12-16-2005 01:02 PM ET (US)     Profile for Sonic  Send Email to Sonic
As someone who has done a decent amount of fabrication for wacky car stuff, I might be able to offer some insight. It sounds to me like a piece of the block casting, which holds the shift cables in a fixed position, has broken off. Something need to be set up to hold the cables again, while attaching to something else.
Go to any good fabrication shop...a good machine shop, a motorcycle building shop, a hot rodder, circle track guy (there must be plenty of these in Alabama)any of them should be able to help as long as they are experienced fabricators with decent skills. Either the piece that broke off can be TIG welded back into place by a competant welder, or a bracket can be made to hold them in place again. Based on what I remember from the shift cables on my Johnson 90, which is probably similar, this should not be that difficult for a good fabricator. A piece of Stainless bar stock, some heat, and a bender should be able to make something, for a reasonable price, probably less than $200 for a few hours of labor.
Good luck with it.
Chris
derf posted 12-16-2005 01:59 PM ET (US)     Profile for derf  Send Email to derf
$200? That should cover a couple of days labor. Offer to take the fabricator fishing. "Yo, fix my boat and I'll put you on some Tuna."
He's right about everything else. I would say $200 is a bit steep, unless it takes a lot of work and a heckuva bracket.
Please post a pic ASAP. I'm intrigued, now.
Mike Brantley posted 12-16-2005 05:07 PM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Thanks, guys. Where are you, derf?
Buckda posted 12-16-2005 05:13 PM ET (US)     Profile for Buckda  Send Email to Buckda
Derf -
I just figured out why you and I have quite different takes on what things cost.
You're in Louisiana!
Nothing wrong with that, by the way...sure would be nice to have some of your climate right about now....but things are considerably less expensive in the south, and particularly in the Deep South.
My brother (in Tuscaloosa, AL) and I go 'round and 'round about this all the time.
In Chicago and the upper Midwest, $200 with a skilled welder or fabricator would probably give you less than three hours of work.
The person who did the TIG welding for warranty repair work on my arch charged $380 to re-weld 4 cracks and add some stabilizing material to my arch. It took about an two hours on a Saturday morning, including the time on the bandsaw cutting the stabilizing material.
Still - even $500 bucks to weld a part on the powerhead is better than the sharp, $3,000 stick in the eye for a new one.
Dave
where2 posted 12-16-2005 09:08 PM ET (US)     Profile for where2  Send Email to where2
$200 in Alabama will get you quite a long way, especially if you are in the right town. (We recently hired a guy who grew up in Troy, Alabama, he's a riot to swap stories with, and an all around straight up good guy). Offer to run down to the filling station with the welder, fill up his truck with fuel, and take him fishing! He'll fix whatever you bring him... (be forewarned, an F250 or C2500 has a HUGE fuel tank! and top off the reserve tank in the bed too.)
You'd be amazed the things I've re-engineered over the years. If you're missing the piece I am envisioning, then good welder will be able to help you. Photos still welcome, we'll draw sketches for your welder if you can get some photos...
derf posted 12-16-2005 09:19 PM ET (US)     Profile for derf  Send Email to derf
Yes, it is hard to get a real professional to turn on any power tool, or pick up a wrench, for less than $100.
I am in Baton Rouge. I have family in Mobile. However, they are coming here for Christmas.
You ever get out this way?
derf posted 12-16-2005 09:25 PM ET (US)     Profile for derf  Send Email to derf
BTW, if that type of cable thing ever happens and puts you in a bind, say you are offshore and the cable mount breaks, just put the thing in neutral and, with the motor off, make sure the cables are both where the should be, throttle closed, shift cable in neutral and lash or tape the two cables together. If both mounts break then lash the two cables together and then lash the pair to something. It is kinda a "duct tape and bailing wire" fix but it could get you home if you are careful.
There are two kinds of outboards:
Ones that are under warranty.
Ones that you have to fix alot.
Remember a boat is a hole in the water where you pour money.
B.O.A.T means bring over another thousand.
lorin posted 12-16-2005 11:01 PM ET (US)     Profile for lorin  Send Email to lorin
I guess that after looking at a parts catalog on-line, I'm beginning to doubt what I said before. The two parts that hold the cable are called the trunnion block and the trunnion cover. These are separate parts that are not part of the powerhead. The trunnion block is held onto the powerhead by a screw, and the trunnion cover is held onto the trunnion block by another screw. Is one of these the part that is broken or missing? If so they're quite easy to replace.
Mike Brantley posted 12-17-2005 12:01 AM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Lorin, your encouraging post had me running out to the car to grab my shop manual to look at the exploded parts diagram. I do see the control trunnion block and trunnion cover on the diagram, but this isn't the broken piece. Those parts appear to be on the starboard side, but what I am referring to is on the lower front of the engine. My diagram is called "cylinder and crankcase assembly," but the piece in question does not have a separate name. It is, however, part of the "crankcase cover," which is the forward cover that bolts into the cylinder block.
I may not be able to take any pictures for a couple of days, as it is supposed to rain one day this weekend and we are supposed to go Christmas shopping on another. But I will try to do that and also post a diagram.
Mike Brantley posted 12-17-2005 12:08 AM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Also, as far as labor goes here... My mechanic charged me $260 labor and $7 for fluid to swap out the tilt/trim assembly. That was for four hours of labor. I supplied the parts.
Thanks, everyone, for the advice.
Peter posted 12-17-2005 07:56 AM ET (US)     Profile for Peter  Send Email to Peter
From what is described, it sounds like this is the part of the lower cover that holds the shift shaft and arm assembly in place (No. 50 in the on-line exploded parts diagram) allowing the assembly to rotate to convert the horizontal movement of the shift cable into vertical movement to raise and lower the shift rod extending down into the leg of the motor.
Assuming this the broken piece, why couldn't some new metal be welded in place and then drilled out to the appropriate diameter to accept the shift shaft and arm assembly?
lorin posted 12-17-2005 10:29 AM ET (US)     Profile for lorin  Send Email to lorin
Yes Peter, I think you're correct. The broken part is located on the very bottom front of the crankcase cover and has the shift shaft and arm assembly passing through it. I think half of this "housing" for the shift shaft is broken off. It seems like it would be very difficult to do much work on this area without first removing the powerhead which involves much labor and $$$. Mike-I emailed you off-list about this. Here's what I said:
Like you said, it's a protrusion on the lower front of the crankcase with a hole going through it. However it does not hold the shift cable. Rather, part number 0436822 the "shift shaft and arm assembly" passes through the hole. This is part number 50 on the catalog list I'm looking at. Like you say, it's on the crankcase cover. It seems like the starboard half of the protrusion is broken off allowing the shift shaft to wobble instead of remaining in one plane as it rotates. The shift shaft still passes through the port half of the protrusion but that isn't enough support to hold the shaft steady. Right? If so, it is indeed in a very difficult location. I'm guessing it would be very difficult if not impossible to do any welding there without first removing the powerhead which involves a lot a labor and even then it would be no picnic. I'm no welder so I can't offer much advice there. What I was wondering about is whether you could use any type of " liquid steel" or liquid aluminum if there is such a product-something that is malleable until it hardens to replace the missing part of the protrusion. I'm also no expert on that type of product but it may be worth investigating as an alternative to welding.
Mike-also maybe your "reverse engineering" idea merits some more thoght.
Mike Brantley posted 12-17-2005 11:57 AM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Peter and Lorin,
Yes, you both have it exactly. We're headed out now on a Christmas shopping excursion in another town (one with a big outlet mall), so no time for more of a reply. Thank you all for being so very helpful!
Sal DiMercurio posted 12-17-2005 12:43 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
I said it has nothing to do with the power head meaning it's certainly not going to effect the way the engine runs, it's an external problem, not internal.
Any machinist worth his weight in salt should be able to manufacture a bracket to attach to the power head to securley hold that cable.
Sal
derf posted 12-17-2005 04:31 PM ET (US)     Profile for derf  Send Email to derf
Oh, Foley, eh? Gave much money to Ralph L. there myself.
Steve Leone posted 12-17-2005 08:01 PM ET (US)     Profile for Steve Leone  Send Email to Steve Leone
Mike, do you have the piece that is broken off? Is it laying somewhere underneath, or possibly it has rattled down into the lower shrouds somewhere? If you can put your hands on the broken piece you may be able to repair it. Take the side shrouds off, I would bet it is there. The part that is broken off is part of the front crankcase half, unlike the older models, which is part of the intake assy. Those crankcase halves can not be interchanged. They are line bored with the other half of the block. IF you can find the old piece you may be able to fix it pronto. IF you have the old piece you can pin and glue the broken off piece back onto the intake casting. Like a dentist, you will need to anchor the pins into the castings. The pins will need to be seraded to hold securely and you may have to use several or more pins, depending upon the diameter of the pins and casting surfaces available. The glue will need to be a strong two part epoxy. This will hold your piece into place, and being from the same casting with the same break, it should line up exactly. The powerhead may have to be removed to do this, but may not. The shrouds on that model come rigt off, exposing the whole powerhead quite clearly. If you have the clearance to drill it can be done. Don`t drill too deep. You can mark the bit to know where to stop. Did both of the "tangs" break off or just the one? Now: Why did it break off? Answer: The upper horizontal shift rod must have seized at that point and the force of shifting it broke it off OR it was a bad cast. OR it was Cock Robin again....Steve
Mike Brantley posted 12-18-2005 09:32 AM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Steve, that's a good explanation for how the break happened. Thanks for the tip about the lower cowling pieces coming off, because this will be easier and less costly to deal with if I don't have to take the whole powerhead off.
I haven't had a chance since I became aware of the problem to really get in there and look at it, so that's what I will do today. It'd be nice if I could find the missing piece, for sure!
I will try to see if I can get a good picture of it.
Mike Brantley posted 12-18-2005 09:35 AM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Derf, yeah, you know the place! The Foley economy benefitted from our visit, I'm afraid. Had a late lunch at Lulu's on the ICW down at Gulf Shores. Next time, I want to go by boat.
derf posted 12-18-2005 11:37 AM ET (US)     Profile for derf  Send Email to derf
Is that Perdido Pass restaurant still there? They had great shrimp last time I made it down that way.
I would love to reside around Fairhope.
Mike Brantley posted 12-18-2005 02:34 PM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Derf, don't know about that restaruant, but maybe a local will chime in. We didn't make it quite that far on this excursion.
First, the photo...
http://photobucket.com/albums/c330/thevideojunkie/Evinrude%20175/ ?action=view¤t=Missing_Piece.jpg
And the diagram...
http://photobucket.com/albums/c330/thevideojunkie/Evinrude%20175/ ?action=view¤t=EvinrudeDiagram.jpg
Now, what I think is the very good news...
I don't think this is such a big problem, if it really is a problem at all. As I said, today is the first day I've had a chance to really look at it. I tilted the motor up so I could see the shift and throttle mechanisms working from the helm and worked the controls back and forth. I did not detect any abnormal movement of the shift shaft and arm assembly. Everything stayed in line as I shifted the motor. It appears to me the other integrated bracket, the one not broken off which is about an inch or so to the starboard of the broken piece, is sufficient to keep everything in place.
The broken off piece is nowhere to be seen, by the way. I wonder if it could have worked itself down into the foot of the motor or the midsection somehow. Or whoever installed this motor for the previous owner could have discarded it.
Anyway, this leads me back to my initial belief -- that the control cables are too short and making bends that are too sharp. The evidence to support this is the throttle, not just the shift, also is extremely stiff. These are new cables, installed early this year by the same mechanic, and the controls have been stiff like this the whole year. I don't see why the missing piece would affect anything other than the shifting mechanism, and I don't believe it is doing that.
What do y'all think? Should I breathe a deep sigh of relief and just take this thing to some other mechanic to get new, longer control cables rigged with a more generous loop in the back? I think so.
Meanwhile, I am going to keep the other boat on the market, because I have decided I would rather have a new E-Tec on this boat rather than having an extra boat I don't have time to use. My Revenge is slightly underpowered, after all. But I want to repower on my own schedule, and I do want to get some resale value out of the '98 Evinrude.
Binkie posted 12-18-2005 04:18 PM ET (US)     Profile for Binkie  Send Email to Binkie
Mike,
I would go with your hunch, and if it proves to be the right path, try to get a refund from the guy who installed the short cables. Also when your mechanic said you needed a new powerhead he was trying to rip you off, because looking at the exploded view, you could fix the problem with a used intake manifold obtained cheaply at a marine salvage yard, even though the labor might be somewhat costly.
derf posted 12-18-2005 04:48 PM ET (US)     Profile for derf  Send Email to derf
I think someone pointed out that that part is line-bored as an assembly with the block, meaning you can't just swap it out with another one.
Depending on how much of the broken part you can get to, I don't see this problem as insurmountable. A simple "J" shaped piece of SS stock can probably be made and screwed into the remaining portion of the bracket. If you can access the bottom of the broken area, make a simple "U" instead of "J" and attach it by drilling and tapping a couple of 10-32 or 1/4" 20 or 28 TPI bolts.
If, like you said, it will work as-is, fine.
New cables should not be stiff. You should be able to easily remove the outboard end and straighen out the area around the transom. If that last bend is what you think is binding them, then reomving the ends and working the controls with the cables disconnected should be easier. Check your control lever. Some control levers have detents and friction clutches that are adjustable.
Are the cables harder/easier to work if the motor is full to port or full to starboard?
Steve Leone posted 12-19-2005 11:13 AM ET (US)     Profile for Steve Leone  Send Email to Steve Leone
Mike, see how it shifts with the cables disconnected at the motor. If it is on the motor end then you know it is either the control box or cables, vica versa. I think Derf is right, a piece can be fabricated quite simply. Steve
derf posted 12-19-2005 11:52 AM ET (US)     Profile for derf  Send Email to derf
Dibs on the 175 if he repowers.
Just kidding. Let us know how the cable thing goes.
Mike Brantley posted 12-19-2005 01:30 PM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Derf, you get dibs on the motor when I repower, if you haven't repowered yourself by then. What's the deal with your Outrage? Does it need a motor sooner rather than later?
My timetable is to repower to an E-Tec 200 (small block or large is the question for another day) a year from now, if circumstances allow. I'd like the luxury of repowering because I want to and not because I have to.
I didn't disconnect anything Sunday, but I did try to ease the curve of the cables and thought I detected easier movement. I believe the cables are making a sharp bend below the helm, too, as well as in the back. They need to be longer.
If and when the 15 Sport sells, the money goes into the repowering account -- not to be touched for any other purpose so long as I can help it. And I will sell the Evinrude 175 at the right time, too.
derf posted 12-19-2005 06:03 PM ET (US)     Profile for derf  Send Email to derf
My 115 is running fine. I hope to find a good used 150 in the next year or so. With all the re-powering to 4-strokes going on and all the hurricane salvage boats, I'm sure an affordable 150 will be mine before too long.
Mike Brantley posted 02-16-2006 10:56 AM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Forgive me for not putting a cap on this thread sooner, but in the interest of putting any lingering suspense to rest I will do so now. I have decided that the missing piece of the bracket mentioned above is not such a big deal after all. As mentioned, careful observation of the shift mechanism while in use shows that nothing is popping out of alignment. I believe the other bracket that's there is sufficient to hold everything into place.
And in the meantime I have swapped the control cables for new, longer ones. It was a much easier job than I thought it might be, so I'm glad I did this myself. There were 20-foot cables previously, and these were not long enough for my installation. There was no loop at all at the stern; the cables went straight into the motor cowling, which according to my Clymer shop manual will cause binding. Also, there were some fairly sharp bends at both ends, going into and out of the rigging tunnel.
A set of 22-foot cables might be perfect, but I went ahead and used 24-foot cables -- allowing for more graceful bends and a big ol' loop at the back.
Now the shifting is much, much easier. The throttle action feels better, too, but I have to say it's still not as smooth as I had on my other (now former) Whaler with the new Evinrude E-Tec installation. Perhaps I can improve it more with some lubrication, or perhaps there is some adjustment to be made either at the binnacle control or under the engine cowling. I'm uncertain, but the situation has improved.
And, yes, my other boat is sold -- to a nice, enthusiastic gentleman in Texas. No, the proceeds aren't going to repower the Revenge -- despite what I said. Repowering isn't necessary right now, and more pressing at the moment is my need for a new tow vehicle.
Thanks, all.
