| Author | Topic: Gelcoat Repair Costs |
| Buckda |
I'm having my transom patched and gelcoated sometime this week. I should have an estimate by Wednesday. I'm trying to "head off" the sticker shock. Here's what's happening: The engine is going to be removed. There are a series of 12 through-transom holes that will be plugged (4 for the ladder, 4 for the engine and 4 for the kicker bracket). Additionally, there are: 9 smaller holes in the outside of the transom for various attachments: SONAR transducer, Speedometer "thingie" and the holes from the screw-clips to hold the associated wires in place against the transom. The outside of the transom is likely to be re-sprayed with gelcoat. On the inside, I have those same 12 holes that will need to be repaired, plus some additional "surface" holes that will be fixed from the poling platform that was mounted there. I'm thinking that the inside of the transom splashwell will also be re-sprayed. Any opinions/ideas on what this might cost? I'm thinking at least $200 for materials alone, plus a few hours of work? -around $500? Dave |
| DaveS |
Last year when checked, there was a place, highly recommended by a Whaler dealer, I was looking into a price to have my front bow repaired. If I was going to complete the metamorphisis from Newport to Montauk I wanted it done right. They told me they had done one before and gave me a soft quote of abouot $750. For that they would repair the notches that were cut to make way for the bolts in the front deck of the Newport and repair all the little screw holes needed to be filled once the gunnel cap was removed. For me it was cheaper just to upgrade to my current 17 Outrage. A good move on my part! Good luck. DaveS |
| Mister S |
I'd think you should ask this question of the guy doing the work. Pulling motor off, filling holes ( they should be checked for moisture and sealed) gel coating and re rigging is sure to be more than 4 hours or so. Seems to be a full day + and maybe more than 1 guy at times. Labor here is ~ $75.00 hr. Make sure it's done right and it will be worth it. |
| kingfish |
Dave- Say it ain't so! You're not going to just patch those yourself? I'm starting to get the feeling I'm gonna have to leave Outré hidden in the barn when Gambler is out on the water for fear of embarassment, once you get finished with all your messin' around... John |
| LHG |
This boat is going to look so good, that I am considering offering "Whale Lure" in trade for it. My problem is, I'm trying to determine how much EXTRA I'm going to have to pay Dave to get his boat. Maybe my 25 Outrage plus an extra $30K? |
| kingfish |
Let me know if Dave doesn't bite - I might consider letting Outré go for that kind of a deal... |
| Buckda |
THanks guys. The motor is a 1/2 hour deal - everything is disconnected already, they just need to put it on a lift, loosen the bolts and then remove the engine. I've done all of the other work there. They will not be re-rigging the boat either. They're delivering the boat with a clean transom. I DID ask my guy - he's getting an estimate together now that he has the boat and will get back to me by Wednesday. I was asking here to help offset any sticker shock I get on Wednesday - to prepare myself. Labor is $69/hour, however there is a 15% February discount. So - it's literally just for the hole patching and gelcoat work. Thanks for your continued feedback.. |
| LHG |
Dave - having done identical work on my 21, I would strongly suggest you set some specifications as to what you want done, and how. What kind of plugs & glue, what kind of resin, where does gelcoat match come from, what if water is weeping out of holes or soft plywood is found, degree of final finish, etc. Be careful, or you could get some real bad work. Not everyone knows how to work on a Whaler. |
| mobey |
Larry is right on with his last post. Over the last 3 years on my Sakonnet, I [spent excessively] many thousands on gelcoat work done, and then re-done the right way. Your repair guy absolutely must know what he is doing on YOUR Whaler- 100%, no if's, and's, or but's. GET SOME REFERENCES! Get a look at some his past work, hopefully something a year or two old. All of the projects just completed and sitting in his shop may look fantastic. It takes some boat use and time to see the real results. I would guess you will be spending in excess of $1,000 for the work you are describing. If stress cracks are found, the proper repair of them will have you spending hundreds additional. Take no short cuts. |
| deepwater |
buckda how well do you know this shop have you heard good things will they let you be there when some of the work is done? |
| Buckda |
My father and I are longtime customers of this shop. They have serviced our engines and boats for many years, and have helped to broker boats for us when the need arose. They're not always the best prices (i.e. Engines for repower) due to their size (low volume), but I do trust them for honest work. There are no stress cracks in this transom - I've inspected it very carefully on that front. Thanks for the advice. $1,000 huh? Ouch. Maybe I will get out my mixing stick and call Spectrum. Dave |
| Plotman |
Dave- I really wouldn't be afraid of doing the hole patching yourself. I have had really good results with the spectrum patch paste. Yes, it takes some time to wet sand and polish the patches -- actually, just plan on wetsanding the entire transom given the number of holes you have -- but it isn't difficult at all, and the results an amature can achieve are surprising. What about trying one yourself before you make up your mind. |
| mobey |
Dave, At your described favorite shop: The guys that sell boats and motors, as well as the guys that do mechanical shop work will not be individual who will do your fiberglass & gelcoat work. It is that very individual who must be the fiberglass expert. He must be an experienced true craftsman dedicated to the specifics of fiberglass hull work. From what I've learned, the best fiberglass guys are full-time on fiberglass boats, and have decades of work under their belt. I learned the hard way by buying into the supposed high reputation of the boat dealer/ shop where my Sakonnet was first worked on. They are a Boston Whaler dealer here in Wisconsin, just north of me. I should have focused on the very individual in the shop doing the fiberglass work on my boat. It cost me thousands, and a lost season of boating. It also was a real downer to be constantly arguing about the problems and money issues with the owner. I eventually had much of the work done by them completely stripped and re-done by another shop. No Fun. Good Luck! |
| anthonylisske |
Buckda, I did the same work myself several months ago. It was pretty labor intensive. (Although I am sure that a professional would be more effecient by a factor of 2) I think the quote of 1000 sounds about right. A suggestion might be to do the glass work yourself, then let the professional do the gelcoat work. I mean, I actually enjoyed doing the fiberglass repair, it was the gelcoat that was a bitch. Any advice I needed was available on this site (P.S. Thanks everyone)and I am completly satisfied with the work. You cannot even tell it was redone on close inspection. Then you could have the shop spray both sides of the transom and blend it into the deck. Good luck. |
| ratherwhalering |
Dave, I had that Outrage-18 Sea Drive converted to a blank last winter for $900.00, including several transducer holes, two large cut outs, and six mounting holes. The final bill was three times the $450.00 estimate, and we settled at two times the original estimate. Get it in writing, my man. |
| Buckda |
Estimate is at $875 for all of it, including holes on splashwell dam. |
| Mister S |
Price sounds about right. Getting things done right on your boat has a lot of added value. Hope I didn't come across wrong on earlier post about estimate - Looks like I may have. All I meant was that the shop's estimate was the one that counted. Sorry. DS |
| Buckda |
DS - No worries - I agree that the shop estimate is the only one that counts...but I've never commissioned any fiberglass work before, but had heard rumors that it was expensive. That nervousness led to my post to try to get some responses so I had a ballpark to play in. Looks like it accomplished that goal. Thanks for the advice from everyone. I'm still deciding what to do. Dave |
| JayR |
Well? What was the quote? |
| Buckda |
Jay - Estimate was $875. I brought the boat home on Saturday - $50 for them to yank the motor. I patched the holes on Saturday using oak plugs and "gorilla glue" as Tom Clark had advised in an article I searched out using the search function. I then "capped" all of the holes with marine Tex epoxy and heated the area overnight. I'll go back and gelcoat patch the holes this spring when the weather heats up enough. I also left a few of the holes open (covered with tape) while I decide what to do on that front. Meantime, my timelines march forward and wait for no one. Next weekend is the last weekend for 5 weeks that I will have use of a farm Tractor to lift the motors for mounting...so I went forward and mounted the brackets: Before: After: I've also been busy replacing rod holders. Here's a glimpse of my home-made replacements (made out of the "Starboard" material): Finally, I got busy working on the console; I added the dual binnacle control and then ran into a slight problem with the key switches. The Merc switch doesn't require as much "depth" behind the switch - the BRP ones require about 2-3 inches! I had to move it down further on the console to accomodate the controls - so I had to improvise a patch over the hole above. I used a bit of teak: That teak will be varnished to match the rest of the wood on the boat and re-installed next weekend. Busy weekend!! Dave |
| Royboy |
Glad you came to your senses and did the job yourself, Dave. Hey, I was looking at the pictures and I got to thinking; since you have two brackets on your transom now, why not go ahead and mount two engines back there? I know, it's a radical idea, but that's what they pay me the big bucks for! I'm thinkin', with two engines back there, nobody is going to be able to catch up and see if the fiberglass work is good or not. No need to thank me, Dave, I come up with stuff like this all the time. It's a gift. Roy |
| Buckda |
Roy - I might do just that... Dave |
| LHG |
Dave - Your brackets look closer togher than mine. Did you use BW's recommended centerline spacing of 29-3/4"? On that teak key switch panel, consider routing a 45 degree surface bevel, half the thickness of the wood. See my similar 21 Outrage instrument panel photos. |
| Buckda |
Larry - I'm following along with the BRP manuals. The manual lists standard ABYC centerline spacings as 22 inches, 26 inches or 27 inches for dual outboards. My brackets are 26 inches apart on center. Another deviation from advice given here on CW (and from you) is the BRP recommendation of the transom bolts. They indicate that the bolt "head" be on the inside of the transom with the shank through the transom to the bracket. This advice/recommendation was echoed by Rite Hite in their instructions...so I went that way. Since this rig has to be checked over for warranty coverage, I'm sticking to the manuals as best that I can to ensure that coverage will be supplied. |
| Buckda |
"Another deviation from advice given here on CW (and from you) is the BRP recommendation of the transom bolts. They indicate that the bolt "head" be on the inside of the transom with the shank through the transom to the bracket. This advice/recommendation was echoed by Rite Hite in their instructions...so I went that way. Since this rig has to be checked over for warranty coverage, I'm sticking to the manuals as best that I can to ensure that coverage will be supplied."
Dave |
| LHG |
Dave - Realizing it's too late to make a change, but BRP doesn't know what they're talking about, the reason being, a HULL'S deadrise angle determines twin engine spacing, not the engine manufacturer! Boston Whaler made this hull, not BRP. The decal on my hull says to use 29-3/4" engine spacing for proper engine powerhead and running height. On a Vee hull, engine spacing determines at what height the engines will cut the water flowing off the hull. Moving them closer raises them, or forces lower mounting height on the transom. I think you will be all right because you are using the jackplate, but if you had to put them directly on the hull, you will be running a bit high. As for bolt direction, that is only based on the ability to seal the lower transom holes by first applying sealant to the bolt shank, which draws it into the hole. When the bolt goes in from the inside, you can't get sealant into the hole on the outside surface. None of this should be a big deal however. Just fine tuning, and less chance for a caulking void. |
| Buckda |
Thanks for the pit in my stomach larry! Okay...assuming that this is a problem this spring/during the test runs, I'm relatively confident that I can pull the motors and re-mount if necessary. By the way...I have no such sticker on my hull. Further, the hull owner's manual recreated on this site makes no specific mention of this spacing number. These are resources that I consulted in the mounting of my brackets...including the Evinrude/Johnson Predelivery and Installation Guide I have to believe that in 1986, when the boats were often sold with dealer rigged motors, that the dealers often followed the instructions provided by the outboard motor manufacturers. ...but I hear your point...and I hope it is not a problem. |
| LHG |
Dave - One more thought regarding the key switches. You might want to conside putting them in the instrument panels. See what I did on Cetacea Page 2. The reason for this is that when mounted in the panels, you won't be hitting them all the time, possible shutting down the engines inadvertantly. Where you have them, they will be in the way all the time. Regarding the kill switch, I also hid that inside the console, where it can do double duty in theft prevention. |
