| Author | Topic: Outrage 19: Refinishing Gelcoat Hull Bottom |
| Chesapeake |
I procured a wonderful 1991 Outrage 19 last summer while out on the east coast. It is bottom painted black, which I just don't flat out like as I love the naked artistry of the Douherty hull bottom. So, I am now back in the midwest and battling with the decision, "do I repaint white or some other color or re-gelcoat the bottom?" I am leaning toward the re-gelcoating but I'd like to know what are the cons of doing so. Is a redo as good as an original job in terms of durability or is it more like paint... meaning it will have to be redone in time. Thanks. Bob PS: Let me add that an Awl-grip job or just sanding and polishing are not options that I am interested in for this project. Reasons: 1) Awlgrip, as good as it is (I have used it extensively), will need to be repainted in 7-10 years. 2) My boatbuilder out east warned me sternly that sanded gelcoat needs to be sealed and not just polished and you might as well paint again at that. |
| keltonkrew |
Re-gelcoating is an excellent option. My only concern would be can you flip it over. It's more durable than paint, easier to repair if needed and if applied properly will last longer than paint. I re-gelled my entire boat, but a 13 is easy to flip and work with! |
| Buckda |
Bob - I don't think that "flipping" the hull is recommended, although forum member GEP did this with his 18' Outrage when he restored it. I believe he also did a bit of gelcoat work on the underside of the hull. Search him out - I believe he has a Web-page with photos of that effort. Additionally - there was just recently; perhaps 3 months ago - a thread by someone down in the deep south - either Louisiana or perhaps Alabama or SE Texas that regelcoated an older 18' hull. They "hung" the hull from the lifting eyes and worked on the boat in an upright fashion. Either way - I think this is the way to go - you'll be much happier with the look of the boat - especially if you plan to keep it on the trailer. It should not be too intensive once you have the bottom paint removed. Good luck - I knew you couldn't refuse a good project. We'll have do do lunch and compare notes. Dave |
| Binkie |
Your project seems like too much effort for the result. Do you have an easy way to turn the boat bottom side up? I wouldn`t attempt that project if you can`t turn the boat over. I can`t even imagine stripping or sanding off bottom paint down to the gelcoat, working over my head. You would have to move the jackstands to sand under them, and do the same when gelcoating. Also an HVLP spray gun won`t work when painting vertical, so you`ll need to use a conventional overspray producing spray gun. Why would you only paint the bottom a little more effort, and you can do the sides also Find a color bottom paint that you like, and use the hard type made for trailer boats, pick out a contrasting color boot stripe, and enjoy your boat. |
| Chesapeake |
Guys: Thanks much for your input. Let me set one thing straight... I won't be doing the gelcoating and I should have stated that up front. I am talking about having someone hang it and do the whole job for me. My marriage is too important. Dawn didn't like it a whole lot when I turned the garage into a portable spray booth when rehabbing the Nauset. She'd like it even less with the 19. So I guess what I really am asking is a re-gelcoat a good repair to make. Is it as durable and as attractive as the OEM finish. Last, what do you think I will pay to have the outside hull shot with gelcoat? Of course, with that done and Buckda working three floors above me, I don't know if I could stand walking into his office and looking at the pics of his new motors without having to buy at least one myself!! :-) Bob |
| jechura |
Bob; Maybe I missed something, but their are countless members that have had the bottom paint stripped and the gel-coat sanded, buffed and waxed, with no problems. Ask David about Paul's 18. The bottom paint would have to be stripped and the original gelcoat prepped before and work could proceed. There are specialty sealer waxes for boat bottoms. Jerry |
| Plotman |
Since you will have to have the bottom paint stripped no matter what you do (you certainly can't re-gelcoat over bottom paint) I would think that you should make your decision about what is next once you have completed this step. As someone who sanded all the old bottom paint off of a 22 from flat on my back while it was sitting on a trailer, I would seriously look at soda blasting. Depending on how badly the bottom was scuffed before the original pain was applied, and whether or not the paint is hiding any old repairs, wetsanding and buffing without reshooting the gelcoat is likely going to be an option. Plenty of folks have done it sucessfully. At least do a test patch before making your decision. Another option would be to repaint with Micron's CSC in shark white. This is sort of a light gray, but is much less glaring to the eye than the standard black, red and blue bottom paint colors. CSC is also an ablative paint designed for the in and out life of a trailer boat. David |
| crusty crab |
Last year Pettit came out with a line of hard, burnishable bottom paints (called Vivid) in a vast array of colors including a stark white. I believe they are geared towards the racing sailboat market and are epoxy-based. Not sure if they have desert tan.... The one year feedback on it is very good (check the forums at www.sailinganarchy.com). If I had the link to Pettit I would post it. |
| jettycat |
I agree that wait n see till you get the bottom paint off. DONT sand it off. Use the best stripper designed for bottom paint. Ive seen bottom paint stripped off to reveal a nice surface beneath. Definately reworkable. Depending where you live the regelcoat will vary from thousand to thousands. good luck |
| David Jenkins |
Chesapeake, Save your money and your marriage! Do not re-gelcoat the bottom. It will cost more than $2000 and is not as durable as a bottom that has the original gelcoat. Paint below the waterline with Interlux brand antifouling "Trilux 33" #YBA068 White. This paint was originally designed for aluminum hull boats but it works great on fiberglass hulls, too. West Marine sells it for about $60 per quart. Roll on about four coats and be back on the water in less than a week. You will need one quart per coat, so you might want to buy a gallon. |
| DaveS |
There was a neat tutorial on thehulltruth.com but for some reason, I can't seem to access it...does anyone know what happened to that site? Here it is, just in case it's me...but it the link is on my other computer at home...I'll post it tonight...a nice arguement to just strip the paint and rework the gelcoat.. Good luck... DaveS |
| DaveS |
Here you go...I just found the link...the guyu put a ton of work in on this hull but it really came out nice... Dave http://www.thehulltruth.com/forums/thread-view.asp?tid=25754&start=1& posts=40 |
| crusty crab |
Here is the link to Powerboat Reports article on bottom paints. http://www.powerboat-reports.com/pub/18_11/features/5604-1.html You have to buy the article to read the findings but they like Pettit Vivid and Pettit Trinidad SR. Sounds like Micron 66 is good too. Maybe a price thing but I'm too cheap to buy the article! |
| Chesapeake |
DaveS: Thanks for the thread. That hull is really gorgeous now. From the sound of it, he simply stripped, sanded and polished and did not re-gelcoat. Is that the way you read it? Bob |
| homey |
Chesapeake, Your boatbuilder out east who warned you that gelcoat must be sealed after sanding is incorrect...Gelcoat is used because it can be repaired or applied easily by spray or paste...I have never heard or seen any documentation regarding sealing gelcoat after its been sanded or polished... Your 19 sounds like an easy job that could be accomplished in 3 days....I did my 25 Outrage in approx 4-5 days. Removed 2-3 coats of paint and now the bottom has a mirror finish without having to re-gelcoat or paint...I didn't like the painted bottom either....Good Luck. |
| bsmotril |
When you sand, polish, and buff out a gelcoat finish, the new surface is very suceptible to staining from bird droppings, rust drips, etc. The polishing process opens pores on the gelcoat surface. You should always seal the surface immediately afterwards with a good quality wax. If you don't the hull will pick up stains very easily that will be difficult to remove with anything other than an acid cleaner. BillS |
| DaveS |
Bob, Yep, that's my take on it...although I never thought about what BillS said about waxing the hull...I've been thinking about doing something like that for some time but am not sure I want to tackle such a labor intensive job in the heat of the summer...I'd rather be fishing...I'll probably attempt to remove it slowly as time permits... Good luck with your project... DaveS |
| bsmotril |
With a good DE Rotary buffer tool, and an air powered jitterbug if your also wet sanding, it's not that labor intensive. About 8 hrs total work if you wet sand, About 5 hrs if you just compound, polish, wax, and buff. This for a Montauk, inside and out including rails. BillS |
| bsmotril |
Should Read "DA Rotary tool" as in Dual Action. |
| homey |
I never observed bird droppings or rust on the BOTTOM of a whaler hull....I've never considered waxing a form of sealing either....Wax washes off easily particularly on the bottom of a boat.... A bottom painted boat requires repainting seasonally a nonpainted bottom requires cleaning. Sometimes with an acid wash.... |
| Chesapeake |
Thanks for everyone's response. Here is the situation. Two local glass guys here north of Chicago have responded and the price for re-gelcoating just the hull (not the interior) would run over $2k and probably near $3500. As Herb Brooks said in Miracle "that's just not going to happen." So I am now investigating the soda blasting routine. Have had some difficulty finding such a person up here, but Larsen Marine said they work with someone and so I am ultimately making a contact. My plan is this: Soda blast to free the hull of paint and see just how aggressive the original sanding scratched the gelcoat. Maybe I will get lucky and it will be little. If that is the case, then I will go to work with my PC sander and then wax. If the scratches are deep, I will not sand the entire bottom as I am concerned (perhaps unduly) about cutting off too much gelcoat. Instead, I will finish sand (and wax) only the boat sides where there is currently paint and then just lay down a barrier coat and re-bottom paint the underside of the bottom, this time with a lighter color paint. Perhaps the shark white previously referred to in a post above. How does that sound? |
