  Replacing water pump on Optimax
Author Topic:   Replacing water pump on Optimax
ivansfo posted 02-08-2006 05:04 PM ET (US)   Profile for ivansfo   Send Email to ivansfo
The water pumps on my 135 Optimaxes are now 2 years old and I think it will be good idea to get them replaced now before fishing season starts.
Last time I had this done at my local Whaler dealer. I remember the total cost was about $500 for the pair.
This time I'm thinking of trying this myself and save both money and time (dropping off the boat). I see Merc sells the water pump kits for about $50 each so savings could be substantial.
For those who have done this before, is the task pretty simple? And any recommendations and tips?
thanks,
Ivan
Lars Simonsen posted 02-08-2006 06:57 PM ET (US)     Profile for Lars Simonsen  Send Email to Lars Simonsen
I took my lower unit off several times last year to check for a leak (I had a problem with water in the lower unit oil). In the process, I also disassembled the water pump. Ultimately, because I found a leak by pressure testing the lower unit, I brought it to the shop to get them to install a seal kit, and had them replace the water pump at that time.
Replacing the water pump isn't very difficult (at least disassembling and reassembling mine wasn't). There is a bolt under the anode/fin on the back of the cavitation plate above the prop that you have to take out to remove the lower unit. Be sure to mark the anode and lower unit so that you can put it back the way it was before you remove it to access the bolt under it.
Once the lower unit is off, it's pretty obvious what you have to do to get the water pump off.
I suspect that all you need are new impellers (not the whole water pump kit) but if it increases your confidence level to replace the whole thing, it's probably worth it.
Lars
bsmotril posted 02-09-2006 09:29 AM ET (US)     Profile for bsmotril  Send Email to bsmotril
On a difficulty scale of 1-5, the water pump on an Opti is a 2. No special tools needed. The first time might take you 2 hrs, 45 minutes after that. Ishopmarine.com has the parts for a bit less than the dealer. On a two year old motor, there should not be any problem getting the bolts loose and dropping the lower unit. Any of the Clymer manuals that cover the Merc late model 135-175 V6's will apply, they use the same gearcase. There is no shift shaft to de-couple on a merc. The shaft is splines and fits right into the gearcase. Just don't move the throttle/shift lever from the position you left it (reverse) when you drop the gearcase. The water pump kit comes with a cheat sheet showing how it all goes back together. BillS
stompy27 posted 02-09-2006 10:17 AM ET (US)     Profile for stompy27  Send Email to stompy27
It is a great feeling to know you can do all the preventative maint on your motors. The lock nuts on the foot are brass so don't overtighten, they will split. Get a torque wrench and find out from the dealer what the torque is for those nuts. You may need a rubber hammer to get the foot to drop. A few little taps here and there should work. Change the gear oil at the same time and inspect for water. If there is any I would just take the foot to the shop for a Vac/Pressure test. Just a few little points. Break a Leg. Fred
bsmotril posted 02-09-2006 02:14 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
Use a small dab of anti-seize compound smeared around all the bolt threads when you replace them. If there is any corrosion on the bolt threads, clean it off before replacing the bolts. A wire brush on a Dremel tool is ideal for this, as are Dentist's hand tools. Also the Dremel works good to clean any corrosion off the mating surfaces on the gearcase and exhaust leg. Be careful if you scrape them, the metal is soft compared to a putty knife or screwdriver blade. Polish and lube (grease or soap) the end of the water pickup tube in the exhaust leg so that iw will slide into (versus crush) the mating grommet on the top of the pump body when you replace the gearcase. BillS
ivansfo posted 02-09-2006 04:55 PM ET (US)     Profile for ivansfo  Send Email to ivansfo
Outstanding info posted here! Thanks for all the advice.
You guys convinced me to give this a shot. With my Merc service manual and this info, I'm confident I can do it. The worse that can happen is that I take all the parts and my boat to my Whaler dealer for them to put it back together. :-)
I went ahead and ordered two water pump kits from boatfix.com. Price was about $32 per kit which I think is really good compared to MSRP. Here's the part# if anyone is interested.
MER-46-96148A 8 Water Pump Upper Housing Repair Kit
I'll post back in a few weeks to report how this goes.
ivan
sosmerc posted 02-09-2006 11:51 PM ET (US)     Profile for sosmerc  Send Email to sosmerc
My recommendation on the 2.5 litre Optimax models (135-175) is that you replace the impeller and the gaskets on either side of the wear plate at the START of your season. Do this every year. The impeller used is very stiff and tends to "take a set" if the engine sits idle for long during the off season. The impellers performance drops substantially when it takes a set.
Also, I highly recommend you use a Merc heavy duty impeller as well as actual Mercury gaskets....they are of a higher quality than aftermarket. The heavy duty impeller is 47-89984T4.
I have nothing against some aftermarket parts, but the water pump and gaskets is one area I'd recommend you stay with Merc.
Do NOT put grease on the impeller to ease installation.
After you have done this service a few times you will be able to do it in less than an hour.
Clark Roberts posted 02-12-2006 06:56 AM ET (US)     Profile for Clark Roberts  Send Email to Clark Roberts
Be very careful to line up the shift spline when putting lower unit back on. The upper (female) part sometimes is a bit wobbly and it's possible to put lower unit back on with the shift shaft spline misaligned. Take a flashlight and have someone watch and verify alignment. Overall (and compared to some other makes) it's a piece of cake! Happy Whalin'... Clark... Spruce Creek Navy
ivansfo posted 02-14-2006 08:30 PM ET (US)     Profile for ivansfo  Send Email to ivansfo
The water pump kit arrived. Here's what the kit looks like. Quite a few parts to replace and more than I expected. It appears all the parts are marked with a PN so I hope it matches the numbers in the service manual.
http://home.sanbrunocable.com/~ivanlum101/boat/merc-pump-kit.jpg
bsmotril posted 02-28-2006 05:35 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
So how did the do it yourself pump replacement go? Any problems?
gss036 posted 02-28-2006 08:38 PM ET (US)     Profile for gss036  Send Email to gss036
Just looked at the picture of the parts for the pump. Those do not look like Mercury packages? I just bought a bunch of parts for my poppet valve and has different looking markings from Mercury. AM Iright in that assumption?
gss036 posted 02-28-2006 08:46 PM ET (US)     Profile for gss036  Send Email to gss036
Just found the answer myself. That is a Serria repair kit. Looks like about $15 savings, maybe?
ivansfo posted 03-10-2006 07:13 PM ET (US)     Profile for ivansfo  Send Email to ivansfo
All,
I'm happy to report that I have successfully changed out the water pump on one of my 135 Optimax. I didn't do this alone though. I had the help of fellow CW member seasickness. The job wasn't extremely difficut but does require some patience. And having a 2nd person around sure helps.
Unbolting and changing out the impeller parts was a straight forward job. This is when I spent time cleaning out the old dried up grease removing some surface rust on some of the bolts. The most difficult part for me was aligning up the spline on the drive shaft during reinstallation. It took me about 10 tries in order to get the drive spline to line back up.
The service manual says put the gear in neutral during removal...but then shift the upper and lower into forward gear during reinstallation. If in forward gear, you could turn the propeller spline so help line up the drive spline which goes into the power head. I had a hard time getting the upper part (power head) to shift into forward so I left it in neutral and just tried to line up the drive spline visually.
I estimate I spent 2 hours on this first motor. Will try to get the 2nd one done this coming weekend. Now that I know how to do it, I estimate the next one should take no more than 1 hour.
For gss036, the kit I bought was made by Quicksilver. I think these Merc kits are somewhat univeral so not all parts in the kit are applicable to my motor. The parts I used from this kit were:
- impeller
- impeller housing
- drive key
- bolt
- gaskets (2)
- steel impeller base
- plastic water pick up guide
- water pickup
Lastly the old impeller didn't look too bad yet. Since it was last changed out, it has been about 2 years and 120 hours. The boat is used exclusively in saltwater in the Pacific and occasionally in San Franciso Bay. I suspect I could have gone a 3rd season before changing this out.
All your tips helped and having the service manual around was very helpful too.
Ivan
Advocate posted 03-12-2006 12:42 PM ET (US)     Profile for Advocate  Send Email to Advocate
Any chance you can post a step-by-step photo guide for those of us contemplating the same maintenance?
seasicknes posted 03-12-2006 01:28 PM ET (US)     Profile for seasicknes
Thats one reason why the first motor took so long to do. We were taking pictures at every step of the way.
Plus it was RAINING.
Second motor lower unit went off, removed the old parts, install new parts and back in within the hour.
*Ivan, thanks for lunch 8-)
Ken (170 montauk / 22 hydrasports vector wa)
skeepyjack posted 03-14-2006 02:28 AM ET (US)     Profile for skeepyjack  Send Email to skeepyjack
Ken,
So next time when need to change the impelleron on mine, I just call you, right? BTW when did you change your call-name?
fishinchips posted 03-14-2006 10:51 AM ET (US)     Profile for fishinchips  Send Email to fishinchips
I have two. fishinchips and seasicknes.
reason why i had two is because I forgot my password at one time and re-registered.
So now i use them interchangably.
Ken (170 montauk / 22 hydrasports wa)
rickeyh posted 07-30-2007 11:12 PM ET (US)     Profile for rickeyh  Send Email to rickeyh
Hi, new here, looks interesting. Was looking for a board with this info. I have a 150 Optimax, with a heating issue. Changed the kit 2 days ago, but horn still sounds at low rpms. Even gutted the T-Stats. Hooked up the DDT and it shows my SB temp @ 176F then guardian mode. I understand there is a service bulletin that may fix this, but cant find it. Adds another smaller hose for more water for cooling. Would lile to see this bulletin or fix this issue, if possible.
Thanks folks for reading.
ivansfo posted 07-31-2007 07:45 PM ET (US)     Profile for ivansfo  Send Email to ivansfo
I had similar issues one year after owning my 135 Optimax. Dealer changed out the impeller AND a part called the poppet valve. That fixed the heating issue.
rickeyh posted 08-01-2007 12:09 AM ET (US)     Profile for rickeyh  Send Email to rickeyh
Thank you sire, tried to buy the poppet kit but the merc dealer didn't have it, so could only change the others. Will check again in a day or 2 and if not order online.
gss036 posted 08-01-2007 01:04 AM ET (US)     Profile for gss036  Send Email to gss036
This was an old post but for those interested, this is a photo step-by-step impeller change for a Mercury outboard.
I know Jim doesn't really care for this type of reference but I don't know any other way to pass along such good information.
http://www.in-depthangling.com/forum/showflat.php/Cat/0/Board/equipment/Number/191911/page/0/view/collapsed/sb/5/o/93/fpart/1
dale in sd posted 04-26-2008 09:47 AM ET (US)     Profile for dale in sd  Send Email to dale in sd
Hello, just wanted to say thanks for this post. The pictures are a huge help. Saved me over a hundred in labor and two trips to my dealer. Took me about an hour and fourty minutes, maybe half next time.
Thanks
