  Trailer Axle
Author Topic:   Trailer Axle
lc posted 03-23-2006 03:02 PM ET (US)   Profile for lc   Send Email to lc
The axle on my Dilly trailer has a crack. I need to replace the axle and since I'm at it, will replace my springs. I have a 15-foot Bosotn Whaler boat (550-lbs.) and a 50-HP Suzuki (240-lbs.). I have no idea how heavy the trailer is. Dilly is no longer in business. Can I get away with 1200-lb rated axle I found at Champion trailer. The only reason I'm considering the 1200-lb rated axle is its shipping weight. I found a complete axle kit assembly 1500-lb on the internet for $169, but shipping the axle kit cost $260! The 1200-lb will cost me $50 to ship (total plus shipping $120). Because I live on the island of Maui, selection is slim. They do have painted axles (about the same cost) but they will rust quickly in saltwater. The local welder will supply 2x2 box tube and weld spindles for $150. I supply the spindle. Alignment comes into play.
Will the 1200-lb axle be okay?
Should I go with the painted axle?
Should I take a chance and go with the local welder? What would you do?
The Dilly trailer is in good shape, looks well-built, but has no specification plate. The old axle was like a 2x2 galvanized box tube minus the bottom side like an upside down U. I assume they made it that way so water or salt would not settle in the axle. I assume axle was made c.1980.
Thanks in advance,
Lance
deepwater posted 03-23-2006 03:16 PM ET (US)     Profile for deepwater  Send Email to deepwater
do you know and trust this welder if he is a welder he should know steel and its strengths how to measure cut and square it up or pay the freight
lc posted 03-23-2006 03:54 PM ET (US)     Profile for lc  Send Email to lc
deepwater- unfortunately, I don't know the welder. Can they get pretty close by just "eyeing" it? I'm clueless when it comes to welding, Are "measure cut and square it up" welding terms I can use or a good welder should be aware of? What comments should steer me away from the welder? I trailer my boat 10-20 miles. Thanks again
Chuck Tribolet posted 03-23-2006 03:55 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Where's the crack? Can the crack be welded?
I suspect 1200 will be marginal, when you add in motor, gas,
battery, anchor, trailer, beer, ... Montauk hulls weigh
935, and usually get put on a 2400-2800 pound trailer. Most
folks figure the weight a of a Montauk rig is about 2000,
and you need headroom.
Is the current axle still sorta usable? Can you weigh the
rig?
lc posted 03-23-2006 04:20 PM ET (US)     Profile for lc  Send Email to lc
thanks chuck,
My whaler is a classic 15'not a montauk and is hull's weight is listed at 550. I carry 6 gallon tank, and additional gear (about 100-120 lbs). The crack is about an inch(or 1 1/2) from the hub. Will welding the crack be a "Band aid" fix or will it still have the maintain the same strenght as the original?
Thanks again, Lance
Don88outrage posted 03-23-2006 05:16 PM ET (US)     Profile for Don88outrage  Send Email to Don88outrage
A consideration when selecting the correct trailer capacity is that ratings, whether it just an axel or the trailer are
static load ratings. I learned that the hard way with a couple bent spindles on name brand trailers that we're "rated for the boat". We have these road anomolies in New England called pot holes, drop a trailer wheel into one of them and your 2000 pound boat may put a 3000 pound load on the trailer. Today I would not own a boat/trailer set up with less than a 25% margin on the trailer capacity.
BBS posted 03-23-2006 05:20 PM ET (US)     Profile for BBS  Send Email to BBS
I bought a new axle and hubs from a local trailer dealer for $120 (1989 18' outrage with a single axel trailer. I do'nt have the specs on the load rating but it is stout. I would encourage you to look around the old fashioned way and save the freight. I would be nervious putting my faith in a weld repair, especially with a single axle trailer.
deepwater posted 03-23-2006 05:25 PM ET (US)     Profile for deepwater  Send Email to deepwater
well than how did you find this welder word of mouth or phone book if hes in the book he probably knows what hes doing welders are not cheep depending on the job or materials a simple axle tube with spindles should be a close estimate of cost ask him if he likes to fish lol
Tom W Clark posted 03-23-2006 05:26 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
15 footer? Just order the 1200 pound rated axle and be done with it. It will be plenty.
Do not fool around with a repair.
Jerry Townsend posted 03-23-2006 05:35 PM ET (US)     Profile for Jerry Townsend  Send Email to Jerry Townsend
Lance - Where is the crack in the axle - on the vertical members or the horizontal top member? How is the crack oriented? This information gives me information regarding the loads causing the crack. What are the dimensions of the axle and the thickness of the material?
If the only problem is the cracked axle, I would have it weld repaired. And frankly - and having done a lot of welding - weld repairing an axle is not necessarily all that difficult. But, being an inch or so from the hub, taking the axle off the trailer, having it welded and then put back on makes the welding easier and faster (cheaper) - and can give a better weld.
Having the axle weld repaired is not necessarily a "bandaid" and if done right would result in that area being stronger than the original. If you were closer I would say, bring it over.
Ordering another axle? - over here, I would order from Northwestern Supply (think that is the right name) - as they ship free. ---- Jerry/Idaho
lc posted 03-23-2006 06:16 PM ET (US)     Profile for lc  Send Email to lc
Thanks for all the replies (even the offer to weld). I decided to place the order for the 1200 rated axle and deal with the shipping (total $120 from Champion Trailers). I'm also going see a welder and see if he can weld the verticle crack. I'll use it as a spare should i ever need one. Again thanks for all you replies. There are some drawbacks that come with living in paradise-SHIPPING COST! Aloha and have yourselves a good weekend (oops, its only thursday!)
Lance
deepwater posted 03-23-2006 11:36 PM ET (US)     Profile for deepwater  Send Email to deepwater
you see lc we have an extreme analytical mind in here design function purpose materials stress cost who did it and who wants it done who do you know we all have our own wants wishes and desires and we spend other peoples money easily but we also share our failures and our mistakes and how we would do it better the next time in the end its all on you who you use and why
JOHN W MAYO posted 03-24-2006 12:01 AM ET (US)     Profile for JOHN W MAYO  Send Email to JOHN W MAYO
They may not have them much in Hawaii, but check at the farm supply stores, such as tractor supply, or agri-supply in North Carolina.
If you have them locally, the axles are very cheap for people who build trailers for farmers etc. Agri-supply has shipped me products when they were out of stock at no charge and I know the shipping cost more than the product I purchased.
jimh posted 03-24-2006 08:17 AM ET (US)     Profile for jimh  Send Email to jimh
If ordering a new axle, look at the torsion axles. They may be an improvement for your trailer.
Chuck Tribolet posted 03-24-2006 08:56 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
My point was that the 925 pound Montauk uses a trailer with
a capacity almost three times the weight of the hull. Three
times the weight of your hull is 1650 pounds, which is a lot
more than 1200.
jimmy c posted 03-24-2006 09:23 AM ET (US)     Profile for jimmy c  Send Email to jimmy c
GO WITH THE NEW AXEL....old rusted metal is difficult at best to weld..the axel is so old I am sure there is a lot of wear in other places...
Check out the rest of the trailer for rust.Make sure the tube frame drains properly.Tube frames rust from the inside out on painted trailers...may look good on the outside especially if it has been repainted...They are especially prone to rust.It has been my expearance that with a trailer this old that has been used in salt water is no longer safe.If you start rebuildng the trailer, axel,hubs,wheels and tires,lights,bunks rollers, coupler etc. you will spend as much if not more than a new trailer and still have a old frame.
The Machinery Killer posted 03-25-2006 10:43 PM ET (US)     Profile for The Machinery Killer  Send Email to The Machinery Killer
Ic,
good move on using a new axel as a replacement. Do not use the old axel even for a spare on the basis that it has developed a crack in one place that is currently visible. The question would be how many other hair line fractures do you not see until pressure is placed on it. When you have the chance please inspect your springs to make sure all are ok. If they crack the individual leaf may be replaced without a lot of heart ache.
The rule of thumb is to make a repair that will allow you to sleep at night with the confidence that you used the best parts possible for the repair. Rather then the idea that I bought the part that "Will fit".
Semper Paratus
Clark Roberts posted 03-26-2006 06:17 AM ET (US)     Profile for Clark Roberts  Send Email to Clark Roberts
If you get a new axle it most likely comes without the bearings/hubs/wheels! There are many different sizes of bearings so make sure that your existing will fit the new axle's spindle and if not get new from axle supplier so you will be sure of fit and specify hub to match your wheels. Happy Whalin'... clark... Spruce Creek Navy
lc posted 03-27-2006 07:41 PM ET (US)     Profile for lc  Send Email to lc
axle and hubs came in. Now just waiting for the rain to ease up so I can get at my trailer. Thank you all for your much needed advice. Aloha lance
