  1982 Johnson Outboard: Jumps Out of Gear
Author Topic:   1982 Johnson Outboard: Jumps Out of Gear
kingluinz posted 04-01-2006 07:59 PM ET (US)   Profile for kingluinz   Send Email to kingluinz
I have had my 1982 Johnson outboard motor for nine months. It has twice jumped out of gear when the propeller breaks the surface.
Give me a URI to an exploded veiw of the gear box.
What causes this problem?
Will a dealer be needed to repair the gear case?
seahorse posted 04-02-2006 05:01 AM ET (US)     Profile for seahorse  Send Email to seahorse
I'm not sure what you mean by "when the prop breaks the surface" that it jumps out of gear. When the prop "breaks the surface" it will spin in the air and the motor will rev up, losing its bite, and the boat slows down.
For a detailed parts list, to to the Evinrude website and click on DIAGRAMS.
kingluinz posted 04-02-2006 05:44 AM ET (US)     Profile for kingluinz  Send Email to kingluinz
The propeller breaks the surface making the engine speed increase. Then it comes out of gear and is revving. The boat stops. Unless i put it back down to neutral and back in gear then away i go again.
jimh posted 04-02-2006 10:40 AM ET (US)     Profile for jimh  Send Email to jimh
If the engine has been operated for 24 years with the propeller coming out of the water and the engine speed allowed to increase dramatically, the gear case may have been damaged or worn and need repair.
Also check the propeller to make sure it is not spinning on the propeller shaft.
bsmotril posted 04-03-2006 09:17 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
Your dog clutches are worn, or the detent on the shifter fork is worn. Not too expensive for parts if you do it yourself, but you need some special tools to get the assembly out of the gearcase. Expect around $400 for a dealer repair, that would include seals and water pump too. BillS
