  Wood Rot In Transom
Author Topic:   Wood Rot In Transom
BT Whaler posted 04-03-2006 06:25 PM ET (US)   Profile for BT Whaler   Send Email to BT Whaler
A can of worms I can deal with. Now I feel like I just opened a 55 gallon drum of snakes. I'm in the process of sanding down all the hairline cracks to prep up for spraying Awlgrip. When I got to the transom there were cracks in the resin around the mouting bolts for the engine. So I started grinding down to the wood and I discovered all around the port side mounting holes the wood is rotted. Starboard side seems to be okay. So I ground out a patch exposing the wood about 2"X4" and the rot seems to continue and I don't know how much further. It only seems to go in about 3/4 of an inch deep. At this point I stopped because I know if I have to replace the whole transom instructions say to cut out the outer shell and save it but in this case I don't think it's the whole transom. What should I do?
John
JBCornwell posted 04-03-2006 07:07 PM ET (US)     Profile for JBCornwell  Send Email to JBCornwell
"Dry rot" is neither dry nor is it rot, John. It is a fungus infection that can and will spread to any available wood. Getting rid of it is like trying to get rid of an advanced cancer.
Not what you would like to hear, but I would replace the transom.
I am sure others will disagree, which is their perogative. It depends on whether you want to fix it or patch it.
Red sky at night. . .
JB
BT Whaler posted 04-03-2006 10:56 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
thanks JB
I don't know if it makes a difference but I don't think its dry rot the wood feels moist. Last summer I installed an engine bracket for my kicker and the holes I drilled started crying so I know there's water in it, but when I grabbed the lower unit and shook it up and down the transom hardly moved so I thought it was okay. Now I'm having second thoughts. I might as well replace the transom before I Awlgrip the whole bottom but I'm not sure how to start. I'm also concerned as to the difficulty of the job and if it will be strong enough and look good enough.
John
BT Whaler posted 04-03-2006 11:00 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
JB - One more thing. Have you ever replaced the transom if so how did it come out.? What was the difficult part?
Thanks.
John
Binkie posted 04-03-2006 11:21 PM ET (US)     Profile for Binkie  Send Email to Binkie
Check out a product call "Git-Rot". I don`t know much about it, or how to use it,but I know its been around since all boats were made of wood. Its supossed to kill the fungus, and I know its a liquid, and maybe it displaces the rotted wood. Maybe someone can shed some light on this stuff.
jimh posted 04-03-2006 11:25 PM ET (US)     Profile for jimh  Send Email to jimh
Repair of the transom can be difficult. There are some discussions in the archives.
Binkie posted 04-04-2006 12:21 AM ET (US)     Profile for Binkie  Send Email to Binkie
I checked out Git-Rot, and it states that its a 2 part epoxy that you pour into rotted areas of wood or glass boats. It kills the rot and restores the original strength. For use on stringers and transoms. I`m not sure how you can pour it into a vertical rotted area in a transom.
PeteB88 posted 04-04-2006 08:17 AM ET (US)     Profile for PeteB88  Send Email to PeteB88
It's not impossible, probably not easy, not done in a weekend but must be done right. I would enlist all resources and probably call West Systems technical staff in Bay City Mich for advice. I generally agree with JB but you won't know until you get into the transom. Perhaps some of the transom around the mounting holes for a few inches around them. What you need to worry about is water migrating through the wood transom infiltrating under the veneers - assuming marine ply transom.
My guess is all bad wood must be removed and I am not sure I would trust Git Rot 100% unless you can confirm from more than one source it works. JB is correct, the fungus must be removed. No shortcuts I am aware of. The other likelihood is if you have wet transom wood then you have wet foam. Keep us posted on how things work out.
Good luck.
PFSQUAN posted 04-04-2006 08:36 AM ET (US)     Profile for PFSQUAN  Send Email to PFSQUAN
John: check out the website: www.seawolfindustries.com and read its thread about transom repair. The drill is straightforward: you shave off the top edge of the transom to expose the inner plywood core. The soft, wet wood is removed by scraping, digging, etc., and then the void is filled with a pourable epoxy mix. The result is solid epoxy core sandwiched with the existing inner and outer fiberglass laminates of the transom.
I have fixed a number of wooden transoms and the job is a chore. Although I have never used the above mentioned product, I would use it if I needed a major transom repair because it allows you to keep the basic shape intact. This would cut down significantly on the amount of time needed to complete the job with eye pleasing results.
With most boat repairs, preparation is the lion's share of the job. Peter
PFSQUAN posted 04-04-2006 08:55 AM ET (US)     Profile for PFSQUAN  Send Email to PFSQUAN
John: I went back to the site I mentioned and need to clarify some things. Seawolf industries is the main site but you should look at www.transomrepair.com to get there quickly. The material is called Seacast. I also was in error because I believed it was an epoxy base; it is polyester. Interesting reading nonetheless and may be the answer to your problem. Good luck. peter
DaveS posted 04-04-2006 09:05 AM ET (US)     Profile for DaveS  Send Email to DaveS
I've heard about the seacast stuff, if I'm not mistaken, someone on this board used it in their whaler...from what I understand, it's kind of "barbaric", they recommend taking a chainsaw and just cutting all the wood out...(isn't that how Jason Voorhees got started?) Once the old transom is removed, you mix and pour...as was said, it might be a fix for your situation...good luck and keep us posted...
Daves
Robob2003 posted 04-04-2006 10:18 AM ET (US)     Profile for Robob2003  Send Email to Robob2003
You might also want to check out the Rot Doctor. I think it's rotdoctor.com to reach their website. Their products claim to kill fungus if the wood is saturated with epoxy.
Although I subsequently replaced some mahogany because the epoxy darkened the wood I bought a small quantity of their two part epoxy and followed the instructions to drill holes and inject the epoxy into the holes. It turned the wood dark but it came out hard as a rock.
If it hadn't been for the cosmetic matter I would have used it
instead of replacing the wood.
Suitable hypodermic needles are available from Vandyke's Restorers.
Bob on Tampa Bay
PFSQUAN posted 04-04-2006 10:41 AM ET (US)     Profile for PFSQUAN  Send Email to PFSQUAN
I am not a scientist, but I am not sure that it is accurate to claim that epoxy kills fungus. From what I understand, living matter cannot survive in cured epoxy, because it has no moisture, food, oxygen, etc. for the organisms to thrive.
I do know from experience with Git Rot that if bad wood is adjacent to a "fixed" area, rot will continue to occur and expand away from the repair provided there is good wood to feed on.
There are many ways to deal with rotted areas aboard a boat, but the only sure cure I know of is total replacement, followed by a complete sealing of the area.
Rot is the result of poor design showing its age in a marine environment. Peter
Tom W Clark posted 04-04-2006 10:46 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
"Git Rot" and other penetrating epoxies will only work if the wood is DRY. If it is still wet, it won't thoroughly penetrate the wood and thus will not magically solve the problem.
Git Rot will not be a good solution for a soggy and rotten transom. The rotten plywood must be removed and proper repairs made.
Either cut enough of one side of the transom to access and replace the damaged plywood or cut the top of the transom open and dig out the rotten wood and then use a pourable resin like SeaCast to fill the void.
BT Whaler posted 04-04-2006 10:39 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
I guess the first thing I should do is drill a series of holes. Maybe a 1/4 inch dia. the only thing is how close and how many should I drill? I'm thinking of setting up a grit and spacing them 6-8 inches apart checking for rot. Does anyone know if this is too many holes? Or should I drill less
John
BT Whaler posted 04-05-2006 12:16 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
I just got off the phone with Seacast. Very interesing concept you hollow out the transom from the top using what ever tool you see fit, they recomend using a small chain saw grinding down the wood keeping the inner and outer shell intact. Once all the wood is removed you pour in resin fiber mixure which is actually lighter then the plywood and stronger. Sounds easy enough, but one small problem.
This Seacast will dissolve foam on contact. That means the whole transom would have to be hollowed out, the wood and also the adjacent foam then replaced with Seacast which will double the weight of my existing transom. But I called back with an idea. I asked what if I build a fiberglass partition on each side to separate the foam from the Seacast. He said because they're both polyester base my idea should work.
John
Binkie posted 04-05-2006 01:21 PM ET (US)     Profile for Binkie  Send Email to Binkie
BTWhaler,
May be an OK idea, but what kind of fiberglas partition do you have in mind, and how are you going to bond it to the foam? If you don`t bond it to the foam the transom will be made up of outer fiberglass shell, foam,cold joint, fiberglass partition, Seacast,fiberglass patition, cold joint, foam, inner fiberglass shell. I don`t think you want the cold joints in your transom. Might trap humidity, and presto, water. May also be a strenth factor.
Rich
Binkie posted 04-05-2006 01:42 PM ET (US)     Profile for Binkie  Send Email to Binkie
I think what I would do, and I`m just summizing because I never did this exact job, but I have patched I/O holes, for outboards. I think it might be similar. I would cut an exploritory hole around the bolts where you know the rotted wood it. Use a circular saw, and cut from the outside , maybe about a half inch deep. Keep making the hole wider until you remove all the rotted wood. At this point, you don`t know how big that hole would be. When you remove all the rotted wood, take out all the wood in that area down to the inside foam. Now you can epoxy new wood or dense foam board in the area that you cut out, and epoxy 3 or 4 layers of mat over that, and then sand and gel coat, or Awlgrip. Seacast may be good, but how do you know you don`t have voids, and it seems like more work, with the chainsaw and all. Sounds good on paper, but it might be a nightmare, trying to preserve the foam.
Tom W Clark posted 04-05-2006 01:51 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
John,
Call Seacast back. I suspect they are making the mistake of thinking a Whaler has Styrofoam in it. It does not, it has polyurethane foam which will NOT dissolve when in contact with either polyester or epoxy resin.
BT Whaler posted 04-05-2006 06:27 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
Thanks guys for your input and concerns but I don't think I'm going with Seacast after all. I went outside and took measurements to figure out how much Seacast I would need. Just to replace the wood I need approx. 2,500 cu squ inches that's more than $600.00 of Seacast material and I don't think that includes shipping. 3/4" plywood cost $75.00 a sheet.
I'm sure Seacast would work well but it's not in my boat budget. West System has a repair manual I bought from West Marine it has a few pages on transom repair it seems pretty straight forward. I also called West Systems and spoke to Tom. He actually replaced a transom and said it not that difficult and to call him if I needed any help
I also drilled a few more holes and found more wet wood.
At this point I'm going to replace the whole transom. I don't think partial replacement is a solution.
John
dfmcintyre posted 04-05-2006 08:02 PM ET (US)     Profile for dfmcintyre  Send Email to dfmcintyre
John -
Tom is a good source up at West. I took a class from them last year. Well worth it.
My 21' had rot. What was done, was to remove the stern, with a small circular saw, carbide blade. Opened it up, removed all the rotted plywood. Replaced with a thicker sheets, and replace the outer shell, by building up with laminate and epoxy. It's a job, but doable. Air powered tools are a help.
When drilling a transom, take a tip from the shop who repaired mine years ago:
Mark and drill for the engine, going significantly oversize, by 1/4 - 3/8" larger then is called for. Mix up some slow acting epoxy, neet. Tape over the lower hole (having the boat raised or trailer jacked up will help) make a small dam from masking tape and slowly pour the resin in the holes. Let set overnight (this is why this technique is not used by most shops....too much delay). Redrill proper size.
What your creating is what West Systems calls an annulus of epoxy, that prevents water intrusion. No water, no rot.
BT Whaler posted 04-05-2006 11:00 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
Thanks dfmcintyre
I think you're right about Tom. He seems knowledgeable and eager to help I'm sure I'll talk with him again. I may buy another outboard so I think I'll wait on drilling any holes. My first question is where do I cut the shell? The wood core section of my transom extends out about 3 inches. So logically I would cut all along the edge othe wood core. Then remove the shell and start removing the wood. Putting the shell back on is where my problem is.
I need to grind a 3 inch bevel all around the cut. The inside of the cut is not a problem. It's the outside bevel
that extends around the corner and cuts back in to the rest of the transom. When I layer the fiberglass and restore the skin on this corner will it be strong enough?
John
DaveS posted 04-06-2006 12:16 AM ET (US)     Profile for DaveS  Send Email to DaveS
John,
Good luck with the project and keep us posted...and take pictures...lots and lots of pictures...I'm sure there's more than one person who'd be interested in reviewing this project!
DaveS
Tom W Clark posted 04-06-2006 12:52 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
John,
I estimate the transom of a 22 will need about 1800 cu. in. of Seacast. That's less that 7.5 gallons or about $300 for materials. You will be into the plywood and resin for more than that.
I do think cutting out the transom and laying in new plywood will be an excellent way to proceed with the repair.
You do not need to cut to the corners of the hull, only where there is plywood which in the motor mounting area only.
dfmcintyre posted 04-06-2006 12:57 PM ET (US)     Profile for dfmcintyre  Send Email to dfmcintyre
John -
I agree with Tom on this, i.e. just cut where neccessary. On mine, they cut open pretty much the whole transom to w/in about 5" of each gunnel. I think the early 21's had wood placement that wide, to handle twins.
Regards- Don
Binkie posted 04-06-2006 01:51 PM ET (US)     Profile for Binkie  Send Email to Binkie
Just an idea:
If your going to replace the whole transom, when you lay in the new marine or exterior plywood, and then cover it with mat and resin, make the patch inset 3/8" from the finished transom. Then cover it with 3/8" marine mahogany plywood, epoxied and screwed to the mat and plywood. Recess and plug the screws. You need to do a neat accurate job when you cut the outer glass from the transom and radias the corners, and the mahogany ply, needs to be flush with the outer glass skin, but it would be a real head turner, and easier than glassing in that area. I saw a 31` Bertram that had the transom done in the manner, it was awsome.
BT Whaler posted 04-06-2006 11:01 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
Tom. I think i took the correct measurements but I'm going to double check. It's very easy to see where the wood core is because it looks like a raised panel coming out of the center of the transom. She's a 79 20 ft Outrage. The dimensions of the wood core is 60 inches wide, 19 inches high and you have to add another 6 inches in the middle for the dead rise. I measured 2 inches thick for just the wood. Then I also subtracted 1 inch from the height to account for the transom crown.
Binkie. The idea of the mahogany sounds really sharp but I'm trying to keep it simple.
This Sunday I'm going to try and get a bunch of guys together and flip the boat over. Right now it's bottom side up. then I'm going to begin cutting the outer shell. I'm taking some pictures as I go along and I'm going to try to get them on the thread. It may take some time I'm not very good at this computer stuff.
John
Binkie posted 04-06-2006 11:36 PM ET (US)     Profile for Binkie  Send Email to Binkie
This will be an interesting project, and a learning experience for most of us. We can contiplate this and that but unless we attempt it, its all conjecture. Keep us informed, and if you figure out how to post pics. let me in on that too. LOL
where2 posted 04-07-2006 01:01 PM ET (US)     Profile for where2  Send Email to where2
You "pour" the Git-Rot into a vertical surface using a large syringe. You cover the holes with blue mask once you inject the resin to keep it from pouring back out. Git-rot is runny stuff and will find all the voids it can find.
With more than 25 years of experience with the stuff, I've watched my father install it in all sorts of challenging configurations. He's got a 1961 Drift-R-Cruz houseboat which used glass over wood construction. Over the years, more than a few spots have seen dry-rot damage.
BT Whaler posted 04-07-2006 05:03 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
where2
I don't think this is dry rot. I drilled a few holes in the transom and most of the saw dust was wet
John
cbgann posted 04-07-2006 07:31 PM ET (US)     Profile for cbgann  Send Email to cbgann
Before you cut off the molded transom skin consider; Cutting off the transom top with a sawzall cutting vertically inside the inner and outer skins. Use a chainsaw to remove the soft wood (quick but messy). Mix polyester resin (glass rich)with the treated glass strands used in driveways in place of wire. This is similiar to chopped roving but does not ball up . Pour and tamp the empty transom full, lay a layer of cloth over the cap, let it cure, sand and regelcoat. The composition is similiar to Seacast at a fraction of the cost and should provide a good bond to the existing foam. Have done this on a number of Whaler Want-to-be's with good results. Good luck Bill
cbgann posted 04-08-2006 06:42 AM ET (US)     Profile for cbgann  Send Email to cbgann
Correction to above - instead of reglassing the transom cap, reuse the cap removed in step one. Then you have just the 1/16" saw cut to regel.
Binkie posted 04-08-2006 09:09 AM ET (US)     Profile for Binkie  Send Email to Binkie
cbgann
Sounds like a good way to go. Do you buy the stranded glass at a concrete plant? How much do you mix with a gallon of resin?
cbgann posted 04-08-2006 11:10 AM ET (US)     Profile for cbgann  Send Email to cbgann
Binkie - I buy it from a fiberglass fabricator in Tarpon Springs. Don't have exact proportions but roughly 1/2 a Publix shopping bag per gallon of resin. Consistancy of pudding and light on the hardener appx. 20cc mek.
Binkie posted 04-08-2006 07:58 PM ET (US)     Profile for Binkie  Send Email to Binkie
cbgann,
Thanks for the info. Tarpon Springs is not far from me. I`ll store this info away for a time when I need it. I`m a retired building contractor, and at first I didn`t trust that stranded glass in concrete, but history has proved me wrong. BTW as far as the bags, no kidding, paper or plastic.
cbgann posted 04-08-2006 09:15 PM ET (US)     Profile for cbgann  Send Email to cbgann
Binkie - It's a small world, last summer we were on a cruise of Scandanavia capitals and there was a couple from Spring Hill. I asked if he knew Binkie who works on Boston Whaler boats. He said never heard of Binkie and was not interested in Boats: only Golf. Guess it takes all kinds.
cbgann posted 04-08-2006 09:16 PM ET (US)     Profile for cbgann  Send Email to cbgann
---Sorry---Plastic. Bill
where2 posted 04-09-2006 12:06 AM ET (US)     Profile for where2  Send Email to where2
So, you've got brown nasty smelling damp mush in your transom. I've seen a bunch of that stuff... I've even seen a fiberglass boat with subterranean termites.
Cbgann (Bill) has owned (and repaired/restored) more whalers than I will ever own, and if he says slice and dice the transom and repair the 1/16" cut, then that's the way to go. I've still got parts on my 15' Sport I bought from Bill 10 years ago...
BT Whaler posted 04-09-2006 12:36 AM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
Guys this really sounds like a way to go. But I live up in N.Y. Does the polyester resin have a brand name? Is Glass Rich also a brand name? My other concern is the weight. Seacast states that there's is actually lighter than plywood. For my application is doesn't have to be lighter but at least close to that of the plywood. As far as the transom cap I plan on cutting it off and reinstalling it when I'm done. I'm just double checking, are you sure the polyester will adhere to the foam adjacent to the plywood core? I'm kind of new at all this.
John
BT Whaler posted 04-09-2006 01:03 AM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
One more question does polyester resin shrink over the years?
cbgann posted 04-09-2006 07:50 AM ET (US)     Profile for cbgann  Send Email to cbgann
BT - Not to worry about compatability. Your whaler was made with polyester resin. Suggest you work with your friend Tom at West, and if you know anyone with a Port Supply card the price is very reasonable expecially if they can get a 5 gallon pail. Sounds like this will be your first experience so you may want to use a (laminating) resin w/o the wax additive which will let you work in small batches As far a weight, If Seacast is the product made in Florida, the additive is made from recycled boats run thru a chopper so weight should be similiar. Est. total cost less than $180 and total Experience "priceless".
Hi Mark - Thanks for the testimonial and pls. say hi to your dad for me.
BT Whaler posted 04-09-2006 05:35 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
cbgann
Thanks for the help and the tips. Now I'm anxious to get started. As soon as I get rid of this bad cold.
John
dfmcintyre posted 04-09-2006 08:46 PM ET (US)     Profile for dfmcintyre  Send Email to dfmcintyre
John -
Polyester /Vinylester has about an 8% shrinkage. Epoxy has a negligible shrinkage rate.
Regards - Don
dr john posted 04-09-2006 08:55 PM ET (US)     Profile for dr john  Send Email to dr john
Damp wood in a transom may not mean it's rotten. I had this issue in a 1980 outrage and when you shook the engine it was relatively solid. Taken the advice of a good friend "dunk" I put a 90 degree aluminum plate across the transom and bolted the engine through the upper holes, several years ago. last week I bored holes to mount a bracket finding a with wet core of wood but still solid transom', keep in salt water 9 mos a year with a 200 hp.
BT Whaler posted 04-10-2006 12:26 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
dfmcintyre
Does this mean that if I pour this polyester in the transom with the filler that it will shrink once it hardens?
JOhn
Tom W Clark posted 04-10-2006 12:34 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I agree with Don. Polyester resin shrinks. I have poured resin in a small hull and had it suck the sides in as it cured and shrank.
BT Whaler posted 04-10-2006 07:28 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
So then maybe I should stick with the traditional method and replace the plywood.
Binkie posted 04-10-2006 07:42 PM ET (US)     Profile for Binkie  Send Email to Binkie
cbgann, I don`t think your Scandinavian friend from Spring Hill would know me. I use another name when I play golf.LOL Actually, I hope I`m not in Spring Hill much longer, When my house sells I`m moving to Sebring.
BT Whaler posted 04-10-2006 07:55 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
Tom
How did the hull come out?
Tom W Clark posted 04-10-2006 08:04 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Is was a bit puckered.
Tom W Clark posted 04-10-2006 08:14 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
John,
I think that if you epoxy and plywood the transom, it will come out very well and be strong. But I had hoped you might try the Seacast approach mostly because I am curious how it will go for you.
As far as I know, nobody around here has actually tried using Seacast though the idea has been kicked around a bit. It sounds like a great idea but I am hoping for some reliable firsthand experience from somebody. This is how we learn.
BT Whaler posted 04-11-2006 10:29 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
Tom
I had actually asked a couple of times in the past if anyone used Seacast so that I would have the same first hand experience that you spoke of. I'm new at this and I don't want to try something that hasn't been proven yet. If I ever do this to a secondary boat I may go that route.
John
starlight marine posted 04-12-2006 07:16 AM ET (US)     Profile for starlight marine  Send Email to starlight marine
Sorry guys, just seeing this one. SeaCast is great stuff. used it on an old 69 Mako 19. Had a 150 Black max mounted on back. This was done three years ago and the owner of the boat uses it all the time. Just follow directions. Probably be the quickest , cheapest way to go. Note. Get all the old wet stuff out. I used a chain saw (carefully) and then let the area dry very well before pouring. I put the original cap back on after. Best of luck,Capt.t
cbgann posted 04-16-2006 11:04 PM ET (US)     Profile for cbgann  Send Email to cbgann
John, I think the shrinkage quoted above is probably a little high. Capt.T has used the SeaCast method and I have used the Driveway fibers, both with polyester and with good results. 8% shrinkage would be 1.6 inches on a 20" transom. I think we would have picked that up, even after a few beers. Keep us updated on your fix. Bill
BT Whaler posted 04-17-2006 09:49 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
HI guys
The verdict is still out whether or not its going to be plywood or Seacast. I just want to finish the underside before I flip it over and start the transom. When I removed the rubrail I noticed the nose of the bow must of had more than a few run ins with piers. The whole front edge is pulverized and some of the core is too. Once I finish patching up I'll Awlgrip up to the transom then roll it over. Ill keep you guys up to date.
John
Binkie posted 04-18-2006 01:33 PM ET (US)     Profile for Binkie  Send Email to Binkie
Since this post was started, I found out my transom is rotted on the 17` Cobia Bass boat I,m restoring. What a bummer, I wouldn`t have minded it so much if I realized this in the beginning, but I Awlgripped the boat and am in the proccess of installing the steering and hardware. and finishing up. I knew the transom had been reglassed when I got the boat, but I unfortunatly wasn`t too concerned about it. I mounted the motor, a Suzuki DT150 Super Six, adjusted the boat on the trailer, and took it out for a tow behind my vehicle to see how it would ride. No problem, but when I got back, I saw that a big crack developed the entire length of the transom. (because of the beveled in sides at the stern, the transom is only 40" wide.)
I pulled the motor, and stored it back in the garage, I stuck a thin flat bar in the crack and pulled and the whole outer shell came off. (with a little help from a circular saw.) The wood core wasn`t rotted, but was completely waterlogged, and had seperated itself from the glass. In an hour or so, I had it all cleaned out, and am now looking at the inner skin from the outside. I would have liked to try the pour-a-transom method, but I had no outer shell, and I think making a form for the outer shell is too much work. I`ll use plywood for the core material, Foam board is the way to go, but I need to consider the cost in relationship to the value of the boat. I`ll do a good job, and I don`t expect any future problems. The big deal is now I have to repaint the sides and the stern again, when I`m finished. It was white after I painted it, but I think I`ll make the sides and the stern Fighting Lady Yellow. Oh well. time to get to work
PS, I never said Cobia`s were well made, but I just like the racy look of this hull, and I can fish out of it too. I`ll take pics.
BT Whaler posted 04-18-2006 10:55 PM ET (US)     Profile for BT Whaler  Send Email to BT Whaler
I'm real sory to here that Binkie. It sounds like your just going to dive in and knock the job out straight away. Not like me I have to stop,think,read, talk to you guys and make some phone calls every time something new comes up. Besides I only get to work on it just a few hours a week so its going to take me a while but I want to do it the right way. Keep me up to speed
John
Binkie posted 04-20-2006 06:01 PM ET (US)     Profile for Binkie  Send Email to Binkie
BT Whaler, John,
Basically I have the transom rebuilt, I have about 2 1/2 days labor into it and about one day to go. Still have a couple of layers of mat to go, and some grinding, sanding, Bondo and then ready for primer. Then I have to re Awlgrip the sides and the stern and the motor well area, but thats another job. I used two layers of 1/2 exterior 4 ply plywood, an one piece of 1/4" exterior ply wood, for the core. Before I started the only thing that was there was the inner liner. I started with a layer of mat against the liner, then the 1/4" plywood, layer of mat, then 1/2" ply, layer of roving, layer of mat, then 1/2" plywood again, then another mat, another roving, another mat another 1/2" plywood, then a layer of mat, then 3 layers of roving, then three layers of mat. On this Bass boat the sides are beveled into the transom on a 45 degree angle, and I had to grind down through the paint and gell coat to the raw glass hull,on the sides for about 12 inhces, and wrap the roving around the sides. About 3 layers go around the sides. The transom is at least 1 3/4" thick. This boat is suppossed to go about 75 mph, so I don`t want to worry about strengh in the transom. I have about $200 in the project, to rebuild the transom, but the transom on this boat is a simple rectangle 40"wide and 20" high.
On your boat if the glass on the exterior is sound I would go with the pour-a-transom method, and save a lot of work, not to mention repainting or re-gellcoat. If you go online, there is a lot of good info on that method, Make sure your chainsaw has a 20" bar, so it will reach to the bottom. I saw online that you have to make a plywood form and attach it to the outside of your transom to keep it from deforming when you make the pour.
I think this method is the best way to go, and I would have done it this way, if I had an intact outside shell. Anyway have fun, and good luck on your project.
Rich
