Topic: Cost of Mercury Service
njwhaler |
posted 05-20-2006 07:44 PM ET (US)
I need to have my impeller and water pump replaced on a 2002 Optimax 135. How much should I expect my authorized Mercury mechanic to charge me for parts and labor? He has done work for me before and I have a feeling I was overcharged.Thanks in advance for the responses.
fairdeal2u
posted 05-21-2006 01:16 AM ET (US)
Depends on what else you had done. $150 to 200 total for waterpump and lower end oil change should be fair. Why don't you learn to do it yourself? It's not very hard to do. |
posted 05-21-2006 01:52 AM ET (US)
The labor charge for replacing a water pump should be about one to two hours. The shop labor rate varies quite a bit with location. Most dealers charge for the parts at full retail. |
KillerWhaler62
posted 05-21-2006 07:51 AM ET (US)
I checked the pricing out with a local Mercury dealer. In the NJ area. His shop rate is $89.00 an hour. I have a 90hp Mercury. To do a complete cooling system check, flush and replace the impeller and thermostat: labor $290.00 and parts $68.00.I am sure there are beter prices out there. Good luck. |
njwhaler
posted 05-21-2006 08:23 PM ET (US)
Thanks for the replies everyone. I think my Mercury mechanic is going to charge about $250. I amthe type of person who does just about everything for myself. However, for some reason, I am just not comfortable taking apart my Optimax without testing my ability to do the job on someone elses' motor first ! HA HA! |
posted 05-23-2006 11:18 PM ET (US)
On smaller outboard motors I used to do my own service of the water pump, but on a larger motor, especially on a V6, I have found it too awkward and heavy to remove the gear case by myself. I hire it done now. |
sosmerc
posted 05-26-2006 10:54 PM ET (US)
If your gearcase comes off easily, a water pump job should not take more than an hour. (I can do it in less than 30 minutes, if its routine). I charge $20 for a Merc heavy duty impeller, and $3.00 for the gaskets on either side of the wear plate. So if a customer ONLY wanted the impeller changed in his 150hp Optimax He'd be looking at about $100. But in reality, there is usually more work to be done such as changing filters, plugs, etc. and a dyno test to confirm all is in order...more like $400 by the time the job is done. |
