| Author | Topic: 15-Foot: Effect on Trim of Relocated Fuel Tank |
| runpasthefence |
This has been bugging me for a while, and the thread about aluminum fuel tanks in 13' Whalers got the question brewing again. After the re-paint this Fall, I'm rerigging my 1985 15' Sport as a Center Console model with an original Boston Whaler console. Rigged how it is now, the boat is a little stern heavy. It is rigged somewhat like this http://img.photobucket.com/albums/v611/yeahtoast02/project%20Ambelina/ IMG_0692.jpg except now, the stern seat box is a little farther forward, the Pate tank is sideways against the gunnel, and there is a fairly heavy glassed plywood foredeck http://img.photobucket.com/albums/v611/yeahtoast02/project%20Ambelina/ IMG_2426.jpg With this set up at idle there is always water in the splash well. Enter Spring 2007 and newly rigged Sport/CC. My plans include --planked mahogany foredeck My concern is that in my attempt to move weight forward, I will do so too much and sacrifice performance. I'm worried mainly about the fuel tank and it limiting my ability to trim the boat for less wetted area. However, because the seat box is being moved back some, and the plank mahogany deck will be lighter than the glassed plywood, would that be enough to compensate and perhaps even make this a perfect setup? Also, the boat is powered by a 90-HP Yamaha. |
I do not know of any method for predicting the effect of weight movement on the trim of any Boston Whaler hull. As far as I know, no mathematical model has been developed to analyze this in advance. I'd just add the same amount of weight as you anticipate your various projects will weigh, then observe the effect on the boat trim. In my experience, the 15-foot hull is more sensitive to weight placement than some of the other small Whaler hulls. It has a distinctly different hull form than the classic 13-foot hulls. |
| Hal Watkins |
"With this set up at idle there is always water in the splash well." My 15' SS with 60hp +18 gallons behind the rear seat seems aft heavy at low speeds and gettting on plain while quick presents a high angle of attack momentarily. It never carries any water in the splash well. With the 90hp on the transom I would think that the fuel tank forward would be of benefit at low speeds and could easily be trimmed away at speed. Your comment about a loss of performance...with a 90...eludes me. My 60 will do 35 gps, into much wind and it feels light on the bow anyway. Good luck, Hal of Waseca, MN |
| skiprobinson |
Hey Mick, good to see you posting! I am going thru much the same thought process on my 15 CC and I am intentionally going to both raise the stock console about 10" and move it further forward then how it was rigged at the factory. I am a big guy at 275 lbs and I am finding that most of the time when I have a passenger they want to sit beside me when we are running and I end up having to fiddle with the trim a LOT and its a bee-hatch to stay on plane unless I am going FAST. I am shifting everything forward, both batteries inside the console and I will probably ditch the 15 gal Pate in favor of a RPS with a 12 gal single tank mounted under the RPS. I hope to have the console raised and moved in June, even if its a not a permanent upgrade, just to see how it runs with raised console and weight forward. I will take pics and post performance numbers. Side note, I just got mine back from the shop with a new water pump and 3 of the bolts holding the pump in place had to be drilled and tapped out, I am glad we didnt try to do it in your shop! I did hate writing a $275 check though! When are you back from NZ>?????? Skip |
| minitauk85 |
Runpast- I don't think it will do any harm to move that tank forward! I have to wonder if the water in your splashwell isn't from the motor weight or trim though. In the stern of my 15 center console I frequently carry two batteries (one starter, one deep cycle for trolling-50lbs?) a stern mounted trolling motor, a 7 gallon modified igloo baitwell (probably about 35 lbs with water in it), a 15 gallon pate under the thwart seat, and my own personal 220 lbs of ballast. Even coming down off a plane from high speeds I don't take any water over the transom. I think my stern sits pretty low in the water, and I carry nothing much in front of the console (anchor and dry cooler maybe 30 lbs). I have a 1988 Johnson 70 hp- I don't think it weighs much less than your 90 Yammie. Do you have a Doelphin or other type of fin on your motor foot? This might help a little, although at low idle speeds I don't think it'll make a much of a difference. If it weren't such a chore I too would be tempted to move my console forward about 2 feet as I fish off the stern most of the time-k |
| runpasthefence |
Thanks for the replies guys. I think if I was just considering moving the fuel tank, I wouldn't be worried. But I am also moving the battery from the stern and also adding a new console. My main concern is that I'll no longer have the ability to trim off of the lifting strakes. The more I think about it, though, the more I think the trim situation won't change much. And even if it does, it won't be a great loss. However I do think this will alleviate some of my "bow up" problems in no wake zones and in skinny water. I'm really looking forward to this modification because of the increased fuel capacity (up to 30+ gallons in 2 tanks), more comfortable ride, more room aft, and better looks. Minitauk, sounds like you've got a bunch of weight astern. Maybe I'm just making a mountain out of a molehill. Although I do think my mahogany seatbox is a little on the heavy side, and I'm thinking about not including it in the re-rig. Regardless, I agree with you about freeing up room behind the rear seat. Without the battery and fuel tank mounted in the stern I should have a basically open floor from bow to stern. Who knows, maybe I'll get a little mahogany crazy and do a plank stern platform as well? Skip, Cheers Mick |
| crabby |
The front of the boat is the roughest riding part of the boat; mounting the gas tank forward means it not only needs to be well secured but you may want to consider the fuel sloshing around in a choppy situation. Have you tried tossing in some sand bags (in the bow) and riding around with the tank in it's present location nearly empty to simulate as best as possible your desired new configuration? Or just get a large friend to sit up there. |
| jflots |
As a quick test, if the boat is currently running, is to temporarily move the tank to the front and go for a ride. All it would take is a longer fuel line. Good luck. |
| runpasthefence |
I plan on doing some weight testing when I get back. It's tough, however, because I'm not sure how far the rear seatbox will have to move toward the stern with the new console. From past experienc, the position of that box greatly affects the trim of the boat, so making a guestimation is going to be a little more complicated than putting 160lbs forward of the console. I'm also trying to take into account the difference in weight between the plywood/fiberglass deck I have now, and the future plank mahogany deck. It may be only a slight difference, but I'm not really sure. There will also be 40lbs of battery and a larger console between me and the fuel tank that weren't there before. It's just a whole heap of stuff to take into account, and at this point I'm ready to just dive in head first and hope for the best. I'm not sure how I'm going to secure it just yet, maybe have some brakets welded on each corner with some angle aluminum attached to the deck...then through bolt, not really sure quite yet. As for sloshing, I'm going to draw up a baffle diagram and see what my fabricator thinks, I'm sure he'll have plenty of ideas for the both of us. As, usual, all the advice is appreciated Mick |
