Topic: Yamaha 130 Lower Unit Replacement
MyOutrage |
posted 07-10-2006 05:28 PM ET (US)
Anyone have any experience replacing the lower units on these engines? I pulled a "boatnick" move and busted off the skeg the other day... fortunately I have a spare unit in my garage now I'm just trying to figure out if I can swap it out at the dock or if it's too complicated to do that way.
bsmotril
posted 07-10-2006 09:03 PM ET (US)
If you've done it before, it's very easy to do. About 30 minutes to swap one out assuming no corroded bolts to fight. The hardest part is learning how to disconnect the shifter shaft as every motor does this a bit differently. I've done plenty of Mercs and OMCs, but no Yammies, so I can't give you any specifics. It would be good to have a service manual at hand the first time you do it. You can do it dockside in a pinch, but I would not want to do it with the boat in the water. Too much risk of dropping bolts or tools. The exception would be clear water, about knee deep, on a nice hard sand bottom. Then I'd go for it. BillS |
MyOutrage
posted 07-10-2006 09:28 PM ET (US)
Appreciate the input... I'm thinking that I'll fix the prop (couple of dents) and wait till fall to replace the lower unit. Anyone know if going w/o a skeg is a problem? |
RMCCAIN
posted 07-10-2006 11:17 PM ET (US)
Remove all of the visible bolts on the under side of the fin and then remove the rubber cap on top of the trim tab, this will let you access the remaining bolt that holds the lower unit to the lower part of the motor housing and the lower unit will slowly start down or should as the shifter shaft is splined, be sure to disconnect the speedometer tubing at the front of housing you can see it partially near the tilt unit, it has a small connector nipple, it can be disconnected there. Make sure the motor is tilted up you will need room for the driveshaft to come out. Regrease with water proof grease on the driveshaft splines and the shifter shaft splines, make sure all is engaged when reinstalling the new unit, also make sure the shifter is in neutral position. Good luck, shouldn't take more than 30 minutes total. Rich |
MyOutrage
posted 07-11-2006 08:05 AM ET (US)
Rich, appreciate the detailed explanation. As I suspected, it seems pretty straight forward but it also doesn't seem like something I should try to do at the dock. One question for you... your comment re: "disconnect the speedometer tubing". I don't have a speedometer on my boat... does this still apply? |
Gep
posted 07-11-2006 08:14 AM ET (US)
MyOutrage, All good advise above. What year is your Yamaha? I have a 1993 130 Yamaha and switched out the lower unit in about half an hour. I did mine while it was on the trailer, I don't know if I could do it at the dock in the water unless it was like bsmotril said and close to shore. I might be able to scan the section of the repair manual for you if you have the same year or close to mine. Mike
Plotman
posted 07-11-2006 09:32 AM ET (US)
I have run a boat without a skeg and really noticed no difference. My prop shop was able to weld a new one on for under $100. Don't trash your old lower unit, just get it fixed. |
MyOutrage
posted 07-11-2006 12:02 PM ET (US)
Mike, my Yamaha is a 1989 130hp... I'm guessing it's basically the same engine you have... If you can scan that portion of the owner's manual and send it to me I'd appreciate it. reedy@us.ibm.com It's always nice to have a reference when you try to do something for the first time. Thanks for the offerPlotman, I too drove my boat around for a couple of hours after my unfortunate altercation and didn't notice any performance issues either. I figured that I better ask the authorities (Continuouswave) to see if I was just setting myself up for getting stranded in the future if I didn't fix it immediately. As for tossing the broken lower unit... It's nice to know that I can always have a new skeg welded on... since I have a spare parts engine in my garage I'm just going to piliage the engine for the lower unit and keep the broken one aside (in case I have a desire to do something stupid again). My plan of attack: Since I don't currently have a tow vehicle, I'll probably see if it's practical to do at the dock... if not... I'll probably wait till fall when I typically borrow or rent a truck to bring the boat home. Thanks everyone for the help (as always). |
