posted 09-04-2006 09:39 AM ET (US)
There are many different bottom paint systems and methods to use when painting a bare bottomed boat.The easiest method is as folows:
Clean bottom with solvent wash
Prime bottom with an etching "no sand" primer
Paint bottom with two coats of bottom paint
This will take you around a half day for the first coat, then an hour or so another day for the second coat.
The method you decribe is if you want to apply a barrier coat system to the bottom prior to painting.
Sand bottom very well (totally break gloss, do not remove gelcoat)
Apply multiple coats of the epoxy barrier coat (read can)
Apply multiple coats of a multi season ablative bottom paint, like the paint you mention (typiclly three coats)
The barrier coat system will take a lot more time, and you will need a good weather window (two days) to apply barrier coat and paint.
The advantage of the multi season paint is you can take it out of the water for a period of time, store it on the trailer, then launch again without painting. The paint does not lose it's ability to prevent fouling.
Standard single season paint will only last a season. You will have to paint every year.
I have had good luck with the "no sand" etching primer made by Interlux. I would do as follows:
Prime bottom with etching primer (no sand)
Apply three coats of a quality ablative multi season paint
Let dry for a few days
Launch boat
I really don't see a huge benefit in you applying a barrier coat. It's effectiveness is theoretical on a boat that the bottom gelcoat is high quality and in very good condition. The boat will only be in the water for six months or so out of the year.
Rich
