Topic: Trailer Service
wwbach |
posted 09-25-2006 08:59 PM ET (US)
Any ideas on where is the best place to have a trailer serviced (brakes and wheel bearings)? I'd do it myself but I really don't the time (and I've never worked on brakes). We don't (that I know of) really have a boat trailer dealer around. I suspect the marine dealers don't do a ton of trailer service work and would be expensive. The one RV place I called quoted $85/wheel to repack the wheel bearings - I would have thought more like $85 for 4 wheels. Any other ideas? Thanks. -- Bud
Royboy
posted 09-25-2006 09:33 PM ET (US)
Try a shop that services landscaper trailers. They may give you a better deal. Also check other RV places, they can vary quite a bit.Roy |
PeteB88
posted 09-26-2006 12:26 AM ET (US)
I'd say find the time and turn your own wrenches. Learn how to do it. If that is 85 bucks/wheel that is too much. You know, I just saw a rig on the side of the road about a month ago with big boat, dual axle trailer and LHS brakes were being disassembled on the side of the road. I guess I would ask - If I don't learn how to do this stuff what happens if I break down like that dude on the side of the road somewhere and I have to leave my rig or fix it? Packing wheel bearings is probably something you should do yourself - I had someone do my trailer bearings "as a favor" and he tightend the big nut way too tight and nearly ruined my axle and bearings. I just happened to stop after about 15 miles first trip after the favor and touched the hubs and I could have fried a hamburger on them. I turned around, went home and missed a great night of fishing. I bought brand new ($80 bucks) and installed them myself - sythetic grease the whole nine. Got them right and perfect. Once, after a 200 mile trip, one side was a bit loose, I pulled the jack out, pryed off the cap and reset/tightened the bearings botta boom botta bing. doing trailer brakes takes some time but they're just drums, springs, and retainers. DO what you have to do but best if you know how if you have to or to trust yourself and not someone else. |
Chuck Tribolet
posted 09-26-2006 10:21 AM ET (US)
wwbach: where are you?$85 a wheel is not out of line with $125/hour shop rates -- It's 40 minutes, and it's a messy job. Chuck |
Buckda
posted 09-26-2006 10:23 AM ET (US)
Bud -Try M&W Firestone on M-139 in Benton Harbor. |
wwbach
posted 09-27-2006 10:23 PM ET (US)
Pete, In a pinch, I could do (and have done the bearings) it but I have a lot going on right now. I ususally check the wheels 10 miles or so into any trip but thanks for the reminder.Roy, Great idea. Chuck, I'm near Dave (live near Chicago and boat in SW Michigan). Dave, Thanks for the tip. I'll give them a call. -- Bud |
kingfish
posted 09-27-2006 11:27 PM ET (US)
Bud-Any place (like Discount Tires or Goodyear) that does tire and brake work on cars will do the same, including bearings, on trailers. John |
Mambo Minnow
posted 10-07-2006 06:07 PM ET (US)
You can save alot if you learn to do some maintenance yourself. I like the piece of mind knowing that I greased the bearings thoroughly. I never did brakes before now, but I just had to do it this weekend. It's actually not much different than changing your engine's lower unit lube oil. You do need a second person when it's time bleed air from the lines though.I understand time is money too. The idea of a local car garage offered by others is sound advice, particularly if the shop is near a significant body of water. I found a local car garage mechanic very helpful providing tips and advice as far as tools and technique. He would have done the work for me if I wanted, for much less than the marine industry specific mechanics quoted. Good luck in whatever you decide! |
blackdog54
posted 10-09-2006 10:28 PM ET (US)
So here's my bearing story- I have a Calkins trailer with an 85 Montauk, seller said trailer came with the boat.Went to West Marine, Kragen Auto, Auto Zone and a local trailers only shop. No one could figure out the parts numbers, inner seal did not have one and the race/bearings had them but really hard to read. Went to a Napa auto parts, kid pulled out a caliper and a few books (don't trust the parts search engines on their computers). After about an hour, we hooked up with all the right parts. A set for each wheel came up to $65 with a discount. Packed them myself but THINK I used wrong grease-used the red marine grease. PLEASE TELL ME IF I AM WRONG AND NEED TO REPACK WITH DIFFERENT. Anyway, most of the reference manuals do not have specs for trailers. I don't think $85 a wheel is high, if the bearings are $32 a wheel. However, in general, this is one of those things you should know how to do if you trailer a lot. It is probably wise to keep a 2nd set if you travel further. I saved all the invoice and parts #s for when I need to do this again. |
cwolf
posted 10-10-2006 02:20 AM ET (US)
I usually pay one of those mobile service guys (we come to you) $150 to repack two wheel bearings, test the brakes and wiring. Takes about a hour. |
Binkie
posted 10-10-2006 07:51 PM ET (US)
I thought this was a "hands on" forum where folks were interested in learning how to do their own work. What happens when you have a breakdown, and you can`t find a repairman on the road. I know you would do it, if you had the time---or the tools,---or the knowledge,---or didn`t hate to get your hands dirty. Sorry for venting, I realize there`s an ass for every seat.Rich |
