posted 10-02-2006 07:14 PM ET (US)
Depends on your budget and your use of the boat.I also bought my first "personal" boat - prior to this one, I'd mooched off family boats - a 15' Whaler a few years ago.
The owner also liked to waterski with his kids and had underpropped the boat. I'd hammered that puppy several times to the top of the tach before figuring out as you have that you just can't do that.
it ran for another year with a new prop that held it to the appropriate RPM level, but eventually it blew the powerhead and I had to rebuild.
At the time, I blamed the VRO, however over time, I've come to wonder if I hadn't done some damage (As well as the previous owner) by overrevving the engine.
I recommend that you let a dealer undertake a careful inspection of the motor. The question is this: is it worth $500 for a service if it saves you a $2,500 rebuild? I think so - but I couldn't have convinced myself of that at the time; especially because it's no guarantee that there won't be a failure moving forward.
Racers over-rev outboards all the time - but they're running very rich oil mixtures, and they overhaul the engines often.
Consult with your dealer/mechanic. Perhaps there is a way that they can scope the pistons for damage without too big of an expense.
Then also consider the costs that you may be faced with: Rebuild will cost about $2,500 or so. New engine will cost more like $9,000. I'd start those mental excercises now and consider the continued operation of the motor as gravy...
...oh, and I would now strongly consider tow insurance if you don't already have it.
