  Gelcoat
Author Topic:   Gelcoat
jjandpop posted 10-11-2006 02:00 PM ET (US)   Profile for jjandpop   Send Email to jjandpop
I have completed several reconstructions on sailboats. We did not use gelcoat because it was, for one thing, not impervios to water. A better solution was the use of West system epoxy or other epoxy coatings. The final finish was usually an applied epoxy primer and then a two part urethane finish.
I'm sure you all heard of the blistering problems in fiberglass boats that have spent a long time in the water. Much of that was caused by water entering the fiberglass through the gelcoat. This happened either from the interior bilge of from the exterior.
Another problem in using polyester resin gelcoats is that they do not adhere to existing polyester resins where epoxy resins do.
I am trying to restore a 1987 BW Outrage that has seen some rough treatment. The hull is in very good condition but the boat had a number of items added that left many holes in the floor, console and transom. I want to paint the interior and the transom with a paint or whatever that is somewhat the same Whaler color. I see several comments here where gelcoat is recommended. How is it applied and does it have to be covered to cure??
Also, I see where some folks are trying to remove their gelcoat with either sandblasting or grinders. I would recommend the use of a commercial fiberglass peeler. There are some offered for sale commercially. It's been a long time since I had the work done so I am unable at the moment to suggest a supplier.
penningtonjeff posted 10-11-2006 02:45 PM ET (US)     Profile for penningtonjeff  Send Email to penningtonjeff
Hey there, I'm in the same spot with the 'holy' interior on my recently acquired '71 Nauset. From scouring this site, my chosen course of action is to use 'UltraTuf' or another bedliner type coating in the original whaler blue color. For me:
- Downside: not 'original', maybe it holds onto dirt more than smooth gelgoat
- Upside: helps hide 35 years of hard use, protects interior for a while, looks good, reportedly comfy under bare feet.
Still going to do as much filling, fairing, and sanding as i can get away with.
Smallfrye posted 10-11-2006 03:01 PM ET (US)     Profile for Smallfrye  Send Email to Smallfrye
I've had good luck using Petit's off white colored ez poxy. It matches the Whaler desert tan quite well, depending on the amount of oxidation.
As with any paint match, try to paint an area up to any physical break. this will allow the color variance to be minimized.
filthypit posted 10-12-2006 10:29 AM ET (US)     Profile for filthypit  Send Email to filthypit
We restored a boat last summer and decided to spray a fresh gel-coat rather than paint. This decision was based primarily on cosmetic appearances. Painted boats never look right & when the paint chips, they REALLY look crappy.
The boat we restored was in pretty rough shape and took a lot of patching, filling & fairing. We began by soda-blasting 20yrs of bottom paint off (and were lucky to only have 3 or 4 blisters to deal with). For the most part, we left the original gel-coat on, and we sealed all of the areas we repaired w/ a thin coat of epoxy (roughly 45% of the boat). We have had no problems with the new gel-coat bonding anywhere on the boat.
You do have to rough-up the original finish (a little) before spraying a new gel-coat.
It took three coats of mint-green gel-coat to cover the badly stained original white gel-coat plus all of the repairs. We used a product called "patch-booster" to reduce the viscosity in order to spray a smooth finish, but we still ended up having to wet-sand & polish the final spray.
After a LOT of work, the finished post-production gel-coat came out so smooth & shiny that you can see your reflection in it. The boat looks brand new. There is no comparison.
All said, I think that the quality of your finished job will depend on how much you wanna sand. I have heard it's not unusual to spend $100K on sanding alone when having a boat built - now I know what they mean. We spent approx $130 on materials to gel-coat a 20ft boat. I would say there was, at least, $2K in labor though.
Good luck!
filthypit posted 10-12-2006 10:34 AM ET (US)     Profile for filthypit  Send Email to filthypit
If you're interested, you can see a picture of the boat we restored @
http://www.hatterasgear.com/87atlantic.jpg
The whole story is @
http://www.hatterasgear.com/skiff.html
The Judge posted 10-12-2006 01:46 PM ET (US)     Profile for The Judge  Send Email to The Judge
Filthy is right but if you do NOT do the right prep work, a re-gel can be a flaking nightmare...then again so can paint. I like Awlgrip but it ALWAYS looks like it was just painted.
