Topic: Trailer Axle Bearing Caps Keep Falling Off
HankT |
posted 06-14-2007 08:05 PM ET (US)
Hello. I've had a continuing problem, and could use some good advice. I've lost several bearing caps lately. The trailer repair place said that they flange out the edges when there's a problem. I thought that I came up with a reasonable solution when I took a thick nail punch and put some dimples around the inside edge of the cap. Unfortunately, one axel keeps dropping caps. I was thinking of using gorilla glue, but I don't know if it will stand up to the heat that may be generated. The only other idea I've come up with is to remove the wheel, and drill a small hole through the end of the axel shaft, and into the bearing cap, and screw in a self-tapping screw. Anyone have any ideas I might try???
posted 06-14-2007 09:37 PM ET (US)
If you are using a small metal cap, try forming the cap into a larger diameter. Clean the inside of the axle so there is no grease or oil where the cap will seat. This will make the metal-to-metal fit have more friction.How is the tire alignment and balance on your trailer wheels? If the wheel is wobbly it may be vibrating and working the cap loose. |
Henry
posted 06-15-2007 12:54 AM ET (US)
I had that problem once. I lost the cap on the highway. The spinning hub spit out the grease burnt out the bearings and damaged the axle which I had to replace. Try bearing buddies, they have a tighter fit. Otherwise new hubs. Some things do not have an easy fix. If you lose the cap at the wrong time you have to replace the axle. |
Ablewis
posted 06-16-2007 10:20 AM ET (US)
I had this same problem on a trailer with bearing buddies. It's an ugly solution, but cut off the bottom end of a beer can and secure over the top of the cap with a hose clamp. Worked for years. |
PeteB88
posted 06-16-2007 01:36 PM ET (US)
How hot are those hubs getting? I had a trailer once that after driving a short distance could not touch the cast iron because it got so hot. I replaced bearings and races (old, shot) lubed with Mobile ONE synthetic grease, made double sure I tightened the bearings correctly (not too tight but no slop) and everything was fine. I can actually grab on to the hub, it is warm but never hot |
pglein
posted 06-19-2007 02:52 PM ET (US)
Bearings should never get so hot they would burn your hand or melt glue. They will sometimes be a little warm after a long high-speed drive, but that's it. If you're having trouble with your bearings, just replace the whole assembly. |
montauk steve
posted 06-22-2007 06:30 PM ET (US)
Mine do the same thing until i put duct tape/clear packaging tape around them to hold them on. I remove the tape every 3 trips or so and re apply grease to the zerk fitting and then cap and then tape again. They are still there. |
wwbach
posted 06-28-2007 12:17 AM ET (US)
Also, jack up the trailer and give the wheel a shake to make sure there isn't too much play in the axle. If there is, the wheel will wobble and throw off the bearing cap. -- Bud |
