  Cleaning Teak
Author Topic:   Cleaning Teak
Gene in NC posted 07-19-2009 09:05 PM ET (US)   Profile for Gene in NC   Send Email to Gene in NC
I have searched and read great posts. The condition of the teak on my 1987 Boston Whaler MONTAUK is really rough. I saw a demo of the Dremel MULTI-MAX today so I tried it on the louvers and frame of the port side hatch door. [The Dremel MULTI-MAX] worked well with good access and speed.
On the reversible pilot seat back I tried a well worn 60-grit on a Bosch orbital sander. It worked well and gave a little margin of error to first time effort.
Is there a problem and loss by cleaning up super-roughness before the chemical cleaning? Sanding takes more than two-thirds down to raw teak, or at least the hard part of the teak.
Oil may work pretty well, but no way to varnish this one.
PeteB88 posted 07-20-2009 05:47 AM ET (US)     Profile for PeteB88  Send Email to PeteB88
You might try scrubbing with solvent and steel wool followed by solvent and clean painter rags. I do this when stripping to bare wood - learned from pros years back. Solvent is lacquer thinner, acetone or both. Rags are painter's rags I get at commercial laundries in 10 pound bags (usually worn out commercial table cloths ripped into rags). Gloves and proper mask is required not an option. It works great. You can't expect sanding to work in every case. It removes or reshapes wood. Good luck.
Narragansett Outrage posted 07-20-2009 07:06 AM ET (US)     Profile for Narragansett Outrage  Send Email to Narragansett Outrage
I've been refinishing all the teak on my boat this summer.
After all the reading, and now the hands-on experience, I've found that cleaning badly deteriorated teak first with some kind of product (I've been using the two-part Snappy Teak) is probably the best way to go. After I've removed all the dirt and stains with the cleaner, I then start sanding.
I use an orbital sander on the flat parts, starting with 80, then moving gradually up to 220. I don't touch the curves with the orbital - I use my hands, or I use a nail file.
I'm in the process of applying 9 coats of Le Tonkinois varnish. So far, so good - at least, far better than what was there before.
Demps posted 07-20-2009 07:41 AM ET (US)     Profile for Demps  Send Email to Demps
Gene,
I'd caution against using steel wool. Small pieces of the wool will invariably be left behind - somewhere on your boat - and will start to rust. Go with brass wool instead.
Good luck.
Dave
jimh posted 07-20-2009 09:01 AM ET (US)     Profile for jimh  Send Email to jimh
I have been doing some teak cleaning this weekend, too.
My teak was in very good condition and nicely oiled just two seasons ago. It has already deteriorated. In the grain of the wood a black residue builds up. I believe it is mildew. This may be more of a problem in fresh water than in saltwater. I see many large sport fishing boats in saltwater with gray teak, but I don't see the back mildew in the grain. Their teak just looks uniformly gray. My teak still has a golden wood color, but the grain is filled with black streaks.
I don't know if my approach is the best, but I usually proceed like this:
The initial step is to scrub the teak with a cleaner. I tried two different cleaners recently. Oxalic acid is mentioned as a cleaner. I had some BAR KEEPER'S FRIEND powder which has Oxalic acid. I tried it, but the results were not particularly great. Next I tried some liquid teak cleaner. I used the WEST MARINE house brand one-step cleaner. This was not particular amazing, either.
Because the black mildew is in the grain, I found that removing it was difficult with a scrubby-sponge. I switched to a scrub brush. I tried three different brushes before I found one whose bristles seemed able to get into the grain and remove the black streaks.
Giving the wet wood a hard scrubbing tends to raise the grain and make the wood softer. After the wood dries, I follow up with some Teak-Treatment, a product that says it helps to remove any cleaner residue and prepares the teak for oil. It is a light and volatile liquid, probably has some mineral spirits in it. I wipe the teak with this solvent and let it dry.
Next, I sand the teak. I try to keep the sanding to a minimum. Each sanding is removing wood, and if you kept sanding the teak eventually you would reduce its thickness noticeably. I also find that teak sawdust is quite an irritant. I don't have much scientific information to add about sanding. My technique is probably poor and could easily be improved with mechanization and better quality abrasives.
Using a cleaner before sanding gets rid of a considerable amount of the black streaks in the grain, all but the very deepest. I suppose if you scrubbed relentlessly you could get to those deep grain areas, too. I don't know for certain that it's true, but it seems to me that removing the black mildew before sanding is a better approach. If you remove the mildew by sanding you could be sanding the mildew into the remaining wood.
On the other hand, wetting the wood and scrubbing it does seem to raise the grain of the wood, so more sanding is needed to get the surface back to smooth and level.
Narragansett Outrage posted 07-20-2009 09:30 AM ET (US)     Profile for Narragansett Outrage  Send Email to Narragansett Outrage
Jim, that's why I eventually switched to cleaning the wood before sanding - I found myself really grinding down the wood in order to remove all traces of embedded "black stuff." By cleaning it first, while I do still sand, I'm not now removing perfectly good wood to get at the stains. Also forgot to mention that after the final sanding, I wipe it all down with acetone to remove any dust.
Speaking of sparkling teak, I was at the local Evinrude service center here in Barrington, RI, last week, and noticed that the yard's run around is a 20'(?) Outrage of mid-80s vintage. What struck me is the varnished teak (well, to be frank, the entire boat is immaculate). I had planned on oiling the gunwhales and varnishing the rest, but after having seen this boat, I'm leaning towards varnishing everything (in addition to which, I have to oil at least once a month in the salt air/water).
Snapped a couple of phone-photos. They're a little dark, but you can see the shine (not just from the teak... what I wouldn't give for that Etec right about now):
[URL=http://s72.photobucket.com/albums/i199/oscarboscar/?action=view¤t=stanleys2.jpg][IMG]http://i72.photobucket.com/albums/i199/oscarboscar/th_stanleys2.jpg[/IMG][/URL]
[URL=http://s72.photobucket.com/albums/i199/oscarboscar/?action=view¤t=Stanleys.jpg][IMG]http://i72.photobucket.com/albums/i199/oscarboscar/th_Stanleys.jpg[/IMG][/URL]
Phil T posted 07-20-2009 09:41 AM ET (US)     Profile for Phil T  Send Email to Phil T
Fixed links:
[URL=http://s72.photobucket.com/albums/i199/oscarboscar/?action=view¤t=stanleys2.jpg[/url]
http://s72.photobucket.com/albums/i199/oscarboscar/?action=view& current=Stanleys.jpg
Narragansett Outrage posted 07-20-2009 10:20 AM ET (US)     Profile for Narragansett Outrage  Send Email to Narragansett Outrage
That middle link seems to work best, showing the photos full size - the top and bottom link are just thumbnails. Many thanks for posting that info correctly!
L H G posted 07-20-2009 01:33 PM ET (US)     Profile for L H G
You never clean teak! Never use liquid cleaners of any type. Teak has to be sanded, usually by machine, enough so that the embedded black is sanded away and you have a flush surface with no soft grain grooves.
Using a brush to clean teak with liquid cleaners literally ruins the surface, and will require even more agressive sanding to restore the surface. The more you clean and scrub, the quicker each subsequent job will deteriorate.
All of this is why I recommend varnish. It only requires one finish sanding of the wood, and putting on coats of varnish is less work than all the repeated oiling. With varnishing, black streaking is thing of the past, and the appearance is vastly superior.
Dan posted 07-20-2009 05:29 PM ET (US)     Profile for Dan  Send Email to Dan
All wood near the deck is varnished. All wood above is sanded and oiled with Starbrite Premium Golden Teak Oil. I oil about once a month. Takes 10 minutes. Wood and boat are protected by a mooring cover. I agree with LHG about not liking chemicals.
