| Author | Topic: Improving Fuel Economy |
When the price of gasoline at marinas in northern Michigan reached $4-per-gallon this summer, the fuel economy of my Boston Whaler REVENGE 22 W-T WD boat became an area of greater concern than it had previously been. When I first began boating with outboard motors, gasoline was selling for about $1.25-per-gallon. This threefold increase in fuel costs has made me begin to pay more attention to my Whaler's fuel economy. In my case, my current boat averages about 1.8-MPG overall, and even at optimum cruise only reaches 2.1-MPG. I began to look at performance reports of other types of boat to see what sort of fuel economy their hulls and motors were producing. What I found surprised me. GO-FAST BOATS Many people think that the epitome of bad fuel economy must be the high-power offshore-hull go-fast boat. It turns out these boats are not as thirsty for gasoline as you might think. In a recent issue of POWERBOAT MAGAZINE (May 2005) the editors reported on the performance of a 24-foot V-hull runabout, the ULTRA 24 STEALTH. This boat is roughly similar in dimensions to my Boston Whaler. It is 24-feet long, has a beam of 8-foot 6-inches, and has a V-hull with 22.5-degree deadrise at the transom. It is powered by a 375-HP stern drive, and it weighs about 3,800-lbs. The engine has a displacement of 496-cubic-inches, or 8.1-liters. This combination of boat and motor has enough power to reach a top speed of 63-MPH. That is about 50-percent faster than my boat. But here is the surprise: This boat can cruise at a comfortable 25-MPH and get 3.5-MPG fuel economy! That is about double the fuel efficiency of my two-stroke outboard and Boston Whaler combination at that speed. You can cast a cold eye on the ULTRA 24 STEALTH's gaudy paint job, on her plush upholstered race-style seating, on her impracticality for fishing or cruising, but it is quite hard to ignore this boat's very significantly better fuel economy when compared to my classic Boston Whaler! HOW THEY DO IT What is the secret to the improved fuel economy of this go-fast boat? Of course, the first advantage it has is the four-stroke engine. A four-stroke engine guarantees some improvement over my old two-stroke outboard due to its more efficient fuel use and better valve timing. Less unburned fuel goes out the exhaust port of a four-stroke. But what really helps the go-fast boat is the choice of engine horsepower and propeller pitch. With a 375-HP engine, this ULTRA 24 STEALTH can swing a 24-inch pitch propeller, even though the gear ratio on the stern drive is a tall 1.5 to 1. As a result, that 25-MPH cruise speed come with the engine only turning over 2,000-RPM. In contrast, my Whaler is turning a 15-inch propeller through 1.86 to 1 gears. To reach 25-MPH the outboard has to turn over at 3,800-RPM, almost double. The go-fast boat's engine is loafing along at 25-MPH cruise, while my outboard is running about 66-percent of throttle. WHAT WE CAN DO Using the performance of this go-fast boat as a model, what can we learn from it to help with the fuel economy of our Boston Whaler boats? The most obvious factor is to switch to a more efficient engine, either a four-stroke or a direct-injection two-stroke. Next, choose the engine horsepower to be at the very high end of the hull's rating. This will allow you to choose a propeller with a higher pitch. And this will permit the boat to run on plane at cruising speeds with a lower engine speed. MORE PROPELLER CHOICES Naval Architect Dave Gerr notes in his excellent technical booklet, Propeller Handbook, that "unless your boat speed will consistently be above 30 or 35 knots" propeller efficiency will increase with slower shaft speed and larger diameter propellers. (Note: 35-knots is 40-MPH). Most Boston Whaler boats are operated below 40-MPH most of the time. Thus Gerr's advice seem applicable. Go for lower shaft speed (which implies larger pitch) and larger diameter propellers. WHERE THIS LEADS If all this advice is followed, where does it lead? Using my boat as an example, to maximize fuel economy it seems I should do the following: --re-power with a four-stroke or direct-injection two-stroke The engine that comes to mind that best fits these criteria is the SUZUKI 250-HP four-stroke outboard. What distinguishes it from others is the ability to turn larger diameter propellers with its 2.29-to-1 gear ratio. Before bolting one on the transom, let's look for some performance reports on other boats with similar dimensions. Suzuki's website provides some good information. They have tested the 250-HP on a 22-foot 5-inch center console with 8-foot 6-inch beam that weighs 2,700-lbs. This is somewhat comparable to my Whaler. On this boat the engine is turning a 16-inch diameter 23-inch pitch propeller. Now for the fuel economy numbers: At 3,500-RPM and 28.6-MPH = 3.9-MPG !<--see below for comment; this number is in error! The fuel economy is impressive, to say the least. That is just about double what my current boat can obtain. In another test on a heavier MAKO 23-foot center console with a lower pitch propeller (21.5-inch), the big four-stroke still achieved an impressive 3.9-MPG fuel economy at a slower cruise speed (23-MPH). KEY WEST 225: [Hyperlink: www.suzukimarine.com] OTHER OPTIONS HONDA—Another four-stroker with a reputation for fuel efficiency is the HONDA BP-225. This engine has a more conventional gear case, with a 1.86-to-1 ratio. It does not swing large diameter propellers. Curiously, the Honda website provides a performance test on the same MAKO center console mentioned above. With the smaller engine, smaller pitch, and smaller diameter propeller, the fuel efficiency was not as good. Optimum cruise: At 3,500-RPM and 22-MPH = 2.9-MPG MAKO 232: [Hyperlink: www.honda-marine.com] E-TEC—To discover how two-stroke engines compare we can look for results using the E-TEC engine. For performance reports we have to turn to the excellent resource of e-tecinfonet.org . They have more test reports on the E-TEC than anyone else, including Bombardier! Unfortunately the MAKO hull is not among them, but there is a test of a 23-foot sport boat with 8-foot 6-inch beam that weighs 2,700-lbs. This appears to be the closest comparable boat tested. The E-TEC shows strong fuel economy. Despite turning only a 14.75-inch diameter, 19-inch pitch propeller, the modern two-stroke achieved: 3,5000-RPM and 27.4-MPH = 3.5-MPG NAUTICSTAR 230: [Hyperlink: http://www.e-tecinfonet.org] |
| Peter |
The Suzuki/Mako data at 3500 RPM contains a math error with respect to computed MPG. 23.3 MPH / 7.7 GPH = 3.0 GPH, not 3.9 MPG. The reported 3.9 MPG is far too good for a boat that size to be believable based on my experience as well as looking at all of the other data points. All other clean/efficient outboards 4-stroke or DFI 2-strokes (except the Yamaha HPDI at low engine speeds) will produce very similar numbers as the Honda and the Suzuki on that Mako. |
Peter! Very sharp eye. Thank you for pointing that out. |
I have been looking for some comparable data for the Verado. Unfortunately, I can't find listings of performance reports on the Mercury website. (If anyone know of a collection of boat test reports with Mercury engines, please mention it.) As as substitute, I search the Boston Whaler website for data with Verado engines. I found one comparable, although not perfect match: VERADO—Using a Boston Whaler 210 OUTRAGE with a length of 20-feet 6-inches, a beam of 8-foot 4-inches, and weight of (a rather husky) 3,400-lbs as a comparable boat, the 200-HP Verado turned in some amazing fuel consumption numbers: 3,000-RPM and 19.5-MPH = 4.06-MPG I believe these fuel consumption numbers are reported by the engine's own electronic management system. A number of testers have reported that the fuel consumption of the Verado cannot be measured by external fuel flow meters due to the volume of fuel being recirculated in the engine's fuel injection system. But even if this number is off by ten percent, it is quite an impressive demonstration of the improvement in fuel economy which can be obtained with more modern outboards. |
| Tom W Clark |
Here is the performance info for the 210 Outrage Jim is referring to: Even more amazing is the Verado 175 on that boat which is reported to provide 4.69-MPG at 3250 RPM and 21.1 MPH. This tends NOT to support the notion that one will achieve better mileage with a larger, more powerful motor on a given boat. You will forgive me if I take Whaler's reported performance data with a grain of salt. |
| fourdfish |
Tom-- Did you notice the notes at the botton of the page. A disclaimer which allows them to counter any crtique. They can always say that what we got on that day! |
| Tollyfamily |
I slowed down. My 40 Tollycraft gets 1/2 mpg at 17 knots, 1 mpg at 10 knots and 2 mpg at 7 knots. We just got back from a weekend cruise across the sound to Kingston and we allowed extra time to go slow. Dan |
| newportguy |
Even more telling is the fuel efficiency of the 90-HP E-TECon a 17 ft boat that weighed 1400 lbs. Check this link: [Hyperlink: www.e-tecinfonet.org] As well there is a link as follows comapring the Verado and E-TEC. I have to tell you I though the Verado's were the be all to end all, but this does not appear to be the case as can be seen in this report: [Hyperlink: www.e-tecinfonet.org] All always new I liked Evinrude and now a whole lot better, thanks for the link for the great information. What really impressed me is how the E-TEC has much better fuel economy at the top end and how it burns way less fuel at the top end. Why would anybody buy a Verado based on the reports seen here. And I am not trying to stir it up but the figures do not lie. Especially the way I boat with the throttle down most of the time. Larry |
What I have found most surprising is how fuel efficient the stern drive boats were, even ones with very high power engines. As long as you were not running around at 65-MPH, they generally are quite efficient. Their inboard four-stroke engine, with relatively low-tech port fuel injection, seem to run quite efficiently. I would be very happy to re-power my 22-foot Whaler and discover I could be running at cruise at 4-MPG instead of 2-MPG, no matter what brand of engine. Another area where fuel economy could be improved is total weight. You will recall that according to Crouch's formula, boat speed is in proportion to the ratio of horsepower to weight (to the 0.5 exponent). SPEED = C X (HP/LBS)^0.5 where SPEED = boat speed Solving this for HP produces HP = LBS x (SPEED/C)^2 In other words, the horsepower needed is directly proportional to weight. In the case of my boat, which I estimate to weigh about 4,800 pounds when underway with normal fuel, gear, and crew, if I could reduce the weight I should also reduce the horsepower needed to maintain the same speed. Let's try an example: At 4,800-lbs, I need 225-HP to reach 39-MPH (using C=180). If I could find 400-lbs of gear to leave ashore, I could reduce the boat weight to 4,400-lbs. This is a reduction of (400/4800)=0.083 or 8.3 percent. Using this lighter weight and solving for horsepower, I would only need HP = 4400 x (39/180)^2 Fuel economy should improve if the horsepower is reduced to 206.5 from 225. This is a reduction of (18.5/225)=0.083 or 8.3 percent. Therefore, every pound I can take off the boat will produce a direct and proportionate improvement in fuel economy. This is one area where not much attention has been paid. Both engines and hulls have been increasing in weight. A boat manufacturer with a strong but light hull that was powered by a modern light-weight fuel efficient engine should be able to produce some very significant improvement in fuel economy compared to existing hulls and older two-stroke engines. Will higher fuel prices provide the incentive for boat builders to turn to lighter weight construction? |
| sosmerc |
Jimh, you said "A number of testers have reported that the fuel consumption of the Verado cannot be measured by external fuel flow meters due to the volume of fuel being recirculated in the engine's fuel injection system". I don't see why a fuel flow sensor mounted between the boat's fuel tank and the engine would not read correctly...regardless of engine design. The fuel flow is still going to vary depending upon engine demand. I recently installed a standard analog FloScan on my Ventura/135 Optimax combination. I have not water tested the setup yet...but just testing on the flush it seems to work. Like the Verado, the Optimax engines recirculate whatever fuel is not used back into the VST...but this is constantly replenished as needed from the boat's fuel tank...past the flow sensor. It will be interesting to see what my FloScan shows for flow at speed in comparison to what Merc tests have shown. FloScans website lists some new models that they claim were designed for the more efficient DFI and 4 stroke engines. I elected to go with the old standard 0-20GPH analog model because it is very easy to read and I like the totalizer. (much better than a fuel guage) |
| fourdfish |
If I remember the PowerBoat Reports stated in the Verado shootout test that they were told they could not use the FloScan but had to go with the Merc guage they were given. The other two engines used a Floscan or ?? I could be wrong here so I will have go back and check. |
| Tom W Clark |
Jim, I have to reject the simplistic results of Crouch's formula predicts. Reality does not seem to be quite so simple. I say this based on my own observations in recording performance data from my Revenge 25 Walk Through. Here is a good example. last month I had the opportunity to test my boat on two consecutive days with similar weather and the boat set up in the same way but with very different total weights. On October 21 I went out by myself with 35 gallons of fuel on board. I estimate total weight at 6200 pounds. Cruise speed data was: 4000 RPM -- 33.0 MPH -- 2.09 MPG On October 22 I went out with 45 gallons of fuel on board, two coolers and four female passengers in addition to myself. I estimate the total weight to have been 6900 pounds or 11 percent more. Cruise speed data was: 4000 RPM -- 33.2 MPH -- 2.14 MPG In spite of the 11 percent increase in total weight, there was no decrease in fuel efficiency, in fact my figures indicate an increase. While this may have been due to any number of reasons, error in my measuring no the least of the possibilities, it certainly does not suggest a decrease proportionate to weight. Another observation (made from data collected just this afternoon while testing propellers) regarding fuel efficiency and total horsepower: My boat gets considerably better fuel mileage while operating with only one of its 150 outboard motors. This in spite of the fact tat while operating with only one motor, the propeller is obviously not pitched correctly. Let's look at the cruise data from today. Both motors running (300 hp): 3500 RPM -- 30.0 MPH -- 2.11 MPG Just one motor running (150 hp): 3500 RPM -- 19.2 MPH -- 2.56 MPG * WOT, I did not get a measurement at 4500 RPM I will say that in the case of the good mileage while operating only one motor it does seem that motor was burdened by a prop that has too much pitch, and maybe a high pitch prop is the key to good fuel economy even if it is at the expense of motor longevity. |
| jmontani |
Love the stats and the discussion. Great topic. I am sold on Tom Clark's data... Boating solo is the same performance as adding 2 full coolers, more fuel, and 4 Females! What other stat do you need to look at? Oddly enough, if it was four men, performance would have been reported as "lousy" (reguardless of the data). They would have needed to pay for the beer and chip in for the gas. In all seriousness, Tom thank you for the data. While I am not an engineer, I could only think that wetted surface area did not change that much, nor did the wind resistance of the additional passengers. Engine trim may have been able to negate the additional crew/weight while still providing efficient power. In addition, while you may not had intended to do so, weight was optimally distributed. Jack |
Clearly Tom's ability to accurately record data was impaired by the consist of his crew (all female). It goes without saying that fuel economy must be inversely proportional to weight. If it were not, we'd all be able to go faster by adding weight to our boats, which is counter-intuitive. |
| boatdryver |
The first part of this topic is really interesting. The comment about I/O's getting better MPG because of their four stroke engines rings true. I have welded aluminum 22 ft jet drive boat weighing 3500 lbs in which I get 5 mpg at 25 kt at 3200 rpm. For most of us whalers with good running outboards, though, the most economical options are to either slow down or re-prop. Ok, does the discussion above mean we can go to a larger diameter prop or more pitch, sacrifice on the whole shot and top speed, and cruise at lower rpm, get more mpg, and not hurt the powerhead? Jim |
| sosmerc |
"and not hurt the powerhead?" That's the big question. I've always been under the assumption that outboards need to be propped such that they are ABLE to reach their max rated RPM with a normal load in the boat. This doesn't mean it has to be run wide open, but by propping it in this manner, the correct "load" has been established on the engine. (since we can't shift gears like a car...our load is there all the time) Running too high a pitch may yield better miles per gallon at cruise...but it also puts a higher load on the engine and this may lead to damage from detonation...especially if your fuel quality and octane is marginal. I think it is wise to prop for at least the middle of the rpm range with full tanks and load. I think trim tabs are a significant factor if you are trying to achieve maximum fuel economy, right up there with correct prop and engine height. For even further improvement...lighten the load and and be sure and keep the bottom clean! |
My interpretation of why the go-fast boat I described above got better gas mileage than my Boston Whaler is still the same as I began this discussion: the go-fast has a large displacement, high-horsepower four-stroke engine which is able to turn a high-pitch propeller. This combination allows it to get on plane and loaf along at comparatively low engine speed, a situation which produces quite good fuel economy. I have suggested that outboards move to a higher pitch propeller, but you first have to move to a higher horsepower outboard in order to be able to turn a higher pitch propeller. My recommendation is to always select a propeller that will allow the engine to reach proper wide-open throttle speed with the typical loading on the boat. Getting better fuel economy than a Boston Whaler with outboard motors is not limited to light-weight go-fast boats. Here is another example, just a random boat review from a random magazine issue: A 26-foot cuddy cabin cruiser that weighs 5,350-lbs is powered by a single 320-HP stern drive. This gives the boat a top speed of 44.4-MPH, again faster than my Boston Whaler. But--hold on to your Boston Whaler baseball caps--at optimum cruise around 28-MPH this beast still gets 2.7-MPG! This is embarrassingly better fuel economy than I can coax from my two-stroke outboard motor, which only gets 2.1-MPG at about that same speed. A rather larger and heavier boat is getting 28-percent better fuel mileage than I can. What is wrong with this picture? And it gets worse! In the same magazine they test a 28-foot express cruiser. This monster weighs close to 7,000-lbs, and it is powered by a 8.1-liter, 375-HP stern drive with a duo-prop set up. You better be sitting down for this number: it gets 3.0-MPG at optimum cruise! I am out there banging around in my 22-footer with an ice-chest getting 2.1-MPG and these guys are cruising around with microwave ovens and refrigerators in the galley, getting 3.0-MPG. It is enough to make you want to sell your Boston Whaler and get a blow-boat! (Well, maybe not quite enough.) |
| jmontani |
Jimh, I know that your comment was in jest, but I have both a Whaler and a 36ft "Blow-Boat." The main difference is that on the power side, most of the opperating money goes into the fuel tank. I recently took my "power boat" friends out on the sailboat and one made the comment that "this (sailing) doesn't cost any money" and I just about fell over. I know that this isn't the thread for this duscussion and will stop here, but if anyone is getting into sailing because they think that it would cost significantly less money - they are making a mistake.
