Topic: Whaler 21 and 23 Walkaround: Performance Data
hardknots |
posted 03-08-2006 09:50 PM ET (US)
I've been searching for information about the performance of the 1991-1993 Reebok-era Whaler 23' Walkaround model. I've found some contradictory information. Input will be appareciated on the good or the bad things about the 21- and 23-Walkaround hulls, offshore handling, fuel efficiency compared to classic hulls, maximum speed, any information.Thanks, Ricky
posted 03-09-2006 09:37 AM ET (US)
I have travelled many miles by water with a group of Whalers that included a 21-Walkaround. We have been in all kinds of sea conditions. The group has never had to slow down or wait for the 21-Walkaround to catch up. It seems to be a fine boat for its size in terms of sea keeping ability.I do not expect it would have radically different fuel efficiency compared to classic Boston Whaler boat hulls. |
gqwhaler
posted 03-09-2006 11:41 AM ET (US)
i would be happy to answer any questions you may have about the 21. i did alot of research on it before i purchased mine. i have owned mine about 1 year and logged 200hrs on the so cal pacific. |
gqwhaler
posted 03-09-2006 11:55 AM ET (US)
I have a 1992 21walkaround, 2000 200hp mercury efi.The deep-v does very well off shore no complaints there. it does tend to have bow steer in a following sea. My top speed is 45mph with light load 40mph loaded. fuel effeciently is another matter, it all depends on what power plant you have. on mine i can get as good as 3mpg at cruise 26-30mph. 2.6mpg at 22mph, and 1.8mpg at 14mph. this is according to my fuel flow, and i feel it is very accurate. trim tabs are a must on this hull it tends to be stern heavy and rides bow high. The walkarounds are great boats if your looking for a small cuddy boat. |
hardknots
posted 03-10-2006 11:47 PM ET (US)
Thanks jimh and gqwhale for your feedback. Any 1991 to 1993 Whaler 23' Walkaround owners here ? I need your expert advise. Please, tell me anything before I fall in love with one of these boats. They look really good. But I heard something about their construction using some "balsa core" whatever that is. Is that true? Is it good or bad? I know they were build for just 3 years but why is there so little information about them? Seems like Whaler didn't sell many of them. Well, thanks again, Ricky
Riptide23WA
posted 03-11-2006 08:59 PM ET (US)
I have a 1992 23WA, bought a year ago. I don't have alot of hours on it yet, but the ones I have logged, I've been pretty pleased for the most part. Don't know anything about balsa cored... I don't think that BW did that, but not certain.I'm not sure of fuel burn, but I have the May 1991 issue of Boating magazine where they tested a 23 WA with the typical twin Yamaha 200's. I forget what the results were. Top sepeed was around 54 mph. It's kinda hairy for me at that speed, and anyway, the water is never that smooth around here. Am planning to put a Flo-Scan in this spring for fuel management. My main complaint is with the Whaler Drive bracket. To me, it seems to lift the engines out of the water more as the boat pitches in a swell, but I plan to run 4 blade props this year to minimize that some. As mentioned, the boat can be twitchy running down swell, but she seems solid. I have wanted one since they came out in 1991, and plan to take a few tuna with her. My buddy just bought a 91 21WA last fall, so we're gonna give them a both a workout this year hopefully. Do a search on 23 Walkaround; you'll turn up some more info. Pat |
Riptide23WA
posted 03-11-2006 09:07 PM ET (US)
BTW, the use of balsa core usually refers to a type of sandwich contruction, where a layer of balsa, usually end grain, is sandwiched between fiberglass on both sides. The advantage is that it is much lighter than solid fiberglass of the same thickness. A downside is that, if water seeps into the coring, usually from cracks or drilled holes, the balsa gets mushy. Often times in boat construction, balsa cored FG is used for hull sides, decks, and cabin structures, as its light weight contributes to stability.I don't recall ever seeing reference to BW using balsa coring in any of their boats, but I haven't cut mine in half to check. I don't think BW was too concerned about saving weight on their boats, at least the older ones. Pat |
hardknots
posted 03-13-2006 12:20 AM ET (US)
Riptide23WA:Hope you catch those tunas. I did the search but I still feel a bit confuse on how it compares with the classic hulls handling the waves (Deep V Whaler vs Classic Whaler). You mention the "typical twin Yamaha 200's" I was thinking 150's or even 130's for a 23' hull. Will that be ok or will It need that more power to reach 40 to 42 mph at WOT? I'm trying to find one of this boats here in Puerto Rico, to see it in person but so far I haven't. If any CW member from here knows where I can see one please let me know. Anyone else knows something about these hulls? |
Riptide23WA
posted 03-13-2006 08:42 PM ET (US)
Well, I really don't have much to compare her to, having never been on a classic Whaler hull like an OR 22. Others can probably attest better.I say typical Yamaha 200's, because that seems like a common setup that I've seen on 23WA's. However, the BW catalog from that year showed a twin 150 setup, and I think 300 hp was the recommended min HP. I think twin 150's would be more than adequate. Having said that, keep in mind that this is not a lightweight boat, and can carry 150 gallons of full, with a 180 gal tank as an option, supposedly. I am of the opinion that a little less weight on the stern would probably improve handling, although the additional leverage of the Whaler Drive bracket might also come into play as far as overall trim. I think mine rides bow high a little, although not terribly so. Again, my experience is limited, and I'm still playing with trim tab settings and engine trim. There was one for sale down in the Keys a few months ago, on Yachtworld.com. Closest one I know of to PR... Pat |
hardknots
posted 03-14-2006 09:42 PM ET (US)
Riptide23WA: Do you know the maximun speed of your boat with those 200's? 54 mph? I just saw a thread by jimh that may give me a better understanding of what speed/hp to expect from this boat, but I'm not really sure if the wheight shown in the Whaler catalogs includes the engines or not. I guess they are included but I'm not sure. Do you still have that 1991 Boating magazine where they tested the 23 WA? If you do, Can you tell me what they liked or not about the boat?I have a deal on a 23WA in the States subject to a sea trial and comprression test, but I'm trying to find all the information I can before hand, because that sea trial it's going to cost me plane tickets, hotel and time. I'm very happy with my Classic Outrage 25' but my wife and daughter want the cabin. I just saw this Whaler model (23WA) last month and it looks a lot like my former 2550 Pursuit, but with the unsinkability of a Whaler. Anybody else have or know the performance of this model? |
ROI
posted 03-18-2006 04:35 AM ET (US)
Have 1991 23'Walkaround, whaler drive, twin Yamaha 150 four strokes, with fiberglass hardtop, that is wounderful for what is.I run out of San Francisco Bay / Golden Gate (where there is usually a significant chop) and run in the area of 14 to 16 gallons an hour at 23-30 mph at 3400 to 4000 RPMs weather permitting)usually carrying the full 180 gallons of gas and fresh water capacity of 12 gallons. I very seldom open it up but I am in the 42-45 mph range -- (It's not totally tweaked to the high end range - aluminum props) Aspects of the boat that I have found (owner of 7 years): 1. The boat is a tank and the ride that is given is excellent -- considering conditions. 2. I think the boat may be a little stern heavy as originally configured with the heavier "older" engines. I used to have a hard time keeping the boat from taking off. (in my conditions) Solved my problem by moving weight forward (100+ lbs of lead weight in anchor locker -- also the repower with four strokes changed the handling aspects significantly (for me). 3. Have had several boat owners comment on the hull details: cleats, bow pulpit, stainless rail quality. (Have some minor stress cracks -- where deck flooring hatch ends - leading to the walkaround step) 4. Only complaints -- Can easily fish four people; have fished five; where do you put the people when running a minimum 17+ miles one way to the fishing grounds out of SF Bay -- on a usually choppy day ?? Note: There is another 23'Walkaround for sail out of San Francisco Bay Area -- fully loaded; $32000; coastsidefishingclub.com
JG |
hardknots
posted 03-18-2006 08:51 PM ET (US)
ROI:I appreciate all the information you gave me, however I still have some doubts. When you say; "I think the boat may be a little stern heavy as originally configured with the heavier "older" engines. I used to have a hard time keeping the boat from taking off. (in my conditions)" Correct me if I'm wrong but aren't 4 stroke motors heavier than older 2 strokes motors? I guess the performance you mention is with 4 strokes engines. Do you remember gas milage with 2 strokes motors? Again thanks ROI, as you can see there have been very little participation on this threat, maybe because there are not many owners of these boats in CW. I'll keep trying so if anyone can say anithing good or bad about these hulls please come forward, any info will be gladly receive. Thanks, Ricky
6992WHALER
posted 03-19-2006 02:54 PM ET (US)
You are correct, about a lack of 23 walkarounds on this forum.I own a 1992 with whalerdrive and twin 200 Yamahas. I love it for what I bought it for, family cruising and scuba diving. Unfortunately I am not gong to be too much help as far as fuel economy. I have only had the boat one summer. I installed a Navman fuel flow system but one of the sending units was bad so all my data is useless. (Navman is sending out a new unit to replace the bad one.) Most of the time my boat is on small bodies of water. I have only had it in 3-4 foot waves and it did great. The two times I had her up on Lake Superior this summer the lake was glass calm. So I have no experience with her in any kind of big water. I don’t think the boat is stern heavy, she jumps right up on plane, but with time and more hours I may change my mind. The boat is heavy for a 23 footer, 4,300 pounds dry, 800 pounds for the engines equals 5,100 pounds with no gear or fuel. I have the 180-gallon fuel tank so you can make her pretty heavy with fuel, people and gear. Sweet spot is 27 knots; top end is around 42 knots max horse power is 400, minimum with whaler drive is 275 (Transom hall 400 max, 225 min) There is no balsa wood in the hall, there is some in the decks. Contact Chuck Bennet at Boston Whaler. He sent me a diagram of the deck showing all the different kinds of wood used. If you have a fax number I can send it to you. (Have some minor stress cracks -- where deck flooring hatch ends - leading to the walkaround step) I have the same stress cracks. I also agree it would be nice if there was some more seating, but I bought her for her large back deck, so that is a trade I am willing to make. This is a deep v boat, it will ride different from your typical Boston whaler, she will cut through waves head on but she will also dig into a wave and veer to the side. You have to drive it as a deep V. She will roll more at anchor when waves come in from the side, and she will be a little less stable at rest then similar sized classic halls. I think the hall may still be being produced as a different model, someone here would know that. I like my 23 a lot, the past owner ran her way off shore fishing and actually hired a charter captain to drive so he and his buddies could fish. Hope that helps. |
Riptide23WA
posted 03-19-2006 09:01 PM ET (US)
I checked the Boating magazine copy that I have... as stated, top speedo of 54 mph w/ twin Yam 200's. The fuel consumption numbers were something like 12 gph at 30 mph at 3500 rpm. I can't confirm those, mainly 'cuz I don't pay attention yet.The article glowed about the boat, but then again, BW was a paying advertiser, so they don't find too many faults, I think. But, there isn't too much to find fault with.... t |
hardknots
posted 03-19-2006 10:05 PM ET (US)
6992Whaler and Riptide23WA:Thanks for your help (Great information). I think, I will be more comfortable now making a decision. Thanks again, Ricky |
ROI
posted 03-19-2006 11:18 PM ET (US)
Hardnots:You are probably right about the weight of four stroke engines in most cases -- was not thinking about higher HP engines or other boats. I THINK, IN MY CASE, the weight of the Yamaha 2-strokes that I replaced was VERY CLOSE or heavier than the new engines that were installed ?? I did do the comparison at the time , ie removal of 2 cycle oil tanks; different steering rams , etc. I do know that the handling characteristics changed for the better in my case. As far as gas mileage, my gas mileage (AND MY RANGE) just about doubled with the installation of Yamaha 150 four strokes. The engines that were replaced were Yamaha 150 -- carbourated two strokes. Since installation, 2 years ago, I have 408 hrs on the engines and have burned aproximately 2502 total gallons. My savings or payback since repower is around $5754 in two years. (I am anal retentive) As far as useable fuel capacity -- the most that I have ever put in at one filling is 157 gallons on a 180 gallon tank -- too chicken to run any more out and was too lazy to pump remaining into empty gas cans. Would like to know exactly how much of the 180 gallons is useable. My "world record" is 95 miles from the Golden Gate and I didn't hit the 157 gallon mark at that time -- 157 gallons was burned by the two strokes. Hope this helps. I don't always check this web site but I'll probably be checking in more. JG PS: As far as ride -- I have one friend who owns a Farallon; another who owns a Davis Rock Harbor -- they are both impressed on quality and dryness of ride -- absent totally horrible conditions.
hardknots
posted 03-21-2006 09:01 AM ET (US)
ROI:Very detailed information, thanks for taking the time to help me. The ride comparison with the classics is now my main concern, and you mention your friends been impressed with the "quality and dryness of ride" of your boat so that's another point on the good side. Thanks again, Ricky |
