  MONTAUK 17: Propeller Comparison--17 and 19-inch Pitch
Author Topic:   MONTAUK 17: Propeller Comparison--17 and 19-inch Pitch
boatdryver posted 06-12-2006 11:09 PM ET (US)   Profile for boatdryver   Send Email to boatdryver
Here is some performance data that may be of interest to people considering a prop change. The nearly identical performance of two props 2-inches different in pitch and the same diameter can only be explained by different materials and blade design
Boat: '79 Montauk with clean bottom. Motor: Honda BF 90 mounted with AV plate 1.5 inches above bottom (3rd hole). One adult, 12 gal fuel. motor trimmed way up till it got a little squirrelly. Both runs within a half hour. Flat water. 5 kt wind, no canvas up.
Old prop: aluminum 13X19 either Honda or Merc, in new condition with minimal cupping:
WOT rpm 5800
average speed by GPS (up and down current and 5 kt wind): 34.7 kt=39.9 mph
Stilletto 13x17 SS
WOT rpm 5800
average speed by gps: 35.0 kt=40.3 mph
Subjectively the hole shot with the Stilletto is faster and mid range acceleration is better. Idle speed seems slower, better for trolling, and minimum planing speed seems to require more rpm. (I had little experience with the old prop on this recently purchased boat/motor package.)
No fuel flow meter.
I hope to do some speed runs at different rpms next
JimL
jimh posted 06-13-2006 12:42 AM ET (US)     Profile for jimh  Send Email to jimh
It looks like you have that Montauk running quite nicely with the Honda BF90 outboard.
There is quite a bit of data that shows that the marked pitch of a propeller is something of an arbitrary value, and among several manufacturers it is common to see differences in the assignment of pitch. What one manufacturer calls a "17-inch" propeller may, as you have demonstrated, produce performance very similar to a "19-inch" propeller from another manufacturer.
If you stay within a particular brand and also in a particular model or style of propeller in that brand, then propellers of different pitch ought to produce different results.
RobertRibley posted 06-13-2006 10:22 AM ET (US)     Profile for RobertRibley  Send Email to RobertRibley
Thanks for info I am waiting for a Stiletto 15 to test on my 82 will report soon Robert
pasino posted 06-14-2006 10:59 AM ET (US)     Profile for pasino  Send Email to pasino
I had the same experience when I put a new yamaha 115 on mi 1980 montauk.
The motor came with a 21" aluminium prop and performed 38.7 knots at WOT 5800. Then i put a 19" teflon covered steel yamaha prop that performed 39.7 knots at 5900.
Am I wrong supposing that was because the steel propeller was much more efficent?
davej14 posted 06-15-2006 11:06 AM ET (US)     Profile for davej14  Send Email to davej14
Shouldn't a 115 on a Montauk do at least 45 mph? Less than 40 mph at WOT doesn't seem right to me. Maybe the motor is mounted too low??
Tom W Clark posted 06-15-2006 11:09 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
39.7 knots is 45.6 MPH.
davej14 posted 06-15-2006 11:42 AM ET (US)     Profile for davej14  Send Email to davej14
That makes more sense, I didn't notice the "knots" vs. "mph" on the post.
