Author | Topic: Yamaha 250 fuel curves |
BillG |
![]() ![]() ![]() Anybody have any fuel consumption data for a Yamaha 250 EFI, about 2001 model year (Ox66, in particular)? Numbers for a 225 would also be close enough to be helpful. I'm rebuilding a Yankee Voyager 20' and plan on getting rid of the old I/O in favor of an outboard. I was going to go with a 4-stoke but found a deal on a very clean 250 and am thinking I can buy an awful lot of gas for the $ difference. Only question I have is how much tankage I'm going to need to get any kind of range out of the boat. Thanks, Bill |
Tohsgib |
![]() ![]() ![]() That is the thirstiest outboard made sans V8 OMC's. I think they burn about 18gph at cruise and close to 30 WOT. Friend has a 21 Parker with a 225 Yamaha. Engine blew and he put a new 250EFI on it and it was slower. They are made for heavy boats so maybe not a good choice for the Yank. Better make that tank big and at todays gas prices, beter off with a 4 stroke or DFI. Good deals on used Fichts and Optis. |
Tohsgib |
![]() ![]() ![]() PS...my 225 carbed OMC burned 13gph at 3900 and 24gph WOT. a 30 mile TOTAL run would cost me $100. Your I/O or 4 stroke will burn roughly half and no oil(hopefully). |
Peter |
![]() ![]() ![]() Here is a typical fuel curve ranges for the 250 Ox66. Very thirsty above 4000 RPM. RPM GPH 1000 1.5 - 2 I'll bet that at your typical cruise speed that the 250 OX 66 won't burn more than 2 and at maximum 3 GPH more than a 4-stroke or DFI 2-stroke of equivalent HP. 3 x $4.00/gallon is $12.00/hour more to run the 250 Ox66. If there is a $10,000 difference in price between this motor and a new 4-stroke, it would take over 800 hours before you break even plus you'll keep the weight on the transom down which is always a good thing on a 20 foot boat. |
rtk |
![]() ![]() ![]() Peter's numbers are consistent with my 2003 Mercury 250 EFI. On my 1997 21 Outrage, at cruise speeds 25-30 miles per hour, my fuel economy is typically around 2mpg, range 2-2.5mpg depending on conditions and load. I went with the new EFI instead of a new DFI/4stroke because I got a deal also. I've burned about 2500 gallons over 300 hours since I have owned the engine. If I chose an engine that burned 30% less fuel, I'd have burned 750 less gallons. At $3.50 a gallon, savings over the 300 hours would have been about $2600. The Optimax 225 or Yamaha 4 stroke 225 was about $4000 more to purchase at the time. Rich |
Tohsgib |
![]() ![]() ![]() 12-13 at 4k...no way on a 250 Yamaha(not Merc). My 175 did close to 10 and my 225 was about 14. Look up the archives in boating mag, etc. I am not talking avg per tank, I am talking throttle at 4k for an hour. A 225/250 4 stroke/dfi will burn 8-10 at cruise which is about 5+ less per hour($15/hr). Most engines including 4S and DFI will burn 10% at WOT. The fact a 250 will do 27+ says it all. The only way I could see a 250 Yam doing 12-13 at 4k is on a light hull like a 22 OR but that is being optiomistic in my opinion. Now don't give me that fuel flow meter stuff either because if you do not calibrate it correctly it is as useless as tits on a bull. |
Peter |
![]() ![]() ![]() Hull weight and shape have nothing to do with fuel consumption rates. Hull weight and shape only effect fuel economy --> MPG. If you don't believe that or the consumption rates noted above, then go look at performance reports at Yamaha. In particular, compare www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_otb_2StrokePerf_OX666_250hp_017-COB-Z.pdf (Note: Saltwater version) and www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_otb_2StrokePerf_OX666_250hp_01148-SKT-Z.pdf (Note: VMAX version which is tuned a little differently than Saltwater version). Both motors are in the 12 to 13 GPH range despite being on different boats. The only difference is that the Cobia achieves 31 MPH at 4000 RPM and the Skeeter is making nearly 50 MPH at 4000 RPM. By the way, the fuel consumption numbers in that Cobia report are consistent with the numbers my friend sees on his calibrated NAVMAN F3100. His boat is a 4000 lb 24 foot cuddy cabin with a top speed of about 40 MPH. There are no corresponding Yamaha performance reports for the F250 4-stroke on identical boats (Yamaha has removed many of its Ox66 reports). However, these two are the closest performance reports that I could find is this one => www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_4stroke_hpv6_sws2_hyd-vector2200vx-f250txr.pdf and www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_4stroke_hpv6_sws2_pkr-2510wa-f250turd.pdf . Note that in both cases, the most efficient cruising speeds for the F250 (no matter what boat) occur between 4000 and 4500 RPM (about 67 to 72 percent of full throttle (just like the 2-stroke Ox66) and in that range the F250 is using fuel at a rate of 10 to 12 GPH, not 8 to 10 GPH. As I said above, there is about a 2 to 3 GPH difference, at most, between an Ox66 250 and an F250 at cruise. Finally, you cannot compare the two motors based on the same RPMs because a 4-stroke needs to turn faster to achieve the same speeds. An Ox66 has a 5500 RPM redline. The F250 has a 6000 RPM redline. The power output at 4000 RPM (~70 percent of full throttle) for an Ox66 is about the equivalent of the power output at 4400 RPM (~70 percent of full throttle) for an F250. |
cooper1958nc |
![]() ![]() ![]() Predicting fuel flow based on RPM alone is only an estimate. The estimate works fairly well if and only if the engine is propped for a given maximum RPM; any other prop and gear combination will throw the predictions way off. Beyond that, hull weight and shape do affect fuel consumption predictions. The shape of the resistance curve may differ in different hulls. Fuel consumption is a function of RPM and manifold pressure (MP). MP is not measured directly in marine practice but corresponds to throttle setting. At a given RPM, different boats may be at equivalent RPM but different throttle settings necessary to maintain that RPM. These differences disappear at full throttle for equivalent RPM (and equivalent air density), but they are real at partial throttle operation. |
Peter |
![]() ![]() ![]() Hull weight and shape don't effect fuel consumption rates, they only effect top speed and fuel economy. Of course this assumes that the same motor on two different boats can be propeller loaded across the operating range the same which is never perfectly the case. Again, the premise is load on the powerhead is load on the powerhead whether that load comes from a 75 MPH go-fast boat like the Skeeter or a 42 MPH family fisher/cruiser like the Cobia. if both motors are propped to achieve the same WOT RPM, they should be consuming fuel at the same rates because they are seeing the same load. The data shows this. Of course the two examples given are not propeller loaded exactly the same nor are they run in the same conditions so there are some variations in the data. |
cooper1958nc |
![]() ![]() ![]() You are correct that load on the powerhead is load on the powerhead. My point was more subtle. Take two different boats. One is a planing boat that has a huge resistance at transition speeds, say 13-17 mph. It then gets over the "hump" and has less resistance for a while, then the resistance increases again. Assume it reaches top speed of 44 mph at an RPM of 5500 at full throttle (manifold pressure of 29 inches). Boat 2 is a full displacement boat, where the resistance is more or less exponential with speed, without any inflection points. Boat 2 reaches full throttle at 5500 RPM (very different prop or gear of course) at 9 mph. At 15 mph boat 1 will be at 3000 RPM, but its manifold pressure will be 27 inches, almost full throttle, to deliver sufficient torque to get over the high resistance of transition. Boat 2 at 3000 RPM is going, say 6 mph well down on the resistance curve, with MP of 20 inches. Much less fuel is burned at the same RPM. Note the examples are fairly real life, though extreme because of the difference in boat types. Does this help? |
Peter |
![]() ![]() ![]() Not really helpful. I can't think of any instance where someone has put or would put a Yamaha 250 on a displacement hull. If the displacement hull needs 250 HP to perform, the Yamaha's propeller won't be large enough and won't be in the right place to be effective. Marine diesel manufacturers provide power/fuel curves for their engines. These power/fuel curves are independent of boat hull application. For them, load is load. If load X provides 6 MPH or 26 MPH, depending on application, the fuel consumed should be consistent with what the curve says for load X. When the same motor is propeller loaded the same even though on diferent boats, they will consume the same fuel, except for, perhaps, the transition zone to which no one is really worried about because no one strives to operate their boat in the transition zone. Again, look at the numbers and forget about the transition zone. The fuel consumption rate for a given motor is quite consistent from boat to boat, RPM to RPM. |
Tohsgib |
![]() ![]() ![]() Suzuki 250 does 9.0gph at 4k according to Boating. The 150 Yamaha 4s burns 6.2. The 150 etec did 7.6. And the 350 yamaha about 14. |
Peter |
![]() ![]() ![]() I'll say it again. You simply can't compare motors on an RPM to RPM basis. You have to compare them on an equal load basis. 4-strokes typically need to spin about 500 RPM faster than 2-strokes to produce the same power output --> same speed. Redline on the Suzuki DF is 6000+ RPM. Redline on the Yamaha is 5500 RPM. That means that the Suzuki needs to turn faster to push the same boat the same speed as the Yamaha if it is propped to reach 6000 RPM at WOT like it should be. Recall from the above performance report that the Yamaha 250 could push the Cobia 31 MPH at 4000 RPM (~12 GPH). If the Suzuki D250 was pushing the same Cobia boat 31 MPH it would be turning more than 4000 RPM and probably something closer to 4500 RPM. If you look at Suzuki's own fuel consumption data for the DF250 between 4000 and 4500 RPM, it is pretty consistently between 10 and 12.5 GPH. So I highly doubt that the Suzuki would push that Cobia to 31 MPH at 4000 RPM on 9 GPH. I suspect you'd see something in the 11 GPH range. |
Tohsgib |
![]() ![]() ![]() Uh...4500 is 10.5 |
Peter |
![]() ![]() ![]() Uh, take your pick from Suzuki's own performance data: 12.4 GPH at 4500 RPM ( www.suzukimarine.com/boat_builders/boat_tests/key_west_boats_inc/ keywest_225/df250/ ), or 12.25 GPH at 4500 RPM ( www.suzukimarine.com/boat_builders/boat_tests/carolina_skiff/ sea_chaser_2400_offshore/df250/ , or 12.5 GPH at 4500 RPM ( www.suzukimarine.com/boat_builders/boat_tests/carolina_skiff/ sea_chaser_250lx/df250/ ), or 11.8 GPH at 4500 RPM ( www.suzukimarine.com/boat_builders/boat_tests/ranger_boats/ ranger_2300_bay/df250/ ), or 12.1 GPH at 4500 RPM ( www.suzukimarine.com/boat_builders/boat_tests/mako_marine_intl_inc/ mako_232/df250/ ) |
Tohsgib |
![]() ![]() ![]() I was going by Boating mag and you asked about 4500. Personally I really don't give a flying fart what they burn because I do NOT own one, nor will I ever. The guy wanted some info...I gave him what I had, don't need to get into a pissing match over who's research is better. |
cooper1958nc |
![]() ![]() ![]() The examples I used were for illustration. However, these outboards do push patio boats, large pontoon water taxis, and barges, which are generally displacement boats. The fuel consumption figures given were from similar type boats. I would like to see a fuel curve for the same motor on a water taxi. Just curious. |
BillG |
![]() ![]() ![]() Hey, check it out! Ask a simple question, come back a day later and a bunch of total strangers have been going at each other big time. Come on, guys, this is supposed to be fun. Let's keep it friendly. Thanks, everyone, for your responses. About what I expected. I used to have a Yamaha 225 Excel (carbs) on a Robalo 21 Cuddy, a very similar boat to the Voyager. That motor "exceled" at turning dead dinosaurs into noise. Even so, at 20 knots/medium load I'd get an honest 2MPG, if not better. Don't remember the exact RPM's but I think 37-3800. At 4000 the secondaries started opening and the burn rate went to about 35 gph-wot. I would expect at least as good from an injected motor with more advanced electronics on an almost identical boat. If I was clocking tons of hours, Tohsgib's arguments would make sense, but I'm not. Assuming, in a really good year, I put 100 hrs at 20 knots on the boat. At 2 MPG that's (duh!) 1000 gallons, or $3250 at last summer's gas prices here. If the 4-stroke gets 3 mpg at the same speed, that's 667 gallons @ $2167 for a savings of $1083/yr. Add in $1000/year depreciation for the first few years and I'm looking at 15+/- years to recover the extra $10K for the new 4-stroke, not including dealer service costs, etc. Even if the fuel economy is twice as good, the payback still has to be 10 years. Cooper and Peter both sort of hit the nail on the head without saying it. Stay off of the throttle, run the boat at a reasonable speed and the difference 2S vs.4S is negligible for the average user. By the way, I have seen a displacement hull with outboards on it. Big, steel, trawler looking thing somebody obviously built in their back yard. About 50' LOA, 3 decks tall with slab sides, bluff bow and probably 16' beam. Had a pair of V-4's on a bracket welded to the transom. OUTSTANDING! I never saw it under way but it moved from Ft. Meyers, FL one winter to a canal in Punta Gorda the next. I bet the neighbors paid real close attention when that thing left the dock. |
outragesteve |
![]() ![]() ![]() Keep us informed: I am interested in the Voyager. There is a guy in my area that has one and it had been in his garage for 20 years! Never touched the water. He has replaced the trailer just because of age/rust caused it to fail. I have inquired about the boat,he will not sell it....go figure! I thought an ideal power package would be a Merc diesel/Alpha set up: You are going outboard/bracket. The Voyager was "splashed" here in Hawaii to create the 22' Islander. It was a great boat with twin 150's on it. The mold was later sold to SunRunner and they produced a center console for a few years. Interesting chain on the Voyager. (Can you see the 20' Bertram/Ray Hunt design?) |
BillG |
![]() ![]() ![]() Hi, Steve, I bought this one from the original owner right here in town. It's rotted under a tree in her yard for the last ten years. I've been trying to buy it from her since I was a kid. It's in pretty bad shape. My understanding is that Bertram sold the molds for the 20' to Nauset Marine. They built the Voyager, or the hull at least, for Whaler. When Whaler gave it up, Nauset marketed (and still does) the boat as the Highliner 21. Or some history to that effect. There's a thread about it somewhere on this site. I'm going with the outboard for 2 reasons. First, I hate outdrives. I always swore I'd never own one, then 3 years ago I bought a Tiara 20' and rebuilt it. Put in a fresh 350 Chevy with an Alpha. I know it's hard to argue with success, there's a bazillion of them out there, but always something wrong and what a pain to work on. All those gears, universals, gymbal bearings, rubber seals and boots..... I'll never own another one. Plus all that weight right in the butt of the boat and those dissimilar metals sitting in salt water all the time. Just inherently stupid, when you think about it. Second, experience. When I was in high school a buddy bought a Bertram 20 at a NOAA auction. We pulled the drive, glassed in the hole and hung a 200 Johnson on it. What a great boat. Unbelievable ride in a sea. He kept it for ten years and still regrets selling it. I don't think the vee on this one is quite as deep but it's pretty close. At the least, it's definitely got the Hunt look. Bill |
Peter |
![]() ![]() ![]() We weren't really going at it. Just want to make sure that there is accurate information regarding fuel consumption. I've had the Ox66 in a 225 HP form on a 22 Revenge and as long as you keep the revs under 4000 RPM you'll be OK. That shouldn't be any problem on the Voyager. By the way 4000 RPM was good for about 31/32 MPH on the Revenge, plenty fast cruise. I typically ran the motor in the 3500 to 3900 RPM range, 25 to 30 MPH, about 9 to 11 GPH for the 225. |
John from Madison CT |
![]() ![]() ![]() quote: That is not at all accurate. Do you really believe the Ox66 burns more than a V6 Looper OMC OB?? I have owned two of these 250hp engines, and FWIW, on a 22' Whaler, on a whaler drive, I got 3mpg. On my current boat, a 25' Parker, she runs around 4200RPM's, gets around 25mph and burns about 13 gph. This is measured by a calibrated Navman 2100. At 4500RPM's she will burn around 14-15gph. Running above that shows more fuel burn, but every OB is that way. Efficiency goes way down. Every Carb'd V6 OB burned more than the Ox66. |
JMARTIN |
![]() ![]() ![]() I got an OMC V6 Looper 200hp on my Revenge 22 and the figures look similar. At WOT I am 22 gph, at the sweet spot, 3500rpm, 11 gph, 25 mph, 2.25 mpg. John |
![]() ![]() ![]() You have 50 less HP and you're doing a comparison ??? |
JMARTIN |
![]() ![]() ![]() " Do you really believe the Ox66 burns more than a V6 Looper OMC OB?? " I'm sorry, thought you were asking a question. Did they make a 250 hp V6 Looper OMC? John |
Peter |
![]() ![]() ![]() Did they make a 250 hp V6 Looper? Yes. From 1999 to 2001. |
LogeyPogey |
![]() ![]() ![]() The fuel rates that peter posted for these are pretty much right on . I have twin 99 250 ox66's bolted on to my Grady . Yes they burn their fuel up but you can burn a lot of gas compared to the cost of repowering with 4S moters or the time bomb etech . They also burn they fair share of 2 stoke oil which also has to be synthetic because of the o2 sensor. But they are "bulletproof moters". |
macfam |
![]() ![]() ![]() The fuel rates Peter quotes are right on the money. Those are rates I would consistantly see on my 25 Revenge WT. |
![]() ![]() ![]() Since I happen to own an OMC V6 looper (225-HP), it would not be hard for me to believe that a Yamaha Ox66 outboard would be able to operate with better fuel economy. The Ox66 has a closed loop control system and electronic fuel injection, and it ought to be able to adjust its fuel-air mixture to much more optimum ratios than the fixed jets in the six carburetors of my motor. The Ox66 also probably has temperature sensors for air and engine power head, as well as a barometric sensor, and these inputs should also help the control system manage the fuel-air ratio better than on an OMC V6 looper. Since the V6 looper with its six carburetors has to be one of the more fuel-hungry motors ever made, I don't want to damn the Ox66 with faint praise, but I think that of any of the classic two-stroke motors with fuel injection, it ought to have a good chance at better fuel efficiency due to its closed loop system. If the Yamaha engineers did their homework, that engine ought to be running with just the right mix of fuel and air, and therefore close to optimum fuel efficiency. |
