  Average Fuel Economy 22 to 27-foot Hulls
Author Topic:   Average Fuel Economy 22 to 27-foot Hulls
newt posted 09-06-2011 01:11 PM ET (US)   Profile for newt   Send Email to newt
I am interested in learning what other users obtain for average fuel economy on their larger Boston Whaler boats. Please chime in with some real numbers if you have them.
I'll go first. This is based on the last 100 miles logged (via gps) on the boat.
Boat: 1986 Revenge 25, full canvas (up), arch, bottom paint. Fuel/persons/gear = approximately 1800 lbs.
Engines: Twin Johnson 2-stroke 150's
Average fuel economy = 1.4 mpg.
jimh posted 09-06-2011 02:22 PM ET (US)     Profile for jimh  Send Email to jimh
A Boston Whaler REVENGE 22 W-T Whaler Drive with E-TEC 225-HP gives me an average fuel economy of 3-MPG based on several weeks of long distance cruising where I travel about 60-miles per day with the boat loaded with fuel, gear, and two people. This is a very real number based on many observations. Unfavorable winds, waves, and non-optimum boat speed will, of course, lower that MPG figure.
Hal Watkins posted 09-06-2011 03:09 PM ET (US)     Profile for Hal Watkins  Send Email to Hal Watkins
Labor Day weekend 2011
MS River from Genoa, WI to Guttenberg, IA and return
(58 miles each way with 1 lock thru)
205 Eastport w/150 Optimax
2 adults 3/4 fuel
3600/3900 RPM
4.4 MPG downstream
3.9 MPG upstream
Hal Watkins posted 09-06-2011 03:10 PM ET (US)     Profile for Hal Watkins  Send Email to Hal Watkins
As per SMARTCRAFT output
Tohsgib posted 09-06-2011 03:22 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I don't have a GPS nor even a compass so I can only go by GPH. Donzi averages about 6-7gph and Revenge about 2.5-3 per tank. MPG however is not that far apart because the Donzi cruises at what the Revenge does WOT. Yes I burn twice the fuel but get there in half the time so......
jimp posted 09-06-2011 04:55 PM ET (US)     Profile for jimp  Send Email to jimp
Boat: 1990 Revenge 22 WT, canvas down, bottom paint. Fuel/persons/gear = approximately 1,500 lbs.
Engine: 2003 Mercury Optimax 225, 19" MiragePlus propeller
Average fuel economy for 135 nautical miles (Juneau - Glacier Bay National Park - Hoonah - Juneau), excellent weather (seas less than 1-ft, wind under 5 kts) = 3.0 NAUTICAL mpg (3.45 statute mpg) @ 3900 RPM.
Boat continuously get 3.0 nmpg in good weather. Rarely use canvas.
JimP
JMARTIN posted 09-06-2011 07:34 PM ET (US)     Profile for JMARTIN  Send Email to JMARTIN
1983 Revenge V-22, 1992 Evinrude 200, 17 Rebel, 1000 pounds fuel, gear, people. Lots of current and winds vary from 2.3 to 2.8 so 2.55 sounds about average.
John
Buckda posted 09-06-2011 08:01 PM ET (US)     Profile for Buckda  Send Email to Buckda
1983 25' Outrage Cuddy with twin V-4 130 HP carburated 2-stroke Johnson Ocean Runners provided an average of 1.5 MPG over 221 miles of cruising (figure based on filling tanks to full again and carefully recording the miles traveled each day). I believe I can improve this figure by raising the engines, however, life intervened this summer, so I haven't had a chance to do so.
themclos posted 09-06-2011 09:15 PM ET (US)     Profile for themclos  Send Email to themclos
I have a 1986 22 Outrage Cuddy with a 2002 225 HP Mercury Optimax.
I consistently get 3 MPG or better as well.
Dan
L H G posted 09-07-2011 12:10 AM ET (US)     Profile for L H G
On my 25 Outrage "Whale Lure", with twin Armstrong bracketed
1997 Mercury 200 EFI's running 21" Revolution-4 props, I consistently get 2.5 MPG at cruise, running about 30 MPH at 2800 RPM.
martyn1075 posted 09-07-2011 03:11 AM ET (US)     Profile for martyn1075  Send Email to martyn1075
1990 25 Whaler Walkaround (wide) twin 225's give about 1.8 mpg at cruise which is about 28knots. It weighs in at about 8000 + pounds so its big and heavy. It can really take off and tops out at 48 but your burning crazy amounts of fuel so it better be worth it. There is a spot with the Optimax motors with proper trim and only on certain seas that can obtain better milage then 1.8mpg but you are moving around 21-23k which is painfully slow for me most times but can be useful if you are alright with it. Its a very comfortable boat at all speeds but especially at cruise and I'm fairly happy with the results on such a big Whaler that can achieve many different types of boating all year round.
Martyn
newt posted 09-07-2011 08:01 AM ET (US)     Profile for newt  Send Email to newt
This is good information, please keep it coming. Even with the limited sampling so far, there are clear trends showing.
LHG and Martyn, do you happen to have overall average fuel economy figures as apposed to "at cruise"?
Toshbig, can you extrapolate fuel economy from the numbers you posted?
Jimh, is your figure of 3 mpg an overall average including "Unfavorable winds, waves, and non-optimum boat speed"?
jimh posted 09-07-2011 09:06 AM ET (US)     Profile for jimh  Send Email to jimh
Re my MPG data: A Boston Whaler REVENGE 22 W-T Whaler Drive with E-TEC 225-HP gives me an average fuel economy of 3-MPG based on several weeks of long distance cruising where I travel about 60-miles per day with the boat loaded with fuel, gear, and two people. This is a very real number based on many observations. Unfavorable winds, waves, and non-optimum boat speed will, of course, lower that MPG figure.
newt posted 09-07-2011 09:55 AM ET (US)     Profile for newt  Send Email to newt
So Jim, your 3 mph figure was based on several weeks of cruising under favorable conditions - no unfavorable winds and waves, always cruising at optimal speed. Got it.
Slick 50 posted 09-07-2011 11:15 AM ET (US)     Profile for Slick 50  Send Email to Slick 50
This is great information. Thank you all for posting.
It appears the 22's with newer engines get around 3 MPG or a little better while the older engines get about 2 to 2.5 MPG.
Looks like the 25's are getting between 1.5 MPG to 2 MPG.
It would also be nice to get MPG comparisons of Whaler Drives to notched transoms.
Excellent thread.
Rick
Tohsgib posted 09-07-2011 11:51 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Newt that would be pretty much impossible due to the fact that I don't know how many miles I run w/o a GPS. I do however have an hour meter and know how much fuel I put in the tank so I know how many gallons/hour I am averaging per tank. I am pretty consistant as I run the same thing pretty much every weekend. I will bring out the handheld one day. As far as MPG at cruise I burn roughly 3.5-4 with the Donzi and 5-6 with the Revenge at cruise. The 115 gets way superior mileage in slow speed zones as it is a 2L compared to a 7.4L. The Donzi however cruises at 35-40 and tops out closer to 70 where the Revenge cruises at 25-26 and tops out at 40. I also don't need to slow down for every little wake in the Donzi which helps eliminate the off and on the throttle which kills MPG.
martyn1075 posted 09-07-2011 11:52 AM ET (US)     Profile for martyn1075  Send Email to martyn1075
newt.. I don't have real data on the higher or lower speeds and would need to get back to you on that with this particular model with twin setup.
Important to note the this boat can obtain and balance a large amount of weight. The gas tank is 1000L so weight in fuel alone is substantial. Its doesn't seem to affect its balance and performance data at cruise. One thing I have noticed with a full tank is that it does push through the waves more and I have noticed in rough sea I can keep the speed up a bit and not feel what I would normally feel with much less gas. I am thinking I save a bit due to not shifting speeds with a 8000 pounds to lift back up on plane constantly.
I would say 1.8-2 mpg is average and honest. The lower speeds with this particular boat (21-23) are interesting and I think would achieve better? The haul being nearly 10 feet and more like 28-30 feet long tends to keep its bow down even at lower speeds rather than most which stick up at those speeds and gives most unfavorable gas milage. My meters are showing impressive numbers I just have not set the boat at this speed and bothered to measure my data because of a need to get to where I need to be.
At higher speeds more like 35ish the engines rpm are still down at around 4000rpm and overall I would say slightly less mpg then 1.8 my guess without data probably around 1.4. After this point it just gets worse fun but not economical at all.
Martyn
6992WHALER posted 09-07-2011 12:40 PM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
1992 23 Walkaround, hard top, Whaler Drive, twin 1992 Yamaha 2 stroke 200s, lots of fuel (180 gallon tank) 2 adults, one child.
1.4 MPG
350 mile cruise good weather but lots of different speeds.
Tohsgib posted 09-07-2011 02:05 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Wow...I need to really check my AVERAGE MPG. I was under the notion that your cruise would be the worst and your average would be much better, especially if you do a lot of slow speed driving. My 115 gets like 20mpg at 5mph, I get 5+ at cruise and like 4 at WOT. I don't understand how people are getting 1.4 over a tankfull unless your cruise is like 1.0.
newt posted 09-07-2011 02:21 PM ET (US)     Profile for newt  Send Email to newt
Bigs, you are running modern engines. Old two strokes are not efficient at displacement speeds. Plus, if most people cruise at the most efficient planing speeds, then average would always be worse.
Tohsgib posted 09-07-2011 02:44 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
True. Even with my "obsolete" engines back when I still averaged about 2/3's the fuel per tank than I did at cruise which I still do today but again no way to tell what my MPG was per tank as back then there were no GPS's.
jimh posted 09-07-2011 05:57 PM ET (US)     Profile for jimh  Send Email to jimh
With my older two-cycle motor the optimum cruise was the best MPG I could get at any speed. Low speed fuel economy was terrible, sometimes worse than running at fast cruising. I think this is typical of older two-cycle outboards. By just giving the MPG at optimum cruise you get the optimum MPG possible. The rest of the time, faster or slower and particularly idle speed, the fuel economy is worse.
The older two-cycle motors are reasonably fuel efficient at their optimum fast cruise. They are not as fuel efficient as a modern motor, but they are not terrible, either. However, what one finds out is that you really don't spend all your time at cruising speed, or at least not as much as you think.
For my REVENGE 22 the long-term average MPG with a classic two-cycle engine was 1.8-MPG. The improvement to 3.0-MPG with a modern motor is very substantial. It is a 1.2-MPG improvement from 1.8-MPG, or an improvement of 67-percent.
Regarding Whaler Drive boats, one should remember that they make the boat at least two-feet longer. My 22-footer with Whaler Drive is only a few inches shorter than the 25-foot hull. So when one hears, "a Whaler Drive reduces fuel economy," it must be realized that the comparison should be with a larger hull, not the same length hull without a Whaler Drive. In that sense, my Revenge-22 W-T Whaler Drive fuel economy should be compared with, say, a Revenge 25, not with a Revenge 22 without Whaler Drive.
jimh posted 09-07-2011 06:00 PM ET (US)     Profile for jimh  Send Email to jimh
newt--Yes, if you spend a week going 60-miles a day into 25-knot head winds, four-foot head seas, and slogging along at 12-MPH you will not get the same fuel economy that you will if you run the boat at optimum plane most of the time mixed with the usual down speed operation. This applies to all Boston Whaler boats 22 to 27-feet in length, not just mine.
You might also inquire how people derived their data. Some people measure fuel economy by the seat of their pants. Others actually collect data.
Tohsgib posted 09-07-2011 09:47 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I have really bad gas!
newt posted 09-07-2011 10:34 PM ET (US)     Profile for newt  Send Email to newt
Thanks for the unsolicited elementary lesson Jimh. It's good information, but still doesn't clarify under what conditions you obtained your 3MPG figure. I'll assume it was under average conditions and not by avoiding unfavorable winds, waves, and non-optimum boat speeds, which would of course, lower that MPG figure. I'll also assume that you weren't traveling in reverse or towing a barge loaded with gravel. I am pretty sure those would decrease your MPG also.
On another note, given the small data set we have so far and considering that your boat has a Whaler Drive, it would appear that you obtain the best overall fuel economy among the reporting 22 foot hulls.
Buckda posted 09-08-2011 07:30 AM ET (US)     Profile for Buckda  Send Email to Buckda
Here's a data point for you.
Crossing 56 miles of lake superior, I ran a "short tank" from my aux deck tank and saw 1.9 MPG "at cruise". The idling on 2-strokes will decimate overall MPG.
crabby posted 09-08-2011 08:50 AM ET (US)     Profile for crabby  Send Email to crabby
22 Outrage Cuddy with WhalerDrive and Super Console, 2009 250hp E-Tec, 17 inch Rebel
At cruise (about 32 mph / 4200 rpm's) I can generally get 2.6 - 2.7 mpg
Overall my mileage is probably similar to that as I usually do some running at higher speeds and of course some at lower speeds.
jimh posted 09-08-2011 09:44 AM ET (US)     Profile for jimh  Send Email to jimh
My trip average fuel figures are obtained by using the GPS receiver and chart plotter to log the miles, and using a fuel manager function to accumulate the fuel flow data during the same period into gallons used. The last two long cruises have been averaging between 3.0-MPG to almost 3.2-MPG.
This method is in opposition to the method were the distance is estimated by looking at a chart and the fuel use is derived from how much gas you buy at the fuel dock. Both of those measurements tend to be subject to inaccuracy.
The average fuel economy is influenced by the average boat speed, and the faster we go the worse the fuel economy. This is the opposite of many of the boats with older motors, who will tend to always want to go fast, at their optimum cruising speed, because their motors run most efficiently in that relatively narrow speed band. My motor has quite a wide range of planing speed where it is efficient.
In my case I think I have worked out the most fuel efficiency I can in the boat set-up for my type of use. The only options for me to save more fuel would be to change boats to something that was lighter and had a hull surface optimized for efficiency. There may be some savings in a different motor if I went with a naturally aspirated four-cycle engine of moderate horsepower. That might add a few more percent improvement.
ASIDE: I recently was gazing at the MJM 29, a very nice cabin boat which can achieve 3-MPG at its cruising speed (25-nautical miles per hour), quite remarkable fuel efficiency compared to these Boston Whaler boats. The MJM 29 has a hull designed for good planing efficiency, uses diesel power, and is built rather light and strong with exotic laminates to save weight. You pay for that; it's an expensive 29-footer at $300,000.
jimh posted 09-08-2011 09:49 AM ET (US)     Profile for jimh  Send Email to jimh
newt says about my MPG"
"On another note, given the small data set we have so far and considering that your boat has a Whaler Drive, it would appear that you obtain the best overall fuel economy among the reporting 22 foot hulls."
I think jimp reports much improved fuel economy. He runs in much colder water and generally colder air, and his boat does not have the Whaler Drive.
newt posted 09-08-2011 12:25 PM ET (US)     Profile for newt  Send Email to newt
I was thinking that since Jimh's boat has the Whalerdrive, and probably typically canvas in the up position, that his fuel economy figures were most impressive among the 22' hulls
For sure Jimp shows great numbers, as do most of the Optimax equipped boats.
newt posted 09-08-2011 12:28 PM ET (US)     Profile for newt  Send Email to newt
My economy numbers in the original post are based on distance recorded by GPS, and fuel consumed as measured using Lowrance EP-60R fuel flow sensors coupled to a Lowrance LMF-200 gauge. I have not yet checked the accuracy of the EP-60R fuel flow sensors though.
martyn1075 posted 09-08-2011 12:30 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
I would say jimp is getting phenomenal milage for that setup. I had the same boat 1990 22 Revenge even had the 225 2000 Optimax and I struggled to get decent milage for mine. My haul was dry and sound. I do suspect my engine was not operating like it should and I think that was the problem. 3.0 mpg is excellent and I always figured was more like what I should be getting but never could.
Tohsgib posted 09-08-2011 02:31 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I would expect better than 3 with a modern engine. My 20' Hydra-Sports with a 1994 Johnson 225 carbed gas hog would fetch 2.8+ at cruise. With a modern engine I would guestimate 3.7 at 31mph. She toped out at 50+ with a T-top and bottom paint and only 1 hole up which I later changed. Then again not many 20' Outrages are running 225's here to make it comparable.
jimp posted 09-08-2011 03:39 PM ET (US)     Profile for jimp  Send Email to jimp
The Glacier Bay trip in 2005 was fun and exceptional (in regard to the weather we had). As you can see by the photos in the link it was flat calm. For this trip, with the load, we were cruising at 3,900 RPM. Depending on current, we ran from just under 29 knots to over 30 knots.
http://smg.photobucket.com/albums/v395/jimp/Kelsey%20J/ Glacier%20Bay%20Cruise%202005/?start=all
The best the boat has gotten is 3.2 nmpg (that's nautical, not statute). With the 19" MiragePlus propeller we continually cruise at +29 knots at 3,750 RPM and the Merc SmartCraft gauges show anywhere from 9.3-9.7 gph.
JimP
makoman310 posted 09-08-2011 05:58 PM ET (US)     Profile for makoman310  Send Email to makoman310
did a trip on my 22 outrage wd with 250 verado ran 26 miles 5000 rpm cruising 39mph burned 10 gals on smartgauge return trip back going into west wind 20kns 4500 35mph burned 11gals
Tohsgib posted 09-08-2011 08:30 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Ok...so we are ALL on the same page, can we PLEASE post statute MPG which is what I go by and so do many magazines. We can go by "as the crow flies" but again I think we should stick to statute which is what many are doing if going by 100 miles and I burned 8 gallons, that is usually statute.
Tom W Clark posted 09-11-2011 05:51 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Boat -- 1988 Revenge 25 Walk-Through, full Mills canvas (up), RADAR arch
Engines -- Twin 1989 Mercury 2-stroke 150's
Fuel economy -- 2.3 MPG (2 NMPG)
I have verified this many, many times by calculating the GPS measured boat speed divided by the FloScan measured rate of fuel consumption.
Additionally, I have measued this fuel economy by dividing the miles traveled between Seattle, WA and Neah Bay, WA by the number of gallons of fuel used, on two occasions as well as countless trips between Seattle, WA and Bainbridge Island, WA.
The catch? The motor speed must be kept between 4000 and 4500 RPM to the greatest extent possible to achieve this optimal fuel economy. At 4200 RPM my boat is doing about 35 MPH (30 knots).
Like Jim Potdevin, I find the Mercury MIRAGEplus propellers provide excellent fuel economy.
newt posted 09-12-2011 12:37 PM ET (US)     Profile for newt  Send Email to newt
Among the old 2-stroke powered 25' Whalers, Tom and Larry, with Mercury engines and Mercury Props have blown away Dave and myself with our OMC engines, and (in my case) OMC props in the 25' Whaler catagory.
I guess a pair of Mirageplus props are in my future for testing.
jimh posted 09-12-2011 08:34 PM ET (US)     Profile for jimh  Send Email to jimh
With two-cycle engines you have to run them at the sweet spot of fuel economy to get any sort of decent fuel economy. Once you install a real-time fuel flow meter and accurately monitor fuel economy, the engines start to dictate what the boat speed will be.
The alternative approach is to never really accurately measure fuel economy and just throw out some numbers that sound about right.
L H G posted 09-13-2011 01:26 AM ET (US)     Profile for L H G
The Mercury 2.0 - 2.5 liter 60 degree Vee, loop charged, 2-strokes get pretty good fuel economy, much better than those old design 90 degree Vees from OMC. My experience indicates that EFI improves fuel economy also over the carburetor versions. The later Optimax 150's also get great fuel economy on this same block
I doubt if switching to Mercury Mirage Plus props, as good as they are, will do much to improve the economy of those OMC 90 degree Vees. They were all fuel hogs. Their later 60 degree Vee's, around 1992 and later, get much better economy.
Buckda posted 09-13-2011 07:44 AM ET (US)     Profile for Buckda  Send Email to Buckda
Tom and Larry have reported "at cruise" figures. My report is "overall" including slow speed operation, where the performance of a carberated 2-streoke is truly lackluster.
Apples to oranges. I am confident I could obtain better than 2 mpg once I have my boat cleaned up and dialed in. I also note I was running with a "to-the-gills" loading for a week of camping on Isle Royake.
Tom W Clark posted 09-13-2011 10:38 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Actually, my trip-computed fuel mileage is all-inclusive of slow speed operation as well, I have just learned to minimize my slow speed operation if I am trying to get somewhere.
Discussion of trolling speed fuel economy is a separate discussion, and my motors do not do well in that arena.
Buckda posted 09-13-2011 11:30 AM ET (US)     Profile for Buckda  Send Email to Buckda
Tohsgib posted 09-13-2011 01:27 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Dave has been eating Parrot food again ;)
Buckda posted 09-13-2011 08:53 PM ET (US)     Profile for Buckda  Send Email to Buckda
Sorry about that. I posted this morning via my blackberry, and apparently "reposted" this afternoon when checking this thread from that same device. Usually, if there are spelling errors in my post, it is due to "thumby business" via mobile device.
Tom - I apologize, as I re-read your post and realized that you didn't report "at cruise" specifically as others in this thread have.
I may be investing in a fuel flow meter over the winter to provide a more accurate "real time" measure of my economy and dial in the cruise speeds and maximizing time run at the most efficient speeds, but my cruising usually involves other boaters and very scenic locations that I may not have seen before, so slow speed operation is often necessary, or desired. That and the fact that I don't have a fuel flow meter means I have to rely on an "overall" economy figure derived from careful measure of distance (via gps) and fuel used (by starting with a full tank and finishing with a full tank).
jimh posted 09-13-2011 10:27 PM ET (US)     Profile for jimh  Send Email to jimh
The absolute best way to remain optimistic about the fuel economy of your older two-cycle outboard engine is to just never measure it. Keep telling yourself it gets really good fuel economy and don't install a fuel flow transducer. Once you install a fuel flow transducer and actually measure fuel economy, you will have report the actual fuel economy like the rest of us have done. Better to keep yourself in the dark and avoid the truth.
martyn1075 posted 09-14-2011 01:21 AM ET (US)     Profile for martyn1075  Send Email to martyn1075
Is it abnormal to get better milage at lower speeds? I am talking in the 21-23mph range? I seem to be getting better mpg at these speeds. I also use a flow meter.
jimh posted 09-14-2011 08:01 AM ET (US)     Profile for jimh  Send Email to jimh
With older two-cycle motors it is normal to find the best fuel economy comes in a narrow range of speed when the boat is on plane and the engines are running around three-quarter-full throttle. Even an older two-cycle engine when running at its optimum brake specific fuel consumption (BSFC) is capable of delivering reasonable fuel economy for the boat speed that usually results.
Exactly what the boat speed will be when the engine BSFC peaks depends on the boat, the load, and the engine. For boats with plenty of horsepower, for example for Tom Clark's REVENGE 25 with 300-HP in the form of twin engines, the speed at which best fuel economy occurs may be a rather fast planing speed. Tom reports his best fuel economy occurs around 35-MPH.
On boats with more modest power, for example on my REVENGE 22 W-T Whaler Drive with 225-HP, the optimum boat speed for best fuel economy may be slower. Mine was around 28-MPH.
And for boats with really high power, such as L H G's OUTRAGE 25 with 400-HP, I don't have a good feel for fuel economy because I have never seen any actual measurements of fuel economy from L H G. He does not have any way to measure his fuel economy at various speeds. If you do not have a fuel flow sensor you cannot measure fuel consumption in real time. Without measured data we have nothing to compare.
It would be unusual, in my opinion, that the optimum boat speed for fuel economy on a moderate v-hull boat like a Boston Whaler would be as low as 21 to 23-MPH. It is my experience that the 22 to 27-foot Boston Whaler hulls are not easily maintained on plane at those speeds. The hulls are just coming onto plane at 21-MPH. They like to run faster to stay on plane. Because of that, I would be surprised to see that a series of careful and accurate measurements showed that 21 to 23-MPH was the peak of fuel economy for a 22 to 27-foot Boston Whaler hull.
I do not believe for a moment L H G assertions that OMC two-cycle engines are all fuel hogs compared to Mercury two-cycle engines. That is just another example of L H G's brand blindness, and appears to be based not on actual measurements or well-controlled comparison testing but on faith.
Boats with twin engines can perhaps gain a bit of an edge in fuel economy from use of propellers with higher pitch. For example, my REVENGE 22 W-T Whaler Drive often ran with a 15-pitch propeller. I think Tom's REVENGE 25 with twin engine runs with 19-pitch propellers. At cruising speeds with twin engines the higher pitch propellers allow the twin engines to run at a lower speed than the single engine turning a lower pitch propeller. This certainly helps with fuel economy at cruise. Also, at displacement speeds, boats with twin engines can operate on only one engine. This cuts their fuel consumption in half. The higher pitch propeller helps at displacement speed to improve fuel economy because the boat speed will be higher for engine idle speeds. These effects tend to enhance fuel economy with twins. Whether this overcomes the added drag of twin gear cases in the water is something to be discussed and analyzed, but one would need some real measurements and good testing to have a real basis to determine the truth.
L H G posted 09-14-2011 06:17 PM ET (US)     Profile for L H G
I don't really care whether anybody reading CW believes me or not, for as far as I am concerned my boats speak for themselves. I give you what I know and have learned over 40 years of "Whalering", and you can decide if it's worth anything or not.
As an example, I have found the tank mounted, direct reading fuel gauges that Whaler in these used in these Outrages give EXCELLENT repeatable accuracy. Maybe you disagree with that finding.
I have also found that NOAA marine charts are highly accurate on distance measurements and scale accuracy, if you have a good ruler to measure what they are showing you!
With that in mind, I recently ADDED 20 gallons of fuel to my 25 Outrage with twin 200 Mercs, the boat indicated in a prior post, in the Traverse City, MI Municipal Marina.
I noted exactly where the fuel gauge was reading prior to the addition. Mills full canvas set, providing additional wind drag.
We then ran the boat, non-stop, up to Irish Boat Shop's (a Whaler Dealership) Ferry Street Marina in Charlevoix MI, at times running in seas as high as 6' with 20-25 knot cross winds. Some no-wake idling was also involved out of Traverse City and from the Charlevoix Channel entrance through Round Lake. I always idle on only one engine. Cruising speed out on the big Lake was between 25 and 28 MPH (per GPS), and about 2500-2800 RPM's on the tachs. This is not the most efficient running speed for my 25, but that is what we had to do under those conditions.
On arrival back at our slip, with boat still in the water, looking at the floor fuel gauge, I noted that I had not quite used all of the 20 gallons I had added, but it was close. I also figured, from the Chart, that we had run pretty close to 50 statue miles, but not as the crow flies obviously.
So, for this trip, I figured the Merc 200 EFI's fuel economy for these various speed averaged, at 2.5 MPG. Maybe it was somewhere between 2.4 - 2.7 MPG, who cares, but 2.5 is a good enough figure for me to rely on when cruising in reasonably decent weather.
And I think 2.5 MPG is a reasonably accurate figure to give Newt in response to his question. Incidentally, of the 5 Mercury powered Whalers that I own, this boat gets the worst mileage of them all, not to be unexpected since it is the largest, heaviest and highest powered.
jimh posted 09-14-2011 09:20 PM ET (US)     Profile for jimh  Send Email to jimh
Boats, no matter how fabulously cared for, cannot tell you their fuel economy at various speeds by themselvles. The only way to know that is to have a fuel flow sensor and a good speed measurement. It was only when I installed a fuel flow sensor on my boat that I discovered what its real fuel economy was. Until then, I had only a vague impression.
martyn1075 posted 09-14-2011 09:43 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
This whole thread has really gained my interest in what I am personally burning from the beast that we own. Sadly where we live the season is ending so I plan on adding a little fresh fuel with stabilizer and performing a few tests. I hoping to see a better result at higher speeds cause to be honest I like to move faster than 22mpg. The boat can fly with the current power but I would like to see more of a savings at the 30mph which usually is around the 4000 rpm.
Martyn
prj posted 09-15-2011 09:30 AM ET (US)     Profile for prj  Send Email to prj
quote:
Boats, no matter how fabulously cared for, cannot tell you their fuel economy at various speeds by themselves.
While this is true, its relevance to newt's specific request in this thread is minimal. Newt has requested "average fuel economy" and Larry, with his "fabulously cared for" boats has provided exactly that.
I can think of no more accurate measure of average fuel economy as expressed in MPG than one provided by dividing miles traveled by gallons used. Matter of fact, MPG is the very result of that equation.
Tom W Clark posted 09-15-2011 09:39 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Martyn -- What propellers are you using? On my boat, I improved the fuel economy by 15 percent when I ditched the original aluminum props for the Mercury MIRAGE[i]plus[i/]s.
I am surprised your fuel economy is not better at higher speed, especially considering your 450 total horsepower.
martyn1075 posted 09-15-2011 11:46 AM ET (US)     Profile for martyn1075  Send Email to martyn1075
Tom they are Mercury Enertia props 19 pitch. The boat came with a extra pair and I believe they are Mirage plus. I am a bit guilty of running them a tad on the slow side at times. The boat is on plain and not straining I know this as well I change speeds all the time but perhaps they were made to run a little faster and should dial them in a little higher them my comfort zone. I am going to find out good or bad this week hopefully if I can get out.
L H G posted 09-15-2011 02:27 PM ET (US)     Profile for L H G
Thank you for your support, PRJ.
As a matter of fact, I was going to say that I have found fuel flow sensors to not be that accurate, at least on my Cadillac STS. I can't imagine marine ones are any better. It consistently gives me wrong readings when I measure MPG the old fashioned way, the way our grandfather's did it, which is still THE MOST ACCURATE way.
Fill the tank, drive a distance on your trip until you need gas again, fill the tank back up, divide miles traveled by gallons used. No fuel flow sensor is that accurate.
That is the same system I use on the boats, and I'm sticking with what I calculated on the Traverse City trip mentioned above.
L H G posted 09-15-2011 02:30 PM ET (US)     Profile for L H G
Tom - I also improved my fuel economy when I switched from the small blade surface 23" Laser II's to 21" Revolution-4's. They made a huge difference in the overall performance of the boat.
Tohsgib posted 09-15-2011 03:03 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Larry I found my STS to be off by about 1mpg, not too far off from the ole fashioned way. I also find that car speedos are not accurate so make sure you GPS your car and find out how close you are. If you are 2% off the GPS you need to add or subtract 2% from your total mileage so 200 miles would be 196 miles by # of gallons. Today most car computers use the injectors to flow fuel which is pretty darn accurate but check your speedo. In older cars they used vacuum which in my opinion was good for +/-10%.
Jim I don't agree with your statemnet unless it was YOUR meter that we are discussing. If ANYONE on the blue planet has his flow meter dialed in to the very drop of fuel it would be you. I bet most people however take them out of the box and reley on the its accuracy without doing much or any calibration....same goes for compasses by the way people.
Personally you get a GPS and a place you want to run to that is at least 1/2 hour away. Once on plane and at cruise you switch to a 3 gallon tank and hit the stopwatch. When the tank runs dry you note distance, speed and time divided by your 3 gallons and you will get a VERY accurate cruise mpg estimate.
martyn1075 posted 09-15-2011 03:24 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
My Flow meter came with the boat. I like it for the reason of fuel management. I know what I have put in and what I have burned. I find it to be pretty accurate that way. The tank is so bloody big and fuel burn is not fabulous at times I tend to burn fuel pretty good and although the smart craft meters are decent they are not a good way of measuring gas usage imo. The gas meter for the tank is ok but how accurate is it. Im my boat I wouldn't dare trust it because the gas burn could be crappy one day perhaps in rough sea conditions whatever and I may get stuck out there with red cheeks embarrassment. The flow meter gives me good reading I would trust in conjunction with the other meters.
Tom W Clark posted 09-15-2011 10:35 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
What is an STS?
jimh posted 09-16-2011 08:58 AM ET (US)     Profile for jimh  Send Email to jimh
There is absolutely nothing wrong with getting an average fuel economy by using the total fuel consumed on a trip and the total distance run. That is precisely the method I employ when I present a figure that is my average fuel economy for a particular voyage or trip. The accuracy of such a figure comes from the methods of obtaining those measurements: fuel used and distance run.
Distance deduced from pacing off lines on a chart is not likely to be as accurate as distance recorded by a GPS receiver on the vessel which tracked the course line.
Fuel used deduced by relying on a fuel tank level float gauge as a precision indicator is not likely to be as accurate as fuel consumption measured with a flow sensor or other fuel flow device.
Modern instrumentation can greatly increase the accuracy of fuel tank level float sensors by using a calibration process. The mechanical dial indicator on a Boston Whaler fuel tank is not calibrated. In fact, L H G himself presented a procedure for calibration of his fuel tank level float gauge which involved carefully filling of the tank and recording of the fuel at various levels. However, in this regard, I doubt that the repeatable accuracy of the fuel tank float and the dial calibration of the gauge can match the accuracy of good flow sensors or other fuel flow measurement techniques.
As for car fuel flow measurements, my current 2011 vehicle is uncanny in its accuracy in both the measurement of fuel flow and the level of fuel remaining in the fuel tank. I have pulled into a fueling station with the on-board fuel manager showing I have only enough fuel left for 10-miles of travel. Using my average of 30-MPG this implies about 0.3-gallons in the tank. When I fill the tank the pump indicates I have instilled an amount of fuel into the tank that is within 0.3-gallons of its rated capacity.
jimh posted 09-16-2011 09:01 AM ET (US)     Profile for jimh  Send Email to jimh
I see that L H G has agreed with me in his car example. He relies on the car's odometer to record the mileage. He does not pace off the mileage from a map. [I also see he does not rely on the tank level indicator in his car. This is also at odds with his boat method.]
Tohsgib posted 09-16-2011 11:33 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Tom-STS is a Cadillac.
Jim-I am amazed that you would push the envelope to leave only .3gals in your tank. I freak when the light comes on.
LHG-I bought a new to me 24 Baja and ran it for a few weeks before season ended in NJ. The day I pulled the boat it was literally 3-5' in the bay blowing way more than small craft and NOBODY in sight for my 20 min run. In the spring I filled it up and the gauge read 1/4+. It took 97.3gals in a 100 gal tank. I NEVER went by a gauge again, I almost lost the boat that day as NO anchor would have held if I ran out of fuel. Make sure you know your gauge people!
Lastly-My Donzi has 2 gauges. 1 on the dash that is not worth it's weight in tin although a VDO. The sender on the tank is pretty accurate though. Unfortunately I can't read it while driving as it is under a plate. My Revenge the sender broke about 4 years ago. I just fill it up every 3rd trip with about 15-25gals out of the 40.
jimp posted 09-16-2011 11:43 AM ET (US)     Profile for jimp  Send Email to jimp
The difficulty with using boats and cars is that cars travel on a roadway and boats travel in water and water has currents running with you (your GPS tells you that you are going faster and covering more ground)or against you (your GPS tells you that you are going slower and covering less ground). Or you adjust your RPMs to tell you something. There are other "vectors" working on you besides tires and asphalt. Throw in some wind and waves for fun too. Calm water, your boat runs smoothly. Add some waves and each one of them (head seas, astern, abeam, quarter, etc) slows you "some amount" as they are hitting the hull and causing resistance.
For a very rough example:
For a 10 mile trip (11.5 statute) at 10 knots (11.5 mph) with no current, you travel 10 miles (11.5 statute)through the water. 1 hour. The chart & GPS say you covered 10 miles (11.5 statute).
For a 10 mile trip (11.5 mph) against a 1 knot (1.15 mph) current at 10 knots (11.5 mph), you travel 11 miles (12.65 statute) THROUGH THE WATER. 1 hour 9 minutes. The chart & GPS say you covered 10 miles (11.5 statute)
For a 10 mile trip (11.5 statute) with a 1 knot (1.15 mph) current, you travel 9 nautical miles (10.35 statute) THROUGH THE WATER. 54 minutes. The chart & GPS say you covered 10 miles (11.5 statute).
Regardless, one trip doesn't necessarily define you mpg. I swithched props at the start of the season, from a MiragePlus 19" to a MiragePlus 17", and increased my cruising RPMs from 3,750 to 4,200 RPMs and my cruising spreed from 29.3 knots (33.7 mph) to 30 knots (34.5 mph). My SmartCraft gauge tells me I used about 99 gallons of fuel for the season (the Kelsey J is now under a tarp, winterized and we're on to the next project of remodeling the kitchen and dining rom, UGH!). I covered aproximately 290 miles (333.5 statute) and ended with about 2.93 nmpg (3.37 mpg).
As L H G stated on the 14th at 6:17 PM "good enough" is the answer". Overall, this summer, 2.9 nmpg is "good enough". A bit worse with the 17" than the 19", but the 2003 225 Optimax is WAY better than the 1989 225 carbed Johnson (roughly 50% better).
And yes, I use nautical miles and knots because I grew up that way and my charts are in nautical miles. Conversion 1 nautical mile = 1.15 atatute miles.
JimP
martyn1075 posted 09-17-2011 02:49 AM ET (US)     Profile for martyn1075  Send Email to martyn1075
I had a good night of testing took the advise and pushed the boat faster then usual and the results were way way better. My boat is not abnormal at lower speeds and does not achieve better gas milage as I thought. Its ok but tonight 4000rpm engines tilted brought me to average 28.8 on the GPS my flow meter burned almost 4 Liters and a total trip of 2.8NM at this speed. If I have done calculations properly I was getting 3.6mpg. I am pleased but one test is not good enough to make an average I will work at it some more this weekend.
jimh posted 09-17-2011 09:38 AM ET (US)     Profile for jimh  Send Email to jimh
jimp is both right and wrong about the GPS measurement of distance. The GPS will always get the distance over the bottom correct. That is really what it is measuring--distance over ground. The only thing the GPS will get wrong is the speed through the water.
Jim's observation of a 50-percent improvement in fuel economy when changing from a classic two-cycle to a modern engine is in the same ballpark as mine; I observed about a 67-percent improvement.
Even a process which has some error can produce an accurate measurement if the error is random and if the measurements are made over and over. A truly random error will tend to cancel itself if enough measurements are made. A classic example is the measurement of the height of Mount Everest. The height of Mount Everest was measured by a survey party who began from sea level and worked inland. They made thousands and thousands of measurements of elevation. The error in their measurement process was random, and it did not produce a significant error in the final outcome. Some climbers took a precision GPS to Mount Everest. The elevation obtained was within a few feet of the traditional value from the survey 100-years earlier.
The problem I see with boaters and their boat fuel economy is that there is not a random error. The people making the measurements often have a tendency to influence the direction of the error or imprecision in a favorable way. The measurements made by devices like a GPS receiver for distance and a fuel flow sensor for fuel flow are typically impartial, and they are not disposed to be biased.
There is certainly room for error in any method of measurement, and electronic measurements are not immune to error. However, I find them more impartial.
jimp posted 09-17-2011 10:32 AM ET (US)     Profile for jimp  Send Email to jimp
JimH -
Correct.
I wrote it wrong. What I meant by "covering more ground" was referring to speed. Could have said "covering more ground (or less) "at the greater (or less} speed in the same amount of time." Or something like that. And GPS does get the distance right over the bottom.
Anyway, a 1-knot current at 20 knots can give you roughly a 5% error. At higher speeds, there is less impact.
And with normal cruising/dayboat mode with the 19" MiragePlus I was up to 3.2 nmpg (about 3.68 mpg) and a roughly 63% increase over the old 225. Needless to say, the new engines are a lot better than the old.
JimP
Tom W Clark posted 09-17-2011 11:29 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Martyn -- Covering 2.8 NM with 4 liters of gas is 3 MPG or 2.65 NMPG, a amazingly good rate for a boat as large as yours.
What was the rate of consumption, per your fuel flow meter, at 28.8? Is that 28.8 MPH or 28.8 knots?
martyn1075 posted 09-17-2011 11:59 AM ET (US)     Profile for martyn1075  Send Email to martyn1075
Tom I know its seems too good to be true. I will be back at it today or tomorrow for more testing to make sure this is actual reading rather then just a one time or a mistake on my part. I will have to check the data on if its knots. The GPS shows both it determines and average overall and a top speed achieved in your route. I think it may be knots however. The bottom figure on the GPS I truly believe is MPH and its was 30.2. I reported my test as an average because it seemed to be fair rather then a top speed that may have only been for a minute of the trip.
I think you are right the 4000rpm seems to make a huge difference for these engines as well the way a bigger boat operates with them. There really was not to much in between the low speeds at 23mph and the 28-30 mph range. Its like another gear in a car.
Buckda posted 09-17-2011 04:12 PM ET (US)     Profile for Buckda  Send Email to Buckda
- L H G on 9/7/2011
Then the story changes...
quote:
I recently ADDED 20 gallons of fuel to my 25 Outrage...I noted exactly where the fuel gauge was reading prior to the addition.
On arrival back at our slip, with boat still in the water, looking at the floor fuel gauge, I noted that I had not quite used all of the 20 gallons I had added, but it was close. I also figured, from the Chart, that we had run pretty close to 50 statue miles...So, for this trip, I figured the Merc 200 EFI's fuel economy for these various speed averaged, at 2.5 MPG.
I don't believe that finding a spot on the tank indicator is as accurate as filling the tank to full to measure economy. Granted, neither method is as accurate as using a fuel flow meter, but Larry doesn't like them; however, he does agree with me about filling the tank to full to get an accurate measure of fuel used.
I'm glad that L H G agrees with me on the second most accurate way to measure overall fuel economy, however, I believe his original post above defends my position that he reported "at cruise" economy. Given the information I had, that was an accurate assessment.
I find it difficult to believe that normally aspirated 2-stroke Mercury and OMC motors deliver vastly different fuel economy figures. I think we're seeing the difference that comes from propeller selection, motor mounting method, operational differences (speed, conditions, etc) and variations in the quality of data reported (and that includes mine, however, I provided my data collection method in my original post).
One thing is for certain, with apologies to Hoosier and Jimh in future cruising....I'll be running my 25 Outrage a heck of a lot faster than I have been to obtain better economy.
Tom W Clark posted 09-17-2011 04:28 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Yes, I agree that the most accurate way to determine fuel mileage is to divide the distance travelled by the quantity of fuel used. There can be no argument over this point. As Pat pointed out, that is exactly what MPG is.
However, measuring how much fuel has been used leaves open many chances for error. As the owner of a 25 foot Whaler I can tell you that the 140 gallon tank's float gauge is a poor tool to use to figure out when 20 gallons has been used.
I use a calibrated FloScan fuel flow meter in my boat and it's accuracy is superb. I always fill my tank full...at the same gas station...with the boat parked in front of the same pump...pointed in the same direction. I usually put 110-125 gallons aboard and the FloScan totalizer never varies from the amount of gas I pump by more than a gallon, many times it is within a few tenths of a gallon.
When I report rate of fuel used, you can trust my data.
Tom W Clark posted 09-17-2011 04:37 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Sidebar discussions aside, I am glad this thread appeared and again allowed the point to made that often, contrary to intuition, the best fuel economy in a large Boston Whaler can be achieved by going faster not slower.
I too do not believe there is as profound a difference in fuel economy between twenty year old OMC outboard motors and twenty year old Mercury outboard motors as the data presented so far suggets. Propeller selection, motor mounting height, cruise speed and trim all come into play to achieve optimal fuel economy and many here would do well to study the subject in greater depth. Too many older Whalers are simply not well set up.
While the new modern outboards obviously offer many, many advantages, fuel economy not least among them, there are significant opportunities for owners of older outboards to vastly improve their boat's performance with very simple and inexpensive modifications.
martyn1075 posted 09-17-2011 05:25 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
Tom I agree and I will add the way an owner drives their boat is key as well. I now think I have been a little passive and although not harming the engines I was not driving it the way the engines were designed to be driven for best performance with the current power configuration. I thought I was saving more money in gas by laying off and that has proven not to be the case.
I have had the beast for about two seasons and I am still in a learning curb with it. If one wants to get real technical with data it will take along time to perfect.
It seems you have great control over your 25 and know what it takes and what it will give back in return. I am not there yet with mine. Of course its easy just to put gas in and go but different seas with a different load, full gas tank half tank these all come into play that will determine your AVERAGE MPG. and in a big heavy boat like mine I think may vary quite a bit. I was pleased with last nights performance though.
Tohsgib posted 09-18-2011 10:49 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Funny that nobody has posted this:
Back in the dark ages when I ran old technology outboards, I used to cruise at their "happy" speed. Happy speed was when your engine quieted down and the hull ran flat with a nice flat wake...you could hear it and feel it. Today with 4 strokes that is not really possible as they are always happy and quiet. Can't speak for DFI's. I think the EFI is part of it as well as there is no transitions from low speed to high speed jets, etc. Basically I cruise at 41-4200 @ 25-26mph in the Revenge as it seems happy there and from what I have read, should be a good spot to be at.
The faster the boat the better the MPG obviously and hence why LHG gets such good results. People are shocked when I tell them my 454CID 330hp Donzi gets roughly 4mpg at cruise. I think it is pretty amazing myself considering my friend's 454 240hp? powered Suburban 4x4 only gets 7 on the road.
martyn1075 posted 09-18-2011 12:17 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
If anyone can get 4MPG they are doing just fine in any GAS propelled boat imo. especially if you can get up to the speeds of the Donzi.
Tohsgib posted 09-18-2011 01:39 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Scary thing is it get about 2.5mpg at full throttle. Just like modern engines the I/O's get good mileage at slow speeds as well. This is one reason why I/O's were so popular over outboards. Now that we have modern outboards and I/O's are having EPA problems/costs, many companies are starting to sell outboard versions. They had a comparo in Boating a few months back. What always amazed me was how well small boats performed with I/O's. A 18 SeaRay with a 4 banger will do like 40 even though the engines weighs like 800lbs with the drive. Put 800lbs in a 18' Whaler and see how well it performs. My 454 weighs like 1189lbs.
WT posted 09-18-2011 02:22 PM ET (US)     Profile for WT  Send Email to WT
My last mpg measurement was a long distance trip from Sacramento to San Francisco and I averaged 7.14 mpg with my 170 Montauk. 93 miles and used 13.02 gallons. I measured my fuel usage the old fashioned way, filled up my tank before I left and filled up my tank in San Francisco. Distance measurement was with GPS.
I have a hard time cruising under 30 mph if I have the opportunity to cruise faster. Well, I suppose I'm not cruising when I'm going faster.... :-)
Warren
WT posted 09-18-2011 02:37 PM ET (US)     Profile for WT  Send Email to WT
Maybe it's time to downsize from the larger Whaler hulls? :-)
Warren
Tom W Clark posted 09-19-2011 10:27 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Warren -- It makes sense that your boat would get 7.14 MPG. That is more than three times the fuel mileage I get with my Mercury powered Boston Whaler.
My boat has more than three times the horsepower of your Whaler. My boat weighs more than three times the weight of your Whaler. So it seems logical that it would take three times as much energy to move it a given distance.
The only puzzling thing is, my Mercury outboard motors are two strokes with carburetors and are 21 years old. How old is your Mercury outboard?
WT posted 09-20-2011 12:49 AM ET (US)     Profile for WT  Send Email to WT
My current motor is 4 years old with about 400 hours. My 2004 170 Montauk has about 800 hours with both the old and current motor.
How many hours on your 21 year old motors?
Warren
Tom W Clark posted 09-20-2011 10:40 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Collectively, about 1600.
jimh posted 09-20-2011 09:54 PM ET (US)     Profile for jimh  Send Email to jimh
I have re-evaluated my fuel economy data using the techniques presented here by others. I measured the distance by eyeballing it on a chart. I measured the fuel flow using the tick marks on my fuel gauge. I am now pleased to announce that my boat is getting 3.75-MPG using this new method.
martyn1075 posted 09-24-2011 10:48 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
I have had the boat [which was not identified specifically, but apparently, based on the weight cited, must be the 1990 Boston Whaler 25 Walkaround with twin 225-HP engines of unspecified type. Dig into earlier positings to find out exactly what is being talked about here--jimh] out about three times and have re-tested it at the same settings as first recorded. One time I had 3.1-MPG; second 2.7-MPG; and the third time 2.9-MPG. I would say it [is] safe to say my average is about 2.8 or 2.9-MPG at 29-nautical-miles-per-hour [apparently over a distance of] 2.0-nautical-miles [and at an engine speed of] 4,000-RPM. [The wieght is ] 8,500 to 9,000-lbs [for the] boat with twins DFI motors.
Martyn
vin1722or posted 09-25-2011 09:51 AM ET (US)     Profile for vin1722or  Send Email to vin1722or
I have a 1979 [Outrage 22] with twin 1987 [Yamaha] V4 115-HP [two-cycle outboard engines]. At cruise [with an engine speed of] 3,500-RPM they are burning 11 to 12-GPH while running at 32-MPH. [Fuel economy] is [3-MPG] in ideal conditions. Trimmed out, no tabs down at all, with 2 adults, 70-gallons of fuel onboard, with a 10 to 12-MPH wind when tested. We used a FLO-SCAN to generate these results.
Tom W Clark posted 09-25-2011 01:56 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
[A boat speed of] 32-MPH at 11 to 12-GPH is [an average of] 2.78-MPG. Wow, that is pretty good for a pair of old 115's on an classic 22. Likewise, 2.85 MPG on a 25 Walkaround (widebody) with 450 HP is amazing.
jimh posted 09-25-2011 04:11 PM ET (US)     Profile for jimh  Send Email to jimh
Thanks for the data with the FLO-SCAN as the fuel measurement device. I don't know that every FLO-SCAN is precisely and absolutely accurate, but they certainly do tend to give repeatable results. I know Tom has verified his FLO-SCAN to be accurate within about one-percent when compared with a highway fuel station pump. Getting agreement between two measurements with only one-percent difference tells me that the two measuring devices are probably both well calibrated.
Devices like a FLO-SCAN seem particularly well suited for older two-cycle engine fuel measurement because the older engines still have substantial fuel low at lower engine speeds. I found that I could NOT get accurate fuel flow readings with a fuel flow sensor at low engine speeds because my direct fuel-injection engine used very little fuel at those speeds, typically less than 0.2-GPH flow. The turbine sensor was not very accurate at those flow rates, and tended to indicate a fuel flow that was lower than actual.
At higher fuel flow rates, such as reported for twin engines of 225-HP running at 4,000-RPM, the fuel flow rate should be large enough that a device like a FLO-SCAN is in a measuring range where it can be very accurate.
I am surprised that twin 225-HP engines running at 4,000-RPM only consume a total of 12-GPH. If we use a figure for brake specific fuel consumption of 0.5-lbs/HP-hour, this implies that a flow of 12-GPH would be producing
12-gallons x 6.25-lbs/1-gallon x 1-HR-hour/0.5-lbs = 150-HP
Is that a reasonable amount of horsepower to reach 32-MPH with a 1990 Boston Whaler 25 Walkaround?
Tom W Clark posted 09-25-2011 04:25 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
jimh edited Martyn's post from 9-24-2011 at 10:48 PM EDT thus:
quote:
...[The wieght is ]...
Jim -- The word is spelled weight not wieght[/b]. Since you love correcting trivial errors and then broadcasting the corrections to the world, I am sure you appreciate my bringing this mistake to your attention and sharing it with everybody.
[This is really rather funny. In the process of making a big deal out of my typo, Tom also made one. Tom--I did not use the orphan tag "[/b]" in my article. I think you made a little boo boo in your article. It's not that hard to do--jimh]
martyn1075 posted 09-25-2011 10:58 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
Yes Tom Thank you.. I am happy with the results the boat is now going into hibernation now after a short season but I want to test its milage on a much longer trip and on a tank with more fuel. We will see if that will change the figures. The last three times out the (WEIGHT) configuration was slightly different with gear etc but the results were in the ballpark each time.
Peter posted 09-26-2011 07:19 AM ET (US)     Profile for Peter  Send Email to Peter
A single Optimax 225 propped correctly running at 4000 RPM should burn fuel at a rate of between 10 and 11 GPH. So two Optimax 225 propped correctly running at 4000 RPM will burn between 20 and 22 GPH. If two Optimax turning 4000 RPM produce a boat speed of 32 MPH, then the expected cruising MPG at 32 MPH would be between about 1.5 and 1.6 MPG.
A DFI 2-stroke outboard will produce better instant MPG at off-plane boat speeds than on-plane boat speeds -- the opposite of what a carburated or EFI 2-stroke does. It would not surprise me to find Martyn's 25 Walk Around off-plane (5 MPH or under MPG) to be 3 MPG or better with both motors running. So I expect that Martyn's average MPG for all operating speeds is higher than 1.5 MPG. How much higher depends on how much of the distance covered on a trip is a off-plane versus on-plane speeds.
jimh posted 09-26-2011 09:17 AM ET (US)     Profile for jimh  Send Email to jimh
Tom--Many thanks. From now I on will make a point of commenting on all of your typing mistakes. Is that fair?
jimh posted 09-26-2011 09:29 AM ET (US)     Profile for jimh  Send Email to jimh
Weight is always an influence on boat speed: more weight means less speed. However, when we get into a total boat weight of 8,000 to 9,000-lbs, a 100-lbs change in weight will not have a huge effect on the boat speed because it is such a small percentage of the total boat weight.
In reflecting about this topic, I think its range of inquiry is much too broad to solicit comparative data. A 22-foot Boston Whaler hull in its lightest configuration will be substantially less weight than a 27-foot Boston Whaler hull. And the motors employed to push the boats around also have a wide range of fuel efficiency.
Tohsgib posted 09-26-2011 11:01 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Wow...an Opti burns 10-11gph at 4k? That is roughly what my 1993 carbed 225 Ocean Runner burned. Suzuki website shows all of their 225's buring 8-8.5gph at 4k which seems more like a modern engine. So if they burn 8ea. which is 16gph at 4k @ 32mph would be 2mpg. I can't see how a DFI could bet closer to 3. They would have to be burning under 6gph each at 4k...not possible with 225hp. Maybe 150's.
Peter posted 09-26-2011 01:05 PM ET (US)     Profile for Peter  Send Email to Peter
Nick --
1. You cannot compare motors on an RPM to RPM basis. An Optimax redlines at 5750. A Suzuki 225 redlines at 6100. Go look at the Mercury test reports. At 4000 RPM the fuel burn ranges from 10 to 11 GPH. I bet that a Suzuki 225 probably needs to spin close to 4500 RPM to produce the same speed the Optimax does at 4000 RPM. At 4500 RPM a Suzuki is burning 11 GPH.
2. I guarantee that a 1993 Johnson Ocean Runner 225 does not burn 8 GPH at 4000 RPM. Try more like 13.
Tohsgib posted 09-26-2011 02:20 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Ok...I see your point on higher RPM, I was thinking it had a 6k redline. 2) My 225 ran about 11gph at 4k and about 32-33mph, just like I stated above, not 8gph, read it again.
Now comparing my 225 to the Optis, my 225 got 3mpg at cruise. I can't see how twin 225 Optis would almost double my efficiency with 2.8-2.9 and hence why I said maybe 150's. For a pair of twin 225's to fetch 2.9mpg they would need to burn 11GPH for the PAIR...not going to happen at 4k like martyn said above, he needs to double that 11gph. My 225 was on a Kevlar hulled 20' Hydrasport that weighed 1/3 his weight. So with DFI's he is getting about 1.5-1.6, my carbed would have been about 1.2 in twin setup on his rig.
My 454 is a bit better at 10gph at 35-38mph.
martyn1075 posted 09-26-2011 02:46 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
1.6-1.8 was what I was getting at lower rpm and obviously lower speeds (21-23) I thought originally I would be achieving better milage and therefore go down hill from there. Tom and others were getting better milage at higher rpm (4200) bringing there speed up to about 30mph and getting overall much better then I was receiving. I gave it some serious thought and setup the GPS with conjunction with my flo scan meter and am getting these numbers. Like I said I think 2nm is a bit short for testing and I plan on making my next test at 6-8nm and see what comes of that as well put a little more gas in the tank to weight it down. My guess is it will average out a bit less at around 2.0-2.5.
The old 25 Whaler Walkaround (wide-body) were setup mainly with 1989-90 twin Blackmax 175hp. It would be interesting to see what they got in MPG. The other owner had them before switching to these DFI's so maybe I can dig some data from him and share on this thread. Twin 225 modern DFI's are slightly on the larger side of what this boat is normally powered with. I'm not too surprised it can achieve these numbers. Its quite powerful setup which can be run a little faster back off and cruise gaining a little more efficiently at these speeds in the 30mph range. I was just running them way to conservatively most times. Lesson learned!
jamesmylesmcp posted 09-26-2011 04:24 PM ET (US)     Profile for jamesmylesmcp  Send Email to jamesmylesmcp
Just out for a ride yesterday and shot this, SmartCraft shows 5.1 GPH per engine, GPS 29+MPH, I can live with these numbers. Boat is a 1982 Revenge 25 Walk around twin 150 Mercury Optimax engines.
http://www.youtube.com/watch?v=CtY81eaC8Dk
I can play around and find 3+ MPG but the boat seems happiest right here.
Tom W Clark posted 09-26-2011 04:30 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Jim -- That is about 2.9 MPH. [Gosh--I think Tom made an error here. He probably meant 2.9-MPG--jimh] Pretty good.
What propellers are you using to achieve this fuel mileage?
jamesmylesmcp posted 09-26-2011 04:41 PM ET (US)     Profile for jamesmylesmcp  Send Email to jamesmylesmcp
Tom, 19P Aluminium Quicksilvers next year I'll try for stainless, would like to try 21P Mercury Offshores.
Tom W Clark posted 09-26-2011 05:02 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I have a left hand 14" x 21" Mercury Offshore I could sell you for cheap but I already sold the its right hand sibling.
Unfortunately, I cannot recommend the Offshore (VenSura) for your boat; there were the worst of all the propellers I have tested on My Revenge 25 with its twin Mercury 150s. No grip at all.
I've now tried 13 pairs of props on my boat and have yet to find anything that offers better fuel economy than the Mercury MIRAGEplus props I use.
jamesmylesmcp posted 09-26-2011 05:14 PM ET (US)     Profile for jamesmylesmcp  Send Email to jamesmylesmcp
Engines are 20 inch shafts with standard rotation.
Tom W Clark posted 09-26-2011 05:30 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I went from 19" Quicksilver aluminum props to 19" Miragepluss and gained 2 MPH as well as going from 2.0 MPG to 2.3 MPG, a 15 percent gain in fuel economy right there.
My 20" shaft length motor were both standard rotation too, until I converted the port one to counter rotation.
captbone posted 09-26-2011 06:23 PM ET (US)     Profile for captbone  Send Email to captbone
Try the Enertia props over the Mirage Plus if you can get your hands on them. I gained 150rpm and 2mph over the Mirage Plus.
Dialing in your boat by raising the engines and getting a new set of propellers can make a world of difference. I would rather have an engine 50hp less that is dialed in perfectly swinging the best stainless steel prop then a larger engine mounted all the way down swinging an aluminum prop.
6992WHALER posted 09-26-2011 06:31 PM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
1992 23 Walkaround, Whaler Drive, hard top, 1991 twin 200 Yamahas, 60 gallons of fuel, 2 adults. Trim tabs were fully extended for all measurements.
Water temp 61, air temp 66, wind calm, fresh water.
SOG from GPS, MPG from Navman fuel flow meter.
800rpm 4.7mph 1.18mpg
1100rpm 6.1mph 1.02mpg
3300rpm 24.2mph 1.73mpg
3600rpm 29.0mph 1.74mpg
3700rpm 29.2mph 1.68mpg
3800rpm 31.2mph 1.73mpg
4000rpm 32.6mph 7.72mpg
4700rpm 38.9mph 1.16mpg
Running on one engine only:
800rpms 3.5mph 1.2mpg (I want to recheck this one)
1100rpms 4.8mph 2.1mpg
1200rpms 5.0mph 1.9mpg
I am going to do this again with the trim tabs up and see what effect that may have.
Peter posted 09-26-2011 07:38 PM ET (US)     Profile for Peter  Send Email to Peter
Nick -- Yes, I misread your report. Even 11 GPH at 4000 RPM for a 225 OceanPro is optimistic. More typical is 13 GPH at 4000 RPM with the motor propped correctly. DFI shaves just about 2 GPH at all RPM from the carb'd motor.
