  Evinrude E-TEC 300
Author Topic:   Evinrude E-TEC 300
glen e posted 10-08-2007 04:00 PM ET (US)   Profile for glen e   Send Email to glen e
[The Evinrude E-TEC 300-HP engine was] shown at a show in Brazil. Supposedly 524-lbs. Congratulations to BRP. It looks very nice:
L G H posted 10-08-2007 05:22 PM ET (US)     Profile for L G H  Send Email to L G H
Beautiful looking motors.
glen e posted 10-08-2007 05:42 PM ET (US)     Profile for glen e  Send Email to glen e
But be warned: ONLY TWO STAR! Oh god no!
L H G posted 10-08-2007 06:08 PM ET (US)     Profile for L H G
Is that just a shell, or is there actually a powerhead under that plastic cowl?
With those 300 HP decals, we at least know BRP has finally been able to produce a 270HP outboard. How much more HP is available from 1/10 liter of additional displacement? 3% additional displacement produces 20% additional HP? Not likely.
Or another way of looking at it:
Current 250HP engine produces 75.75 HP/liter of displacement
New 300 HP produces 88.23 HP/liter of displacement.
How did they improve the HP output so significantly?
Or, if you use a 270HP, you get a more reasonable (closer to what they've been getting before) 79.41 HP/liter of displacement.
Inquiring minds want to know.
Jefecinco posted 10-08-2007 06:10 PM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
If these engines are for sale in Brazil they must be VERY ethanol tolerant. Nice, I want one for my 16.
Peter posted 10-08-2007 06:47 PM ET (US)     Profile for Peter  Send Email to Peter
It'd be nice if Glen gave Jorge Paragon credit for his photo. Other photos of the motor that were posted by Jorge on The Hull Truth reveal that this motor has a sticker placed on it that shows it to be a pre-production motor. So where the emissions certification ends up is still open and there is no CARB or EPA certification data posted for this motor yet.
Instead of putting a 3-Star sticker on the motor, they play conservative and put a 2-Star sticker on it. In the event that they can't get the production motor certified at 3-Stars or don't feel comfortable if its close, they won't have Merc's problem of having to back peddle on emission certification to correct a compliance problem and then make up a story about improving fuel efficiency which, from what I can tell, never showed up in the 2-Star designated Gen I Verados.
These could be a nice repower candidate for a 27 Whaler, with or without the Whaler Drive. A pair would be 250 lbs lighter than the Verado 300 and a whopping 550+ lbs lighter than the newly announced Yamaha F300.
"How much more HP is available from 1/10 liter of additional displacement? 3% additional displacement produces 20% additional HP? Not likely." -- LHG.
Before you ask such silly questions, you might want to think about what you just said lest you wish to cause credibility problems for your beloved Optimax 300 XS made by the racing department. The motor was stroked just like in the case of the Optimax 300 XS.
The fuel injection system is capable of injecting enough fuel to make 80 HP per cylinder so at 300 HP they are still far, far away from maximum HP production out of a V6. This motor was not possible with the Ficht injection system having a limit of about 45 HP per cylinder.
Jorge's other photos show this motor with the cowl off so to answer L H G's question, its a real motor and it even has a real serial number.
L H G posted 10-08-2007 07:17 PM ET (US)     Profile for L H G
Come on, Peter, get realistic. An old fashioned 90 degree OMC block from the late 80's cranking out 480HP? When pigs fly. Even the smaller 3.2 liter Merc Optimax can't do that. I don't care how much fuel you can pump into it. That old block just can't produce that kind of HP, and never will. First we should see if it can produce the dyno-ed 310 HP of the Opti 300 XS. Since you like to talk about weight, a pair of 300 Opti's would be 50# lighter than these.
Peter posted 10-08-2007 07:25 PM ET (US)     Profile for Peter  Send Email to Peter
Read more carefully, Larry. I said "a V6". Assuming you have enough displacement for the fuel and adequate cooling, etc, a 480 HP V6 is possible with the E-TEC fuel injection system. That couldn't be done with the first generation Ficht fuel injection system. About 270 HP was the limit on the Ficht V6 no matter how much displacement was provided.
fourdfish posted 10-08-2007 07:59 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Larry it looks like you jumped in with both feet on this one!
You see a pic and just can resist making up specs which you have no idea about. It is good that Peters posts have set your imaginary spec posts on you ear!
L G H posted 10-08-2007 08:36 PM ET (US)     Profile for L G H  Send Email to L G H
I love etecs but my other personality can't come to grips with it.
sweetrevenge posted 10-08-2007 11:04 PM ET (US)     Profile for sweetrevenge  Send Email to sweetrevenge
I understood that when BRP took over OMC, they brought in dumpsters and threw away practicly everything when they realized that old tech was not going to work with BRP's new high tech engines. I understand they have totally retooled and that even the blocks are new.
jimh posted 10-09-2007 12:03 AM ET (US)     Profile for jimh  Send Email to jimh
Here are some in-line images which show a few details.
Photo: New Evinrude E-TEC Injectors
The new style E-TEC injectors. The case now has the name "E-TEC" embossed on it. I saw similar injectors on production motors last month.
New gear case design with what appears to be water pick up holes on the leading edge of the torpedo.
Photo: Evinrude E-TEC 300 water pick up
Closer look at the water pick up holes.
I got these by email but the photographer was not cited. Perhaps the same correspondent as mentioned above. I bet you will see these motors at the Fort Lauderdale Boat Show in a couple of weeks.
From the manufacturer's serial number label:
Displacement = 3441 cc (210-cubic inches)
Weight = 238KG (523.6-lbs)
Power = 223.7 KW (300-HP)
To jog the memory of all those who forgot about the two year delay from Mercury with the Verado, just re-visit
http://continuouswave.com/whaler/cetacea/cetaceaPage54.html
to see the first showing of their Verado motor prototype (without the cowling removed and probably just a shell), and then
http://continuouswave.com/whaler/cetacea/cetaceaPage77.html
to see the introduction of the production Verado motor two years later.
If we apply the same time standard between the first showing and actual introduction, this will give Bombardier TWO YEARS to get this motor into production. My money is betting they will beat the benchmark set by Mercury with the Verado.
fourdfish posted 10-09-2007 09:18 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
I would also bet they will be 3 star compliant by production!
It would be interesting to see what improvements BRP's R&D has made to the new injectors.
These engines do not look larger than the 200 series!
Larry-Now that you mention it I suspected you were bipolar!
Tohsgib posted 10-09-2007 12:24 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
DAMN!!! Jim just slammed his bud Larry HARD!
Hey larry...at least these don't HAVE to run premium unleaded to make the stated HP on the cowl like Mercs. The 275 Verado is only 250hp on 87 octane. The 300XS requires premium as well(or did).
Tohsgib posted 10-09-2007 12:27 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
PS..Mercury made a 300hp 3.4L outboard back in 1981 or 1982. Did not have a long production run(reliability and fuel consumption) and weighed 550lbs or so. I do not see why a 300hp outboard took so long to make since OMC discontinued the V8(another gas guzzling wonder).
jimh posted 10-09-2007 01:52 PM ET (US)     Profile for jimh  Send Email to jimh
I wonder if these ultra-high-horsepower outboard motors are realistic for owners of classic Boston Whaler boats. To use a 300-HP motor you have to have at least a 22-foot hull with a Whaler Drive or a 25-foot or larger hull. While there are plenty of such boats extant, they are a small segment of the total classic Boston Whaler population. And in these days of soaring fuel prices where marine gasoline is being sold for almost $5/gallon at places where not that long ago it was under $2/gallon, you might find that owners are more interested in smaller motors than bigger ones. But in any case, Evinrude returns to the 300-HP outboard club that it pioneered many years ago with its V8 models. It now has a horse in the race.
As for the amount of power per displacement, this motor is still rather tame. With 3.4-liters and 300-HP it just 87.2-HP-per-liter, and this is in contrast to the very high output we are seeing from the Verado in-line four cylinder motors which crank 200-HP from 1.7 liters of displacement or 117.6-HP-per-liter. That is a greater output by a factor of 1.348 or a 34-percent higher output per unit of displacement.
According to Claus Bruestle, the engineer hired by Mercury to take over the Verado project and bring it to reality, in the original supercharged Verado engines the cylinder pressures are on the same level as a diesel engine, that is, very high, and much higher than on a conventional gasoline four-stroke. So with these new Verado models that are cranking out even more power, I would assume there is even more stress. Yet reviewers seem to have little concern about these numbers.
Two-stoke motors usually have low compression ratios, sometimes on the order 6:1, so my guess--and just a guess as I am not by any imagination an engineer of internal combustion engines--is that there is probably some room to increase compression and get more power in the E-TEC. Maybe that is where the modest increase in output per displacement comes from.
L H G posted 10-09-2007 02:55 PM ET (US)     Profile for L H G
Just trying to figure out how a puny 1/10th of a liter of displacement generates an additional 50HP. I doubt it.
Peter says "cubes count" (except with Mercs, who proves that saying wrong all the time). Well, they don't add up here when compared to the 3.3 liter block.
If they have some new magical invention in this powerhead that somehow produces all this extra HP per liter, they had better go back and apply it to the 3.3 liter engines, and the 90 also. Those all need more power to stay competitive with the performance crowd.
Glad to see, however, that they finally copied the Merc 3.0 liter/Verado low water intakes of 5 years ago. Now all we need is a little DTS.
I am glad they finally joined the 300 HP decal club, and only wish them well with this new engine. Not having many new boat transoms to install 300 Evinrudes on, in singles, twins, trips or quads, I am wondering how big the repower market actually is for 300's of any brand, especially with no DTS to run the trips and quads. It makes me wonder why Honda is not moving up into this HP range also. Merc and Yamaha are still the best positioned to sell the high HP engines.
Binkie posted 10-09-2007 03:15 PM ET (US)     Profile for Binkie
Larry,
I thought you were still talking up BLACK MAX technology! ;-0
jimh posted 10-09-2007 09:49 PM ET (US)     Profile for jimh  Send Email to jimh
From a manufacturer's perspective, making more horsepower from an existing engine design is a good way to increase profit. In general, the selling price of a motor is directly proportional to horsepower, but the cost of goods sold is not. It costs almost as much to make a V6 150-HP outboard as it does to make a V6 250-HP outboard. Therefore the profit is much higher in a 250-HP than in a 150-HP outboard. If you can stretch the 250-HP model to 300-HP, you can get an even higher price, and thus even higher profits.
The ability to stretch more profit is not infinite, however, and at some point you have to put more expensive components into the higher horsepower motors. For example, you might have to use pistons, connecting rods, crankshafts, rings, bearings, etc., which were more expensive in the 300-HP model, and this drives the cost up. So perhaps the margins are not as great in the 300-HP motor as in the lower horsepower motors. Information like this is impossible to get and one can only speculate about it.
On the other hand, from the buyer's perspective, buying marginally more horsepower is often a bargain. If you go from a 225-HP model to a 250-HP model you probably have to pay about $1,000 more. You cannot buy a 25-HP outboard for that same money. In one sense you can rationalize and say that the extra $1,000 spent on the 250-HP model was the cheapest extra 25-HP motor ever made. You can probably extrapolate this to the 300-HP models, too.
I find the holes on the leading edge of the torpedo of the gear case to be interesting. There are all kinds of patents about water pick up holes on outboard motors, and some have speculated that these patents were restraining Bombardier from using such water pick up holes on their engines. The appearance of these water pick up holes on the new E-TEC 300-HP model seems to belie such notions of patent restrictions. Either that, or Bombardier is licensing the patent from the patent holder. In any case, it looks like the cooling system has been augmented on the 300-HP model. It is interesting to see things like this evolve.
TexasWhaler posted 10-09-2007 10:40 PM ET (US)     Profile for TexasWhaler  Send Email to TexasWhaler
LHG stated:
"I am glad they finally joined the 300 HP decal club"
I believed they joined that club in the late 80s, with the V-8, 300.
I guess you could say they're like Merc - returning members ;-)
Here's a little tidbit of trivia for LHG:
What outboard holds the top end speed, world record?
(Hint..........it's not a Merc)
Answer: A 1989 Evinrude V8, officially clocked at 176.556 mph. (The motor actually ran 190 mph test run, the day before the "official" event, but due to some prop damage sustained during the test, 176.556 mph was all they could achieve for the official run.)
onlyawhaler posted 10-10-2007 12:05 AM ET (US)     Profile for onlyawhaler  Send Email to onlyawhaler
Great for Evinrude. Terrific looking engine. They are really back. What is interesting to me is that they could be both the value leader and performance leader with this new offering in the big horsepower war.
Considering everything like "cleanest and quiet" , non complicated design, ligher weight than the 300 Verado, the Suzuki 300 and the Yamaha 350 V-8 helps alot.
Add the probably reality that it will outperform all of them simply by virtue of the two stroke power and hp per lb ratio. Gallons per mile will undoubtly be close enough.
If is based, as speculated on the existing 250 block, it would probably be the least expensive to manfacture of the big three.
I am looking ahead and I see new a new BRP DVD showing this new 300 pulling some big 4 strokes underwater.
Onlyawhaler
Tom W Clark posted 10-10-2007 01:06 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Here's a nice 1989 Johnson 300 HP outboard on the nicest Revenge 25 Walk Through I have ever seen, a 1989 model boat.
http://home.comcast.net/~tomwclark/JohnsonGT300.jpg
This boat is owned by Mark and Peggy Ingraham of Gig Harbor, WA. This boat is almost identical to my own except for the power. The Ingrahams are the original owners and it has always been kept at their home in the garage when not in use. I took this photo at our PNW Rendezvous in June at Cornet Bay State Park just as Mark and Peggy were casting off.
I am glad I didn't bring my boat to this rendezvous and instead bummed a ride with John Kaloper in his Outrage 24. Mark's boat is showroom clean and shiny where mine needs some elbow grease. Mark told me the Johnson 300 has been completely reliable all these years except for the original gearcase which self-destructed early on and was replaced by the much more robust design used on later V-8s.
This motor smokes, but not as much as the twin Mercury 150s on my boat. Speed and fuel consumption is close to what my twin 150s can do. In this case it seems horsepower is horsepower and displacement is displacement no matter how you divide it up.
It should be noted that this motor is not a hand built racing motor but a regular recreational production motor. Mercury has yet to be able to offer such a motor.
The OMC V-8s are really big motors, too big for most boat back in the 1980s. This motor looks nicely proportional to the Revenge 25 and leaves room on the transom for a kicker, something I dearly with I could do.
If the BRP E-Tec 300 is the spiritual descendent of this Johnson 300 and can do it with less weight than the Yamaha V-8, fewer parts than the less powerful Verados, and less smoke and fuel consumption than my twin 150s, I say to BRP: congratulations, I hope this motor is a success.
Peter posted 10-10-2007 08:30 AM ET (US)     Profile for Peter  Send Email to Peter
Yes Larry, on outboard motors, "cubes count". The more you've got, the better. So while we are "counting cubes", let's count them all, not just some of them. The current 250 HP E-TEC V6 has a displacement of 3279 cc so doing simple subtraction from 3441 cc, which is the displacement for the 300 E-TEC, the increase in displacement is 162 cc not 100 cc.
And while were at it, since you've already injected your Mercury advertisement into a BRP thread, let's play along by comparing the Evinrude displacement increase for the E-TEC 300 with the Mercury displacement increase for the Optimax 300 XS. The Optimax 250 XS displaces 3032 cc and the Optimax 300 XS displaces 3160 cc. So, subtracting 3032 from 3160 leaves only 128 cc. 162 cc is greater than 128 cc.
So Larry, with a statement like "trying to figure out how a puny 1/10th of a liter of displacement generates an additional 50HP" followed up by "I doubt it", sounds like you must have some doubts about the 300 XS which you have previously touted here. ;
Whalerdog posted 10-10-2007 09:27 AM ET (US)     Profile for Whalerdog  Send Email to Whalerdog
nice motor and I hope it works well. I like the look of the E-Tec's better than Mercs. I like my 07 115 Merc but the styling leaves a lot to be desired. I guess it's made here so it's more jobs for USA.
Binkie posted 10-10-2007 11:37 AM ET (US)     Profile for Binkie
Tom
Those OMC V8`s were cool looking monsters. Can`t recall ever seeing one on a boat though. Saw one one E-Bay that supposedly ran, but needed a rebuild. It didn`t sell, and it was near me, so I called the guy and he would have taken $500 for it. I was thinking of cosmetically restoring it, and building a mahogany engine stand, and displaying it in my family room. After thinking about it for a while, I thought better of it.
I bought a Suzuki DT150 from a guy in West Palm Beach that collects those OMC V8s, and has a garage full of running ones. A sight to see. It makes you feel small physically just standing near them.
rich
TexasWhaler posted 10-10-2007 11:47 AM ET (US)     Profile for TexasWhaler  Send Email to TexasWhaler
It sure would be awesome if BRP were to bring back the V-8. Possibly as an E-TEC 350, 375, or even a 400.
L G H posted 10-10-2007 12:06 PM ET (US)     Profile for L G H  Send Email to L G H
Peter you are my hero.
Peter posted 10-10-2007 12:23 PM ET (US)     Profile for Peter  Send Email to Peter
I figure if the new 3.4L 300 E-TEC V6 is only 524 lbs, that means they probably could make a 4.5L 400 HP E-TEC V8 and keep the weight at 650 lb or less. Doubt that there is much of a market for a 400 HP outboard to incentivize them to come up with such a beast.
jorgeparagon posted 10-10-2007 12:59 PM ET (US)     Profile for jorgeparagon  Send Email to jorgeparagon
Just check this out
http://corp.brp.com/en-CA/Media.Center/Press.Releases/1/2007-10-10.htm
Have a nice day
blkmtrfan posted 10-10-2007 01:15 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
Tom, I have to agree with your comments about Mark and Peggy's boat, it is beautiful and a very neat package with quite a few custom upgrades.
Their boat would be an excellent test bed for a comparison between the old OMC 300hp and the new Etec 300hp.
blkmtrfan posted 10-10-2007 01:19 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
Also regarding seeing V-8 johnsons on normal boats, there was a early 90's 21' outrage for sale last year just down the street from my work with a 250hp V-8 OMC on it. It was in mint shape and I had a real hard time driving by it every day without wanting to bring it home...
JMARTIN posted 10-10-2007 01:40 PM ET (US)     Profile for JMARTIN  Send Email to JMARTIN
I concur with Tom and Scott on Mark and Peggy's fine Revenge. It sounded cool taking off also.
http://i34.photobucket.com/albums/d137/jmartin-/rend07005-1.jpg
Another shot with the boat set up for "at the dock" time. I was intrigued by the table. It is a better design than the one I made for my boat.
http://i34.photobucket.com/albums/d137/jmartin-/rend07006.jpg
I am glad to see Evinrude, and other manufacturers, come out with these big horsepower motors. Hang a 300 on the back of a 24 to 28 foot boat instead of a I/O. John
JMR posted 10-10-2007 02:46 PM ET (US)     Profile for JMR  Send Email to JMR
Jorge just posted a BRP press release for the 2008 year improvements including a 250 H.O. at 3.4 liters. Is this the production version of the [prototype?] 300 previously shown in Brasil?
andygere posted 10-10-2007 04:21 PM ET (US)     Profile for andygere  Send Email to andygere
Larry, you really do a disservice to your own credibility when you publish garbage like that. Is it implausible to you that any company other than your beloved Mercury can produce a decent outboard motor?
fourdfish posted 10-10-2007 04:42 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Wow, It has been a very long time since I have seen that old OMC 300! Thanks to JMARTIN
BRP is actually pulling one off here by investing very little time and money to answer the other manufactures
in the 300hp range without a big increase in weight.
Actually Andy, Larry showed his own true colors with his posts on this thread. Glen started the thread and did not really bash BRP. However, Larry just could not resist a chance to criticize BRP and knock the engine. Peter thoughtfully answered each of his posts and what was left of Larry's credibility was destroyed.
L H G posted 10-10-2007 06:38 PM ET (US)     Profile for L H G
Thanks, Fordy, for the following:
"BRP is actually *pulling one off here* by investing *very little time and money* to answer the other manufactures
in the 300hp range without a big increase in weight."
That's what I have been saying all along regarding BRP's failure to invest much needed R & D into Evinrude, to keep up with the Merc and Japanese competition.
Coming from an Evinrude promoter here, which lends considerable creditibility to the comment, I appreciate your honesty and support of my own observation.
CAUTION: THE FOLLOWING COMMENTS HAVE BEEN RATED "M", WHICH MEANS THEY MAY BE OFFENSIVE TO, AND NOT BE APPROPRIATE FOR, THE EDITORIAL BOARD OF CONTINUOUSWAVE, BRP MANAGEMENT AND DEALERSHIPS, AND E-TEC OWNERS & PROMOTERS IN GENERAL. PARENTAL DISCRETION IS ADVISED BEFORE CONTINUING.
(pst) - the 300 XS Optimax weighs less, and dyno's at 310HP!
We'll just have to wait for E-tec 300 results and see where it falls under the 10% plus or MINUS HP rule.
Hopefully, Bass and Walleye Boats will do a 300 shootout for us. I'm really sorry Evinrude refused to compete against the puny 3.0 liter 250XS Optimax and the 2.6 liter 250 Verado with that 3.3 liter beast of theirs in the last 250 shootout. Very revealing. Hopefully, they won't be afraid to run this time against the 300 Optimax and 300 Verado, after all the engine does have 1/10 liter of ADDITIONAL displacement over the 250.
And Andy, before you call me an idiot, you should consider the following:
Also announced is a new 250HO engine, on the same block. Funny about that, but revealing.
Using the 10% rule, the 250HO is probably about 270-275HP, since it is widely known that Evinrude uses the "HO" designation to mean more than the stated HP. This we know from Peter. Just co-incidentally, the 300 HP decals, since they are on the identical engine, could mean as little as 270HP, so the 270-275 HP estimate sounds just about right for that one also! I have learned from experience. They play this same sucker's game with the 225HO, which Peter tells us is about 245HP (under the same HP rules), and is the same engine as the 250, which then puts out the same 245. No wonder they wouldn't run it against a 264HP 250 XS Opti or Verado. They'd have gotton smoked, even without talking Merc's superior Fleetmaster, Torquemaster and Sportmaster gearcase options and ET props.
Buckda posted 10-10-2007 07:07 PM ET (US)     Profile for Buckda  Send Email to Buckda
WOT, or top speed, is used by average boaters for less than 5 minutes each year (based on a 100 hour year).
For northern boaters, my guess is that there is fewer than ONE time each season where a 5 MPH difference in TOP SPEED will make any kind of difference at all in his fishing, cruising or other recreational uses of his craft.
However, most northern boaters winterize their motors at least once every year, and when an indian-summer saturday comes along, wish it weren't such a pain in the ass to re-winterize the boat so they could go out and get some time on the water.
Last year, I probably winterized my motors 4 times, because I was able to find yet another nice day to use the boat and enjoy my time on the water, and re-winterizing the motors is a simple matter of three different throttle settings and a few minutes of time.
That feature, in and of itself, wipes out ANY top speed argument out there when we're talking about small differences betwixt engines.
Since we're making up HP figures, I guess my 99 HP 90 HP E-TECs are great. I like them, anyway.
Spending less on producing the same HP with clean technology isn't a bad business decision - it's a good one. I don't think that BRP is really worried right now about how to keep those American workers in Wisconsin busy. In fact, I bet they're working on how to put more Americans to work on lower HP E-TEC models.
How many Americans will be put to work producing low HP Mercury motors in the next five years?
Good on BRP for producing this beast. The challenge will be one that is faced by many Americans in business: how to beat the guy who's dad gave him everything in business when you're out manned, out financed and have limited entry points to the market? The answer: do what you've been doing - deliver a great product at a good price and market the hell out of it.
fourdfish posted 10-10-2007 07:43 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Larry- Yes I did say (much to their credit) that it is likely that BRP did not have to put a lot R&D into that engine to produce the 300hp. Actually, I am baseing that assumption on the similar engine configuration as the 200hp series.
However, you of course used that comment to produce a sweeping generalization on all of BRP's R&D.
In any case, even a fool can tell that your post shows a
desperate lack of credibility. Anyone can see that MAKING UP HP and weight numbers is your speciality.
The weight of this engine is so much less compared to the Verado, Yamaha and others that it will be a serious consideration for those interested in that HP range.
I have to go along with Dave and say that "Bravo to BRP
for doing more with less money and Bravado".
More success to the company which means More egg on your face!
As for myself, I could care less if they have a Magazine race shootout or not because it is meaningless with no real
research involved.(No engineer would use their data and conclusions)
After 3 years you have failed to purchase any of the engines you are trying to sell here. What does that tell everyone here?
andygere posted 10-10-2007 07:56 PM ET (US)     Profile for andygere  Send Email to andygere
Larry, I think we all understand the 10% rule, but I don't think any of understand how it's always +10% for Mercury and -10% for everyone else. Now, when called on it, you sarcastically give the benefit of the doubt:
How you got to 270 hp is not my point. If you can't figure out what my point is, you are more lost than I thought. By the way, I didn't call you an idiot, I said you did a disservice to your credibility. Don't put words in my mouth.
jimh posted 10-10-2007 08:04 PM ET (US)     Profile for jimh  Send Email to jimh
Winterization is a real problem for owners of the Mercury OptiMax. Everyone considering the OptiMax in a northern climate ought to read the winterization procedure, which includes disassembly of the fuel vapor separator, disconnecting fuel lines, and draining of the fuel from the motor. It does not sound like much fun.
http://www.mercurymarine.com/_media/pdfs/serviceandwarranty/storage/ StorageInformation-OptiMax.pdf
At our recent Great Lakes Boston Whaler Cruising Club fall rendezvous, I watched Dave's demonstration of how to winterize an E-TEC. Quite impressive, and very easy to do.
sosmerc posted 10-10-2007 09:01 PM ET (US)     Profile for sosmerc  Send Email to sosmerc
Proper winterization of an Optimax is really no big deal. I do it all the time.
Like any other outboard that has been run in salt water, they need to be run in fresh water long enough to get the engine up to temperature so that the thermostats can cycle a few times. I do this by running them on my dyno for approximately 15 minutes at various rpm's. I use large cattle feed tanks filled with fresh water and a little joy soap. During this period of running I am using a fuel mix of mid-grade fuel, 50:1 ratio of Premium Plus Merc oil and Startron fuel additive in the gas. I run the engine long enough to get this mix well into the entire fuel system.
That's basically it. (other than lubing the steering and all zirc fittings and changing the gear oil and treating the boat's gas with Startron.
In the Spring I run the engine again on the dyno using the boats gas (and I ask my customers to put fresh gas on top of what is left in their tank before bringing it to me for the Spring service). At this time I do routine tune up items such as fuel filters, spark plugs and impellers. This procedure is basically the same for all 2 strokes and has served my customers very well. The key is keeping the fuel clean and relatively fresh with a good conditioner like Startron. Running some oil with the gas through the Optimax helps to keep the fuel pump(s) lubed during a long layup. No need to drain the VST.
MDI posted 10-10-2007 09:18 PM ET (US)     Profile for MDI  Send Email to MDI
Tom, Scott & John,
Thank you for your kind words about our Revenge. As we speak, the boat is in Anacortes having a Radar Arch put on. By the way, have you all donated to the 300 E-TEC repowering fund?
Thanks again,
Mark & Peggy
jimh posted 10-10-2007 10:53 PM ET (US)     Profile for jimh  Send Email to jimh
Evinrude E-TEC 250 High Output Tops BRP 2008 Line-up
Entire line-up features enhancements
Genoa, Italy, October 9, 2007 - BRP's 2008 model year line-up is headlined by its largest, most powerful outboard yet - the 250-hp High Output. With 3.4 liters of displacement, the additional power and low weight of the 250 H.O. allows boaters to plane heavy loads, make faster hole shots and increase top speed on a variety of recreational boat applications.
Enhancements have been made throughout the entire Evinrude(R) E-TEC(R) line with component and design upgrades that extend the easy-to-own, low maintenance attributes to maximize the owner's quality time on the water. The following upgrades create increased durability, longevity and operator comfort: unique iridium spark plugs; enhanced calibration and a patent-pending fast rise inductive ignition system for smooth running at every RPM range; improved cylinder sleeve design; and enhanced fuel injectors. BRP continues to refine its outboard line for continuous cutting-edge leadership in superior engine performance and reliability.
"We have improved our entire product line to incorporate advancements in technology that have evolved at a very fast pace. Evinrude engines offer a perfect package of power, ease of use, reliability, and cleanliness no matter the horsepower," said Roch Lambert, vice-president and general manager, Outboard Engines, at BRP. "The model year 2008 line-up expands consumer choices in high quality, low maintenance outboards and substantiates BRP's commitment to expand its Evinrude line-up above 250 hp and below 40 hp," he added.
Like all Evinrude E-TEC outboards, the 250 H.O. is compact and lightweight - an amazing 128 pounds (58 kg) lighter than competitive engines at the same horsepower. With less weight comes improved fuel efficiency, less draft and improved boat handling, superior visibility while planing the boat quicker, and less stress on the boat transom. The 250 H.O. tops-off the Evinrude E-TEC line-up in horsepower and advanced innovative features including the high-speed, nose cone Lightning(TM) gear case, manufactured from the toughest grade metals and alloys for increased strength and performance.
"As we roll out our Evinrude E-TEC line-up, we want to keep it state-of-the-art. This is why it's critical for us to continue to innovate," noted Michel Hade, vice-president and general manager, BRP International Division. "The Evinrude E-TEC technology is changing the industry; it has been a key driver of growth in our markets around the world and has resulted in profitability for both our dealers and distributors and BRP," he concluded.
The Evinrude E-TEC expansion includes nine models in the 40 through 60-hp in-line two cylinder engines; three models in the 75 through 90-hp in-line three cylinder engines; one new model in each of the 115-hp V4 60-degree and 150-hp V6 60-degree engines; two models in the 200 through 250-hp V6 90-degree platform; and two models in 250 H.O. The additions include new tiller choices, increased color and shaft length options, and counter-rotation availability for 115-hp twin applications. Also new for 2008 are 65 and 90-hp Evinrude E-TEC outboards developed for commercial and government use. Available in four models, the engines are more tolerant to varying fuel grades and the demands of commercial markets. I CommandTM instruments, designed specifically for the NMEA (National Marine Electronics Association) 2000 certification, are standard in Evinrude E-TEC V4 and V6 engines.
The 2008 Evinrude E-TEC line-up, including the 250 H.O. engine, will be on display at the following events:
Genoa Boat Show, October 6 - 14, Italmarine's booth, BRP's distributor in Italy;
Club BRP, Gold Coast Resort, Australia, October 15 - 19;
Fort Lauderdale Boat Show, October 25 - 28, booth 2035.
Bombardier Recreational Products Inc. ("BRP"), a privately-held company, is a world leader in the design, development, manufacturing, distribution and marketing of motorized recreational vehicles. Its portfolio of brands and products includes: Ski-Doo(R) and Lynx(R) snowmobiles, Sea-Doo(R) watercraft and sport boats, Evinrude(R) and Johnson(R) outboard engines, direct injection technologies such as Evinrude E-TEC(R), Can-AmTM all-terrain vehicles and roadsters, as well as Rotax(R) engines and karts.
www.brp.com
andygere posted 10-11-2007 10:48 AM ET (US)     Profile for andygere  Send Email to andygere
Counter rotating 115's sound like a nice repower choice for all those twin engined Outrage and Revenge 22's out there.
TexasWhaler posted 10-11-2007 11:17 AM ET (US)     Profile for TexasWhaler  Send Email to TexasWhaler
I though I'd add a little comic relief to this thread.
Here is the perfect desktop photo for LHG...........
Someone posted it on another site. I was unable to determine who actually took the photo though.
http://www.wellcraftv20.com/gallery/albums/album07/Image1_32.jpg
L H G posted 10-11-2007 01:38 PM ET (US)     Profile for L H G
From Lambert's quote above by JimH, this statement makes him out to be an absolute liar:
"Like all Evinrude E-TEC outboards, the 250 H.O. is compact and lightweight - an amazing 128 pounds (58 kg) lighter than competitive engines at the same horsepower."
All of the Merc 3.0/3.2 liter engines, including the 250XS and 300XS Optimax at 505 lbs, weigh LESS than this 250HO.
If the DFI Merc Opti's at the same HP aren't considered to be competitive HP levels to the DFI Evinrudes, I don't what is. These French Canadians need to clean up their publicity act.
fourdfish posted 10-11-2007 02:24 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Larry, Larry, Larry, desperation is coming out! It is your credibility at question here!
jorgeparagon posted 10-11-2007 04:02 PM ET (US)     Profile for jorgeparagon  Send Email to jorgeparagon
EPA will tell !
Peter posted 10-11-2007 04:14 PM ET (US)     Profile for Peter  Send Email to Peter
Larry, if you haven't figured it out yet, the primary competition for Evinrude is the Yamaha 4-stroke, not the Mercury Optimax. That is what Evinrude has had its gun sites on for years and years now. Taking 10 percent of Yamaha's marketshare of 4-strokes will yield far more sales than taking 10 percent of Mercury's independent Optimax sales which are few and far between as compared to Yamaha 4-stroke sales.
Why? As I've said before, the Optimaxes really aren't that competitive. Even though some like to refer to the latest Optimaxes as GEN 2, they really aren't on GEN 2 yet. They are more like a GEN 1.2.1. They won't get to GEN 2.0 until they have:
- Self winterization
- battery condition independence for the fuel injection system
- NMEA 2000 compatibility
- 4-stroke like noise attenuation
- low oil consumption mode
- pull start capability
- 3-Star emissions across the entire product line
to name a few features.
Your focus on one thing and one thing only, speed reports from a publication in which Mercury advertises heavily really continues to miss the big picture. The world has changed, the general consumer base has raised their expectations in what they want in an outboard, and its more than just a high power to weight ratio. If it were just high power to weight, there would be NO 4-stroke outboards.
There is probably no better evidence that the Optimax is not competitive in the general independent boat hull marketplace than by looking at the outboard motor options offered by Wellcraft boats. Take the 252 Fisherman for example. Motor options offered are Yamaha 4-strokes, Evinrude E-TECs or Mercury Verado. No Optimaxes. Same thing for the entire Wellcraft Coastal series of products. No Optimaxes. Even Mercury's own sister company, Whaler, has dumped the Optimax line.
I know it hurts CW's No. 1 Mercury fan and sometimes salesman to think about it but the reality is the Optimax has been relegated to a 2nd class citizen both internally at Brunswick and by independents. Perhaps its fallen so far off the general radar scope that that the Evinrude execs don't even think about the Optimax anymore. ;)
Plotman posted 10-11-2007 04:50 PM ET (US)     Profile for Plotman  Send Email to Plotman
One of the things that is unsaid in all of this is that as HP gets larger, the NMMA standard that outboards must list HP within +/- 10% of actual has got to be revised.
Larry is right, under those standards, the same motor could be sold as both a 250 and a 300 under the rules with no changes other than the decals.
pglein posted 10-11-2007 05:48 PM ET (US)     Profile for pglein  Send Email to pglein
I still don't understand the need for a 300hp outboard. It's always seemed to me that if you want that kind of power, an inboard or I/O configuration makes so much more sense. Not just from an engineering sense, but also in terms of weight distribution in the boat. Not to mention noise.
L H G posted 10-11-2007 05:48 PM ET (US)     Profile for L H G
Peter, your broken record E-tec hype is getting old and well worn around here. Same old song and dance about batteries. In your Optimax compaints, most of which are meaningless, (the guys down south are REAL concerned about winterization, I'll bet) you failed to mention that E-tec needs much better fuel economy standards.
Yet Optimax outsells E-tec by a 3 to 1 margin, or something like that? Offshore cruising and fishing is heading all 4-stroke, all brands. Been saying that for some time, and everybody here knows it. Offshore high performance and racing, mostly Optimax and Verado. Freshwater bass, walleye and performance, mostly Optimax and Vmax (check out screamandfly.com). E-tec gets what ever scraps it can find between all of these, and in the leftover repower market. They should face the fact that Optimax and hpdi ARE INDEED their real competition (since they are also DFI 2-strokes), that these engines don't weigh 128 pounds more as Lambert states, and that they are NOT in competition with the 4-stroke buyers at all. The guy that wants to buy a big offshore Whaler, Grady or Regulator, is not thinking E-tec envy. They WANT those big Verado, Yammie or Suzuki 4-strokes. It has come full circle. Now those engines are part of the reason why they WANT to buy a particular boat.
A credit to Boston Whaler for figuring this out.
For the readership here, mostly running older Whalers from the 70's and 80's, small 4-strokes, big single 4-strokes, conventional leftover and still being made 2-strokes, and the 3 brands of DFI's are still the best choices. But any engine company basing it's hopes on this bunch won't last long. Combined, we are nothing but fly on the total outboard engine marketplace. And our collective opinions are probably treated as the same.
pglein posted 10-11-2007 06:49 PM ET (US)     Profile for pglein  Send Email to pglein
I have no particular opinion non the Evinrude vs. Mercury debate. However, I think quoting sales numbers or where the bulk of buyers are "headed" is somewhat irrelevant. Merc moves TONS of product simply because of their exclusive rights on the boat lines that Brunswick owns. It has exactly NOTHING to do with their actual or perceived superiority.
The debate here is not about what's most popular, but rather about what is best. I will admit that I haven't done all the research since I'm not really in the market one way or another, but from reading peoples' opinions and experiences on this and other websites, when it comes to brand new outboards, the general concesnsus seems to be that the Evinrude E-Tec motors are superior in just about every way aside from, perhaps, horsepower per dollar.
If the time comes for me to repower my boat again, and I can't get my hands on a relatively new, traditional 2-stroke engine, and I'm forced to purchase a brand new low-emission engine, I will buy whatever gives me the best power/weight ratio with a relatively strong reliability record (which all the major manufacturers seem to have at this point). Period. End of discussion. It's all about power to weight. What else matters?
Jefecinco posted 10-11-2007 07:22 PM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Ford sells more cars than Porsch. Therefore Ford is superior. Better buy Ford or you'll be left behind.
Everyone knows that!
jamesmylesmcp posted 10-11-2007 07:35 PM ET (US)     Profile for jamesmylesmcp  Send Email to jamesmylesmcp
Larry have you seen this ?http://www.texs.com/magazine/tsg_13.htm
L H G posted 10-11-2007 07:40 PM ET (US)     Profile for L H G
Everyone but you, Jef. Outboards all cost about the same per HP, Verados cost a bit more, for more features. Fords and Porsches do not cost the same. If they did, Porsch would sell more cars.
In outboards, sales figures matter. First of all, whether the company will have profits to put back into R & D. Second, it indicates the consumers preference. Third, for sales and marketing. The more of a given product the consumer sees on the water, the better the advertizing and expectation of additional future sales. You always go to the restaurant that has the most cars in the parking lot.
Buckda posted 10-11-2007 07:58 PM ET (US)     Profile for Buckda  Send Email to Buckda
I'm sorry, but it does not indicate consumer preference. Perhaps preference to the BOAT that the motor is powering...THAT I'd bet on.
Most BW owners, when they DID have a choice in the 1980's, chose to put OMC or Yamaha power on the back. Just look at the classic Whalers at the various rendezvous' whose trip reports are posted to this site.
Mercury certainly has a strong showing, because they make a good engine - and in some cases, they make a GREAT engine...but come on, how can the consumer's preference be truly indicated when there is no ability to excercise preferential decisions in the boat-buying process?
jimh posted 10-11-2007 09:51 PM ET (US)     Profile for jimh  Send Email to jimh
To quote Shakespeare, when Boston Whaler dropped the OptiMax as an option for powering new Boston Whaler boats, "that was the most unkindest cut of all."
fourdfish posted 10-11-2007 10:16 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
[Too much personal invective; deleted.--jimh]
L H G posted 10-11-2007 11:06 PM ET (US)     Profile for L H G
Zzz...
george nagy posted 10-12-2007 10:36 AM ET (US)     Profile for george nagy  Send Email to george nagy
Larry drop me an e-mail if you are going to be in town, I never got to see that 21'.
L G H posted 10-12-2007 03:29 PM ET (US)     Profile for L G H  Send Email to L G H
[Too much personal invective; deleted--jimh.]
jimh posted 10-12-2007 07:10 PM ET (US)     Profile for jimh  Send Email to jimh
Gentlemen, please, let's keep the discussion on the topic of the boats and motors, not on the people in the discussion.
Tohsgib posted 10-17-2007 12:03 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Was up in Southern NJ this past week....holy smokes they must have had an E-Tec repowering mandate. There were E-Tecs everywhere and on some of the junkiest boats I have seen. I will say I was puzzled.
JayR posted 10-17-2007 12:28 PM ET (US)     Profile for JayR  Send Email to JayR
Lots of intelligent people in NJ.....
Tohsgib posted 10-17-2007 02:07 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Considering they STILL live there...dunno ;)
Amazing how many people are still running older engines up there, even after ethanol gas. Seems like here in FL there are way more modern engines, then again we use them more. Funny to go out on my friend's Mako with the original 1984 Johnson still running the same as it did in 98 when I left...poorly ;)
Buckda posted 10-17-2007 06:33 PM ET (US)     Profile for Buckda  Send Email to Buckda
L H G states above:
quote:
. . . E-tec gets what ever scraps it can find between all of these, and in the leftover repower market.
From someone who is sensitive about being called on misrepresenting the truth, and then goes on to call an executive of BRP an "outright liar," this is an interesting observation, given the available evidence to the contrary in the public domain.
I find it very unlikely that Mercury, Yamaha, Suzuki and Honda are such sloppy marketers that they leave a whole lot of "scraps" lying around in the marketplace; and yet, BRP is running three shifts of workers at their Wisconsin facility to manufacture the E-TEC motors.
Either there was a HUGE backlog of people waiting to repower (because it seems that they play a pretty big role in the repower marketplace), or the above statement is just not true. How do you keep 3 shifts of workers busy when you're getting the meager scraps from the big boys sitting at the table?
Well, for one thing, you make your existing customers very happy:
http://www.evinrude.com/en-US/About.Us/Press.Releases/1/2007.02.15.1. htm?popup=true
(Now that L H G is on board with J.D. Power and Associates, I think we can reference their awards as having significance...otherwise, L H G will have to call himself an "outright liar," given his past positions on the awards given to Mercury by J.D. Power.)
According to the authoritative J.D. Power survey, customers are very happy with such "weaknesses" in the E-TEC lineup like fuel economy, acceleration, reliability, quietness at cruising speed, emissions and smoothness when shifting. Wow. Either it is true (afterall, J.D. Power and Associates Surveys are authoritative - we've established this amongst owners of all outboard brands) or the owners of E-TEC motors who fill out these surveys are idiots.
It's clear to most that Evinrude isn't under the table collecting crumbs...they're sitting at the table, snapping their fingers and calling "Oh Waiter!"
Since Larry likes to put Mercury at the top, let's imagine, for a moment, this table. Mercury is at the head, with Yamaha and Evinrude on either side. At the down the table next are Honda, Nissan/Tohatsu and Honda. Then disaster strikes. Yamaha and Evinrude are pretty poor dinner guests! They're ordering things which are off the "menu" that Mercury had laid out for them. This is causing Mercury some consternation, indigestion and perhaps a little constipation. It's no wonder they're crabby about JimH rebranding their diminutive "FourStroke" motor which is based on the VERADO block yet does not contain the requisite components that make a VERADO a VERADO the "Veradito"! (c.f. http://continuouswave.com/ubb/Forum1/HTML/015079.html reference the post from glen e)
This truly isn't a pretty dinner party anymore because not all of the "guests" were willing to follow the masses to substitute tofu for real meat. The "Faux-fu fourstroke" as the only green option idea was thrown out the window when Evinrude brought a brown bag lunch to the dinner and pulled out a juicy T-Bone steak for people to consider as an option.
The insolence!
Now, the other guest is causing problems. You see, since Yamaha had gone ahead and ordered the "faux-fu fourstroke" menu option and then saw Evinrude brought "outside food" to the table, they quickly did what the Japanese are renowned for: they refined, and improved...and turned to their manufacturing prowess to one-up Mercury. If they're stuck in the tofu game, they decided that they would bring the biggest block of tofu ever out of the kitchen! Introducing the F300.
Mercury, upon hearing of this ultimate offense and not to be outdone pulls out an old trick in their marketing gamebook, and throws a black napkin on this ginormous block of tofu and says "That's only a 270 HP bit of faux-fu fourstroke...not a true 330, like ours!"
It's only a matter of time that Mercury paints their engines white to look larger than before, after all...size matters in this ultimate pissing contest....and the expectation is that the dinner guests push their chairs back, fall prostate on the ground and worship the 330 HP 300 that is the Mercury Racing Division's OptiMax XS (only when burning premium fuel though..on regular fuel, it's more like 300 HP)
Here's the real rub on this particular thread: This wasn't Mercury's dinner party. It was Evinrude's - the Mercury contingent showed up on an informational thread about a particular product manufactured by Evinrude, and first questioned if the motor was actually real (A HILARIOUS comment from that camp, by the way, given that the VERADO SHELL was promoted and promised to consumers a full TWO YEARS before it was ready to sell). The poster then proceeded to question the veracity of the claimed HP output. Nice manners, especially from a camp that also promotes 'actual' HP figures pulled from a magical hat for all Mercury motors, right down to the made-in-China 2.75 HP 2.5 HP motor for dingies (Man! That thing can crank out the HP!).
Heh...yeah - pretty funny. Just like the 275 HP VERADO being sold that only puts out 250 HP unless running on PREMIUM fuel. My side hurt after pondering that one...until I cried just a little when I thought about how diabolically brilliant that one is - get a premium profit on a 250 hp motor by requiring the owner to put premium gas in!
L H G posted 10-17-2007 07:56 PM ET (US)     Profile for L H G
As long a Buckda wants to keep bringing it back to the surface, I should repeat my contention that Roch Lambert of Evinrude is lying to the outboard buying public in his PATENTLY FALSE statement, as published by JimH:
1. Is a Mercury 250XS or 250 PRO XS Optimax not a 2-stroke DFI engine, just like an E-tec? OF COURSE IT IS!
2. Is a Mercury 250XS or 250 PRO XS not a competitive engine to the E-tec 250 HO? OF COURSE IT IS! The Merc model has only been on the market 4 years, and still counting, ahead of this Evinrude product (which is a little late to the dance unfortunately). Evinrude as actually HOPING that this yet to be available model can run competitivley with Merc 250 Opti's. Time will tell.
3. Is the Mercury 250XS (which "blkmtrfan" has produced a link to the Merc HP graph per JimH's request) not a 270HP engine like the 250HO MAY be? OF COURSE IT IS!
4. Does the Mercury 250 XS and PRO XS not weigh LESS than the Evinrude 250 HO? OF COURSE THEY DO! Yet he says it weighs 128 pound MORE. Therefore, what an outright lie and false statement. Fortunately, most buyers of an engine of this type aren't that stupid to fall for such a marketing ruse.
PS, Buckda: people who knowlingly tell lies are called LIARS.
jimh posted 10-17-2007 08:39 PM ET (US)     Profile for jimh  Send Email to jimh
I think Roch is speaking in a manner we in the States call "lawyer speech." There is nothing at all false about what he said. The E-TEC is much lighter than competitive engines at the same power. He did not say that it was lighter than ALL competitive engines at the same power. But it definitely is lighter than more than one competitive engine, so the plural is completely justified.
I am sorry but I don't see the link to the published power curves mentioned and attributed to blkmtrfan. Perhaps I am overlooking it, but it is worth repeating.
Binkie posted 10-17-2007 08:44 PM ET (US)     Profile for Binkie
JayR
Your comment--Lots of intelligent people in NJ--haha, I liked that, were you trying to be sarcastic? :)
rich
Peter posted 10-17-2007 09:00 PM ET (US)     Profile for Peter  Send Email to Peter
Jim See i61.photobucket.com/albums/h53/blkmtrfan/merc300/300xspowergraph2ra.jpg . According to the graph, the 2-Star 300 XS is good for about 305 HP at 5750 RPM. Of course its a Mercury marketing department produced graph so take it for what its worth.
fourdfish posted 10-17-2007 09:07 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Actually Jim, Lambert never mentions which engines he is refering to! He never said anything about Optimax! LARRY is the person putting those words in his mouth. Larry also is
the source for the any horsepower guessing which is not
actually advertised on any engine talked about here.
He has no proof what so ever of the 270 horsepower claim
for any engine he talks about.
So in fact Lambert never lied about anything!
However Larry is upset about Evinrudes progress in the market or he would not have made such claims.
When he says "OF COURSE IT IS", It is just his opinion again. When you know you can't back something up but say it anyway, Is that also a form of telling a lie!
Then at the end of #4 he actually calls everyone who has
purchased an Evinrude--STUPID
The desperation is truly showing now!
jeffs22outrage posted 10-17-2007 09:55 PM ET (US)     Profile for jeffs22outrage  Send Email to jeffs22outrage
You know all of this bickering gets no where. It is a losing battle on both sides.
Any how Horsepower is only ONE part of a given motor's measure of output. Torque is the more important factor for me at least. Why manufactures do not post torque ratings is beside me. Is it because the manufactures believe the buying public only knows what horsepower is (most in a very loose sense) and that the more the better? Hence the Horsepower wars?
Boats run for the most part at a constant speed which is where torque plays an import role. Horsepower might get you up on plane faster but, more torque will let you turn a higher pitched prop at lower RPMs which uses less fuel at the same speed over water. Big selling point to me.
Also, I have said it before when repowering I would imagine the dealer has a lot to do with that choice. If you have a long standing relationship with one guy and he only services brand X. A buyer is more likely to go with that brand and keep the relationship with a trusted Mechanic. I feel that way. All of my life up until my 22 with the Evinrude 235 I only had experience with Mercury based products. Products I LOVED but, when something went wrong every dealer or service shop experience was less than pleasant. Some where down right horrible. I do not know of one Mercury service shop or dealer in my area that I would trust. My father is going to try one of the few we have not been to for service yet. He needs some work done on his twin 150's Hopefully that will be a good experience.
On the other hand, upon the recommendation of others I took my 22 Outrage with the 235 to Lockemans for service. I fully expected the same run around and cost over runs. Not the case. It was better than both the Lexus and Saturn Dealers I have ever dealt with (Both ranked at the top of JD Power at the time). Infact it was the best service experience I had ever had hands down for anything. Every visit since only helped to solidify my trust with them. With that I would most likely ONLY repower with a product they sell and service (BRP). Not only am I supporting a business that has been good to me but, I know that if something goes wrong it will be in good hands.
Now about that Merc dealer that we have not been to yet. I am holding out hope that things would go well. I think they will. Why? Because there is a loose family connection to those how own Lockemans. So, it is my trust in my OMC mechanic is what has giving some hope / faith to a Merc dealer. Larry if you can offer up a name to a trusted Merc service / dealer here in my area it would be appreciated.
glen e posted 10-17-2007 10:22 PM ET (US)     Profile for glen e  Send Email to glen e
Jeff -
Merc has updated their website so you can find a local dealer...if you have anything but a verado, look for a "Premier dealer" - if you have a Verado, look for a "verado certified" dealer
http://direct.where2getit.com/cwc/apps/w2gi.php?&client=mercurymarine&template=search
tmann45 posted 10-18-2007 07:49 AM ET (US)     Profile for tmann45  Send Email to tmann45
Did anyone notice that the HP graph was in BHP not prop shaft horsepower?
blkmtrfan posted 10-18-2007 11:46 AM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
BHP = Brake Horse Power
fourdfish posted 10-18-2007 11:56 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
Tohsgib posted 10-18-2007 11:56 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Larry I agree about the weights of the XS series outboards but I have to add one thing, they are not really "competitive" to mainstream engines being they are more race inspired than daily drivers. Not saying you can't use them for that, many do, but I do not think you will EVER see one on a Whaler, Grady, Hydra-Sports, etc. Sure you will see them on go-fasts or flats boats and a few Concept or Donzi offshore rigs but they are not competeing with the 26 Grady guy who wants twin F150's or a single F300.
Tom W Clark posted 10-18-2007 11:57 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Brake Horsepower = power at the powerhead, not the prop shaft.
Good catch tmann45.
blkmtrfan posted 10-18-2007 12:23 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
Tom I am pretty sure that the horsepower listed is at the propshaft, perhaps XSTech can confirm.
I do know that both the 250xs and 300xs have been pretty well tested on many boats on http://forums.screamandfly.com/ and the claimed horsepower has compared well with know motors.
I realize that the brake horsepower is "at the motor" when refering to automotive engines and in the car croud they typically brag about RWHP or rear wheel horsepower.
But in the outboard motor world, propshaft horsepower is the standard method...
blkmtrfan posted 10-18-2007 12:30 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
From the Mercury Website
http://www.mercuryracing.com/products/consumeroutboards/optimax300xs.php
The 300xs hp is listed as:
Propshaft Rated Horsepower (HP / kW) 300 (224kw)
http://www.mercuryracing.com/_media/images/products/optimax300xs/ large_optimax300xs.jpg
Peter posted 10-18-2007 12:40 PM ET (US)     Profile for Peter  Send Email to Peter
A little expansion on the BHE education....
quote:
Brake horsepower (bhp)
Brake horsepower (bhp) is the measure of an engine's horsepower without the loss in power caused by the gearbox, generator, differential, water pump, and other auxiliary components. Thus the prefix "brake" refers to where the power is measured: at the engine's output shaft, as on an engine dynamometer. The actual horsepower delivered to the driving wheels is less. An engine would have to be retested to obtain a rating in another system. The term "brake" refers to the original use of a band brake to measure torque during the test (which is multiplied by the engine RPM and a scaling constant to give horsepower).
Source: en.wikipedia.org/wiki/Horsepower#Brake_horsepower_.28bhp.29
tmann45 posted 10-18-2007 01:01 PM ET (US)     Profile for tmann45  Send Email to tmann45
blkmtrfan,
Don't get upset, I am also a Mercury fan, I own two.
However, the graph states BHP and the specifications state Rated. A graph is usually something that is measured, Rated is just that, rated.
From Merriam-Webster dictionary:
Rated-
2 a: to set an estimate on : value, esteem <black is rated very high this season> b: to determine or assign the relative rank or class of : grade <rate a seaman> c: to estimate the normal capacity or power of
blkmtrfan posted 10-18-2007 01:22 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
tmann45, I am not upset :)
Yes I am a Mercury fan, but not a total fannatic, LOL
I am probably more of a 2-stroke fan than anything else.
I think the Etec is great and hope BRP has continued sucess with it.
However, I do want to make sure that the facts we are using are correct.
I will try to dig up the original source of the graph and see if there is any insite on it.
fourdfish posted 10-18-2007 02:05 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Sounds like Larry was comparing Apples and Oranges when he used the graph as a source for his horsepower comparisons.
Open mouth and insert foot!
L H G posted 10-18-2007 03:17 PM ET (US)     Profile for L H G
Nick: I think you are getting senile at an early age!!
See: http://continuouswave.com/whaler/cetacea/cetaceaPage78.html
Besides the fact that you and JimH photographed well at this event, there are two photos of a 320 Boston Whaler Outrage with twin 250XS Optimax engines installed. Before the Verados became available, Boston Whaler sold many 320's with these Merc XS engines. I will agree, however, that since the big 4-strokes hit the market, DFI applications for offshore boats has just about disappeared, except for the SKA and offshore performance segment, basically owned by Optimax XS.
More on Jim's "lawyer speak" regarding Lambert. Good try, but simply not true, or Lambert & crew is really out of touch with REALITY (which I doubt).
1. The high performance DFI market (i.e. "competitive" engines to an Evinrude HO), are Merc XS Opti's and Yamaha Vmax, NEITHER WEIGHING 128# more than Evinrude's offering as he says). These are your bass boat engines, etc. Like Nick says, these engines are not used for offshore boating, except for the Opti's, which come up to 30" shaft length. Who puts triple HO's or Vmax's on a Whaler type boat? Nobody. So, the REAL competitive engines to an Evinrude HO *ARE* the XS/ProXS & Vmax, the one's Bass and WAlleye Boats Mag likes to test. Verado, and especially Yamaha and Suzuki 4-stroke 250's are not widely bought for the bass boat market. Lambert needs to know who his real competition is with the Evinrude HO's, and it's XS/ProXS Optimax and Yamaha VMax, not 4-strokes (they are widely bought for offshore, fishing and cruising applications.
2. So as I said before, his statement is patently false.
He should clean up his act (or fire his press release writer, or at least read what the guy writes before publishing it under his name).
I'm just the messenger here, but is there no integrity at all? This isn't the OJ Simpson trial. Can't someone with a white motor admit the guy has the wrong facts. It can happen to any of us, too, and often does, from the President, to the Moderator and on down! I'm done with this, and wish Evinrude the best with their new HP offering.
None of us matter here, the market will speak.
Plotman posted 10-18-2007 03:18 PM ET (US)     Profile for Plotman  Send Email to Plotman
The corrected part of the graph is a correction for air density differences caused by temperature, humidity and barometric - the measured values are used to calculate a standardized HP that can be compared across engines on different days.
fourdfish posted 10-18-2007 03:53 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Larry- No matter what you say, BRP is aiming squarely at the 4 stroke market. As you said the Optimax is being offered less and less. (Example Boston Whaler) Along the way any sales from the Optimax market is a bonus for BRP. Now that your horsepower graph has been revealed as a non comparison, you still think people will not notice that your horsepower claims here are false! What do you really think your bashing here will accomplish? Do you think that you will really be able to affect BRP or overall outboard sales in any way. All I see here is a disgruntled black motor advertiser, who has nothing better to do and is trying to provoke!
XStech posted 10-18-2007 04:09 PM ET (US)     Profile for XStech  Send Email to XStech
""""Tom I am pretty sure that the horsepower listed is at the propshaft, perhaps XSTech can confirm.""""
Yes, its prop shaft HP.
Just to stir the pot a little. BRB marketing 2>4 is working.. Since the E-tec and its informercials came out, Optimax sales have gone thru the roof.
Buckda posted 10-18-2007 04:45 PM ET (US)     Profile for Buckda  Send Email to Buckda
xs - no stirring....that is a normal phenomenon in advertising to consumers - you raise the tide of awareness, you also lift your competitor's boat..er..motor.
It is one of the decisions that has to be made when producing an advertisement, and a part of why your product's sales will see a drop when a major competitor stops advertising or withdraws from the market.
Dave
blkmtrfan posted 10-18-2007 04:52 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
Thanks XSTech
fourdfish posted 10-18-2007 06:43 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
More Advertising Again!
onlyawhaler posted 10-18-2007 07:29 PM ET (US)     Profile for onlyawhaler  Send Email to onlyawhaler
"Just to stir the pot a little. BRB marketing 2>4 is working.. Since the E-tec and its informercials came out, Optimax sales have gone thru the roof."
Are Optimax sales up? Can this be confirmed? That is a bit suprising to me in the wake of 4 stroke momentum. It would tend to indicate that BRPs two stroke message is working
Onlyawhaler
blkmtrfan posted 10-18-2007 07:53 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
If anyone knows the inside scoup on Optimax sales, I would think XSTech would...
jimh posted 10-18-2007 08:06 PM ET (US)     Profile for jimh  Send Email to jimh
There is not any verifiable unit sales volume data available about outboard motors. Anecdotal reports of certain brands and certain models experiencing significant increases in unit sales volume are just that--anecdotes.
fourdfish posted 10-18-2007 08:28 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Then maybe XSTECH can provide all of his SOURCES for his
statistics here! Larry obviously could not!
XStech posted 10-18-2007 10:59 PM ET (US)     Profile for XStech  Send Email to XStech
I talk every day to the guy whos wife bought a cat from the sister of the janitor at gas station next to the Mercury plant.
fourdfish posted 10-18-2007 11:37 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
It figures, another member here who is a Merc rep who can talk out of both sides of his mouth.
L H G posted 10-18-2007 11:46 PM ET (US)     Profile for L H G
"XS" - Surely you must be aware that the Evinrude website has a hot new product in their "Evinrude boating gear" offerings. Besides the regular caps and tee shirts, they are doing very well with Rose Colored Glasses, called "Denials".
It appears they are big sellers here around ContinuousWave.
Incidentally, I'm sure many of us appreciate your contributions here.
Jefecinco posted 10-19-2007 10:11 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
LHG,
Initally in this discussion I believed some good natured ribbing was at work. But it seems to go beyond that.
It's difficult for me to understand why a fan of product "B" is threatened by a move forward by product "A".
I happen to think Whalers are the best recreational boats made. I also think BRP makes the best outboard engines. However, that does not mean I cannot admire Edgewater boats and Verado engines.
I hope I never appear silly in my admiration of and loyalty to Whaler and BRP. Lets try to get a grip out there, pardner.
XStech posted 10-19-2007 10:47 AM ET (US)     Profile for XStech  Send Email to XStech
First off, I'm not bashing with this post. There are things about the E-tec that I like, and I think they have done a pretty good job. I just have a question.
What makes you think that? Is it their marketing? Have you owned all brands and had the best experance with BRP?
Are you a mechanical engineer and had every brand apart? Or is it just the overall running experience you had with a BRP product?
Just curious because I hear that statement so often and wonder what its based on.
Thanks
XS
fourdfish posted 10-19-2007 11:34 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
XStech-I'm sure you aware that everyone here knows you are a company rep! That being the case, Have you noticed that Seahorse, a respected Evinrude mech often comes on here to help but never posts outright advertisments or bashs other manufactures.
Larry expresses his opinions and calls them facts without
credible sources.
So you say you are hearing Butchs statements so often (really)! He also says ("I think") so he has his right to his opinion and actually says it is his opinion! Not misrepresentative facts!
XStech posted 10-19-2007 11:45 AM ET (US)     Profile for XStech  Send Email to XStech
He also says ("I think") so he has his right to his opinion and actually says it is his opinion! Not misrepresentative facts.
As I said, this is not a bash, just true curiosity.
What is it about BRP that brings on the opinion? Simple question.
XS
blkmtrfan posted 10-19-2007 11:51 AM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
fourdfish, what "bashing" are you refering to?
I will agree that LHG likes to bash, but where has XSTech done it?
fourdfish posted 10-19-2007 12:23 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Please reps, posting during company time. You can try to hide it but anyone can see a sales pitch here! On an ETEC thread to boot!
blkmtrfan posted 10-19-2007 12:43 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
fourdfish, so now you think I work for Merc ...
Sounds like you are the one who needs to check his facts!
Tohsgib posted 10-19-2007 12:48 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
My senility is not the problem Larry, it is the rose colored glasses I lent you in Stuart. The dealer told me that boat was custom ordered and you know it and why you took the pic. Look through your brochures, the XS is NOT an option in my 2003 nor 2006 or 2007 brochure. I don't have an 04 or 05 so somebody take a look.
Why do you have to be such an ass, I was trying to be nice and on your side but you just...why am I wasting my fingers on you.
fourdfish posted 10-19-2007 12:58 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Sorry blkmtrfan, I typed it out faster than I was thinking!
elaelap posted 10-19-2007 01:28 PM ET (US)     Profile for elaelap  Send Email to elaelap
Some of you brand name enthusiasts may have noticed that I never take sides in these debates. Give me a nice, new four stroke or E-TEC with a solid warranty from any of the major manufacturers and I'm happy, as long as the motor doesn't have any obvious flaws, is quiet and smokeless, and gets decent fuel economy.
That being said, and since we have Mr. XStech--an acknowledged Mercury spokesperson--on board, let me tell you a little tale. When I was shopping for my second Whaler I kept going back and forth in my mind about whether to buy a brand new Montauk 170, powered by the obligatory Mercury outboard, a 90 hp four stroke, and a classic Outrage 18, which I would immediately repower with a new four stroke of my choice (E-TEC wasn't an option back then). After twisting our local BW dealer's arms a little, I finally got to sea trial the MT 170 (I already had had the opportunity to cruise and fish in a CW member's OR 18 on several occasions, and I wanted to compare the two boats). I really loved the big Montauk, and drove her hard in the Oakland Estuary, purposely bouncing over tugboat wakes, spinning the boat around so she could launch off her own wake, putting along at slow trolling speeds to see how she would handle like that, repeatedly taking off from dead stops to check out the boat's time onto plane, etc. I really liked the BOAT's performance (and I've grown to appreciate the 170s more and more over the years as I've cadged rides in them from friends), but that Mercury 90 4/s...man oh man oh man. Plenty of power, but a very obnoxious, worrisome 'clunk!' when shifting from neutral into forward or reverse, and an absolutely awful grinding, whirring sound when I backed off the motor swiftly and dropped the boat off plane. The metal grinding together sounded like the motor was tearing itself apart.
The poor guy who was with me during the sea trial (actually one of the owners of the dealership--Craig, for you locals) just didn't have anything valid to say when I asked him about both these perceived problems: "Uh, uh, don't worry about it; it's just the way the motor is designed" was all he could come up with, as he saw another potential sale fading into the foggy sunset. I really felt sorry for him. No way was I going to buy a clunker like that for the kind of money Craig was asking (or for any other amount, truth be told), even though I really liked the boat itself.
Soon after, I bought the wonderful 1988 Outrage 18 I renamed 'Cetaceous', immediately repowered her with a new Yamaha F115, and put over 750 happy, non-clunky hours on that quiet, smooth shifting motor without a problem over the next two years. And the repowered Outrage ended up costing me substantially less than the sweet 170 with the sour Merc 90 would have ;-)
So, Mr. MercTech, since you're here--why the hell couldn't Mercury fix those problems? I'm sure that I'm not the only person who passed on buying a new Boston Whaler because of them. And please, please don't tell me the problems were "nothing to worry about." Nothing to worry about indeed. I didn't worry about them...I bought a motor built by a different manufacturer.
Tony
blkmtrfan posted 10-19-2007 01:35 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
No problem fourdfish :)
Tohsgib the 2003 320 Outrage brochure (a seperate supplement to the full line catalog) Shows the yellow 320 with the 250xs motors on it and the 250xs motors are listed as optional power.
The 2004 full line catalog shows the same boat/motor combo.
The 2005 catalog shows Verados on the 320 Outrage.
I just happen to have Tom Clarks CD handy :)
XStech posted 10-19-2007 02:46 PM ET (US)     Profile for XStech  Send Email to XStech
First off, let me say this. I have very little first hand knowage about small 4 stroke outboards. I've spent the last 20 years with large 2 stroke outboards.
That being said, I'm not the person that can answer your questions. But I'll take a shot.
In the age before E-tec's, the small Merc 4s were Yamahas in black paint (although I think the gearcase was Merc)
Gearcases "clunk" when shifted. Some more than others. What can I say. Is it a "problem"? Not to most of the buying public. If a company has a set amount of time and money to improve a motor, and they could choose to reduce the "clunk", or reduce the amount of fuel burned, most would work on fuel burn. The fact that some companys chose to work on the "clunk" is a win for the consumer, as now they have a wider range of products to buy.
The grinding, whirring during decel I will guess was a ratcheting gearcase. The clutch dog was spring loaded, so as the moter deceled, and the prop tried to keep going, the clutch dog would come in and out of gear (basicly).
During that time, all Mercs had that type of gearcase. Currently, all Merc large outboards have non-ratcheting gearcases, and you will no longer hear the whir. I have no idea what the mid and small 4s have these days, so if you were to trial a more current Merc outboard, I don't know what you would think.
Sorry I couldn't give you a better answer.
XS
L H G posted 10-19-2007 03:15 PM ET (US)     Profile for L H G
Thanks, "blkmtrfan", for supplying backup information on my posts, first when JimH challenged the XS horsepower, and secondly with the 2004 Whaler offerings when Nick wasn't very nice to me! The photo of the XS rigged 320 Outrage in Cetacea, incidentally, was taken and posted by Jimh, not me.
But I'm shocked that you, of all people, called me a "corporate basher" :)
I'm just having a little fun around here keeping ContinuousEtec fair and balanced. Some take it the wrong way, however. It's just that Peter, Fourdfish, Buckda and Andy Gere (Etec fans all), have been so mean and hurtful to me.
elaelap posted 10-19-2007 03:17 PM ET (US)     Profile for elaelap  Send Email to elaelap
Thanks for your swift response, XS, though it didn't really go much further than Craig's.
In rhetoric and logic, a statement such as the following is known as a "false dichotomy":
"If a company has a set amount of time and money to improve a motor, and they could choose to reduce the "clunk", or reduce the amount of fuel burned, most would work on fuel burn."
Works with the gullible on occasion, and is often employed by politicians:
"If we've only got a certain amount of time and money to improve our nation, and we could choose to spend five billion on children's health care or over one trillion dollars on the Iraq invasion and occupation, most of us would invade and occupy Iraq" (NOT!!)
Get it? First you set up a false (unnecessary) dichotomy--a false choice between two not-necessarily-related alternatives--and then you assert a supposedly sound basis for supporting your choice. With respect, XStech, what the hell does improving fuel economy have to do with fixing a trashy, flawed gearcase?
Anyway, to prove I'm not just attacking Mercs, I actually own a very powerful, torguey year 2000 Merc 75 two stroke, which fires right up and runs like da bomb. And my latest four stroke (I sold my OR 18) isn't a Yamaha at all, but a very nice Suzuki 140 4/s EFI. Again, I'm not a brand name enthusiast, but I sure don't think Mercury outboards are AUTOMATICALLY better than any others...not from my experience anyway.
Tony
fourdfish posted 10-19-2007 03:31 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
LHG-- OMG you have to be kidding! If that is not trolling I don't know what is!!!!
Tohsgib posted 10-19-2007 03:44 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Larry it is time to change your Depends...you are obviously full of crap! How was I mean to you? And this is your idea of fun..WOW holidays much be a knee slapper around you.
blkmtrfan posted 10-19-2007 04:13 PM ET (US)     Profile for blkmtrfan  Send Email to blkmtrfan
I was under the impression that some of the "clunking" issues in the earily 2000's had more to do with the FloTorq prop inserts than the lower units, which have since been improved?
I for one don't mind and in fact really like my ratcheting (sportsmaster) gearcase :)
XStech posted 10-19-2007 05:34 PM ET (US)     Profile for XStech  Send Email to XStech
Man, you caught me. I was hoping you WERE more gullible. Plus it was a little good natured shot at another company (What, nobody caught that???)
There is no "better" outboard. Some do something better that one consumer wants, some do something different. Every consumer product is a compromise in some fashion.
And with respect, what does any of this have to do with the 300 E-tec???
And now back to your regularly schedualed bashing. ;-)
elaelap posted 10-19-2007 05:42 PM ET (US)     Profile for elaelap  Send Email to elaelap
"There is no "better" outboard. Some do something better that one consumer wants, some do something different. Every consumer product is a compromise in some fashion."
AHHHHHHHHHHH!!!!!! Now there's true logic, and a bracing breath of fresh salt air, from a particular outboard manufacturer's rep, no less. Y'all listening, folks?
Tony
fourdfish posted 10-19-2007 07:18 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
XSTech appears to have spent the whole day posting on this web site. I hope he had the day off! Or did the company pay him to post during work hours? Most companys would not put up that!
XStech posted 10-19-2007 07:20 PM ET (US)     Profile for XStech  Send Email to XStech
I can fix that.
Some companys do a lot of things better that a lot more consumers like. ;-)
Ah, and just when we were about to have a group hug.
just kidding
XStech posted 10-19-2007 07:22 PM ET (US)     Profile for XStech  Send Email to XStech
Vacation on Friday = three day weekend.
andygere posted 10-20-2007 12:42 AM ET (US)     Profile for andygere  Send Email to andygere
Geez Larry, you see a new thread about a new non-Mercury motor and you immediately attack it knowing nothing first hand about the product. Now you want sympathy because the "E-TEC" gang is ganging up on you and being mean and hurtful. Give me a break. You entered the discussion looking for a spirited debate and you got one. You threw barbs and accusations at anyone that disagreed with you but somehow you are shocked when they come back your way. Sad.
I'm sure in the non-virtual world, say out on the water on a Saturday afternoon, you are a decent guy. You know a great deal about Boston Whalers, and there was a time when you readily came to this forum to share that information and be a friendly participant in discussions on boats and motors. Lately its all this BS. What happened?
Finally, guys like Buckda, Fourdfish and me are all making our points about E-TEC motors based on our actual experience as owners of them. Yep, we put our money down, bolted them on and can provide first hand information, good or bad about how they run. When you've done the same, I'll be happy to talk outboards with you again.
AG out.
Jefecinco posted 10-20-2007 11:08 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
XStech asked me, in effect, to justify my belief that Whaler makes the best boat and BRP maked the best outboard engine.
Of course I was simply expressing my personal opinion based upon goodness knows how much evidence. It's an opinion that took a lot of years to form as I've only recently formed the opinion and I've been boating, off and on, for about 55 years.
My experience stretches between a wooden skiff with a small Evinrude in the fifties to a 6,000 ton vessel with OP FBM diesels and GE LM1500 turbines in the eighties. I've owned a recreational boat continuously since 1977. I've owned a FICHT powered Whaler for the past eight years.
I have an extensive mechanical background but mostly in the large diesel arena.
My experience tells me that simplicity in design and build of an engine is better. That engine will be less likely to break and easier and less costly to repair when it breaks. IMO, the E-Tec and FICHT engine has an elegant design with the E-Tec being a much more refined example of the FICHT. Sort of like the Model T followed by the Model A?
Furthermore my FICHT experience has told me the underlying design of the E-Tec is bullet proof.
Thus my belief. Just an opinion like those expressed by others. Clearly, YMMV.
XStech posted 10-20-2007 12:17 PM ET (US)     Profile for XStech  Send Email to XStech
Interesting, thanks.
