ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Evinrude E-TEC Maintenance
Author | Topic: Evinrude E-TEC Maintenance |
Ferdinando |
posted 12-24-2013 04:08 PM ET (US)
If someone could answer this for me I'd be much obliged. I have a 2009 E-TEC 150. The scheduled first maintenance is at 300-hour or three years. I arrived at the three years long before I hit the 300-hours; only have 149-hours. Do I give the engine another three years or 300-hours before I perform the scheduled maintenance again? Or is [the next maintenace interval to be done at] a totally different number? Thanks and a very Merry Christmas to all. I appreciate all of your help throughout the years. --Fred |
OMCrobert |
posted 12-24-2013 04:58 PM ET (US)
I really like the winterization feature of the Evinrude. Other then that, do normal maintance. The 300 hour/3 year no maintance is for fresh water and even then I would still want to change the gearlube, pull the prop, grease the props haft and zerk fittings. It is a good marketing ploy but routine maintance is always better. Can you get 6 years out of a water pump or 3 years on gearlube, sure but why chance it. |
Peter |
posted 12-24-2013 11:03 PM ET (US)
Unlike some other manufacturers, Evinrude uses a full synthetic gear lube in the gearcase. There is no reason why it cannot go 300 hours between changes unless you have water intrusion from a bad seal. If there is significant water in the gearcase oil, it will settle to the bottom of the gearcase and it will be the first thing that comes out of the drain. If there is a little bit of water, it may be suspended in the oil doing no harm due to emusifiers in the oil. Between the 300 hour intervals, just crack the drain plug open slightly and let a few drops out to see if there is any water. |
Jefecinco |
posted 12-25-2013 10:11 AM ET (US)
Fred, The oil has been in the leg for at least four years. I suspect you've had your moneys worth out of that oil. I would change it. I believe your boat use is in salt water and offshore. If it was my engine I would replace the impeller, change the oil and lubricate the propeller shaft. If you find water in the oil consider replacement of the shaft seal. Consider it an investment in peace of mind. Butch |
Ferdinando |
posted 12-25-2013 01:50 PM ET (US)
Butch: I think you misunderstood me, I did my 300 hr ck up and change of oil, plugs, impeller, etc, etc, etc last Oct 2012 when my engine hit it's three year mark although I was not even close to the 300 hr mark (only had 149 hrs). Ran me 500 bucks and was completed in 2 hrs by the the Evinrude Tech. I am asking if I can go another 300 hrs and or 3 yrs before my next maintenance? No one seems to have a confirmed answer. Thks, Fred |
saumon |
posted 12-25-2013 05:40 PM ET (US)
The answer is yes. If you did it at 3 years, you won't do it again when you'll hit 300 total hrs. You'll do it in 3 years or at 449 total hrs, whichever come first. |
Ferdinando |
posted 12-25-2013 09:08 PM ET (US)
Thanks. |
posted 12-25-2013 11:59 PM ET (US)
In the E-TEC owner's manual there is a list of items for maintenance and the intervals at which each item is to be done. Many items are routine maintenance, and should be done routinely. Some are only needed every three years or every 300-hours of engine running time. And some intervals vary depending on the environment or the use. If an item is specified for your environment as an every three year maintenance or every 300-hour maintenance, whichever comes first, then you perform it every three years or every 300-hours, and repeat that same procedure at the next three-year or 300-hour interval. E-TEC does not say there is no maintenance for three years or 300-hours. What Evinrude says is there is no scheduled dealer maintenance for three years or 300-hours. The owner should be performing the routine maintenance in a routine fashion. This is all listed in the owner's manual. |
Ferdinando |
posted 12-26-2013 07:33 PM ET (US)
Thks Jim! |
Mambo Minnow |
posted 12-29-2013 10:31 AM ET (US)
The no dealer scheduled maintenance schedule is for freshwater use only. The advantages of the E-TEC for those of us operating in saltwater is far less compelling over other motors. |
Peter |
posted 12-29-2013 08:03 PM ET (US)
Exactly what dealer maintenance is required in saltwater prior to the 3 year/300 hour intervale? |
Mambo Minnow |
posted 12-29-2013 09:17 PM ET (US)
From page 44 "Maintenance" in reference to the 3 year/300 hours : "1) Average recreational use. Commercial use, heavy use, or use in salt or polluted water requires more frequent inspection and maintenance (annual checks are recommended)." |
Peter |
posted 12-30-2013 07:15 AM ET (US)
Again, my question is exactly what dealer maintenance is required more frequently? Which of the items on the maintenance list would require more frequent maintenance if used in saltwater and then which of those items would require a dealer to maintain it? The maintenance schedule identifies, by way of reference number (2), exactly THREE items in the list that require annual maintenance if use is in saltwater: 1) anti-corrosion anodes; 2) lubricate grease fittings; and 3) inspect and lubricate propeller shaft splines. Would you take your outboard motor to your dealer to have these items addressed annually if you used your boat in saltwater? If it is your position that everything on the list requires more frequent maintenance (dealer performend or otherwise), then I invite you to explain why in the case of salt versus fresh that the item called out as retorquing the transom mounting bolts to 40 ft-lbs would be required more frequently, or why sparkplugs would require more frequent replacement, or why the oil filter on the pickup tube deep within the remote oil tank would require more frequent replacement. |
posted 12-30-2013 10:59 AM ET (US)
There seems to be a lot of confusion and contradictory advice provided about the E-TEC maintenance. The E-TEC owner's manual and factory service manual are really the authoritative source of information, and I would rely on those sources rather than the off hand remarks made by various persons, some of whom may not even own an E-TEC. The guidance and experience of a trained and certified master technician is also valuable. One frequently misinterpreted maintenance procedure regarding the E-TEC is the service of the thermostats. The thermostats are only to be inspected at 300-hours or three years, or, as suggested for extremely heavy use, commercial use, or use in polluted water or in saltwater, at more frequent intervals, perhaps annually. It is not necessary to replace them if they are in good condition and working properly. When my E-TEC was checked by my Evinrude Platinum level dealer's fully trained and certified master technician, the thermostats housings were opened, the thermostats checked for debris and general condition, and the system was reassembled. New thread seal compound was applied to the housing. The engine was operated until the thermostats opened. Temperature of the individual cylinder heads was monitored on the EV-Diagnostic software to infer the temperature at which each thermostat was opening. The two thermostats operated within a few degrees of each other and within the range limit specified in the service manual. As a result, they were not replaced. In a similar manner, it is not necessary to replace the water pump impeller and associated wear plates and seal at precisely 300-hours or three years. When my engine was serviced at the three-year interval, the water pump was still providing cooling water at the specified pressures, so it was not replaced. My dealer remarked that it is quite normal for the water pump to provide more than three years of service when the engine is operated in the sort of environment that my engine has been. I operate the engine in clear, clean, cold freshwater. I supposed if you operate the E-TEC in a soupy swamp of tropical saltwater you might get a different outcome. This is clearly explained in the owner's manual. Some of the hostility that seems to exist regarding the E-TEC and the 300-hour or three-year maintenance seems to be a result of people misrepresenting the stance of Evinrude about these service intervals. People seem to invent their own version of what Evinrude has said, and then use their invented version to be the target of complaints or attacks that it is misleading. I recommend reading the owner's manual and the factory service manual to become acquainted with E-TEC maintenance. You may also find good advice from other E-TEC owners who have operated their E-TEC for more than 300-hours or three years. I would prefer those sources to advice from people who seem to be somewhat unfamiliar with the actual advice of Evinrude regarding maintenance of the E-TEC and who don't seem to have any first-hand experience with the maintenance of an E-TEC. When any advice is given in which the term "marketing ploy" is used, I would be especially wary. In my experience the biggest "ploy" is often the misrepresentation by these non-expert advisors of what Evinrude actually recommends for maintenance for the E-TEC. |
OMCrobert |
posted 12-30-2013 04:56 PM ET (US)
I will then contend that the Evinrude Etec when used in saltwater does not offer real any benefit as to less maintenance than any other 2 stroke outboard (Yamaha HPDI's not included) In fact I will argue that the 3 year no maintenance ploy has caused much confusion and may result in lack of required basic maintenance such as greasing fittings and prop shaft. As we saw with the Yamaha 4 stroke that went 7800+ hours on the watertaxi, any engine can go past the required schedule of maintenance without blowing up.
Jefecinco |
posted 12-30-2013 05:37 PM ET (US)
Robert, I don't recall reading any comment that says if the maintenance requirement schedule is not meticulously followed the engine will blow up. Even the Army says it's OK to be 10% beyond the scheduled maintenance hours, miles, days or operations(functions). I believe the majority of maintenance professions agree that there are no dire outcomes from missing a maintenance period now and then. Too many misses can and often will result in a gradual deterioration in reliability. Butch |
OMCrobert |
posted 12-30-2013 06:06 PM ET (US)
Butch I agree. My point was that any outboard motor company in theory could claim the same as Evinrude with little downside. Hence why I call it a good marketing ploy. |
Ferdinando |
posted 12-30-2013 07:27 PM ET (US)
I purchased a brand new 15 SS back in 1985 with a 70 VRO Evinrude. I had this engine for 13 years. The only thing I did to it in that time frame was change the gear oil every 50 hrs, 2 water impellers and 3 sets of plugs. The engine never was serviced by an Evinrude Tech and was still going strong when I sold it, even the VRO never gave me any problems. When I sold the 15' I bought a new 17'with a new 1998 90 Johnson Ocean Pro, same thing 10 yrs of flawless service without ever seeing a marine tech. Did basic preventive maintenance and that was it. That' one of the reasons I've always stayed a loyal Evinrude/Johnson fan all these years, and why I dumped my |
posted 12-31-2013 02:04 AM ET (US)
Fernando--Many thanks for your first-hand account of your experience in operating an Evinrude in saltwater. It is always great to have actual, real-world, first-hand results in a discussion. They are much better than speculations and conjectures. |
posted 12-31-2013 02:17 AM ET (US)
If Evinrude states that maintenance is to be done at a certain interval, the critics decide--based apparently on their expertise--that this interval is wrong and is too long. The maintenance actually needs to be done more often than the manufacturer recommends. If a manufacturer of another brand says their maintenance needs to be done at a certain interval, these same critics decide--again based apparently on their expertise--that this interval is wrong and is too short. The maintenance actually needs to be done less often than the manufacturer recommends. I have to depend on the manufacturer to tell me how often his product should be serviced. There may be experts out there that can tell me the better way to perform maintenance, but I am old fashioned: I just follow the recommendation of the manufacturer. And that is what I recommend to others. |
2manyboats |
posted 12-31-2013 09:11 AM ET (US)
We have owned a 2007 60hp E-TEC, a 2009 90 E-TEC and currently own a 2012 90 E-TEC and a 2010 150 E-TEC. The 60 had about 900 hrs on it when we sold it. Never changed the impeller, we did hit the grease fittings a few times and changed plugs 3 times. Changed lower unit oil 2 times and it looked good both times. It took 4 years to get to 900hrs. The first 90 had about 1500 hrs on it( 1300 in the first 2 years) . We had to replace an injector and the tilt and trim unit around 950hr and the starter relay at about 1400hr. Changed the impeller at 900 hrs and again when we replaced the lower unit at 1300 hrs. Lower unit failure was from smacking a big log in the swamp. I changed the plugs probably 4 times on this motor, it didn't need that many as one change was when I was looking for what ended up being the injector problem. The 150 has had no maintenance as it has less than 300 hrs. The new 90 has been in service for one year and needs to go in for service, that will include impeller and scan for fault codes,based on miles traveled I suspect we have close to 1000 hrs. I have changed plugs once and lower unit oil once. I now change plugs when mpg's start to drop or slow to start. So plugs seem to last 300 to 400 hrs. We run ethanol gas with blue stabil through 10 micron filters and only use XD-50. We track miles on the GPS and the 90's travel about 10,000 miles per year. We have 2 Yamahas and 2 Hondas and I change the oil once a year both in the engine and lower unit. |
Peter |
posted 12-31-2013 09:52 AM ET (US)
I agree that any outboard company COULD lengthen their specified maintenance intervals. But Yamaha won't do that because part of the appeal of Yamaha outboards to their dealer network is scheduled maintenance opportunities. A reduction in scheduled maintenance opportunities means less after-sale revenue opportunities. Based on my experience previously with Evinrude DFI outboards and now with Yamaha DFI outboards, Yamahas are not built with DIY maintenance in mind, but rather dealer maintenance and parts department profits in mind. Evinrudes are clearly more DIY friendly. For example, changing the fuel filter(s) is far more difficult on the Yamaha HPDI than on the Evinrude Ficht or E-TEC. On the Evinrude, the fuel filter/water separator is a spin-on filter which takes about 5 to 10 minutes to change out and costs between 10 and 15 dollars and the only tool required is a simple strap wrench to loosen the filter. In contrast, on the Yamaha HPDI, there are two filters, a first filter/water separator which is relatively easy to get at but the other is a little $30 (costs about $1 to make) plastic filter on the end of the fuel injection lift pump buried inside the vapor separator tank. If this little filter clogs causing the motor to starve for fuel, and they frequently do, one has to unbolt the vapor separator from the engine block using a socket wrench, then separate the top and bottom halves of the vapor separator tank by unscrewing 10 Philips head screws with a long length but moderate driver size Philips head screwdriver so as to be able to reach some of the difficult to reach screws. One also needs a coffee can or equivalent to put all the bolts and screws for later reuse. There is also a $30 custom shaped o-ring that fits between the upper and lower halves of the VST. Once you've had experience performing this maintenance, which the parts manager at the dealer tells me should be done every Spring commissioning, it takes about 45 minutes to an hour to complete. I'm sure that the less mechanically inclined would just take one look at the situation and resign themselves to having the dealer do it when they can get an appointment with the dealer. The 4-stroke motors are even worse because the VST is buried behind the air plenum so you need to remove some of that as well to gain access. |
OMCrobert |
posted 12-31-2013 10:11 AM ET (US)
Well said Peter. Looking at the new outboard engine designs hitting the market in the past 2 years, I would agree that we are seeing a shift to DIY accessibility. The latest engine designs on the market have a QR code for easy scanning and the maintenance schedule right under the cowling with all easy to change filters and even catch cans. Marketing is a powerful tool and many people will follow blindly what they are told without using common sense. I am sure many people change their car oil right at 3000 miles because that is what they are told.
posted 12-31-2013 01:23 PM ET (US)
The two-dimensional scan code on the engine has to be about the dumbest thing I ever saw. In order to have any utility, the owner has to invest in: --a code reader capable device which can interpret the code into some sort of URL --a web browser that can use the URL --an internet connection that can access the URL When you get the information that is provided, it is just static information. What is called "boiler plate" text. (The term boiler plate comes from the notion that the text can be "unbolted" from one place and put in another place without change. It is just static text.) I don't think that is a very useful application on any of those devices. It really is a silly practice. Why not just print the URL in plain text? Why not jut print out the text--which has probably been done in the owner's manual. Even if I fetch the text with my Smartphone (which cost $300) using my wireless mobile data connection (which costs $1,000 per year), all I get is some text and a picture on my little Smartphone screen. The resolution and size of the images will be small. The text will have to be scrolled on the display to read. Are you really going to do this while you are in the process of performing maintenance? With oily hands or grease on your fingers you will be using your Smartphone? As far as I am concerned, the two-dimension scan code is essentially useless. It is a bit of whiz-bang that provides nothing that couldn't be provided better by another method. A good example of an application of modern electronics to engine maintenance is found in my automobile. Using the display of the dashboard and a switch on the steering wheel, I can interrogate the engine to see how much life is left in the oil. The engine computes the oil life based on the actual hours and engine speeds the engine has been run since the oil was last changed. The automobile displays this as the percentage of remaining oil life. When the percentage of remaining oil life approaches, say, 10-percent, then I think about changing the oil. This is an example of how technology can be applied to an engine in a useful way to facilitate maintenance. The difference between this sort of smart application of technology and a stupid application of technology (like a QR code to provide a web URL to static information) is very distinct: --Smart technology, like the computed oil life remaining, adds computation and dynamic data, takes advantage of built-in displays and input devices, and makes the maintenance more timely. --Dumb technology, like the QR code, requires the user to invest thousand of dollars in additional devices in order to even use the method, and delivers the same or inferior results as could be achieved with much less expensive and much simpler methods. Its purpose seems mainly to adapt some technology for a purpose for which it is not very well suited. I'll take no-extra-cost smart technology over expensive-add-on dumb, wiz-bang technology. |
posted 12-31-2013 01:28 PM ET (US)
quote: I cannot help but make the inference that the speaker of this quote thinks he knows better. The conclusion is then that the reader should ignore what the manufacturer tells them and follow the advice of the speaker of that quote. This leads to the following statement: I am sure many people will not change their car oil at the interval recommended by the manufacturer because they read advice from some guy on the internet who said to ignore that advice and follow his. I don't see that there is any difference in these paradigms, other than to decide who is the expert. Is the expert the manufacturer of the device? Or, is the expert the guy on the internet who says the manufacturer's advice is bad? |
OMCrobert |
posted 12-31-2013 01:53 PM ET (US)
"--Dumb technology, like the QR code, requires the user to invest thousand of dollars in additional devices in order to even use the method, and delivers the same or inferior results as could be achieved with much less expensive and much simpler methods. Its purpose seems mainly to adapt some technology for a purpose for which it is not very well suited." You realize that the vast majority of people of under 40 years old have smartphones and QR readers are free on just about every smart phone. They bring you their website with tips on how to do things, videos showing it being done and even ways to troubleshoot basic problems. QR codes are the wave of the future and very helpful all while being at the tip of your fingers. Also, you can take shots at me all you want, but as you stated previously "Many thanks for your first-hand account of your experience in operating an Evinrude in saltwater. It is always great to have actual, real-world, first-hand results in a discussion. They are much better than speculations and conjectures." This directly contradicts you point that you should listen to the manufacturers recommendation not taking into consideration that marketing and sales in any large corporation has a large impact on final policy and recommendation. But as you fail to see the value in QR codes and the benefits, I am sure you will follow what a marketing tells you to do instead of using actual, real-world, first-hand results. |
Peter |
posted 12-31-2013 05:03 PM ET (US)
I too don't see much value in the QR code pasted on the engine component to provide static info. No reason why they can't provide the same info with a URL address to get the same static info. The QR code simply saves a few key strokes on the mobile device. It still doesn't reduce the routine maintenance effort for the motor. Reducing routine maintenance effort is where the value is for an outboard motor. |
OMCrobert |
posted 12-31-2013 05:25 PM ET (US)
The QR code provides much more. Such as engine specific information, serial numbers, maintance log and tracker. As well as parts specific to that exact serial number since it is a direct link. The QR code is just one single example of ways that a new outboard is making DIY more user friendly and geared toward not going back to dealer. My initial point was that three years without having to go to the dealer is not that impressive. All outboards require routine maintance, I think we can all agree on that. |
Peter |
posted 12-31-2013 06:32 PM ET (US)
If you are impressed by a simple QR code that doesn't do anything except retrieve information stored remotely that you then have to review, understand and execute to perform the maintenance, then you must have been blown away when a motor that goes through a self-fogging storage routine with the turn of a key was introduced -- 10 years ago -- and even without a viable internet connection. |
ericflys |
posted 12-31-2013 10:25 PM ET (US)
OMCrobert, you should know better than to making factual comments here on continuousETEC, afterall no motor can compete with the dated ETEC design. As I've said before, I think it would be hard to be unsatisfied with any of the current offerings from the big outboard manufactures, they have all been producing decent products for some years now. |
posted 01-01-2014 08:27 AM ET (US)
I am aware that many people carry around with them devices that have enormous capability for electronic communication. That is really not the point of interest. Since we seem to be pointing out the obvious, let me point out something else: most people who have outboard engines can read the character set in which the URL's for internet resources are written, even if they cannot read English. As far as I can see, the QR code on an engine block is about the technological equivalent of a decal with text on it. It is nothing more than a very expensive way to read text in a language other than English. To make a comparison, you might say that it is similar to having the instructions written in Chinese instead of English. The Smartphone is a device that translates Chinese into English. There really is nothing to marvel at in this. It would have been simpler to just print the text in English. Instead, it is printed in Chinese and you have to buy an expensive device to read them and translate back to English. I say "Chinese" because that is a language who character set is incomprehensible to most of us and a language we cannot read. The engine serial number is already on my engine. It is written in Arabic numerals and I can read it without needing a machine. That this information is also provided by the QR Code is not anything exciting, new, or exclusive. The QR Code does not change on an engine, therefore it cannot track anything. The QR Code has no idea what maintenance has been done. If there is some sort of tracking of maintenance, it is being done somewhere else, not in the QR code. All the QR Code does is make obscure and hard to read the place where that tracking is being done. Because the QR Code cannot change once it has been painted on or applied to the engine, it is impossible that the QR Code contains any data that has changed. At best, the QR Code just points to some resource on the internet that contains data. All the QR Code does is make it harder to reach that resource for people who have not made an additional investment in a QR Code reader. The QR Code does not contain any video recordings. If there is a video recording, it is being provided from somewhere else. The QR Code might point to the place where the video recording is hosted on the internet. But you will not get a video to watch from your outboard engine with a QR Code unless you have a device that can retrieve it from the internet, you have access to the internet, and the resource is available from the internet. If you are in the middle of Lake Michigan, you won't be able to watch a video from a QR Code because you won't have access to the internet. The QR Code is not a video, but it is just a pointer to a video. I also very much doubt that the video changes its content based on anything that has happened to the engine. The video does not change because the engine has a certain number of hours on it, or change because the engine won't start this morning, or change because I forgot to replace the fuel filter. The QR Code just points to an unchanging, generic video that is applicable to an entire class of engines. If a manufacturer wanted to provide a video with their engine, they could include a memory storage device, say a micro SD memory card, and you could put that into your device and watch it. Then you could get the video without the internet connection. That might actually be useful. The QR Code really postpones the delivery of information. Instead of having the information on the engine in a form that a human could read, the QR Code puts the information somewhere else (the internet), and makes the pointer to the information hard to read. There is so much that could be done in terms of communication between an engine and a very sophisticated device like a generic smartphone that would be useful. But pointing to a URL is not impressive. |
posted 01-01-2014 08:40 AM ET (US)
OMCRobert writes to me:
quote: I don't quite understand why you think I am taking "a shot" at you. If you are saying this because I pointed out the logic you were using regarding whose advice should be followed, you should not consider this to be an application of principles that is applied only to you. I have simply shown that the basic logical assertion being made regarding how often the maintenance needs to be done on a particular engine boils down to a question of who holds the expert knowledge. OMCRobert has asserted that the manufacturer does not hold the expert knowledge because their advice is not to be followed. He seems to suggest that anyone who would follow the advice of a manufacturer is a fool and is being duped, because he says that advice is "a marketing ploy." I now have a further problem with OMCRobert's advice and his consistency. OMCRobert seems to be suggesting that if the manufacturer provides his advice by encoding it into a non-human readable form, the QR Code, requiring the user to buy an expensive device to read the QR Code, which results in the user being able to visit a site on the internet, assuming the user has access to the internet, then the manufacturer's advice is now to be followed. The most logical conclusion is that if a manufacturer gives you advice in plain English in a printed manual, you should consider it a marketing ploy, ignore it, and follow other advice, but, if the manufacturer puts the advice on the internet and prints the URL for its location on a decal in the form of a two-dimensional code (QR Code), then you should consider it to not be a marketing ploy, you should follow it, and ignore any other advice. |
posted 01-01-2014 08:54 AM ET (US)
Eric writes to OMCRobert:
quote: Eric--your observation is slightly off. I would characterize the website has having some of the most critical comments about the E-TEC that can be found. The E-TEC has been under more or less continuous attack here by a variety of people since c.2004. I don't know if you can find another website whose contents contains so much negativity about the E-TEC, and especially about Bombardier Recreational Products. Thanks to the efforts of a few really persistent individuals, the E-TEC receives a constant bashing here. As you see here, a simple question about the definition of an interval--three-years or 300-hours, whichever comes first--has turned into an E-TEC bashing. And you seem to have joined the party with your comment regarding "the dated [E-TEC] design." Thanks for providing an example of what I have just pointed out. As for content on the website, I do have a strong preference for factual comments. But I do not consider that expression of a personal opinion is automatically evidence of a fact. |
boatdryver |
posted 01-01-2014 10:32 AM ET (US)
A simple paper manual printed in the language of the country in which the motor is sold can be real handy for the thousands of outboard motor users in areas too remote for cell phone or internet access. JimL |
Peter |
posted 01-01-2014 11:18 AM ET (US)
I don't see how posting the QR code on the power head really advances the state of the art regarding avoidance of dealer visits. In years past, dealer visits have been avoided simply by reading the owner's manual and, if more advanced service is desired and still within the typical skill set of the DIYer, a service manual. The actual maintenance effort itself is not reduced by the presence of the QR code. Still have to put a wrench to the motor to change the oil and filter and fog the cylinders, neither of which need to be done on what some refer to as a "dated" design. Query: If I put a QR code sticker in the engine compartment of a 1980s Volkswagen making the information in the owner's manual regarding maintenance retrievable via the Internet on a mobile device, does that make the 1.8L 4-cylinder, 4-stroke EFI, single overhead cam and 8 valves per cylinder motor in the engine compartment a current design? |
OMCrobert |
posted 01-01-2014 12:43 PM ET (US)
I will respectfully wager a guess that most people are speaking about QR codes while never having experienced them and the benefits. Here is info right from a company's website. "Under the cowl, the new outboard has a convenient maintenance label highlighting basic maintenance intervals and requirements for the "do-it-yourself's". This label features a QR code that links to a series of step-by-step videos demonstrating just how easy it is to perform routine maintenance such as oil and gear lube changes. How is this not helpful and a step in the right direction? I guess for people that are not tech savvy, it would seem intimidating but it does provide the most up to date information and does not required "the user to invest thousand of dollars in additional devices in order to even use the method." This is just one step in the right direction and outside the box thinking allowing for the most up to date information. I am speaking from actual, real-world, first-hand results and not relying on speculations and conjectures on QR codes. But I digress, I still contend that the three year maintenance marketing ploy is successful but still largely a gimmick. |
thegage |
posted 01-02-2014 04:47 AM ET (US)
quote: Whether or not it is a gimmick can be easily taken out of the realm of conjecture by comparing an E-TEC to a comparable engine from another manufacture over a specified use period and seeing what the maintenance costs are for each engine at the end of that period. Seems to me that would be a better way to decide the question. But as we all know from experience, internet opinions never let facts get in the way of expression. John K. |
Peter |
posted 01-02-2014 08:07 AM ET (US)
Evinrude has a calculator/comparison tool on its website that calculates the maintenance cost based on following the manufacturer's maintenance schedule. In the past this calculator has been dismissed by the naysayers because they claim that all of the maintenance specified by the manufacturers other than Evinrude is not necessary and they also argue that an Evinrude requires more maintenance than Evinrude specifies. Of course the naysayers always know better than the manufacturers. My first hand experience with doing the maintenance on the fuel filters of Evinrude and Yamaha DFI outboards, as described above, makes me believe that the calculator/comparison tool is for more right than wrong. |
Ferdinando |
posted 01-02-2014 08:08 AM ET (US)
There is an interesting article in Boating Magazine's Oct issue (page 74)(The Cost of Owning Outboards) regarding outboard costs which factors in scheduled maintenance, fuel and oil. According to this article which includes a Evinrude 150 E-TEC, Honda 150, Mercury 150 4-Stroke, Suzuki DF-150 & a Yamaha F-150. Sked maintenance costs only for (300 hours) were as follows: Evinrude $648.94 Honda $1604.00 Mercury $1206.59 Suzuki $1608.40 Yamaha $1588.00 Makes for some interesting reading on a cold winter day! (for some of us) |
posted 01-02-2014 09:26 AM ET (US)
I don't quite understand the obsession with QR Code labels. The QR Code is just a way to write something in a manner so only a specialized machine can read it. There is no magic in a QR code. Apparently the QR Code that has been repeatedly mention here as some sort of technological breakthrough just provides a URL to some internet resource. The same results could be obtained by giving the URL in text. To insist that use of a QR Code represents some sort of technological breakthrough in outboard engine manufacturing is really quite an exaggeration. It might be more amazing for some to learn that the contents that are embedded in QR Code could be easily read by a human if those contents were just presented in plain text. I guess, for people who are technologically unsophisticated, a QR Code can impress them as being some sort of advanced technology. A further problem with providing information that resides on the internet on a website by pointing to its URL is the long-term durability of that URL. In order for the pointer to the internet resource, no matter if provided by text or by QR Code, to be useful at some time in the future, the provider of that web information will have to make a commitment to maintain that web resource at that URL for perpetuity. I have concern about the commitment that outboard engine manufacturers will have for maintaining those URL's. If their past behavior is any example, the websites of outboard engine manufacturers are extremely inconsistent in the preservation of information at a particular URL. It is quite common to find that pointers to information resources that are only a few months old result in dead links or redirection to generic pages. When this happens, the value of a pointer to information hosted on the web becomes zero. It would be far better for an outboard engine manufacturer to simply include the audio-video recordings that he wants the owner to have access to by providing them on some sort of data storage media, such as a DVD or memory stick. |
posted 01-02-2014 09:47 AM ET (US)
Let me add one additional comment about the QR Code: |
OMCrobert |
posted 01-02-2014 11:15 AM ET (US)
I guess, for people who are technologically unsophisticated feel that it requires the user to invest thousand of dollars in additional devices in order to even use the method. But then again many people already think that the fuel filters clean themselves or the engine creates it own grease. |
Ridge Runner |
posted 01-02-2014 11:51 AM ET (US)
For modern two-cycle outboards the main difference seems to be the lower unit oil on and E-TEC is rated for three tears. Here is the Mercury Opitmax maintenance schedule: |
frontier |
posted 01-02-2014 01:58 PM ET (US)
The least we could do is have a 20th birthday party for the QR Code - invented by Toyota in 1994. |
mb159 |
posted 01-02-2014 02:46 PM ET (US)
and perhaps eat a sandwich on sliced bread as part of the celebration ;) |
Chuck Tribolet |
posted 01-02-2014 03:33 PM ET (US)
Yes, a QR code is just a URL, but you don't have to type the darn thing in, just take a picture of it. Chuck |
posted 01-03-2014 10:50 AM ET (US)
OMCRobert posits:
quote: I think you are proposing the follow paradigm: If you do not agree with me (OMCRobert), then you probably believe in fairy tales. I cannot take your advice seriously. In order for me to take your advice seriously, you will have to create a video presentation that gives the information you want me to have. You will have to post the video presentation on the internet. Then, you will have to create a QR Code that gives the URL to that advice. In that way, after I decode your QR Code URL, use my web browser to visit your hosting site, and use a video viewer to watch your video, I will be able to take your advice seriously. Sorry to put you to the trouble of all that, but when you just write out your advice in plain text, I think of it as "a marketing ploy." |
Peter |
posted 01-03-2014 11:40 AM ET (US)
I suspect that the naysayers who hold the belief that the 3 year/300 hour interval for the gearcase lube change is a "marketing ploy" have never actually seen an E-TEC gearcase, such as the Magnum series gearcase, side by side with the OMC era "Offshore" series gearcase that was used on V6 outboards prior the creation of the Magnum. I suspect that they have also never compared a Magnum next to a Yamaha gearcase on a comparable Yamaha V6 2-stroke such as the Yamaha 300 HPDI. If they had, they would observe that the Magnum is a larger and far more robustly built gearcase. If they actually did gear oil changes on all of those gearcases, as I have, they would know that the Magnum gearcase takes about 25 percent more gear oil (39 ounces) versus 31 ounces in the case of the Yamaha V6 gearcase or 32 ounces in the case of the old OMC Offshore gearcase. The volume difference is even greater on the counter rotating gearcases (41 ounces for the Magnum counter versus 27 ounces for Yamaha counter). That more robustly built gearcase with a much larger oil capacity, coupled with the use of full synthetic gear oil allows a longer interval to be specified. But such facts should not get in the way of the naysayer's campaign. |
seahorse |
posted 01-03-2014 03:25 PM ET (US)
The Evinrude HPF-Pro E-TEC gear oil is a synthetic blend. It has a special proprietary formula for long life and mixes with water while still offering anti-wear protection. |
OMCrobert |
posted 01-05-2014 09:37 AM ET (US)
I guess since the Verado and Suzuki are using larger gearcases, with larger gears and larger gear lube capacities, all they would have to do is switch to a magic gearlube and "walla" no need to replace? The gearlubes of these two companies is also semisynthetic and designed for the following- Extensively tested to provide excellent protection against corrosion and excessive wear. Specifically formulated to help prevent failures due to water entering the gear housing. Extreme pressure synthetic additives protect gears from metal to metal contact. No industry-wide standards exist concerning marine gear oils. Sounds like Evinrude marketing is still working in the face of facts. Gearlube does not get better with time. I still have not heard how the filters get changed or grease points get greased either. As previously stated, almost any manufacturer can stretch their maintenance schedule out to three years without negative effect, it is simply not the best for the engine. Marketing and sales has a heavy hand in policies like this. It is best you use common sense vs blind alliance to what a company tells you. |
Jefecinco |
posted 01-05-2014 09:58 AM ET (US)
Robert, Your latest is right on the money. Why is there no mention of oil filter change intervals from Evinrude? Why no mention of zerk fitting service? Clearly BRP is guilty of some kind of misrepresentation. You must be correct when you accuse Evinrude of not suggesting a maintenance interval that is best for the engine. After all, Evinrude must enjoy the added cost of warranty claims resulting from their ridiculously long maintenance interval. Don't give up the struggle. Soon Evinrude will give up their marketing direction and suggest a more sensible maintenance schedule. Butch |
OMCrobert |
posted 01-05-2014 11:39 AM ET (US)
If Evinrude says tomorrow that it does not need maintance for 5 years, you guys will claim the greatest innovation since the wheel. My point the entire time is that just about any 2 stroke outboard can go the same amount of time with identical maintance as the Evinrude. They do not do anything special to warrant the increase in time in the maintance schedule. Actually if you read further into the manual you will see that when used in saltwater the engine requires the same maintance as any other engine according to Evinrude. The marketing and hype is tHe only difference between an Etecs, an Optimax or an Tohatsu TLDI. I have not seen any real piece of information was warrants the increase in time between maintance. It is marketing but you guys will believe anything Evinrude says without question. I am an Etecs supporter, I just don't buy into the hype and marketing so easily. |
posted 01-05-2014 10:46 PM ET (US)
These are the claims made herein by some, principally by OMCRobert, regarding Evinrude and the E-TEC maintenance schedule. Let me list them. Evinrude in their E-TEC engine maintenance has: --made an error in the schedule of maintenance --made this error intentionally --and their motive was to deceive their customers When these pronouncements are made they come with warnings that, if you don't buy into them, you must be naive, inexperienced, gullible, lacking in scientific or common knowledge, or be otherwise some sort of babe in the woods. A further argument put forth is that the manufacturer who is recommending too little maintenance is simply exploiting some option that is really available to all manufacturers, and because the other brands do not do it we should recognize them for their altruism and being more honest. These are wonderfully imaginative claims, but in the end, those making the claims offer no proof of any of them. Nothing has been demonstrated in any way that there is an error in Evinrude's recommended maintenance. Not a single piece of evidence. If someone has some real proof of any of the claims, please lay it out for us. You need to show us in some real form where: --Evinrude is wrong in their maintenance schedule --Evinrude made this error intentionally --Evinrude's motive was to deceive their customers --all other manufacturers refrain from this because they are nice guys I will be interested to see what is offered in the way of support for these claims. |
OMCrobert |
posted 01-06-2014 12:05 AM ET (US)
I have never made any of those points and those points are a complete fabrication. My point has always been and still is the following: That just about any 2 stroke outboard can go the same amount of time with identical maintenance as the Evinrude. Evinrude does not do anything special to warrant the increase in time in the maintenance schedule. I have seen no real proof showing why an Evinrude requires less maintenance vs other 2 stroke engines. When questioned on how the filters get changed, things tightened, or how the prop shaft and fittings get greased, I get no answer. Instead I am belittled for questioning the manufacturer when there is no real difference in these systems vs any other brand. Please give me some proof as to why the engine requires less maintenance and we will discuss the facts like gentlemen. Until then I contend that the hype around the less required maintenance for the Evinrude is a marketing ploy. |
Dave Sutton |
posted 01-06-2014 11:00 AM ET (US)
The truth is that metal is metal, lubricant is lubricant, and that seals are seals. None of it is magic. No near-identical mechanical systems will have widely disparate maintenance intervals associated with their use in similar conditions. Every manufacturer works within the same paradigm of materials and design. That's just basic engineering. They are not going to be much diofferent from one another. The bottom line is that ANY of the modern engines can be maintained on the same interval as any other manufacturers similar product, with similar results. There's no doubt that the modern generations of engines are tightly engineered systems that can be run turnkey without much more than fuel and lubricant for the lives of most owners. If different manufacturers wish to print up different maintenance intervals, "who cares"? Any sensible owner will balance his own operating conditions and tempo and will maintain based on that real world use. Use it two weeks each summer on a freshwater lake? Use it 365 days a year in New York Harbor running crews back and forth to a work barge? Use it in Antarctica in brash ice every day on a Zodiac? Use it in Florida on a flats boat as a guide? The same engine will require a different interval, and sensible operators will take the right steps. With that said, many recreational operators over-maintain their engines. MOST recreational users could ignore their engine for a decade and have no problems. ACTUAL useage of many recreational engines, measured in hours, is very low. 3 years for an eTec to be looked at? Heck... most of them could go thirty.
paulkath |
posted 01-06-2014 02:18 PM ET (US)
We have had a Mercury 225 Optimax on our Dauntless 20 for 10 years. We use the boat at least 150 hours a year and have pulled skiers at least a thousand times. Except the first year when we got the boat, the engine has never been in the shop! Here is what we do: use the hell out of the boat on summer weekends and store it inside all other days. We run West Marine Premium two stroke oil that we buy in two gallon tanks. We buy gas only a few times a year and at a high volume dealer on the highway nearby. Almost every Sunday I hose the boat and flush the engine, but sometimes the whole rig is put away wet. I always tilt down the engine after parking. For "winterizing" I fill the tank and use a good bit extra fuel stabilizer. I have a one gallon plastic tank that I fill about 15/1, interrupt the gasline while running and run the rich mixture for about 15 minutes. I change the lower end oil and grease up in the fall or spring. I have never pulled the prop. We have a Racor fuel seperator that I changed last year ( i have never seen anything in the bowl) This year I am changing the annodes and water pump. I get a new large battery every-other year. Thats it; the Optimax has been flawless, super fast,and easy starting. |
posted 01-06-2014 02:41 PM ET (US)
OMCRobert, in regard to my four points (see above) says:
quote: Sorry, but you have made all of the above claims.Let me refresh you memory: You said the 300-hour maintenance "may result in lack of required basic maintenance." This is a way of saying it is wrong. You said that the 300-hour maintenance was "a marketing ploy." This is a way of saying it was done intentionally and done to deceive. From m-w.com, the definition of ploy: ploy noun \ˈplȯi\ : a clever trick or plan that is used to get someone to do something or to gain an advantage over someone And you said "any manufacturer can stretch their maintenance schedule out to three years..." Here you imply that the other manufacturers could all do it but refrain. This is a way of saying the manufacturers other than Evinrude are nice guys for not doing this. |
OMCrobert |
posted 01-06-2014 02:54 PM ET (US)
You know Jimh lost the argument when he does not counter your points and instead focuses on semantics and vocabulary. Please post my entire comment instead of choice picking words. My statement was "In fact I will argue that the 3 year no maintenance ploy has caused much confusion and may result in lack of required basic maintenance such as greasing fittings and prop shaft." I STICK BY MY STATEMENT AND RESTATE ONCE AGAIN MY POINT. I have seen no real proof showing why an Evinrude requires less maintenance vs other 2 stroke engines. When questioned on how the filters get changed, things tightened, or how the prop shaft and fittings get greased, I get no answer. Instead I am belittled for questioning the manufacturer when there is no real difference in these systems vs any other brand. Please give me some proof as to why the engine requires less maintenance and we will discuss the facts like gentlemen. |
posted 01-06-2014 02:57 PM ET (US)
I accept the recommended maintenance schedule of outboard engine manufacturers. The entire basis for this is my belief those manufacturers know more about their product than I do. If they tell me to perform a particular maintenance procedure at a particular interval, that recommendation carries the weight and imprimatur of the manufacturer. That is the basis on which I accept it. I do this for all the brands. I don't try to quibble that brand X is right and brand-Z is wrong. The alternative viewpoint, espoused by OMCRobbert, is apparently to suggest that one ought to make their decision on which maintenance procedure to follow and which manufacturer has recommended properly. The only basis presented to support this view is apparently a notion that OMCRobert knows more about outboard engine maintenance than any manufacturer, and he can determine what procedures to perform when, and which intervals to shorten or lengthen. This may be a good basis for OMCRobert to use, but I don't see how I can follow that basis, unless I accept the following premise: OMCRobert knows more about outboard engine maintenance than any outboard engine manufacturer. I don't believe that it is particularly unusual for me to be hesitant to accept that premise. It really is the opposite of the presumption that I imply in my view. My premise is: The outboard engine manufacturers know more about the maintenance of their product than I do. We have reduced the dispute about maintenance to its fundamental assumptions. Let me summarize: If you think that OMCRobert knows more about about engine maintenance than the outboard engine manufacturers, follow his advice. Otherwise, follow their advice. |
posted 01-06-2014 03:05 PM ET (US)
OMCRobert: read the owner's manual for an Evinrude E-TEC, or for any outboard engine in general, to learn how to perform the maintenance. All of the procedures that the owner is expected to perform are described in the owner's manual. If you read it, you will learn how to perform those procedures. You can find the owner's manuals by following the link given in http://continuouswave.com/whaler/reference/ownersManuals.html The topic of the discussion is not how to perform the procedures, but rather what procedures are needed, and when they should be performed. This information is also given in the owner's manuals. You seem to be trying to discard your initial argument that the maintenance intervals were wrong. You should focus on that point, as it seems to be the principal difference in our opinions. I invite you to elaborate on what procedures are being performed at the incorrect intervals. Your secondary claims that Evinrude in particular is wrong, has done this intentionally, and done so with the motive to deceive or trick their customers, is another important part of your claim. You should try to make clearer the basis on which you claim those things. I think all of your arguments will eventually resolve to the premise that you know more than any outboard engine maker. I cannot debate that point. You could be the smartest guy in the room. |
OMCrobert |
posted 01-06-2014 03:09 PM ET (US)
All other outboard engine manufacturers (Yamaha, Mercury, Tohatsu, Nissan, Honda, Suzuki) use almost identical materials and very similar systems. All of their systems all require more routine maintenance vs Evinrude. My question is very simple, why?
Jefecinco |
posted 01-06-2014 07:29 PM ET (US)
I don't have an answer to your question. But my Ram has an oil change interval of 10,000 miles or one year, whichever comes first. My Titan has an oil change interval of 7,500 miles or three months. Why? Oil changes are a profit maker for dealers. Does that enter into the possible reasons? Or is it that the Ram is made to better tolerate longer change intervals? Lacking the reason the engineers at the various companies choose one interval over another leads to more or less useless conjecture. But, I believe it is an engineering question not a marketing question. I am hanging my hat on common sense, lacking any better criteria. My common sense tells me BRP does not stretch an oil change interval to sell more units. The cost of warranty service should that interval be found to be excessive is just too high. I don't believe Ram does it for marketing reasons either. I have never seen any sales literature from Ram extolling the virtue of 10,000 mile oil changes. In the overall cost of operation, a lower unit oil change is so miniscule in cost as to be not very visible even to someone as parsimonious as myself. Butch |
Don SSDD |
posted 01-07-2014 08:17 AM ET (US)
Manufacturer maintenance schedules tend to err on the side of conservative, why would Evinrude take a chance by recommending intervals that are too long? If they recommend intervals that are too long, then their outboard engines will start having failures, their reputation will suffer, and no one will buy their products. It would be far easier to take no risk and match what everyone else is doing for recommended maintenance. So what they recommend should be conservative. Maybe what other manufacturers are recommending, given these motors are all built similarly, is way shorter maintenance intervals than necessary? Or Evinrude makes a better product? It has to be one or the other. Don |
OMCrobert |
posted 01-07-2014 09:11 AM ET (US)
I think that is the main crux of the issue. Having a longer maintenance interval is certainly an advantage for the consumer and a positive for marketing. Having a shorter maintenance interval is certainly an advantage for the dealerships and selling parts and accessories. I think that the maintenance schedule is predicated upon several business factors and not strictly an engineering decision. As stated previously,I think most outboards could get away with it. If someone could not get their propeller off after 3 years, that is not a warranty issue anyway. |
Marko888 |
posted 01-07-2014 10:38 AM ET (US)
I believe we are seeing extended oil change intervals in cars requiring synthetic oil, which is purported to provide superior, longer lasting lubrication, and also for environmental reasons, to reduce oil use and waste. It shouldn't be a surprise to see this in the marine industry. Perhaps Evinrude is simply leading the way. To the OP, if it were my expensive engine, at 50hrs use per year, I would still choose to do the service as per the book, every 3 years or 300brs, whichever occurs first, to ensure a long service life of the investment. |
posted 01-07-2014 11:20 AM ET (US)
This whole discussion reminds me of the situation in the outboard engine manufacturing business when SUZUKI announced that their four-stroke-power-cycle engines would come with a six year factory warranty. At that time the rest of the industry was offering warranty periods as short as one year. SUZUKI offered a significant advantage to the consumer. The reaction from the other manufacturers was to dismiss the warranty as a marketing ploy, and that SUZUKI would be paying for a lot of repairs. The standard line was that SUZUKI was trying to buy its way onto boat transoms with this offer, that they were underselling the market, and the six-year warranty was not to be seen as something that differentiated their product from other brands. This criticism was usually offered up by die-hard enthusiasts of the other brands who repeated the mantra from the manufacturers. It did not take long for the criticism of SUZUKI to die down and for the other manufacturers to increase their warranty coverage. For some of those manufacturers, the increased warranty coverage did mean that they were going to be spending a lot of money on making repairs to their products under warranty because their product quality and engineering was not really up to sustaining a six-year warranty coverage. The longer warranty term really resonated with the buying public, in spite of efforts by the other manufacturers to dismiss it. Evinrude has made quite a theme from its need for reduced maintenance, typically presented as part of their "spend more time on the water" campaign. If nothing more. the relentless attack on this program by other brands and their fan-bois tells me that the campaign is also resonating with buyers. The result is an effort to spread fear, uncertainty, and doubt about the E-TEC and its maintenance. |
Chuck Tribolet |
posted 01-07-2014 12:10 PM ET (US)
Only one of our four cars requires synthetic oil. The other three all are perfectly happy on dino oil and have a high oil change interval (7000ish miles) if they aren't towing, or stop and go, or dusty conditions. The one car that requires synthetics doesn't for oil change Chuck |
OMCrobert |
posted 01-07-2014 01:32 PM ET (US)
Funny that you bring up the Suzuki 6 year warranty because that is also huge marketing ploy. The warranty after the first three is aftermarket and it is terrible. It is no where near as good as non-declining factory back warranty that the other major companies are offering like Evinrude. |
posted 01-11-2014 01:12 PM ET (US)
I am not at all surprised that OMCRobert and I hold completely opposite views in regard to the influence of SUZUKI on outboard engine warranty. It is my contention that SUZUKI revolutionized the duration of outboard engine warranties. You can see this clearly in the present day offers from all manufacturers of outboard engines. They have been forced to duplicate the terms and duration of the Suzuki warranty offer. OMCRobert's characterization is completely wrong. Please start the new thread about the failure of Suzuki to have a good warranty, and I will be pleased to correct you in that discussion. That my use of it as an analogy in this discussion has produced the same attempt to spread fear, uncertainty, and doubt comes as no surprise at all. A lot of time when people are wrong, they are very consistently wrong. |
OMCrobert |
posted 01-11-2014 02:41 PM ET (US)
Jimh stated: "A lot of time when people are wrong, they are very consistently wrong." Yet in this very thread he stated the following: "--Dumb technology, like the QR code, requires the user to invest thousand of dollars in additional devices in order to even use the method, " Which we all know is wrong. You know Jimh lost the argument when he does not counter your points and instead focuses on semantics and vocabulary. I STICK BY MY STATEMENT AND RESTATE ONCE AGAIN MY POINT. I have seen no real proof showing why an Evinrude requires less maintenance vs other 2 stroke engines. When questioned on how the filters get changed, things tightened, or how the prop shaft and fittings get greased, I get no answer. Instead I am belittled for questioning the manufacturer when there is no real difference in these systems vs any other brand. Please give me some proof as to why the engine requires less maintenance and we will discuss the facts like gentlemen. |
posted 01-11-2014 03:51 PM ET (US)
Robert: I reduced your argument to its fundamental premise. That is not a case of vocabulary or semantics, but of logic. When you try to argue against logic you are illogical. But, I will give you credit, you are consistently illogical. |
posted 01-11-2014 04:07 PM ET (US)
There is no need for me or for Evinrude to "prove" or explain to the satisfaction of OMCRobert anything about their maintenance recommendations. The reason for this is simple logic: If you accept one manufacturer's recommendation, you must, if following that logic, accept the other manufacturer's recommendations. If you want to pick and choose which ones are satisfactory and which are not, it will become necessary for you, not me, to individually "prove" or "disprove" all of them. I do not have this burden because the fundamental premise I hold is that each manufacturer is fully qualified to set the maintenance schedule for their products. It is on that basis that I accept the recommendation of all the manufacturers on an equal basis. When challenged to "prove" why the E-TEC maintenance schedule is satisfactory, I simply assert this belief. It is obvious that this is a satisfactory argument because this is precisely the argument used by OMCRobert to substantiate his claims for the non-E-TEC engines. No matter how often OMCRobert asks for information about E-TEC maintenance procedures, I will still direct him, as I have earlier, to read the owner's manual to learn the procedures. There is nothing secret or hidden about the procedures or when they are to be performed. It is all given in the owner's manual. As I said earlier, the greatest source of confusion about the E-TEC maintenance seems to occur when individuals invent their own understanding of the maintenance intervals. These individuals then take their own invention and criticize it, as if it were the actual maintenance schedule of the manufacturer. I don't see this discussion going much further because we are now covering the same ground, perhaps for the third or fourth time. In terms of making a decision about who is winning an argument, I must observe that when one participant declares his opponent has lost, it is not a compelling argument. This argument is likely to be asserted no matter what the actual outcome. Continual repetition of this claim does not strengthen the position. I won't repeat myself any further. |
ANDREW PITCHFORD |
posted 01-11-2014 04:08 PM ET (US)
70 post on maintenance for a 2 stroke Gee glad I got a 4 stroke merc. Easy peasy Japanesey |
posted 01-11-2014 05:08 PM ET (US)
This thread also amazes me. The lengths to which people will go to create fear, uncertainty, and doubt about two-stroke-power-cycle engines seems to know no limit. |
Peter |
posted 01-11-2014 05:14 PM ET (US)
"Instead I am belittled for questioning the manufacturer when there is no real difference in these systems vs any other brand." Why don't you identify the "systems" that you believe have no "real difference" then explain to us how they are not different. With the many years of experience I've had with Yamahas and OMC/BRP Evinrude and Johnson outboards, I'm curious to know what system is not different because they sure look quite different to me. |
ANDREW PITCHFORD |
posted 01-11-2014 05:15 PM ET (US)
Sorry had 2 do it. I love 2 strokes. Own a few we may be in trouble when we can't get a small HP 2 stroke in the later years. |
OMCrobert |
posted 01-11-2014 06:13 PM ET (US)
Peter The trim systems Any carb 2 stroke is very, very similar with all manufacturers doing just about everything the same. Beside the fuel injection systems on modern DFI system and ECMs, all the systems still use the same basic concepts. |
Peter |
posted 01-11-2014 07:42 PM ET (US)
OMCRobert -- You've identified some systems that you believe are not different but you haven't explained how they are not different. Then you follow up with more generalities -- "Any carb 2 stroke is very, very similar with all manufacturers doing just about everything the same." I'd like to understand that too now that you've put it on the table. Besides fuel injected Evinrudes and Yamahas, I've owned carb'd 2-stroke Yamahas and Evinrude/Johnsons. They sure don't look like they have the same oil injection systems to me. Where is the Yamaha under cowl oil reservoir with the sometimes sticky float switch located in the Evinrude and Johnson carb'd 2-strokes? The must have done a great job of hiding it somewhere because I haven't seen it anywhere under the cowl all these years. Where is the carb'd Johnson 150's optical ignition system located on the carb'd Yamaha 150? How about the vapor separator on the carb'd Johnson 150, where is that on the carb'd Yamaha 150? How many screws does it take to hold the air silencer on the Johnson 150 versus the Yamaha 150? Which way does the shift shaft move on a carb'd Johnson 150 versus a carb'd Yamaha 150? Getting back to the modern era -- What's the gearcase lube capacity of a QR code bearing Mercury 150 FourStroke? How about Mercury's current belt driven alternator charging system? Where's the belt driven alternator and belt on an Evinrude? |
OMCrobert |
posted 01-11-2014 08:39 PM ET (US)
All of those system shares the same concept. All dog clutches on the gear cases. Maybe different capacities and the spool moves differently but all the exact same concept. No one is using cone clutches or hydraulic clutches. All the gear case are very, very similar. Same with staters, and ignition systems. Comparing a carb 2.6 liter Yamaha to a v6 crossflow is basically a copy as has been addressed many times. For decades the stator, regulator and rectifier were the standard. If the rare engine that use the alternator use the same concept. Beside the electronics one you break it down the basics it is all the same. Why doesn't Evinrude need to grease the prop shaft and drive shaft as much as everyone else? Why don't you have to grease the swivel assembly as much? Do the nuts tighten themselves? Take any competitors recommended maintance chart and 90% of the systems that require yearly maintance are the same yet the Evinrude doesn't need as much maintance with no reason ever given. |
Dave Sutton |
posted 01-12-2014 11:18 AM ET (US)
"Why doesn't Evinrude need to grease the prop shaft and drive shaft as much as everyone else
It's a reflection of what's actually required for reasonable maintenance versus overmaintaining,, which is what's good for the dealer (and not bad for the engine). It's just a choice. That's all. If you want to do more so you feel good, or have a "more perfect" engine, feel free. That's a choice too.
Pushing the published intercal off three years on a eTec? (yawn...) Yeah... so what? Dave . |
posted 01-12-2014 01:43 PM ET (US)
OMCRobert asks:
quote: My reply is not going to be an answer to this question. I want to examine the question itself. First, the question presents a premise, which may or may not be true: there is some difference in the recommended interval at which the propeller shaft should be greased. In order to accept this premise, I would need to see citations to the following: --a citation and quotation of where Evinrude specifies the interval for greasing the propeller shaft --similar citations for Honda, Mercury, Yamaha, Tohatsu, and Suzuki There is nothing given in the premise as it has been made that tends to substantiate the underlying claim. This is a good example of what I described earlier, which is a method of argument in which people invent a position for one manufacturer to hold, then attack it as if the position were actually held by the manufacturer. This premise expands on that theme by also inventing a completely uniform position to be held by all other manufacturers. Yet, in truth, we have nothing presented to substantiate this. For all I know--I have not made a thorough study of this--there is no basis at all for this premise. The next aspect of this question is also troubling. Even if we allow the initial premise to be true, that is, there is a recommendation for performing some maintenance by Evinrude that is at an interval different from all the other manufacturers of outboard engines, we have to consider the implied conclusion contained in this question: the interval of all the other manufacturers must be correct and the interval specified by Evinrude must be wrong. Here again we have a significant premise presented without any sort of justification. It seems to me that the basis for accepting the maintenance interval specified by the non-Evinrude makers (if indeed they actually all follow the same recommendation) must be that they know best how to maintain their engines. How can we then say that Evinrude must not know best how to maintain their engines? What we are being asked to assume and to agree with is a notion that the non-Evinrude engine makers know better how to maintain an Evinrude engine than Evinrude itself does. However, there is nothing in this claim that could not be just as easily reversed. We could say, with the same authority, that Evinrude knows better how to maintain the non-Evinrude engines, and on that basis their recommendations must be accepted over those of the actual manufacturer. Of course, there will be little enthusiasm for accepting that position, but, logically, it is just a sound as the implied assumption of the question. A further aspect this question assumes that all of the elements of the engine involved in the maintenance are the same. This is an unreasonable assumption. In the case of the lubrication of a propeller shaft, there could be differences in the lubrication being used, the metals of the propeller shaft, and the metals of the propeller hub. There has been an attempt to reject this common sense reasoning by suggesting that there is a general equivalence among all the outboard engines of all things. In this case that notion is expressed by observing that they all use some sort of lubrication on the propeller shaft to prevent corrosion and adhesion of the metals. To accept this notion requires that one believe all lubricants or anti-corrosion coatings are identical and all metals are identical. There is no reasonable basis for this assumption. It quite reasonable to assume that there are differences in the lubricants or metals, and those differences account for the differences in the recommended maintenance intervals. I cannot answer this question because the question is built upon three premises which are not proven with any sort of evidence or substantiation. Before the question can be answered, these three premises have to be built and established as true. Finally, the question has been posed in order to lead to a more astonishing premise. Even if we allow the three underlying premises of the question to be substantiated, we are being asked to make an enormous leap to a conclusion. We will be asked to conclude that there has been an error made by Evinrude in their maintenance procedures, but, much worse than a simple error, we will be asked to conclude this error was made intentionally for the purpose of deceiving the owner of the engine in a way that will be to the advantage of Evinrude. This is, of course, utter nonsense, and there is no way to substantiate this further claim, even if the three underlying premises of the original question could be proven. |
OMCrobert |
posted 01-12-2014 05:10 PM ET (US)
From earlier in this very thread. I still have not received a good answer for why Evinrude does not need to do some of these things.
Dave Sutton |
posted 01-12-2014 06:17 PM ET (US)
^^ Once again: Take this from someone who maintains a fleet of 6 jets, some of which fly hundreds of hours a year, and others that fly 12 hours a year. These machies are far more complex than simple outboard engines, and we have "rules" regarding how we maintain and inspect them. There's such a thing as over-maintainence, such a thing as under-maintainence, and such a thing as correct maintainence. Correct maintaince is usually based on tracking trends (oil samples, wear limits as measured using precision tools, and statistical analysis based on the individual operating characteristics of a fleet). It's EASY to make up rules that end up with many operators over-maintaining equipment. Yearly spark plug changes, for example. How many hours were run in a year? Five? Five hundred? Yearly spark plug changes is a very simplistic rule that would *certainly* result in very few spark plug problems. But to gain that, if the recommendation is followed, tens of thousands of spark plugs are changed without any reason to do so at all. Why does the manufacturer do this? (A): It's easy to publish, (B): has no adverse impact on the engine, and (C): is a profit center for the maintainers and parts suppliers. How about the engine that ran one hour last year? Does it need a YEARLY spark plug change? What's a year of use? One year? One six month season? There's no such thing as a What would be better? Well, for a fleet owner running hundreds of engines, they would look at hours of yearly use, cost per plug exchange, track history of failures, and would develop your own maintenance interval based on their findings. My bet is that for the number of hours put on these engines for the typical recreational user, that analysis would put plug changes out at five to ten years. Yearly plug changes are good for spark plug sales. To think they are "required" is silly. The short answer is that there is no magic "number of years" to do any of this maintainence. All you can do is to analyze historical trends based on test, project that agaist anticipated hourly use, bias that with additional data regarding any extreme conditions expected, and then to suggest recommendations based on that experience and evidence. Publishing "X hours of use" would be more sensible, and that's exactly how we maintain jets. Not per year, per hour of use. All you are seeing here is a demonstration that different manufacturers make different decisions based on their own matrix of data, required reliabilty levels, cost/benefit ratio, and confidence in their hardware. Frankly, none of the manufacturers recommendations are carved in stone and any thinking owner will bias maintenance towards their own use and environment.
Dave . |
OMCrobert |
posted 01-12-2014 06:32 PM ET (US)
Exactly. There is nothing special about the Evinrude that allows it to go longer with less maintance. |
Peter |
posted 01-12-2014 07:01 PM ET (US)
"Exactly. There is nothing special about the Evinrude that allows it to go longer with less maintance. " So then I guess we are to conclude from your wisdom that its not an Evinrude ploy marketing because Evinrude is just being honest specifying the appropriate maintenance frequency that could be used for all outboard motors. But then we must also conclude that other manufacturers are involved in a ploy of their own to enrich themselves and their dealer network at the expense of the ultimate user by specifying unnecessarily frequent maintanence which the unwary will follow. So which is it? |
OMCrobert |
posted 01-12-2014 07:38 PM ET (US)
It is both. Evinrude is using the ploy to pretend their engines need less maintance and a corner stone of marketing. While other manufacturers are using it to sell more parts and get customers in the dealership. Same ploy they all all use to charge more for increase horsepower while using the same block. Example- 135HO costing less than the 200hp LO based off the 2.6 liter block. Ploys all over. :) |
OMCrobert |
Peter |
posted 01-13-2014 07:04 AM ET (US)
Well that settles it. Everything the outboard makers do is a ploy intended to separate you from your money. ;) By the way, the crankcase assembly for the Evinrude 200 60 degree ("LO" as you put it) has a different part number than the crankcase assembly for the lower HP models (135, 150, 175) built on the same platform. I suspect that Evinrude has emPLOYed a different location for the ports for the 200 HP model. |
OMCrobert |
posted 01-13-2014 09:02 AM ET (US)
Port timing, calibration and tuner size can all be the difference between 135, 150, 175, 200hp as well with other manufacturers. Since they share the exact same block the difference in cost from the 135hp HO to the 175hp should be extremely small. Some engines only have a calibration as the difference for the extra 50hp+. At first I suspected that the additional cost was the increase warranty cost for the higher rate of failure for the increase HP model but we just do not see significant failures of the block or gearcase for just about any model. The failures are all the same including injectors, sensors and maybe an ECM/PCM/EMM. Nothing that really has to do with the fact that the block is increasing HP. Engine manufacturers have us trained that more HP equal high purchasing price. I loved when the difference between an older 20hp carb 2 cylinder and a 30hp is a larger diameter hole in the intake and a large venturi on the carb. An outboard engine company could really shake up the market by simply selling an outboard model (2.6 liter, 3.4 liter model) at a single price and allowing the consumer to pick what horsepower they want that is available on that block. |
posted 01-13-2014 11:40 AM ET (US)
OMCRobert offers more of his special insight into outboard engines:
quote: There is a general trend in any market that goods which provide greater utility will cost more. An engine that produces more power typically provides greater utility than one that produces less power. That is why price increases with power output. This relationship of the utility of goods and their price is not unique to outboard engines, and it is certainly not due to some sort of behavior learned by customers from outboard engine makers. |
posted 01-13-2014 11:56 AM ET (US)
I have researched the first premise of OMCRobert's question regarding maintenance interval of the propeller shaft of an E-TEC outboard engine. I looked for advice in the Operating Manual of my Evinrude E-TEC 225-HP engine about the propeller shaft lubrication. I found this sentence, in the MAINTENANCE chapter, under the subheading, AFTER WINTERIZATION--ALL OUTBOARDS:
quote: I also found the following in the chapter RIGGING AND ACCESSORIES, under the subheading PROPELLER:
quote: I believe the recommendation of Evinrude with regard to the E-TEC propeller shaft lubrication can be described as follows: --grease the shaft after any winterization procedure --grease the shaft annually at a minimum --grease the shaft when installing a new propeller I have not researched what all other outboard engine manufacturers recommend for greasing of the propeller shaft. I suspect they will be very similar. I cannot imagine they could call for more frequent lubrication of the propeller shaft As a result of this investigation, I find that the original premise of OMCRobert's question is completely in error. His question is misleading because its initial premise is wrong. This demonstrates precisely what I postulated would be found: people who like to spread fear, uncertainty, and doubt about a product tend to invent characteristics of the product they are attacking which are not true. They then attack these self-invented characteristics of the product, and suggest that those characteristics are deficient or will be a problem. OMCRobert has done exactly this. Here he has invented a claim, attributed it to Evinrude, and then attacked it as if it were actual advice from Evinrude. It is wise to ignore attacks like this. |
OMCrobert |
posted 01-13-2014 12:47 PM ET (US)
It appears that the Evinrude really doesn't require any less maintenance. |
Chuck Tribolet |
posted 01-13-2014 04:02 PM ET (US)
JimH clarifies one item, and OMCRobert turns that into a generalization that the E-TEC doesn't require less maintenance. And based on what RidgeRunner posted about the Optimax Chuck |
OMCrobert |
posted 01-13-2014 04:27 PM ET (US)
Chuck That leads back to the original question. Why doesn't the Evinrude require that to be done when other brands do? What makes their splines not require the extra maintance since there is no difference in material or design? No one will answer that question. |
Dave Sutton |
posted 01-13-2014 11:23 PM ET (US)
^^^ You're being deliberately obtuse. Just a hint: It's making the friendly forum that we've enjoyed for year a lot less fun... So give it a rest. Ever consider that shafts don't really NEED to be greased on any schedule if they are reasonably matched in alloy compatability to their respective components, have zincs in the electrolytic chain if appropriate, and a high quality waterprooof antisieze is used in assembly? I've taken props ranging from outboard to tugboat sized off shafts that have been wholly immersed in saltwater for *decades* with simple hand tools and found the antisieze compound to be fresh and intact. This is not rocket science. The more you diassemble stuff like this the more opportunity you have to screw it up. You don't need to grease these every year.
OMCrobert |
posted 01-14-2014 09:41 AM ET (US)
Dave You are actually in agreement with me. I agree there is no difference and that the Evinrude does in reality not require any less/more maintaince vs other brands. That is my whole point. You said the following. quote (of Dave Sutton):
When I make statements like you do, I [was] replied to with the following. [Here a portion of an earlier reply by jimh was quoted, but in a misleading way, with misuse of quotation marks. I have corrected this by clearly indicating the quoted parts, and also by including the omitted portions of the material quoted which reveal that parts of the quoted material were logical conclusions based on the arguments being made by OMCRObert himself.--jimh] quote (of jimh):
I ask you to look to the first reply in this thread. It is mine and I still stand by it. [Note: OMCRobert has invented a new paradigm: the more errors we find in his false accusations of mistakes in maintenance, the more he is proven to be correct in his main assumption. This is very specious logic. What is clear: the more we examine OMCRobert's claims about Evinrude engines the more we find them to be in error. The general conclusion from this process is that there is a good chance when OMCRobert says something about Evinrude engines it is in error. If you do look at OMCRobert's first reply, as he suggests, you see that he makes a mistake about the recommended interval of propeller shaft greasing, one of his several claims of negligent maintenance advice from Evinrude. As shown later, this claim is wrong. Apparently OMCRobert has still not figured out his mistake.--jimh.] |
posted 01-14-2014 10:35 AM ET (US)
Please let me remind participants that the purpose of these discussions is to share boating information. In looking at this thread, it began with a request for information. That request was satisfied by a concise answer that gave the information. This is the purpose of these discussions. I would say the thread effectively ended when the initial poster wrote back to say "Thanks" or "Tks" to two respondents, which occurred by within the first ten replies. From that point on in the discussion, a completely different purpose was put forth. A crusade was begun to try to defame Evinrude, insisting that they, Evinrude, were publishing misleading information about their engines. By the conclusion of the thread, we have seen that it is not Evinrude that is publishing misleading information, but actually the people accusing Evinrude are guilty of publishing misleading information, of creating confusion, and being participants in a ploy, a campaign of deception, to deceive others. This is a bit of irony. We have found the FUD-meisters to be guilty of precisely what they have tried to accuse Evinrude of doing. Normally, I would toss most of this palaver into the trash, but it has been so instructive to see how the accusers are guilty of precisely what offense they have claimed was purported to have been made by others, that the irony is too delicious. I will let this stand as a good example. I must also note that few threads approach 100 articles and are still providing much new boating information. And with that, this thread is closed. |
