posted 05-10-2015 02:27 PM ET (US)
I use marine split loom sleeves from Ancor, secured/closed when needed with zip ties. I cover everything to protect from the sub-tropical sun. I use several sleeves for different things. So far all covered look like new and access is easy.Covered are: steering cable,fuel line,engine harness,12v to console,bilge pump,lighting,VHF antenna cable,water pressure tube,speedometer tube,transducer cable,throttle and shift cables,battery cables to engine. This is on a Sport 15,on her big brother the OFFSHORE 27 all items in the stern well are also wrapped including jackplate harness and trim/tilt exposed cable on the engine swivel bracket.
They are flame retardant and self extinguishing,black with a fine blue stripe. I make smaller branches from the few larger sleeves as I reach the stern to cover individual items.
