| Author | Topic: Dual Battery / Dual Engine |
This message thread is for discussion and comments on the article in the Reference section on Dual Battery installations. See http://continuouswave.com/whaler/reference/dualBattery.html |
I should add this disclaimer: I have not actually tried either of these arrangements myself. I plan to re-wire my dual-battery/dual-engine boat this spring, as the current wiring seems to cause the charging coil on one engine or the other to burn out, probably due to some strange currents occuring from the prolonged connection of the two charging circuits to a single battery bank. Although not as flexible, I may go with the easier to operate 3-switch arrangement. As long as the tie switch is not closed, the two engines and batteries are entirely separated and cannot be accidently connected by inappropriate setting of the other switches. It is also a little simpler to wire. --jimh |
| triblet |
I believe that an alternator run with no battery will blow diodes. The alternate allows this. I don't see how there's much difference in Each has advantages. Original allows either Alternate allows both batteries to start I can see where you would want both of these. I don't see where single battery, dual Chuck |
Two responses: 1) The "Whaler-Factory" wiring does allow the paralleling of the batteries. That happens when either of the OFF-1-2-ALL switches are in the ALL position. They suggest having them both in the ALL position. --- 2) As for my situation, I have scratched my head about it for some time, drawn diagrams, etc., trying to figure out what has happened, but the sad truth is that shortly after spending $300 getting the charging coil replaced on the PORT engine, the coil opened on the STBD engine. It might have been coincidence, but I think something is going in with two alternators charging one battery. This is my best analysis: if the PORT engine charging system raises the battery voltage to a certain level, say 15.0 volts, and the STBD engine charging system is only producing 14.4 volts, then from the point of view of the STBD engine's charging system it is looking at an open circuit. Current from the PORT engine's charging circuit would try to flow into the STBD engine charging circuit. Now, there are diodes which prevent this, but the effect of reverse biasing the diodes is to remove the load of the battery from the charging circuit. Then you are back to the forbidden case: operating the engine with no battery to absorb the charging current. I think that is what is happening to my (over priced) charging stators. Therefore--any theoretical objections aside--I plan to completely overhaul the wiring in the back of the boat to eliminate the present situation where both engines are paralleled to one (bank of) battery(s). --jimh |
Oh, a third topic: I say that the "alternative" wiring is a bit simpler due to the fact that if one were to locate the OFF-1-2-ALL switches at opposite sides of the boat, then you have to run more wiring across to connect them. I made the assumption that the batteries would be located one on each side of the boat. That is how they are in my 20-Revenge. There is a battery case in each extreme outboard end of the engine well, thus the batteries are located far apart. The OFF-1-2-ALL switches would likely be located on the cockpit bulkhead in front of the engine well. Thus you would need to run three pieces of 2-AWG cable across the boat to tie them together. In the alternative arrangement, you only run two pieces of 2-AWG cable across the boat. Now if you locate the batteries and the switches all close by, then there is not much difference. --jimh |
| DIVE 1 |
jimh, I have redone several dual outboard charging systems that were blowing charge coils. On every boat, 2 engines were trying to charge one battery or two batteries tied together at the same time. I can not explain what the problem is, but rewiring using the "alternative" has always prevented the problem from repeating itself. It is important to only use the "tie switch" for emergency starting and then turn it off. If you are worried about losing one battery because of a bad charge coil while underway, install an onboard battery conditioner. This will charge 2 isolated batteries at the same time with one engine. On DIVE 1 we installed 2 starting batteries and 1 house battery with the appropriate conditioner. All 3 batteries are charged from 1 or 2 engines while maintaining isolation from each other. We do not have a tie switch because we are afraid that someone would turn it on without realizing the destruction that could occur. We carry jumper cables. Jim |
Dive1, In a sense I am glad to hear that this has happened to someone else; I was beginning to think there was something weird going on in the boat wiring on my 20-Revenge. Sorry about those blown stator coils. I would also like to ask if anyone can describe the wiring between the battery negative, the fuel tank, and the zinc anode. My boat is in storage and not convenient to visit, so I can't refer to it for guidance. Also, is there something installed in the ground/negative line on your boats? There is a small black plastic gizmo wired in the negative lead on my boat (I recall), and I am thinking it might be some type of noise filter for the electronics, or else it is a galvanic isolator. Anyone have a similar gizmo in their ground (green) wiring? --jimh |
| DIVE 1 |
JIMH, You have the photo of the beautiful wiring that came on DIVE 1 - ha ha. The wiring was so corroded that it all went in the dumpster. We do not have a black plastic gizmo in our wiring harness. Ground Wires: The first wire runs from the ground lug on the fuel tank directly to the anode on the transom. The second wire runs from the ground lug on the fuel tank to the negative side of the batteries. The third wire runs from the fuel tank ground lug to the fuel tank filler assembly. There should not be any splices in the fuel tank ground wires. Jim |
| Ed Stone |
I've always thought you would run both engines on the same battery and save the other one for emergencys. I'm going to mount a on board charger to keep both batterys fully charged. I've wondered about the solar charger that goes directly to your 12 volt plug. Ed Stone |
Ed, Running two engines from one battery is exactly what you must avoid, otherwise you may damage the charging system of one of the engines. The two chargers seem to buck each other until the strong one burns out the weaker one. Then things go just fine, but you have one engine with a burned out charger. You don't necessarily even notice this because the good engine keeps the battery charged. See Jim (DIVE-1)'s comments above. |
I revised the article to include some comments comparing the two techniques. I also discovered while browsing the West Marine catalogue that they are fans of the alternative arrangement. --jimh |
| triblet |
>Notice that the alternate arrangement >connects the circuit breaker panel to only >the Starboard battery. Provided the tie switch isn't thrown. If I think I'd clearly label the normal position Chuck |
| Ed Stone |
Port position #1 Stbd position #2 Starting position All I will look over the wiring to see which |
| Lewis |
I have a 1984 25' outrage with two battery swithces, twin engines and three batteries. The third is under the center console. I know it isn't properly hooked up, you can't parallel start one engine. I want to get it all straight and could use some help. Do I need an isolater? |
| DIVE 1 |
Lewis, I am personally not a fan of battery isolators because of the voltage drop that they cause. I prefer a battery combiner/conditioner. West Marine has several different models to fit almost every need. The instructions that come with the units are well detailed and easy to follow. Jim |
I spent the weekend doing some electrical work on continuousWave (the boat), and in the process I "invented" a new wiring arrangement for use with dual engines and dual batteries. I have added a schematic diagram to the REFERENCE article (see link above in first message) and some comments about the design. One thing I like very much about the "new" arrangement is its extreme simplicity. It is being used, after all, on a small boat. There is not that much room in the rear cockpit or motor well for multiple switches and multiple batteries. This wiring was very simple and yet it provides all the flexibility I think I will need. Of course, after a season of use I may have a different idea. For the moment, we have the boat wired as shown and we'll see how it works! Comments are invited, as always. A group discussion often produces new ideas and improves thinking. --jimh |
| Chap |
Hello jimh, I've been looking at my non-switched dual battery/dual motor set up with a desire to add a switch. Had to jump a battery the other day. Jimh I believe, I read somewhere recently that you now have removed your switch in favor of the set-up I currently am running. True? Are you switchless? If so could you provide your reasoning? I assume simplicity and reliability but..... On the learning curve. Thanks Chap |
| jstachowiak |
For those who can get their hands on a copy of Florida Sportsman mag August 2002, this month, there is a good article about this topic. The article is specifically 4 batteries, two engines, but he talks about other set ups. Also, I just saw battery isolators at West Marine yesterday for about $70. An essential item when attempting this setup. |
| Capt_Tidy |
I have two set of batteries all managed by the Link 2000 system by Heart Interface... it's expensive ($450) but once installed, you will never leave the dock with it again... it has low battery alarms, digital battery readouts etc. If you have ever tried to figure out a short.. .this is the tool. I love it. I can charge via engine, charger, or solar without hassel. |
| Morocco |
Jimh-- In the 'new' schematic, since the batteries are each ALWAYS connected to the engine charging systems, you would never have to worry about burning out a coil because it's impossible to run either engine without being on line to a battery. Is that right? In the normal operation section when both engines are running, the center switch can be OFF, 1 or 2? Anyplace but on Both, right? (on off you would have no house power, though?) This battery stuff makes me batty... |
