ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Bow Bitt removal
Author | Topic: Bow Bitt removal |
jazzpicker |
posted 07-16-2001 12:30 AM ET (US)
I have a 18 foot 1990 Outrage (Rockland boat) and plan to replace the rubrail this summer but am having a slight problem. The 4 phillips head screws in the bow bitt are impossible to remove. I have tried with an impact driver and can't budge them. I hesitate to drill them out not knowing how they are attached under the bow bitt. Can anyone help me in this matter? Thanks |
LarrySherman |
posted 07-16-2001 12:44 AM ET (US)
Try wd-40, let is soak at least 24 hrs. Then try impact driver. I had same problem, used wd-40 (several applications over two days), the impact driver, and ultimatly, a little head, applied sparingly (bough an adjustable temp heat gun at home cheapo). Good luck, Larry |
LarrySherman |
posted 07-16-2001 12:45 AM ET (US)
Pardon me! A meant to say "a little HEAT." Talk about typos! |
Tom W Clark |
posted 07-16-2001 01:14 AM ET (US)
jp, Larry's advice is right on the money. Don't be afraid of drilling them out if you have to; the biggest problem when drilling them is keeping the drill centered and not chewing up the bit itself. Also see: http://continuouswave.com/ubb/Forum3/HTML/000829.html |
JimU |
posted 07-16-2001 11:54 AM ET (US)
If heat (use an electric soldering iron) doesn't work or if you strip the philips head, go to your local hardware store and get an "easy out" (broken screw extracter) and the correct size drill bit and remove the screws with it. JIM |
andygere |
posted 07-16-2001 05:05 PM ET (US)
I have had good luck using a product that gives your phillips head screwdriver better bite. I can't think of the name, but it comes in a little tube, and is available at most hardware stores. This will help prevent stripping out the screw head. |
