| Author | Topic: I'm making a bet. $10 to anyone who... |
| LarrySherman |
has not replaced the thru-hulls in their classic outrage or revenge and finds dry foam when they do. It won't happen. I pulled all of mine today, water in the lowest point of the "V". With this design, there is now way to avoid it. I when over the hull with a mallet inch by inch. No voids/delmaination. Thanks god for small favors. Foam is acutally dry (or only slightly damp) in the thru-hulls above the keel. I'm going to sand & barrier coat the outside, install all non keel thru-hulls and put a vaccume pump on her. Over the winter, I'll put her on blocks at a good angle and let her drain. Seriously, if you have not changed your thru-hulls, do it now. It will save your boat, and your investment.
this offer valid only durring the month of June, in the year our lord 2005, and then oly when Jupiter is ascending through the house of mars. small small print: I'll never pay you a cent, but you can take my advice to the bank! |
| cinco de whaler |
Larry, My 22' Outrage is a 1980 model. Are you saying that it most likely has water in the hull? I'm not sure exactly how you found the water or understand how you you plan to repair it. Please explain in more detail for us beginers. Thanks. |
| LarrySherman |
Cinco, What I am saying is that if those drain tubes are origional, I'm sure they are rotted through, and yes, there is water in the hull. If your boat is in the water, put your finger into one of the drain tubes and feel up and down the inside of it. With marine growth, it may be hard to correct, but you will proably find a hole from corrosion. If your boat is on a lift or trailer, this much eaiser to due from the bottom. My point is that these tubes should be changed reguarly, and that they rarely are.
It seems from these posts that a vaccume pump is the method that has worked for some. |
| bigz |
Larry S has a point but I must add in most cases it is really nothing to get alarmed about. Most of the folks with Whalers in fact probably the largest percent trailer the boat and aside from the occasional week or weekend over the years has never sat day in and day out in the water as say the 25 and 27's of old! The small amount of water will be pretty much localized and the best thing to do is let it drip (after removing the tube, if it will) a day or two in the hot sun. Then glass up the hole and install a heavier drain tube either bronze or the newer plastic types as outlined else where in the Repair section. Another fast sure way to insure no more problems is get the correct sized schedule 30 PVC tube and fiberglass it in sealing well the inter and outer areas, then just use the standard drain plugs either bar or snap to close/open. Clark Roberts I believe has used this method with success. Now, this can be a major headache though with any boats not just Whalers which sit in the water year round or even seasonal (particularly in the warmer climates). These that have rotten drain tubes which have allowed continued water infiltration might want to look at this post from last year for ideas http://continuouswave.com/ubb/Forum3/HTML/000128.html Might add there are a lot of other post on this subject from all last year, so if you need more information from members who have repaired these problems go searching a little -- Tom |
| LarrySherman |
bigz, Great post, I missed the vaccume pump article when I want throught the forum last week. Glad you posted it here. I guess my real point is that this is such a poor design BW owners need to be aware of it and fix it, before a small problem becoems a big one. I think BW must have assumed that water would get into the foam, and that in general the foam can handle it. Any decent enginer would look at thathe old drain tube design and KNOW that water was going to get into the foam. The thru-hulls should have been bronze, with solid glass behind them, just as you have done. I would really encourage anyone with the old tubes to replace them. It is really not that hard, and it will save your boat. PS: what did you do to repair the longer drain tubes? The one in my anchor locker is 9" long. Thaks, Larry |
| whalernut |
I am going to replace my transom drain tube on my 73` `16 Currituck. Again, what is the proper Length, diameter, and material, so I get it right the first time? Also, how much does a flaring tool cost? Regards-Jack Graner. |
| LarrySherman |
Jack, I'm still trying to find out myself. Went to 3 plumbing supply houses, 4 marine stores. Brouth my 3" long brass drain tube with me ($2 and change at West Marine). Result: Plumbing guys laughed at me, said no way was I going to flair that tube, to strong to do with a hand-held flairing tool. Same at all three stores. Marine store had no idea what I was talking about.
Larry |
| tarbaby |
I bought all the tubes and the flare tool at Morehead Marine. Cut the tubes about 3/16 longer than the depth of the hole.( slide it in and mark with a marker). Pull it back out and CAREFULLY cut the tube with a hack saw. Do not crush it. Put 5200 around the hole opening and slide the tube in. The unflared side needs to be coated with 5200 also. I like to put the "factory" flare on the outside of the hull and crimp on the inside. Put the crimping tool in the tube and have someone else on the inside with a wrench. You will feel that you are over tightening but you're not. If the tube is too long, There will be a crack on the crimp. If the tube is too short, You will not be able to make it rollover and make a good seal. The crimper works fine for the short tubes, but is too short for the long ones.Go to the hardware store and buy a piece of threaded rod that is the same size as the bolt on the crimper. I think mine is about 3 feet long. This is a very easy job. Hog on the 5200 before you "crimp" and wipe off the excess. Shay |
| LarrySherman |
Tarbaby, Great news, thanks for the post! Could you give me a number for Morehead Marine, and the name and brand of the tool you used please? From your description, it sounds like you insert the tool through the drain tube from the outside, then attach the flairing device to the threaded rod sicking throught the tube on the inside. Then you tighten from the outside. Is this correct? Thanks much! Larry |
| LarrySherman |
Jack, tarbaby is right on the money. Go to www.moreheadmarine.com. Call the Ships store. They are nice people, know exactly what we are talking about, are a Whaler dealer, and it makes me wish my dealer were even remotly like them! Thanks tarbaby, Larry |
| whalernut |
Thanks guys, I will give them a ring! I bet they even have a factory or can get a factory Transom Tube? Regards-Jack Graner. |
| tarbaby |
All parts are BW. Tubes and crimper. Shay |
| LarrySherman |
I posted the partn numbers in the "Drain Tubes" post a few days ago. Check there. Go get em' tiger! |
| mfrymier |
I was searching "drain tube replacement" and stumbled across this old post -- is Larry still around and will anyone take him up on his offer? June 2005 is only 2 weeks away! |
