ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Preventing condensation in the gas tank.
Author | Topic: Preventing condensation in the gas tank. |
triblet |
posted 08-17-2001 04:05 PM ET (US)
Here's a crazy idea I just had for preventing condensation in the gas tank. Condensation happens because barometric What if we put a flexible bag on the tank I'll try it the next time I store my Montauk. Chuck |
kingfish |
posted 08-17-2001 04:51 PM ET (US)
Snowbirds!! Hey, I represent that remark!! jcf |
andygere |
posted 08-17-2001 05:44 PM ET (US)
Chuck, To take the idea a step further, why not build the fuel tank like a hydropnuematic tank with bladder inside that seperates the liquid (fuel) from the air in a closed system? When it warms up, the bladder compresses, when it cools, it expands. Added benefit would be no need for a primer bulb anymore. Just add a little air to the bladder once a year and you're good to go. Could be tricky when adding fuel to the tank though..... |
triblet |
posted 08-17-2001 06:02 PM ET (US)
You'll still need the primer bulb. That's to fill the float bowls back up after they dry up. Nothing to do with air in the tank. However, I never quite figured out why my Chuck |
Hank |
posted 08-17-2001 11:55 PM ET (US)
How about just filling the tank ? Very little air volume will mean little volume change during temperature cycling. Little volume change will result in very little moisture condensation. Hank |
Tom W Clark |
posted 08-18-2001 12:07 AM ET (US)
Hank, Filling the tank is the convetional wisdom but I think triblet's post might be an extension of the query found here: http://continuouswave.com/ubb/Forum4/HTML/000422.html Chuck, Interesting idea. But the problem I see is that the tank and its filler, fuel outlet and vent all need to be sealed in order to withstand a certain small amount of pressure/vacuum. How do you envision sealing the tank on a Whaler? |
triblet |
posted 08-18-2001 08:17 PM ET (US)
Using my Montauk as an example, there are sealing caps. The bag would be on a separate vent (the Pate has two places to attach the tube, I could just use the second one for the bag, Fuel outlet is probably not a problem, the bulb has two check valves. Tank is already sealed. But again, we don't have to worry about |
Macman |
posted 08-18-2001 08:21 PM ET (US)
Jeez...you engineers want to complicate everything! How about closing the vent and calling it good? Works for me! |
Dick |
posted 08-18-2001 08:37 PM ET (US)
Macman You beat me to it. Closing the vent is the simple answer. It works on mine too. |
Tom W Clark |
posted 08-18-2001 11:08 PM ET (US)
Closing the vent is fine for you Montauk and Sport owners but how about owners of boats with built in fuel tanks? |
Dick |
posted 08-19-2001 10:36 AM ET (US)
Tom Sorry about that, tunnel vision. It is a real problem with built in tanks and I have never seen a solution. What about an inline shut off valve on the vent hose? |
