ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Painting a outboard (touch-up)
Author | Topic: Painting a outboard (touch-up) |
Legobusier |
posted 04-02-2004 09:34 PM ET (US)
My '98 Honda has some paint that has flaked off that needs touch-up. It's the plastic area below the cowling - about 2-3" high. I have some Honda touch-up paint, but the can doesn't really have any directions. Is there any special prep I need to do to the plastic (other than clean it up)? It's pretty slick, so I'm pondering giving it a light sanding. The second picture here shows it pretty well. http://www.covingtonhendrix.com/Montauk/ Anyone have any tips? Thanks in advance, |
andygere |
posted 04-02-2004 10:21 PM ET (US)
Wet sand the transition from good paint to bad, up to at least 400 grit. Make sure there is a smooth, feathered transition. Wash with water, degrease with mineral spirits or acetone, then mask and paint. Make sure temps are 65-75 F, reasonably low humidity (no rain in forecast) and no wind or the overspray will be all over the place. Use 2-3 thin coats, and don't put the paint on too wet (by spraying close and/or moving the can too slowly) or too dry (spraying too far away). It should go on with a nice wet shine, but not sag or run. Also, most paints require recoat within 2-4 hours or else wait at least a week for a full cure. I have found the factory branded paints to be worth the extra cost over the generics. I just used some Mercury touch up and was really impressed with how well it went on, and how much gloss the finished job had. |
posted 04-02-2004 11:18 PM ET (US)
For advice on how to re-paint an outboard lower unit, I suggest this article: Cosmetic Repairing and Repainting of an Outboard Motor Lower Unit |
Legobusier |
posted 04-03-2004 06:46 AM ET (US)
yeah, I saw that Jim. I'm not dealing with the lower unit on this project - at least not yet :) |
Gene in NC |
posted 04-03-2004 12:58 PM ET (US)
Hey Legobusier, I have same problem on '87 Johnson except area affected is more advanced than yours. Andygere's advice sounds good to me except that I would need to pick off a lot of loose edges before sanding. At least you got more responses than my post did. Seems odd that you and I are only ones with this prob. Maybe it's the '87 Montauks that the engines are mounted on |
Legobusier |
posted 04-03-2004 01:28 PM ET (US)
That's probably it Gene :) I too have some loose paint at the edges to pick off....it doesnt' seem to stick well to that rather slick plastic. If you want I'll give it a shot and email you with results. Let me know. |
posted 04-03-2004 01:53 PM ET (US)
In reference to: http://www.covingtonhendrix.com/Montauk/images/Mvc-127s.jpg It looks like you need to re-paint the midsection of the engine. I can't believe that is plastic. I would think the same sort of preparation and painting technique would be applicable as I described. Are you sure that midsection is plastic? |
Legobusier |
posted 04-03-2004 03:40 PM ET (US)
I'm positive Jim...plastic....damn cheap Hondas :) |
Gene in NC |
posted 04-04-2004 12:02 AM ET (US)
'87 Johnson 90 sure looks plastic. Maybe it's like the duck. It's not metal, it's not fiberglass, so it must be plastic. At least it doesn't corrode or rust. |
Bigshot |
posted 04-06-2004 02:52 PM ET (US)
Primer is usually used to prep the area the paint is going to cover. I use Tempo brands. |
