| Author | Topic: Jeff's OUTRAGE 22 Restoration |
Please use this message thread for comments or question about the Reference article Under-deck Repairs by Jeff Rohlfing http://continuouswave.com/whaler/reference/outrageRestore.html Many thanks to Jeff for contributing this excellent documentary of his restoration work on his fine Outrage 22. The article shows in detail the repair of the central deck cover, improvements to the fuel tank cavity for better drainage, re-wiring of the primary electrical system, and a general re-fitting of the under-deck areas of the boat. |
| DaveH |
Nice work Jeff et al. One tip I would add to this fine restoration work is when adding the final bead of caulk around the deck, place a length of monofiliment in the channel to ease the removal of the caulk bead if you ever need to perform any future deck work again. The monofiliment will act as a knife when extracting one end and pulling it up through the caulk. |
| dgp |
This is a great repair article and very well documented. One point regarding dehumidifiers. Standard dehumidifiers only work down to 65 degrees F. You need a low temperature model to work down to 42 degrees F. |
| Bulldog |
Thanks Jeff! Your postings had inspired me to also pull up my cockpit floor in my 1987 Revenge. My floor was in excellent shape,even found a paper packing slip in a slip lock stick on envolope on the bottom of the cover! I found a bad fill hose and also installed a drain similar to yours in the tank well. You did a nice job!............Jack |
| alfa |
Fine job Jeff ! Congrats, I hope I'll not have to do a similar work. Fine details showed. |
| Plotman |
Wow, what a job. I'm impressed by the detail and care you put into this project. It was rather shocking to see how shoddy the original work by Whaler was on the deck fabrication. The only suggestion I might add as alternative would be to look at a vacuum bag set up for bonding the new laminations to the deck instead of piling on the weights. I've been part of doing this for other boat building projects, and it works well. The set up we used just used a heat sealing device to "weld" to pieces of heavy poly together to create the bag, and a small 110v vaccum pump to evacuate the air. |
| HAPPYJIM |
Great article with some outstanding pictures. You made a big job so much easier to tackle with all of the hints and pictures. |
| 17 bodega |
Amazing how well all the tedious steps were carried out. It serves as a reminder that when you think you are taking on one project, it can turn to several when you are talking about boats. If your boat was maintained in the manner in which the seller represented, then it makes me question how many saltwater whalers have the same issue with water below deck. Very impressive undertaking. |
| John O |
Nice job. How many man hours do you estimate the project took? I assume the "1992 Outrage 22" should read 1985. |
| whaler710 |
Jeff, Great article with great pictures. I own a 1984 20 foot Whaler Outrage and it helped me learn much about the contruction of the mid 80s outrage deck and gas tank. Additionally your article provided me with a definite sense of appreciation for deck screw hole leakage relative to the seriousness for potential damage. You are to be commended for restoring and preserving a classic Whaler. thanks for sharing your expererience and the resultant lessons learned. |
| Ethan |
Great project and great article! Thanks for taking the time to share this with everybody! |
Fixed date typo--thanks! |
| Al_A_Buy |
Jeff - Great article. Just one question - why did you opt for plywood instead of some other less water susupetible material? I'm looking at a similar repair on my fuel tank cover and don't ever want to have to re-do it in the future... Thanks - Al |
| ratherwhalering |
That was a concise, informative article Jeff. Thanks, I learned alot and I think others here did too. The task of tank removal and/or floor restoration just became less daunting. Well done. |
| rtk |
Nice job Jeff (and all else involved), on both the repair and the article. That's a big job. Good lesson and reminder to go around and recaulk all the screws you can. I found a fair amount of loose screws around the console area. It is amazing how much damage water can do to the plywood, without showing visible or obvious signs of rot. Your good to go for many years with that repair. The boat does look like it is in excellent condition. Good luck with her. Rich |
| jeffs22outrage |
Thanks guys. When I did this project I wanted to document it fully to help other who will be faced with tackling this job in the future. What is not shown in this article is the electrical system and rewire of the boat my father did. That was just as much work as the floor. I can not thank my father Bill Rohlfing enough for the time and effort he helped put into this project with me. I truly learned a lot from him while working on this project . Not just "Technical Skills" but, "Life Skills" as well. I splashed the boat on Memorial Day weekend in Grand Haven Michigan with Dave (buckda) and Tom (newport_whaler) and have been enjoying it even since (expect for the leaky head gasket). Jack - I do not know whether to say your welcome or sorry for the inspiration. :p Plotman - Dave that is an idea I had never thought of. I used vacuum bags back in school to build furniture and love using them. I guess I never though they would make a bag big enough. John O - With the rebuild of the floor and rewire it took about I would guess 400+ man hours. Al_A_Buy - We used plywood because all of the non wood materials, except for fiberglass sheets, had to glued into place and we felt over time the adhesives would not hold as well. With the plywood and resin you end up with a strong part than if you just adhered lets say HDPE plastic sheets to the bottom of the floor. Using wood was more economical as well. Wood = $45, Fiberglass sheets $1500 , Starboard $1000+ Also if kept sealed the wood should last for ever as well.
| Ethan |
Jeff- I just want to say - your efforts towards documenting and sharing your project are a prime example of the best this site has to offer. I've been dismayed over the past few months at some of the negative, hostile exchanges that have occurred here on Continuous Wave. You not only did a great job, but your acknowledgement of your father's help, thought out responses to questions asked, and thanks to jimh show class. Hope you folks enjoy the refurbed boat and I wouldn't be surprised if you've inspired others to meet the high bar. Regards, Ethan |
| John O |
Jeff, Thanks for the pictures of that fantastic rig in the water. Great boat and great job. I bet that deck will be bullet proof for a long time to come!!!!!!!! Thank your Dad for us as well. John |
| devildog |
Jeff, Great job! I've been following your progress for quite some time and you played no small part in my decision to search for an Outrage 22 instead of an 18 or 20. I purchased a 1980 Outrage V-22 at about the time you were finishing up your restoration. Thanks for the invaluable documentation of all the work you and your Dad did. Jeff Myers |
| Highlander0108 |
Jeff, What good information. I just had a fun weekend replacing fuel fill and vent lines, which necessitated taking up the floor on my 25 Outrage and I found the same problems. The mushroom factor has begun. The layout is similar to the 22, but there is no cutout on the port side "tunnel" to let water back out off the tank. That is only accomplished by the fitting installed on the starboard side aft end. I tunneled out a sump and have been vacuuming water out. I have a few questions and one theory. I have to replace the fuel line to the fuel filter because it is leaking and have the same copper/rubber issue. Mine did not have the cover over the tubing. I think Whaler might have done that in case the well was used as a bait well and the lines could be damaged. I want to run the fuel line out the side grommet and into the slot and avoid the copper completely. I plan to run the sump pump tubing in the old fuel line location and put the pump in the stern. Does anyone know what was used to seal this cutouts or have any suggestion. Mine had been gunked up with a wad of white caulking that apparently wasn't doing much becsue the foam was wet inside. I have an old Sea Drive model with a full transom so I have an easy place to put the new pump. Do have any other info on the pump you used? Thanks. |
| jeffs22outrage |
http://continuouswave.com/ubb/Forum1/HTML/010373.html |
| FU2 |
You are one talented person. Very nice work. Thank's for sharing the project. |
| Sheila |
Jeff, You did a beautiful job. Does the 400 man-hours include the extra time taken to provide such careful, thorough documentation? Thank you! |
| Sheila |
Oh, my. That should have been "Do the 400 man-hours..." 'Scuse me. |
| jeffs22outrage |
Shelia the 400 hours includes everything for researching materails to documenting everything, and the complete restorationg of the hull, trailer, and rewire of both, as well as every time I had to drive to the store, etc. , etc. I figured the time as if I was being charged for the job by myself. |
| Rob Cote |
Jeff, thanks for such a terrific job on the boat repair and documentation. You inspired me to take a look under the deck of my 1986 Revenge 22 WT. At minimum, I need to replace my fuel hoses. The deck on the Revenge has 3 sections: the fuel tank cover, the fish well cover, and a 3rd section under the console area. I have removed the first 2 sections, and the wood was wet and heavy, but in better shape than yours was. Still, it should be replaced, and I have set out to do that. The 3/8" section has been removed. The remaining 1/4" section is still in good shape and I plan to leave it in place. I also plan to remove and inspect the 3rd section under the console. I carved out the sump area behind the tank, just as you did. I am seing some clear water collect there, but not much. I am considering installing a brass tube between the bottom of that sump area and the fish well. Your thoughts? The port-side channel still needs a solution too, and I am considering a tube into the fish locker tube. Also, looking for a good source of marine grade plywood. Any suggestions? |
| Rob Cote |
type-O... re: the port side channel. "I am considering installing a tube between that channel and the fish locker." |
| crusty crab |
Jeff, What an incredible, incredible article. Top shelf. I'm less daunted now by the reality (I'm avoiding) that I have to remove my console, T-top, decks, etc., etc., etc. and start the repair you accomplished. I will print your article for reference but even still I'm sure I'll be nowhere near as organized or thorough as you and your father. Too bad BW doesn't make decks to replace the shoddy workmanship they did on the decks of these otherwise excellent boats. I have just one question, it appears you added thickness to the deck and I wonder if that interferes with any structures (bulkheads, tank straps, etc.) when refitting the deck to the hull. Again, many thanks for sharing your project, I am not worthy! |
| jeffs22outrage |
Crusty, Whaler laid the floor up with 2 sections of marine plywood. A layer of 1/4" that was what first attached to the back of the floor and a layer of 3/8" over that. I used 3 layers of 1/4" and had no issues with fit. In the end it ended up being a much stronger part with 3 layers than if with 2 or even 1. I do have a lot more pictures than what is published in the article. Also I have pictures of the rewiring of the entire motor, console, and trailer. As well as the refurb of the trailer axles. I am currently documenting the rebuilding of my powerhead. So if need other info please feel free to send me an email to the address in my profile. Cheers and good luck! Post some pictures as well. |
| rschneider |
Great job. I am cleaning up a 1982 22' and I was scratching my head trying to figure out where the water on the port side was suppose to drain out. Thanks for figuring it out for me. |
| R I Whaler |
Jeff, I've been studying your project for the last several months. Nice work, to say the least. I am about to embark on some of the repairs you have documented here. The one in particular I am beginning this week is the installation of a pump for the gas tank well (A fuel tank cavity sump). Almost everything you did is clear so I only have a few questions. I have a 1987 20' Outrage. Everything is very similar to yours except I dont have the rear well. First, do you have a closer detail of the pick up of the suction pipe assembly so I can see what you did there? You describe it as a pvc pipe mounted to a piece of mahagony. What I was thinking of doing is taking a 3/4 inch pvc 90 degree fitting with a short verticle nipple and mounting it with clamps so the pick up (the end of the verticle nipple) is virtually at the bottom of the fuel tank sump area to pick up any water. Then I would just transition to clear tube from the horizontal end of the 90 and run clear tubing up to the console pump. I was wondering what the purpose of the mahagony was. I was also thinking of running the drain side of the pump tubing back down to the cockpit sump area and dumping in there so as to avoid a through hole fitting. What do you think about that? I was also wondering about the front compartment sump pump you installed. Do you have any details on that? And why did you decide to put a pump in that compartment? Oh, and where did you buy the sureflow self primimg pump? Is that a common marine store item? Thanks for any advise and feedback you can provide. Mike |
| jeffs22outrage |
Mike, I have a lot of feelings about this pump set up I did. Some good some bad. The idea I still think a great one but if I had it to do over again I would have used a much larger inner dia hose. Right now I am using 1/4" inner Dia hose and it just does not flow as well as it should. I would recommend going to 1/2" inner dia or larger. I would run that hose from the pump into the fuel tank cavity. Once in there I would a 90-degree elbow to run down to the bottom of the cavity as a pick up. The 1/4 inner dia hose has also created such a restriction that the pump will not self-prime. So to solve this problem I added a fuel primer bulb on the exhaust side of the pump to help draw water into, and prime the pump. I feel all of the issues I have encountered would be overcome if I had simply used a larger hose. I would say use the largest you can. As for running the exhaust back through the rigging tunnel to the rear cockpit sump area....Well, that would work so long as the hose is draining overboard and not into the sump area. The reason I say this is because if water gets into that sump area and rigging tunnel it will go right back into the tank cavity through the through hull in the stringer. Also, always keep the rear sump/rigging tunnel plug in when the boat is in the water to help prevent water from entering the cavitiy. I ran the exhaust to a through hull simply because I did not want to crowd an already crowded rigging tunnel even more. I will say, because the foam has been removed from behind the tank I have found that any water easily collects there. Because the foam is gone I can pop the rear deck plate and use a wet/dry shop vac with a modified 1" hose to remove all the water in about a minute (I removed 3-5 gallons before storing the boat). I use this method whenever I can. I truly think removing this water in the fuel cavity is an important step in helping your fuel tank last for a long time. Think about it, if that area is filled with water, and you store the boat any where in the winter where it will freeze, all the water will freeze into a large block thus creating a large force pushing against the walls of the cavity and the tank. This could crack a weld on the tank causing failure or even crack the fiberglass in the cavity.
Hope this helps, If you have any questions feel free to email me. |
| jeffs22outrage |
I bought the surflow from the manufacture. See link below |
| R I Whaler |
Jeff, Thanks for the reply. I do have a few more questions which I am gathering. Is your e-mail currently the Whaler Central address? Mike |
| jeffs22outrage |
Yup, it will redirect it to my gmail account. Or just send me an email and I will give you a phone number to contact me at. Much easier the typing out a long email. |
| jtc12 |
Jeff, This September I purchased a 1981 22 Outrage - it had obviously had a few more owners than I would have preferred, but the hull was in perfect shape and the engine was replaced in 1996 with an 225 Evinrude OceanPro which runs flawlessly. Two years ago I sold my 1989 22 revenge we had owned since new, so I had a general idea of how everything should flow. I also have a 1989 27 FC, a 1988 18 outrage, a 1989 17 sport, and previously owned a 1983 17 montauk. Bit of a classic whaler nut. I've had to do minor maintenance and repairs on these in the past but nothing like this one has turned out to need. The previous owner of the boat installed a bilge pump in the spillwell of the boat expecting it to bail everything - he left the plug at the rear of the starboard tunnel along with all others. The boat came with no other pumps, and the only way for water to exit this tunnel was either overflowing - or into the fuel cavity. Between the fuel cavity and the tunnel, the thru-hull in the stringer was clogged from the factory with the foam used to fill in around the gas tank, meaning for the last 25 years the only way for water to drain from here was the tunnel at the front of the boat. When I lifted deck of the boat, there was 1-2 inches of standing water across the fuel tank and foam. Didn't smell too nice. This was after being pulled from the water over a month ago and in heated storage. When we pulled the main deck of the boat, it basically came out in two pieces - the deck - and the bottom plywood. Thank you for writing a beautiful article on this repair. I pulled the deck only to change the fuel lines and sending unit, and this is what I've ended up with. As with yours, Whaler did quite a shoddy job sealing everything after cutting, and with the extra few years mine had to rot, you can imagine the state the deck is in. I figure do it right once and I'll keep the boat for 20 years though. Anyway, the electrical system in the boat is an absolute disaster. (Driving in the rain you would get quite the shock holding the wheel and the throttle at the same time) I found this caused by a bad ground the previous ownder must have put in. I was wondering if you had any pictures / notes on your rebuild of this system? If you do I would greatly appreciate it... and if it's no inconvenience you may be hearing from me regarding other issued I run into the next several months as well, though your article and this forum should answer the majority of my issues. Thanks again for the great article! |
| jeffs22outrage |
Update: Well this weekend I solved the problem with my fuel tank cavity pump. The reason why it was not work so well was the pick up line in the rigging tunnel was collapsed under a bent cushion clamp. Who knows when it happened, maybe it was stepped on when the floor was reinstalled. Who knows. Any way I pulled the hose out of the the clamp and it opened right back up. Turned the pump on and it began drawing and exhausting water right away. So the set up is finally working the way it should. |
| ReelaX |
Great work and info Jeff, I'm into a complete rework of an 85 Outrage 18 and this couldn't have been a better post. Thanks again. |
| jeffs22outrage |
Reelax Thanks, The new owner of my boat should rest soundly knowing the floor is in good shape. If you have any questions feel free to contact myself through the email listed in my profile. |
| Miestrol |
Thank you again for your great artical. Three years ago after having many smaller whalers, I found a 1988 2200 temptation with whaler outdrive and two 1992 150s on it in Michigan. Seeing the great condition of the boat and bottom never seeing 3 months in water,Ijump at it and repowered with a 225 merc optimax. Boat performed well,but I also saw water soaked foam in the tank inspection opening. After watching a small repair shop near Bayfield Wisconsin do the same repair you did on a 22 outrage, I got pretty worried. for the rest of that summer, I kept tank vacuming the foam every day and left small electric fans in the inspection plates. Iused the boat that fall and it appeared to be floating in less than Knee deep water and appeared to pull up the ramp easier. Because of family issues ect. I never used the boat last year but left all inspection openings open. Other than trying to carve the foam out from the inspection whole, is there any way of d rilling a transume drain plug tube to the sump area to unplug when the boat is on the trailer? I seriously dont think there is a away that is draining. I think that the mere fact that this boat was not used much after it was put into service in 1992, is the only reason my floor appears good. Thank you again for your story. |
| maverick |
Jeff - THANKS for the great articles and detail. VERY helpful as I do a 1990 Guardian. VERY well done and IMPRESSIVE. Question: On your rear gas tank sump to get water out, did you glass over the foam that you cut out in that "well" area? How is your design working? I may do the same, but I was also considering drilling a gravity drain hole from the tank area into the right rear bilge sump 12x12, maybe add a smallk scupper to it so it can only drain out, and not backwards. Thoughts? Thanks, Mav |
| makoman310 |
jeff thanks for the great info on repairing the deck i completly ripeed the whole boat apart today 3/7/09 by my self in 8hours decks off gas tank out and i am going to be choping the old wood out today when i got to the gas tank the rubber strips were there but whaler must have wrapped the tank in white plastic foam sheets before they foamed the tank in on the bottom and all sides the tank is in great shape from 1988 with this white foam i have a new tank comming so i will not reuse the tank bolth rigging tunnels were all full of ice those little plastic drains were clogged and did not let them drain bob highland |
| BarTender |
Jeff, I think you've heard all the superlatives on your article and the actual project itself. As an owner of an '85 Outrage, I have a few questions that I haven't seen asked before; Why not remove and replace the old foam with SPF Sprayed in Place Foam? I don't know if there would be an advantage to doing so or not. Do you seal the screw holes with caulk when reinstalling the deck to insure that means of water entry is alleviated? What type and brand of caulk did you use? Are you happy with its durability? I pulled up the rear deck live well cover and it looked as if there had been previously applied beads of silicone caulk along the lower deck where the cover would have screwed down. As I am the original owner, it would have been done by the factory. Do you have insight on this? I have been trying to dry my boat out for years between seasons and never relaized how much the foam could absorb. You have made everything much clearer for me. Many thanks, Rudy |
| jjandpop |
Jeff, Thanks for your explanation and photographs. I finally removed the deck from my 1987 OR 20 and found what I expected. All the wood was saturated and mostly rotted. Inspection showed that much of the damage was caused by water entering along the edge through the many screw holes where the deck was attached and the many screw holes in the deck where the previous owner made a number of modifications to a "T" top. I could not repair the nonskid so opted to replace it with a sand finish. The removal of the plywood was very labor intensive but with the help of a neighbor we had it all removed in 2 days. It took another day to grind off all the wood that remained attached to the fiberglass. I used a 3/4" sheet of treated plywood leaving 2" on each side for shaping the area where BW had used 1/4" plywood. The edge of the plywood was bullnosed and then laminated to the underside of the deck using West system epoxy with a silica filler to give the epoxy more body. After a few days I filleted the edge of the plywood to make a better surface to lay fiberglass. I used 4" wide biaxial fiberglass to cover the edge of the 3/4' Plywood to the edge of the deck. I then proceeded to fill the edge with fiberglass and fillers. The final layer was another layer of biaxial fiberglass. This brought the total thickness of the deck attachment area to a thickness of 1/2", I had to predrill all the attachment screw holes. The entire bottom was saturated with epoxy before we reassembled the deck. I did not find any water at the bottom of the cavity where the fuel tank resides, so I did not install a sump and pump. The nonskid looks very good and it is much better then the original that was part of the originally molded surface. It all want back together and was ready for a scheduled rendezvous. Again, thanks for your excellent details. Jim |
| Jeff |
Guys, Sorry for my slow response. I will answer all the questions...I just need to find the time. Give me to the end of Sunday. |
| 68 WhaleR |
Jeff, great article, I am deep into my deck now. One thing that helped me removing the wood was a mega chisel that was passed down to me. I removed 98% of my wood in under a hour! 4 inch across blade, 25.5 inches long with wooden handle. I plowed right thru. Still took a bit with the good wood but I had lots of rot so that part was easy. Not sure where people can get one but maybe online somewhere, vintage tools? Check my photobucket page and you will see photos of it. Really handy. I did chip it a bit but it saved a lot of time. http://s955.photobucket.com/albums/ae37/esowder/88%20%2018ft%20Outrage/ thanks |
| EaglesPDX |
Jeff, Just purchased a 1989 22' Outrage. The foam around the fuel tank is saturated. The boat was stored bow up and it looks like the water is only in the last third of foam around backend and sides of the tank. My game plan was to remove the foam, vacuum out the water and replace the foam. Also, I removed the old mounting screws from the previous (original) owner's depth transponder and get drips of water out of the holes low down on the transom, so I've go water in the transom. I drilled into the existing holes and got good colored wood so no dry rot has set in but I want to get the water out. Any suggestions? Boat, trailer, 2 x 115-HP OptimMax engines, 115 gallons of fuel (option big fuel tank) two large 1000-A-h batteries, two electric downriggers, 92-quart cooler with ice, fishing gear and miscellaneous stuff, the scale was 5600-lbs. Trailer 1600-lbs That would leave hull weight of 2050-lbs which is rated dry weight plus or minus 200-lbs, so I'm guessing and hoping there not that much water in the boat. On the transom, the local yard said they have had some luck drilling larger holes and putting their vacuum bagging machines on. They are a spendy yard so I'm trying to figure a DIY version. Still leaves me with the water leaking in, boat will live on an AirDoc, life out of the water with a mooring cover on. I'm guessing re-sealing the deck after inspecting and repairing the foam will help. I like your idea of giving water a place to migrate to and means to get it out via a fuel tank sump and pump. When I re-foam, I'll leave a spot open. Positioning it under the deck inspection port sounds good. Just open and vac out regularly. |
| motoboy |
Nice job Jeff. Can't believe all the water you found in that boat. My Dad was [careful] about keeping water out of [another boat]. We had a full cover for it. Stored indoors in the winter.--Dwight |
| powdahbonz |
Jeff- I need to pick your brain again on a couple of items as I'm tackling the tank/hull now...can you please email me at jdbonz@msn.com? We talked a few months ago. Be great if I talk with you by phone-thanks |
| Jeff |
Derek (and Others), I have no problem at all talking over the phone. I much prefer it. It easier to do rather than emailing long explanations back and forth and it is faster to clarify and describe things. Feel free to email myself at the address listed in my Profile and I will send you my phone number. |
