| Author | Topic: OMC VRO Compared to Mercury |
| seasled |
I had a 1987 Johnson 70-HP outboard motor with VRO that ran 1,500 hundred hours and never had a problem. I would check hoses and clamps at the begining of the season. I like the VRO system. One line to the tank that pulls the oil to the pump; mixes at the proper ratio, and off to the carburetors it goes. I think any system is good as long as works. Let us take a look a Mercury: A two line hose to the tank. One hose presurizes the tank, and the other hose feeds oil to the engine. There the oil is fed to a gear driven pump, where it is pumped to the fuel pump for mixing with the gas. I have looked a both system in detail, and I choose a Johnson 150 over the Mercury 150 as my choice for my OUTRAGE 18 re-power. Like I said any system is a good system as long as it works. SEASLED |
A very thorough description of the OMC VRO system, now the OMS System, is presented in an illustrated article in the Reference section. Here is my understanding of how the Mercury oiling system works: Positive pressure from the crankcase is accumulated and sent by a hose to an air-tight remote oil tank. After the engine has run for some time, the tank becomes pressurized, forcing flow of oil from the remote oil tank via a pickup tube and outlet hose. The outlet hose from the remote oil tank delivers oil to another, smaller reservoir tank, located under the engine cowling. The under-cowling reservoir tank is located above the oil injection pump. Oil is fed via gravity to the oil injection pump. The oilinjection pump is operated via mechanical gearing from the engine drive shaft. To contrast the two systems, I note: --OMC uses one hose; Mercury uses two. Advantage to OMC for less cluttered design and neater installation. --OMC uses suction to draw oil from main reservoir; Mercury uses pressure. Advantage to OMC, on this basis: maintaining an air-tight tank is more problematic than maintaining an openly vented tank. --OMC uses one reservoir; Mercury uses two reservoirs. Advantage: split-decision. I am leaning toward Mercury on this one because the presence of the under-cowling tank. Its gravity feed permits a margin of safety. If the Mercury remote oil tank fails to deliver oil to the engine, there will still be some oil accumulated in the under-cowling tank. This oil reservoir will allow the engine to continue to run for a period of time. On the other hand, having a single tank makes the system simpler, and this is attractive, too. --OMC uses three alarms to monitor the system; Mercury uses [?]. OMC's OMS has three alarms to monitor the oil system. One watches the reservoir tank level; one confirms delivery of oil to the mixing pump; one monitors fuel line suction pressure. All three conditions are signaled separately and can be unambiguously interpreted. In contrast, the Mercury system just beeps at you. Advantage: OMC. ---- |
I also observe this contradiction: Many critics of the OMC VRO like to point out that the system is driven by a crankcase pressure operated pump, whereas the Mercury pump is gear driven. This argument overlooks the fact that the Mercury system also uses crankcase pressure to operate an air pump to provide the flow of oil from the reservoir tank to the gravity tank and thence to the gear-driven pump. Accumulating crankcase pressure and using it for pumping is a very common device in engines. The power brake system of most vehicles operates from |
| Chuck Tribolet |
Can you cite an example of an automotive power brake system that works off crankcase pressure? Every one I've seen works off intake manifold vacuum. And modern engines vent the crankcase into the intake at very low pressure (ounces per square inch). Also, unless there's a mechanism to tell you that the Mercury
On a two-stroke the crankcase and the intake manifold are the same. This is the cause of my confusing statement. I will revisit this discussion after I dig up an excerpt from the Mercury service manual that describes the alarm system in more detail. |
| seasled |
On the mercury system the oil is fed to the pump from the engine mounted reservior. The gear driven oil pump is conected to a linkage on the carburetors. [The throttle position] is what [controls the rate at which the pump] meters the oil. |
| seasled |
The Mercury oil alarm system uses a [sensor] that reads a low level in the engine oil reservoir, and a motion sensor in the oil pump. |
Information on Mercury Oil Injection http://continuouswave.com/whaler/reference/mercuryOilInjection.html Oil system alarm comparison: Mercury: --low level in oil reservoir under cowling OMC: --low level is remote tank reservoir After c.1992 OMC used an illuminated annunciator panel (SystemCheck gauge) to differentiate the alarms. Prior to that the cadence of the alarm signal provided information on the source of the alarm. Mercury's alarm horn had only two cadences (BEEP_BEEP_BEEP or continuous BEEP). The BEEP_BEEP_BEEP indicated an oil system alarm, but did not provide further information. |
| linust |
Hmmm...interesting comparison. For the sake of argument... Anecdotally, I hear more stories of people disconnecting the OMC VRO system than the Mercury oil injection system. Would you rather have a vacuum in your remote reservoir, possibly drawing in dirt and debris or a pressurized tank that will push such contaminants away from the system? And the two hoses are siamesed together (except at the very ends) so routing is no more difficult than a single hose, except for its larger size. In 15+ years with oil-injected Mercs, I've never had an issue with maintaining pressure in the remote tank. The latest Smartcraft systems can monitor remote reservoir levels if you have the right sender on the oil tank. OTOH, with a 3 gallon translucent tank, if you can't determine if you have enough oil for your trip...top it off! |
| Buckda |
On the Mercury, the "BEEP_BIP_BIP" was the alarm indicator when you started the motor to indicate that they system was functioning. When you had an oil delivery alarm, there is a repeated and rapid "BEEP_BEEP_BEEP_BEEP_BEEP_BEEP...." The continuous "BEEEEEEEEP" was for overheat or other malfunction. That rapid "BEEP_BEEP_BEEP_BEEP_BEEP_BEEP...." makes for quite a feeling of urgency when you're 40 miles out in cold water. The good news is that that alarm sounds when no oil is being delivered to the tank-mounted resevoir. Since most OMC Evinrudes did not have this resevoir, I really feel that the Mercury design was superior from a "get me home" standpoint. For instance, when my (malfunctioning) alarm sounded last summer, I knew that I could at least stop every 20 minutes or so and add oil to the powerhead-mounted resevoir. In a 2-hour crossing, this is not ideal, but better than being stranded 40 miles out with no services and when getting home/getting things fixed get REAL expensive. As an aside to JimH on the "advantage" comparison in your first post here, I believe I differ in opinion. Even thought the Mercury uses two hoses, the design is not cluttered on most installations. In many boats, there is a stern area that is concealed for this tank. On an Outrage, you can mount it in the console and route the hoses through the rigging tunnel. This is how it was done on my boat. The hoses hid seamlessly in the rigging to the motor. The pressurized system is better because it provides a steady flow of oil via a by-product of the engine running, whereas the OMC system has to SUCK the oil...the Mercury essentially "pushes" it. In most circumstances, it is easier to push than to pull. The "redundant" tank on the powerhead helps mediate any concerns about maintaining a pressurized system. Should there be a loss of pressurization, the powerhead mounted tank will provide oil even if the engine isn't "Pushing". If the OMC system stops "Sucking"...well, that really..ahem...sucks. I agree on the alarm systems. The upgraded SystemCheck from OMC or SmartCraft from Mercury are huge advancements on this front. Overall, as they stood in the 1980's and 1990's, if I were to be evaluating an engine purpose soley on the basis of the automatic oiling system and had to keep the system as is, I'd rather own a Mercury since I truly believe that their system was superior. |
| fairdeal2u |
Used the VRO on the 70 hp omc for 15 years. Never had trouble with the oil mixing but had to replace the oil tank once due to a bad sensor for the alarm. As long as you checked the connections regularly it should be pretty bullet proof. There is a warning as insurance if the oil isn't flowing properly. Gives you a better mix of oil and gas at all rpms. |
Dave--Thanks for your input. Looking at the schematic diagram of the alarm system (see the new article in the Reference section where this diagram is available--hyperlink below) it appears that the sensor in the under-cowling reservoir tank is located near the top of the tank level. This means the alarm sounds, as you described, when the tank first begins to drop in level. That happens when the remote tank stops filling the reservoir. So, yes, you do get an alarm which is more or less a PRE-ALARM, that is, it warns you before you run out of oil in the reservoir. That is a nice feature. Advantage Mercury As for the suction versus pressure filling, the pressurized tank system requires that both the remote oil tank and the under-cowling oil reservoir tank maintain an air-tight system, along with all of the hoses and connections involved. That is a lot of equipment to keep air-tight. If there is a leak you will get oil spilling out, which can be messy. In contrast, the OMC system draws oil from the single tank using a single hose. As long as the pickup and the hose maintain their integrity, the system will work. Advantage OMC. If there is a leak, air is sucked in rather than oil spilling out. Not as messy. Advatage OMC The same type of device, a check valve, is used in either system to accumulate either pressure or vacuum. On that basis they are the same. No advantage.
Reference article on Mercury Oil System: |
| LHG |
[Edited this article to make clear what material is being quoted from an article published in the Reference section written by Bill Grannis--jimh.] I have to strongly diasagree with Jim on the oil tank and alarm situation. The Mercury system has clearly proven itself to be superior over the last 20 years. Take the remote oil tank, the only source for the engine to get oil. Mercury has the secondary tank in the engine, which gravity feeds the engine and is alarmed. As Dave says, this is easy to keep filled and supports the engine WOT for 1/2 hour. In the article on VRO written by [Bill Grannis] and published here, he says the VRO oil pump is much maligned, improperly. But he never says the OIL INJECTION SYSTEM is superior, because it's not. On tank design, he says:
Well, if you read this carefully, this is a nightmare. A turkey baster? Give me a break. The pressurized Mercury tanks are completely bulletproof, nothing can get in them like the OMC tanks he's describing here which have evidently caused numerous blown powerheads. The Mercury tank, with the large, gasketed filler just plain doesn't leak. I've had experience with this since 1989, no problems EVER, no cleaning necessary, no water, even though the tanks are located in the splashwell. Also there is no primer bulb in the rigging line, just a heavy duty double hose. On tanks, it's a HUGE ADVANTAGE MERCURY. Mercury's oil injection warning system has not had to be changed ever, since introduction, whereas the OMC alarms were a mess. Why, because the system works so well. And as the pump wears out, it lets more oil through, not less, a safety factor. Read what Seahorse says about the OMC alarms, and the need for expensive upgrading: "OMC introduced the VRO on the V-4 and V-6 engines in 1984. The pump consisted of a combination oil pump and fuel pump actuated by crankcase pulses through an air motor. Gasoline reformulation in those early years contained alcohols and solvents that softened the internal rubber components and caused pump failures and damaged engines. Back then, no company had alarm systems for a pump failure or loss of oil flow. OMC took care of the blown powerheads and improved the pumps considerably. (His statement is incorrect about NO company having alarms. Mercury did from day one.) [I think Mr. Grannis is correct. To this day Mercury lacks an oil flow sensor. Read more on this below.--jimh.] Note the times the faulty system has had to be improved. [Grannis] continuing:
(LHG note: ON Mercury all alarms sound automatically when ignition key is turned on - no checking necessary) [JIMH Note: The same alarm test occurs on the OMC/Bombardier system. What Grannis is suggesting here is a check of the sensors, not of the alarm buzzer.--jimh.] "The quickest and easiest test is the grounding of the tan overheat temp switch wire to the engine block. To do this, turn the key on, motor not running, and use a jumper wire to ground the tan wire from the motor harness and listen for the warning horn. It should be a loud steady tone. On 1996 and later engines with a SystemCheck® gauge, only the "hot" light will come on, but no horn unless the motor is running. With the SystemCheck® equipped motors you will have to disconnect the OMS (VRO) four wire connector and carefully ground the tan motor harness wire lead to illuminate the "no oil" light. Why is all this alarm activity needed? Got to wonder? So all of this means you need dash stickers so you know how to interpret a confusing alarm. Or better, spend about $500 for have the updated warning system installed. Why all the alarms? Why continuing pump design upgrades? Because the system appears prone to failure for any number of reasons. And this is supposed to better than the Mercury system, less hassle and worry and upgrading. No way. My contention, and which was expressed by an OMC engineer on the "Lighthouse" website after the bankruptcy, was that the VRO SYSTEM (not the just the original pump) was a defective design, and instead of being continuously upgraded and bandaged, should have been competely re-designed from the gound up. It appears the oil reserve tank was one of the problem ideas. Mercury and Yamaha got it right from day one, and as a matter of fact, I think the Yamaha system is the best of them all - less start-up smoke. |
| Tom W Clark |
I have owned multiple units of both the OMC VRO system and the Mercury oil Injection system. In 16 seasons using the OMC VRO system I had ZERO VRO system failures. In just one season with the Mercury oil Injection system, I have had ONE failure in the oil injection system. These facts may be just bad luck for me (and Mercury), but they do have some influence over my opinion. As they say, the proof of the pudding is in the tasting! Larry says several completely incorrect things above. The VRO system was not "... a defective design." The VRO system is probably the best of all the oiling system made. VRO is a simple and effective system which has the huge advantage of typically over-oiling the motor when the system fails instead of starving the motor when the system fails. Which would you prefer? A motor that smokes like hell? Or a motor that seizes? It is hardly a criticism of the VRO system that it has been improved upon over the years. The same is true of the Mercury Oil Injection system. The Mercury oil pump had been redesigned many times as have other components in the system. |
| LHG |
Tom - If you think the VRO is the best oil injection system of the big three, be my guest. The Yamaha folks may have an opinion on that also. I hope your failed Merc Oil injection system didn't cause a blown powerhead for you, like it often did with the OMC's. After reading [Bill Grannis's] recommendations on the VRO remote oil tank, I find it hard to believe any self respecting mechanical engineer would consider that a good design. It's one of the reasons I think the design of the system is inherently faulty. But if you think the turkey baster is a reasonable thing to expect "Joe Boatowner" to deal with, it's fine by me. As for me, I have never had to carry a turkey baster along with my Mercs. |
| LHG |
Which reminds me, how is the VRO system designed for the V-6 E-TEC? Has it been improved, or is the re-re-re-re-designed original VRO still in use? Does it also use the same vented, suction tank design, with primer bulb? Is this a weak link in the E-TEC engines? [The E-TEC uses a completely different oiling system because the motor is a direct injection motor. Oil is directly injected into the power head where needed. There is extensive documentation about the E-TEC available elsewhere. There is no relationship between the Bombardier OMS oiling system and the E-TEC oiling system.--jimh.] |
The article to which LHG refers was written by Bill Grannis. Speculation about the number of failures of an OMC engine power head which were caused by a failure of the VRO/OMS system is interesting speculation, but, frankly, the entire point of the article is to discount the many wild speculations made about the VRO/OMS system's role in engine failures. I think Bill's article does a good job of dismissing those speculations, even if they are raised again and again. If pressurization of a tank to force withdrawal of fluid in it is a superior method, why this is not done with the fuel tank? Almost universally in outboard applications the fuel is withdrawn from the fuel tank by suction. I am not ready to believe that this technique is inferior to the use of a pressuized tank system. If a pressurized tank is superior, why don't fuel systems use this method, too? |
| Buckda |
Jim - But the tank is vented. If memory serves, the oil tank for both Mercury and OMC isn't the same open flow system. In fact, the fuel tank has a much larger ID Vent hose than the ID Fuel supply hose that runs to the engines. Also - aren't fuel tanks on automobiles pressurized (if only slightly?) This is how your "check engine" light comes on if you leave the cap off, correct? (loss of pressure). Since tanks are standardized by boat builders, I think the engine makers left that question alone and designed the engines to meet the tank specs on the market. For the oiling systems, they could develop their own systems integrated with the motors, so they went in different directions. Another interesting speculation that your question raises is "will Brunswick eventually do just that (spec special fuel tanks) on their boats to further lock the motors used on each brand?" In that case, they could lock up the MerCruiser and Mercury markets! While I hate to feed LHG's anti-OMC onslaught (and he is getting snuggly close with the Yamaha crowd now, I'm sure I'm no longer imagining it!)...but I tend to agree with him on this front for the 1980-1990's systems. I think that by the late 1990's Evinrude had things figured out. And BRP really did come in and clean house from a quality control point of view. I am not at all concerned about their current systems. |
| Tom W Clark |
Larry, While I don't imagine I can straighten out all these threads you've so consistently sown with FUD, I can help the readers here by saying you've missed my point entirely. An oil pump failure with the VRO system typically does NOT result in a blown powerhead. That is one of the many beautiful things about it. Not so with the Mercury system. Let's look at some real life examples. I have a friend, Sam who owned a Sport 15 Center Console (now owned by a friend of Peter Glein, "pglein") powered by a 1986 Johnson 70. A few years ago the oil pump on this old motor wore out. How did Sam know? Because the engine would start but it REALLY smoked a lot. It was a too-much-oil condition, not a lack-of-oil condition. Let's contrast this with Andy Gere's Outrage 22 formerly powered by a 1989 Mercury 200. A 10 cent length of tubing that carried oil from the oil reservoir to the oil injection pump cracked and leaked. No alarm module sounded to alert Andy to the problem. As a result he fried his powerhead, effectively totaling the motor. I'd say that is a design defect of Mercury's to overlook that potential problem and have no alarm system in place to stop if before it becomes a catastrophe. Andy's recourse? Buy a new 200 HP E-Tec for $12,500. I actually do not think Andy is too upset by all this. In fact I know he's pretty excited to be repowering with a new E-Tec! The Mercury Oil Injection System: The best E-Tec promoter out there. |
| LHG |
I think the answer to Jim's question, although I am not a chemical engineer, is that gasoline is highly volatile, and vaporizes and explodes easily, and need vents to keep self generated vapor pressure under control. Closed vent Tempo tanks really bulge up like they're going to blow! Not the case with oil. The Mercury oil injection tank is totally air and water tight, as the lubricating supply should be, and doesn't blow up. Incidentally, it's Seahorse who said the OMC tank design caused engine failures, not me. I knew nothing of this until I read his article. There's where the turkey baster comes in, to deal with that turkey! Dave thanks for your support. You are correct. As for Andy's problem of a hose failure carry lubricating oil, I suppose any outboard with any type of fluid hose could have that problem. The oil has to get from the remote tank to the engine somehow, and a hose is usually how it's done. So how does oil get from the remote tank on an E-tec to the engine? Same VRO design? For Andy's sake, I hope there are no hoses that can split with age. Doesn't anybody know? Are they still using the old vented oil tank design, superior as OMC/BRP thinks it is? I hope not. Incidentally, where is Andy's 200 HP engine? It's almost April already. The thing was introduced 14 months ago, at least. Talk about a "lick and a promise" from Evinrude. Promises broken? Maybe August? Because of it's special exhaust valve, I hope it's not being postponed like it's cousin the 130 is, and nobody's telling him. If a dealership accepts an engine order under false pretenses of delivery, there should be some form of compensation for lost boating time, I would think. Maybe they should give Andy a 3.3 liter 200 for the same money and get him on the water again. All the publicity Andy's (lack of) engine situation is getting here is bad press if you ask me |
For some time now the fuel tanks on vehicles sold in the U.S. have been closed to the atmosphere. They are no longer vented, they're air-tight. In spite of this, I do not recall seeing a design where the tank was pressurized to pump gasoline from it. In any case, the reliability and longevity of a system where liquid is withdrawn from a tank by suction is fabulously well documented by the millions of motors 60 years of experience with outboard motor fuel tanks. They work just like the oil tank on a VRO/OMC. I cannot imagine that using this approach could be cited as a deficiency in the VRO/OMC system. Good heavens, it has worked for a million outboard for decades. The total part count, the total length of hose, the total number of tanks, and so on, is lower in the OMC system. Simpler implies fewer problems. Let's turn to Yamaha for a tie breaker: how do they get oil from their remote tanks? Do they use suction or pressure? |
| LHG |
I just re-read Jimh's post, and missed what he was talking about in his first line. Jim is correct in all my comments, somehow I confused the writer of that VRO article, one Bill Grannis who I do not know, with our own frequent contributor Seahorse. I think I did this because Seahorse is so often giving people valuable information on OMC/BRP products. Very sorry for the mistake, Seahorse. Jim, can you go back and substitute "Grannis" where I erroneously used "Seahorse"? Thanks.
| LHG |
Jim - Here it is again, from the GRANNIS VRO article in the reference section: "One of the most common causes of engine failure is water in the remote oil tank. Condensation and spray can build up over time and, like water in a fuel tank, it stays on the bottom to be sucked up at the worst possible moment. Water pumps through the system as easily as oil, so several time a year use a turkey baster to draw off some fluid from the base of the tank and squirt it into a clean jar. Based on what he says, am I wrong in saying this is a serious design deficiency in the VRO. He indicates failures as a result of the vented/suction oil tank design. Because no one from the Evinrude group has come forward and said anything about the E-tec oiling tank, I assume it is this same, vented/suction system. Seems to be asking for future E-TEC problems if Grannis is correct. I'm worn out on this one. |
| Tom W Clark |
"I'm worn out on this one." Larry, As well you should be. Like a dog with a bone... |
| seasled |
Hi guys, as I said before, If it works, Its good. I was just comparing the two systems. I like the VRP for its simple design. The Mercury system is a good system also. To each his own. seasled |
| seasled |
every one seems to have forgotten about Mercs crankshaft diven gear. The gear on the Crank is plastic. The gear on the pump plastic. I have heardstoies of these gears striping. I have been a transmission rebuilder for 31 years, and have seen many a plastic govenor,and speedometer gear strip. |
| LHG |
I should have known better than to interfere in this pipedream. VRO rules and Yamaha and Merc's 2 stroke oiling is second rate. All of Grannis' necessary VRO preventive maintenance techniques and turkey basters threw me off base. |
[I moved several comments over from another thread, there this same discussion had broken out anew.---jimh.] If you have a loose or defective cap on just about any tank on your boat--oil, gas, water--you risk contamination with sea water. Can you operate a Mercury oil system with a loose or defective cap that would allow water to contaminate the oil? Let's check with the instructions:
It sounds to me like Mercury is rather concerned about their caps being on tight and properly sealed. Larry--Are you saying that if a cap is loose on a Mercury tank and sea water enters there will be no problem? Why do they stress the importance of tightening the cap if it is not a problem? |
| LHG |
Jim - I think you have commented on what a large filler cap the 3 gallon standard Merc oil tank has. It's very well designed, with a large 3-1/2" diamer treaded ring and separate gasketed top that fits inside the ring. If you re-read the bold type instructions above, it appears that if someone forgets to put the tank cap assembly back on, and it's not air tight, hence allowing water and condensation to get in, the tank is not pressurized and will not pump oil into the secondary tank. So no water or otherwise contaminated oil could get to the cylinders or oil pump to begin with, and this would trigger the low oil alarm in the secondary tank. Just another reason why the Merc oil system has been so successful. I really do think it's a superior oil feed design. No one has yet answered either your question or mine: Is the Yamaha oil injection a pressurized or suction/primer bulb system? Is the new V-6 E-tec tank the same as the old VRO system one line suction/primer bulb tank, or have they upgraded to the fully sealed presurized tank delivery system? |
Larry--I don't think OMC has "upgraded" to the Mercury approach because they do not consider it to be better. As you point out, the Mercury system will soon fail to work at all if the cap is ajar. If the cap is ajar, the system will soon sound an alarm when the oil reservoir level drops due to failure of the pumping system. However, as far as I can tell, either tank can be contaminated by sea water if you leave the cap off. When properly operating the Mercury oil tank must be air tight, and this implies it is probably water-tight, too. When properly operating the OMC tank must be vented to the atmosphere. I suppose you can construe this to mean that if air can get into the tank, this implies that water can, too. This is true for any tank which is vented. Just about every tank on a boat is vented, including the fuel tank, the water tank, the waste water tank, the holding tank, etc. Having a vented tank is not particularly unusual. I don't think the OMC oil tank is especially prone to water intrusion. The vent is contained in the cap, and from my casual inspection of the cap it does not seem like it will admit a great deal of water to the tank, even if under a steady spray of water. |
I intend to beat this dead horse a bit more. Here is another flogging of horsehide. Regarding the remote oil tank and how the Mercury and Bombardier systems compare: What is the same? --a remote oil tank of 1.8 to 3 gallons capacity Both systems operate exactly the same. The inside of the tank is maintained at a greater pressure than the pressure at the end of the outlet hose. The differential in pressure causes oil to flow outward from the tank through the hose. What is different? In the Bombardier system the pressure in the tank is maintained at atmospheric pressure, and the pressure at the end of the hose is dropped below atmospheric pressure. This creates a differential which causes oil to flow. In the Mercury system the pressure in the tank is maintained above atmospheric pressure, and the pressure at the end of the hose is at some moderately lower pressure, either at atmospheric pressure or perhaps slightly above or below. This creates a differential which causes oil to flow. To induce atmospheric pressure to the Bombardier tank, a baffled vent is integrated into the removable cap of the filler opening. To induce above atmospheric pressure into the Mercury tank, a second hose and connector assembly is mounted to the tank and sealed with a gasket. I do not see anything so far which causes me to detect something inherently better about one system. At this point I note: --Bombardier tank has fewer openings. It has only two. One for the filler --Mercury tank has more openings. It has three. One for the filler, one for the outlet hose, and one for the pressurizing hose. Potential for contamination In either the Mercury or the Bombardier system, if the filler cap is loose or missing, there is potential for water to enter the oil tank. I do not see any difference in the system. Perhaps one has a cap which is better designed. But if you allow that both have plastic caps with rubber gaskets, they seem to be about equal in terms of being sealed to keep water out. The Bombardier cap has an integral vent with a baffle to allow the tank to be maintained at atmospheric pressure. It is possible, if there is extreme spray or immersion in water, for water to flow into the tank via the vented cap. I do not believe that this happens with regularity. The Mercury cap has no vent. If the cap is in good repair and properly installed, the filler opening will be sealed. No water or air can enter the tank. It is also possible that water could condense on the inside of the tank if the conditions were favorable for it to occur. Let us look at this as a source of potential contamination by water. In the Bombardier tank, the air inside the tank is open to the outside via the vent. Thus we assume the air inside the tank eventually reaches the same temperature and humidity as the outside air. On a warm day, the tank will fill with warm air; as the temperature cools, so will the air in the tank. It is possible dew could form inside the tank. In the Mercury tank, some of the air inside the tank comes from the engine, and presumably from the crankcase of the engine. When the engine is running, the air in the Mercury tank would tend to be warmer than the outside air. When the engine is not running, the air in the tank will cool. I cannot see any way where the air in the Mercury tank can be maintained at a lower temperature than atmospheric temperature, and, indeed, I see just the opposite. Because the air in the Mercury tank comes from the engine, it should be warmer than the outside air. If this is correct, then the air in the Mercury tank will change over a greater temperature, and this implies that it will be more likely to cause moisture to condense out inside the tank. Based on this analysis, it is probably the Mercury oil tank owners who need to check the bottom of their tanks with a turkey baster to see if there is water contamination! Really, I think the two systems are very similar in regard to the remote oil tank. I will look closely at the filler cap on my Bombardier tank to see if there is a gross defect in its design which would cause it to admit water via the vent. I do not believe I will find one. And absent this, I see the Mercury tank as more likely to be bothered with condensation. |
| Peter |
To answer Larry's question about the Yamaha system, the Yamaha oil tank is not pressurized. Oil from the tank is fed to the under-cowl oil reservoir via an electric pump located at the bottom of the tank. The failures in the Yamaha system that I have read about several times seem to be caused by the under-cowl oil reservoir. It seems that the usual problem is that the oil level sensor in the under-cowl oil reservoir has failed or the float has become stuck so that the motor doesn't know that its under-cowl oil reservoir is empty so as to ask for more oil from the remote tank and/or to warn the user about the low oil level. The user usually finds out about the situation when the motor seizes up due to a lack of oil . Water accumulation at the bottom of the remote tank is just as much of a problem (not much of one in reality) in the Yamaha system as it is in the Mercury and BRP oiling systems. I've had extensive time with both the OMC/BRP and Yamaha remote oil tanks and have never had a problem with water intrusion. There would have to be a failure of the seal on the cap or operator error (forget to tighten the cap) for water to get in. The Mercury system is not operator error proof and although it may not pump oil while the cap is loose, water will still be able to get into the system and as soon as the cap is tightened, it's pumping water at the bottom of the tank just like all the other systems. The advice to periodically check for water at the bottom of the remote oil tank is equally applicable to all systems with remote oil tanks, and even outboards with integral tanks. |
In the above discussion, an inference is made that the presence of a primer bulb in the OMC/BRP oil system represents a defect or hazard to proper operation. Let us examine the primer bulb in the oil system to see if this is true. Threat posed by primer bulb A primer bulb is usually made of rubber. It typically has plastic connectors and a check valve. All of these components are used in the oil system of other brands, but may be located in other places. The rubber material of the primer bulb is similar to the rubber in the hoses used throughout the oil system. If rubber is acceptable for use in the hoses, it would seem to also be acceptable for use in the primer bulb. There is some concern about rubber primer bulbs used in gasoline systems, as current formulations of gasoline may contain additives which tend to cause the rubber to harden. However, two-stroke lubricating oil is not thought to contain these harmful additives. I also note that one of the advantages claimed for four-stroke engines is that their components are bathed in lubricating oil. Thus the primer bulb is continuously bathed in lubricating oil. I also note that this lubricating oil is fresh oil, without any contaminants from the combustion process. Therefore I have to conclude, based on the notion that immersion in lubricating oil is a beneficial process, that there is no harm to the rubber from contact with the fresh two-stroke oil, and, in fact, this immersion in lubricating oil should serve to maintain and preserve the primer bulb in good condition. The connectors of the primer bulb are plastic, and in this way are exactly like most of the other connectors in the oiling system. Extensive use of plastic connectors is made in the oiling system, such as fittings on the engine or tank, so their use in the primer bulb does not seem unusual. Therefore I have to conclude that use of plastic connectors in the primer bulb does not represent a significant threat to its operation. The primer bulb contains a check valve. Throughout the oiling system one-way check valves are employed at various locations. I do not find locating a one-way check valve in the primer bulb to be significantly different than locating it at some other point in the system. If you examine the Mercury oil system, you will observe it employs check valves. If there is a threat posed by use of a check valve, this must also apply to those check valves. My conclusion is that the primer bulb does not pose a threat to the operation of an oil system to any greater degree than that posed by the same materials and components used in other locations which are similar in construction and function. Does the primer bulb have any advantage? In the same manner as described in my article, "A Primer on Primers," the primer bulb can be a diagnostic tool which can be used in troubleshooting problems with the oil system. For example: A firm primer bulb will confirm that there is oil in the supply line to the motor and the system is drawing oil from the remote tank. A collapsed primer bulb will indicate a blockage in the system upstream of the primer. A soft primer bulb will indicate a leak in the downstream system. In addition, the primer bulb can be used to prime the system after it has been opened for service. A few squeezes of the primer will expel air in the lines and prime the oil lift pump. Based on its usefulness as a diagnostic indicator and as means of easily priming or pumping oil through the system, I conclude that the primer bulb does have advantages in an oil system. Based on this analysis, I have to reject the inference that inclusion of a primer bulb in an oil system represents a threat to its successful operation or in some way represents an inferior approach to implementing an oil system. |
There is still life in this horse. The beating will continue! So far we have looked closely at several parts of the oil system, including the remote tank, its cap, the hose system, the pumping method for delivering oil. Let us turn to a new area for comparision, the actual mixing pump that combines oil and gasoline to be delivered to the engine fuel induction system. Here we will find some actual differences.
The mixing pump requires input of mechanical energy to operate. Difference sources are used in the Mercury and Bombardier oiling systems. We compare. Mercury The Mercury mixing pump is driven by mechanical gearing which operates directly from the crankshaft of the engine. A plastic drive gear is slipped over a crankshaft journal and clamped into position with a single clamp screw. The drive gear rotates at crankcase speed (i.e, up to 6,000-RPM) in the engine crankcase environment. (Recall that on a two-stroke motor the crankcase is also the intake manifold and thus contains an explosive mixture of fuel and air.) The drive gear engages a long spline driven gear from the mixing pump which extends into the engine block to reach the plastic drive gear. Should replacement of the plastic drive gear be necessary, the following procedure is performed: Installing Drive Gear for Oil Injection Pump onto Crankshaft --Remove centermain bearing (located next to gear) from crankshaft following instructions in appropriate service manual. This instruction is a bit terse. It means you have to expose the engine crankshaft. This means you have to perform a substantial tear down of the engine. Typically this requires removing the entire fuel induction system of carburetors or injectors, removing the reed block, and removing other components as needed to expose the crankshaft for this installation. I am not sure that this procedure can be performed without removing the power head from the engine. Perhaps an experienced Mercury mechanic can follow up with a comment on this. --Remove and discard old gear retaining screw using an allen wrench. --Taking care not to damage crankshaft, spread old gear at split and remove from crankshaft. [The plastic gear is made in a ring with a single split. You spread it open to pull it off the crankshaft.] --Heat new gear in hot tap water for approximately four minutes until pliable. [The new gear has to be stretched to fit over the crankcase, just as the old one was to remove it.] --Dry gear. CAUTION: DO NOT spread gear split any further than is necessary to slip gear over crankshaft journal or damage to gear may occur. --Spread gear at split with lip toward top of crankshaft. Place gear lip in groove in crankshaft, and gear locating pin in locating slot in crankshaft. The rest of the procedure instructs how to tighten the gear with its single clamp screw, and to check for proper alignment and tolerances. The engine is then put back together, i.e., the crankcase cover is reinstalled, the reed block is re-installed, the fuel system is re-installed, etc.] Bombardier The Bombardier system is described in detail in the REFERENCE article. An air motor is connected to the crankcase via a hose and pressure regulator. Pulses of pressure from the crankcase provide the source of energy to be converted by the air motor into mechanical movement of the pump. If the system needs service or replacement: --detach hose from pressure regulator Comparison Service of the Bombardier system sounds much easier. I do not think the typical owner of an outboard motor routinely undertakes replacement procedures which require him to expose the crankshaft journal of his engine. I was surprised to learn that the Mercury system uses a pliable plastic gear. If four minutes in hot tap water makes the gear pliable enough to flex and stretch to fit over the crankcase journal, how pliable is the gear when the engine reaches its 180-degrees-F operating temperature? |
Now we turn to the actual mixing pump itself. Unfortunately the details of the Mercury pump are not as well-known as those of the Bombardier pump, which, again, is described in detail in the article in the Reference Section. Oil Injection Pump The purpose of the oil injection pump is to receive oil from the oiling system, and dispense it in a proportionate volume to mix with the fuel in a volumetric ratio of 50:1 to 100:1 depending on the engine speed. The mixed fuel is then delivered to the fuel induction system. Mercury The Mercury oil injection pump receives oil by gravity flow from the under-cowling reservoir tank. The rate of pumping is a function of crankcase speed and the position of a control lever which is mechanically linked to the throttle position. As the throttle position is advanced toward full throttle, the output of the pump is proportionally increased so as to reduce the mixing ratio to 50:1 from 100:1. A mechanical adjustment permits varying the linkage to achieve proper ratio. No details are known about the arrangement of components in the pump. The output of the pump is a flow of oil which is connected by hose to a one-way-way check-valve which connects via a T-fitting with the gasoline fuel line. Thus oil can flow into the fuel system, but fuel cannot flow back into the oil system. The oil joins the fuel system on the suction side of the fuel pump. This further helps to direct the flow of oil and fuel to the proper destinations at the mixing point. The fuel pump delivers the mixture of fuel and oil to the fuel induction system. The mixing pump contains a sensor which is connected to an external alarm module. The sensor is operated by movement of the mechanical input shaft which drives the pump. The external alarm module compares the signal from the pump sensor with pulses from the engine ignition system. By this comparison it deduces if the rate of movement of the input shaft is proportional to the rate of ignition pulses. If the output of the sensor is not in proportion, an alarm is sounded. Note that this does not confirm oil flow from the pump; it only confirms mechanical input to the pump. If a leak developed in the feed to the pump, this sensor would not detect the loss of oil flow to the pump. Bombardier An air motor in the OMS draws oil from the remote tank and pumps it into the mixing chamber of the pump. Note that the air motor drives both the fuel lift pump and the oil lift pump. If the air motor fails, both the fuel and oil pumps will stop. Thus you cannot get delivery of fuel without oil as a result of an air motor failure. The variable ratio mixing action is accomplished by the action of the crankcase pulses. As the engine crankcase speed increases, the frequency of the pulses increases as well. However, as crankcase speed increases, the pressure of the pulses increases, too, resulting in greater mechanical movement. This is translated into great volume output from the oil pump, and, as a result, the mixture ratio decreases to 50:1 from 100:1 as the engine speed increases. A warning alarm is incorporated into the pump itself. Tachometer pulses (which are indicative of engine speed) are supplied to the pump. The flow of oil from the pump is detected and monitored. The rate of flow of oil is compared to the tachometer pulses, and if these do not occur in the proper ratio an alarm signal is generated. The only external element is the alarm sounder itself, which is common with several other alarm sensors. Comparison The divergence of the Mercury and Bombardier oil mixing systems is most pronounced at this point. The cause of this may be related to patents held by OMC/Bombardier which prevented Mercury from adopting a similar system. The Bombardier mixing pump is a compact combination of three pumps in one: --fuel lift pump All three are driven by a common air motor which is actuated by pressure pulses from the crankcase. The Mercury system is a distributed system of three separate pumps --fuel lift pump operated by engine crankcase pressure pulses The actual mixing occurs external to all of the pumps in a T-fitting. The Mercury system contains twice as many hose and connections than the Bombardier system. The Bombardier system has only four hoses involved at the OMS pump: --1. crankcase pressure In comparison, we note the following hoses involved in the Mercury system: --1. oil inlet to oil mixing pump The internal components of the Bombardier OMS pump and the Mercury fuel pump include some rubber diaphragms. Some of these are in contact with the gasoline. Prolonged exposure to gasoline has been known to degrade rubber diaphragm components, and both these pumps are at risk for damage after long term use. The mixing ratio of the two pumps both varying according to engine RPM, although they use different techniques to accomplish this. The Mercury system has an external adjustment by which the ratio can be changed. The Bombardier OMS pump cannot be adjusted, and the mixing ratios are locked into the design of the internal components of the pump. Which pump is better? Without knowledge of the construction and design of the Mercury oil mixing pump it is difficult to make any assessment of it. It is clear that the Mercury system is more complicated and requires more separate components, hoses, connector, and clamps than required by the Bombardier system by a factor of two, i.e., twice as many things to go bad. If more were known about the Mercury pump's construction, perhaps an argument could be made that it was superior and justified the additional complexity of their system. But in the absence of any details about the pump, I cannot conclude it has any inherent superiority. The Bombardier system uses air motors which operate from crankcase pulses. This is a proven technology and is in universal use in outboard motors. Indeed, the Mercury system contains two such pressure operated pumps itself. It is difficult to make an argument that a diaphragm pump operated from crankcase pressure pulses is adequate to deliver gasoline (as it does in virtually all Mercury engines) and then make an argument that such a pump is inherently inferior if it delivers oil, as it does in the Bombardier system. As a fluid to be pumped, oil seems to be much more gentle on its pump and its rubber components than gasoline. Alarm system The Bombardier alarm system is superior because it monitors actual flow of oil output from the mixing and is self contained. The Mercury alarm only monitors the input of mechanical motion to the pump and cannot detect actual loss of oil flow. It also needs an external electronics module to function. Summary A careful investigation has shown that the greatest difference between the Bombardier and Mercury oil systems is the source of the mechanical energy which drives the oil mixing pump. The drive system used by Mercury involves a pliable plastic gear fitted to the crankcase, while the drive system of Bombardier uses a conventional air motor driven from crankcase pulses. In most other respects the systems are very similar. Both make use of diaphragm pumps driven by crankcase pressure pulses. The Bombardier system is more compact, more easily serviced, has fewer hoses and connection (by a factor of 1:2), and has demonstrated performance. The Mercury system has more components, has an extremely difficult to service plastic gear system, and provides similar performance. As an example, I could replace almost the entire Bombardier oiling system by installing a new OMS pump kit (which costs about $275). Only four hoses have to be disconnected, and a single electrical connector is involved. This single unit replaces all three pumps (fuel, oil, mixing), as well as providing the electronics for the alarm system. |
Re the oiling system on the E-TEC. On the smaller motors like the 90-HP and lower there is only a single oil reservoir under the cowling. An electric pump in the reservoir pumps oil to a manifold that distributes the oil to injection points in the power head. A very small amount of oil is mixed with the fuel prior to being injected. The majority is injected and sprayed into the power head in locations where it is needed. A sophisticated system of sensors and a supervisory computer algorithm monitors the oil system. The system is very different from the VRO/OMS system. On larger motors I do not know if a remote oil tank is used. It should be noted that much of the Grannis article covers elements of the VRO system which were first introduced in 1984, some 22 years ago. The article carefully documents the changes and improvements made to the system. I do not believe there has been a significant change since c.1996, about ten years ago. |
| Peter |
The 115 and up E-TECs use a remote oil tank. With the previously announced end of the line for the Johnson 90, 115, 150 and 175 2-strokes, the VRO system will be retired. |
| pglein |
Tom, I sure wish your friend would have told us about that bad oil pump. We reconnected it and the problem was definitely a "no oil" condition. We rebuilt it, but it didn't do any good. The powerhead was still destroyed and he has since replaced the engine. VRO is a good system, in theory, but anything that relies on a daiphram pump for proper oiling is subject to catastrophic failure. Also, with VRO, there is no guarantee that the fluid being pumped, is in fact oil. I lost a 40 hp Evinrude because, unbeknownst to me, water had gotten into the oil tank. I'm not saying any of these things are any better on any other outboard, but they are certainly areas with room for improvement. |
| BillS |
The problem with the primer bulb is that it is only to be used for initial setup to purge air from the oil line with the line disconnected from the engine. If you pump it when it is connected to the engine it fills the carbs with oil resulting in a no start condition. Since most people don't read the owner's manual, the primer bulbs get pumped, carbs get full of oil, motor gets taken to the the dealer, dealer say you need a new VRO pump, dealer makes money, VRO get a bad reputation. All because of operator error. |
| jeffs22outrage |
The problem is not which one works better because they are both great systems that will work flawlessly for many years. The problem comes in when you have to replace the pump as you should always replace rather than trying to fix these pumps. Like Tom, I have used both of these systems and found them both to be great. The only failure has come on one of my Father's 1998 Mercury's. The gear drive on his Starboard motor failed when the plastic (not metal) internal gear drive for the pump broke. He had two choices to fix this #1 pull the powerhead off and crack the block open to get to the crankcase drive gear and replace it. Option #1 the cheapest quote was $1400 Or #2 purchase an externally mounted electrically driven pump from http://www.marinesolutionswi.com/ and get rid of the gear driven one. The gentleman who create the pump and owns Marine Solutions is a retired Mercury engineer. He is very good at explaining the operation of Mercury System along with how to repair them. He stated Marine Solutions because he knew the PLASTIC gear drives mercury insisted on having for cost would fail. When that happened he wanted to have a product on the market that not only would be less invasive of a repair for the powerhead, cheaper, and "more reliable" (his words not mine) in the long run. Option #2 cost about $500
Any how with proper care my VRO system was worked flawlessly for many years. The one currently on the boat is the second one as the original owner replaced the first one in the mid - late nineties for piece of mind. Which is why I am going to replace mine this spring. I did not replace it last year with the other work because the new VRO heavy ethanol use pumps had not hit the market yet. Cost for a new VRO pump $275.00 and there is no need to pull the powerhead or crack the block open to replace this pump because it is all externally mounted. In the end both operate very effectively however, when that systems fails one will cost more to fix. |
Jeff--Thanks for your first-hand experience and observations with both systems. I think the point you make is very cogent: the cost to replace the OEM system on a Mercury motor is many times greater than on the OMC/BRP system. There is not a reliable source of data on the relative rate of failure of the plastic gear of the Mercury system compared to the OMC/BRP system, but due to the excessive cost of repair of the Mercury system I would speculate that few are ever repaired. In other words, when the plastic gear fails, there is no reasonable repair possible and the OEM oil mixing system has to be abandoned. I asked this same question to my local Mercury dealer, who has been servicing Mercury motors for 40-years. He told me he could not recall ever replacing a plastic gear failure. He also said that such failures were not uncommon and he universally recommended the owners of Mercury motors that had failed should change to pre-mixing the fuel and oil rather than undergo the expensive repair of the plastic gear. If one reads internet discussions which focus on repair of Mercury motors, one finds that failure of the plastic drive gear is a common topic. The plastic gear appears to be the weak link in the Mercury system. ASIDE: Since this discussion began, I have written an article which makes a very long and detailed comparison of the automatic oil mixing systems from Mercury and OMC/BRP. For those interested in more information about how the two systems compare, I recommend that article: |
