| Author | Topic: Temperature Alarm on 2000 DT115S |
| RLSmith |
2000 Suzuki DT115S (2-stroke, less than 200 hours) Today I took my kids and their friends tubing for an hour. After we were finished, one of them wanted to go fast. So I took it up to 5K rpm and zipped along for a minute or so. I then slowed to a "normal" cruise (<4K rpm)and headed in. Within a minute I felt and heard a power reduction and immediately throttled back, primarily due to my panic. I heard the alarm tone but only for a few seconds. I have a Suzuki engine monitor gauge but no temperature or water pressure gauge. The monitor gauge has an oil level indicator, a TEMP light for overheat, and a REV light to show when the rev limiter is active. Everything looked fine but I wasn't looking at the monitor gauge right when the power loss occurred. The tell tale was streaming along. I idled along for a while trying to decide whether my engine is toast, and what to do with four kids. After contemplating an hour of idling back home I gave up and throttled back up to a plane. Everything worked fine for a few minutes, then the same loss of power. This time I was looking at the monitor gauge and the TEMP light lit, but not the REV light. The TEMP light went out immediately when I throttled back. By then I was close enough to idle back to the dock. I did not see anything obstructing the water intakes. Half an hour later, now without the kids, I took the boat back to the boatel. Only a few minutes of this trip was on plane - no problem. Just for fun I hooked a hose up to the flushing port and ran it for a few minutes. Two questions: (1) Why the loss of power? Did the engine control unit detect the overheat and lower the engine speed? I am hoping that is the answer otherwise something very bad has happened. (2) What should I do now? I am thinking that next Saturday I see if the problem recurs by doing a bunch of big circles close by my house. If the problem recurs then troubleshoot water flow (replace impeller, look for blockage, etc.) Thanks for your assistance. |
| Whaler_bob |
Your engine has a rev limiter for overheat conditions. If the overtemp happens at or over 3000 rpm the over rev system takes over and limits the engine to 3000 rpm's. I have a 1999 Suzuki DT225TC, that info is on page 14-15 of the owners manual. Sounds like your water pump impeller is due for a change. Suzuki uses a solid stainless steel impeller housing, so it's probably still good with only 200 hrs on your engine. I replaced my impeller last year (100 hrs on my 1999 225HP) and the housing was still perfect. You can order via the internet if you don't have a local Suzuki dealer. The kit comes with an impeller, wear plate, gasket and key. |
| RLSmith |
Looks like I will be purchasing a water pump repair kit. The kit includes instructions. Are those instructions sufficient or is a shop manual mandatory? For example, do the instructions show how to remove the lower unit, including disconnecting the shift linkage, etc.? If I add the cost of a manual I might as well head to the shop. I need every penny now. Thanks. |
| Sal DiMercurio |
I would change the thermostats before anything. Generally when your "T" stats are bad, your going to heat up around 3 - 4000 rpms. If the Suzuki is like other outboards, after 3000 rpms [ on plane ] the water is forced in by the movement of the boat. The water pump usually only cools at slow speeds like not on plane. This is just my thoughts. Sal |
| RLSmith |
Thanks for the response. What is the failure mode of the thermostat? I am trying to figure out why that would stop working after an hour of tubing. Do I have more than one thermostat on my I-4? I would still like an answer to my prior question about the adequacy of instructions with a water pump repair kit. Surely someone here has purchased one before. Seems like I should replace the impeller regardless of what else I do. Thanks. |
| sonofasailor |
The DT115 also has a water pressure valve located in the cylinder block. The valve opens at higher engine speed to allow extra cooling water flow. After the impeller and thermostats, this may be the next place to check. A Suzuki manual is available at brownspoint.com for about $50. |
| RLSmith |
Replacing the impeller fixed everything. The condition of the old impeller made this quite obvious. Other than breaking a water pump housing bolt when reassmbling, everything went OK. Pics on this post: http://continuouswave.com/ubb/Forum3/HTML/011608.html |
| RLSmith |
Arghh. Forgot the UBB code. |
