| Author | Topic: Spun the hub on my impeller - war story replacing impeller |
| RLSmith |
I described my overheat problem in a prior post. http://continuouswave.com/ubb/Forum3/HTML/011429.html This post describes my impeller replacement. Everything went pretty smooth until a water pump housing bolt broked when putting everything back together. I purchased the water pump repair kit from the local Suzuki dealer, a SELOC manual from West Marine, and dove in. I got some help interpreting the instructions from the repairs/mods forum (thanks). Here is the most interesting pic. The plastic hub on the old impeller separated from the rubber. The rubber then broke. I have two theories as to why: (1) ate something that chewed up the impeller - sand? (2) trimmed too high at high speed and melted the impeller. This is my first time using photobucket so hopefully these links will work. http://i112.photobucket.com/albums/n168/rlsmith999/Impeller/ BrokenImpeller1.jpg Back to the story... After hearing about problems disconnecting the clutch rod on various brands of outboards I was very concerned about this step. The SELOC manual and the repair kit instructions were not sufficient for a first timer like me. I popped the powerhead cover and immediately found the top of the clutch rod. This looked like the right place to disconnect it but it did not appear that the flange at the end of the rod would fit down the hole in the driveshaft housing. http://i112.photobucket.com/albums/n168/rlsmith999/Impeller/ ClutchRodTopMarked.jpg I was seconds away from disconnecting this, when I backed up and examined the outboard from top to bottom. I found gold - good maintainability engineering. There is a cover at the front-bottom of the drive shaft housing. Removing it gives easy access to the clutch rod connection and what I think is the speedo pickup tub. In retrospect this seems obvious but hindsight is 20/20. http://i112.photobucket.com/albums/n168/rlsmith999/Impeller/ ClutchRodCoverMarked.jpg I removed all the lower unit mounting bolts and expected the lower unit to drop off in my arms and crush my foot. Didn't happen. Started with a rubber mallet, advanced to a wooden mallet, then graduated to a metal hammer and block of wood. Bang bang bang. I was about to give up when I noticed a gap. Hope that banging didn't hurt anything. http://i112.photobucket.com/albums/n168/rlsmith999/Impeller/ LowerUnitStuckMarked.jpg I used a recycle bin as my lower unit stand. The second pic shows a good view looking up the driveshaft housing with the important things marked. http://i112.photobucket.com/albums/n168/rlsmith999/Impeller/LowerUnit1. jpg I unbolted the pump housing and removed the housing, the shredded impeller, the key, and the plate with the gasket stuck to it. I cleaned the surface and installed the new gasket, plate, key, and impeller. Many on the forums have reported problems reinstalling the housing over the new impeller. I had no problems at all - just slowly twisted the drive shaft clockwise and the housing slid right down. http://i112.photobucket.com/albums/n168/rlsmith999/Impeller/ PumpHousingMarked.jpg I bolted down the housing and then OOPS a bolt broke!. Disaster - it broke down inside the blind hole. OK so now on a Saturday morning I need to find a replacement metric stainless steel bolt and figure out how to extract the broken bolt. Went to West Marine. They were very helpful but there was nothing metric in the wall full of stainless hardware (how can this be?). Called the local Suzuki dealer Deep Blue Marine. They were also very helpful but did not have the bolt in stock. But they did find the bolt size (8 x 50). Armed with the size, I hopped on the phone. No luck at auto supply store. Finally found a fully-threaded 8 x 50 bolt at an industrial fasteners distributor, a long way away and short Saturday hours. Then on a lark called Cape Henry Hardware, a mom-and-pop hardware store one mile from my house. Surprise - they have the exact replacement. They were incredibly helpful, also selling me a screw extractor and a cobalt drill bit to drill the starting hole in the broken stainless bolt. Good prices too. I expected an arduous process extracting the bolt. Fortunately my brother knew what he was doing and helped so it went smoothly. Of course I had the occasional annoyance. For example, the torque wrench would only fit clear on four of the eight lower unit mounting bolts. I put everything back together, tested on the muffs, then went for a half-hour test run. Everything worked great. I am back on the water. |
| deepwater |
You are right on the money ,,That's the way it always goes,,Glad you wet again |
