| Author | Topic: 170 Montauk 10 years later |
| Barney |
After having owned my 2003 170 Montauk for ten years, I thought I would summarize the repairs, maintenance and odd things that have occurred. Here was my original post a long time ago http://continuouswave.com/ubb/Forum8/HTML/001778.html Starting at the bow: 1. Bow light: Installed tinned bare copper wire in the light to make connections. The pressed fittings would not carry current. I wrapped the tinned wire around the fittings, as the fitting would not take solder. |
Thanks for the ten-year follow-up on the 170 MONTAUK. When the 170 MONTAUK was introduced in 2002 it really created excitement and interest. I don't think any other new model Boston Whaler boat since has been able to generate so much interest. Boston Whaler did a great job with their new MONTAUK. See http://continuouswave.com/whaler/cetacea/cetaceaPage58.html |
[Moved to REPAIRS/MODS.] |
| picflight |
Barney: Very good to hear feedback after years of care. What was the reason for the motor replacement and what did you do with the old motor? |
| fishinchips |
I had a 170 montauk for 10 years and recently just sold.
Starting at the bow: 1. Bow light: Reconnect with waterproof butt connector and heat sealed during first year. 7 years into it, replace the red/green lens, original had cracked and sea water got in and premature burning out light bulb. 2. Hull: No problems. 3. Outboard: (90 4 stroke Merc) original. One time carbuarator clean out. Would not start. Since then use quickleen and no more problems. Recommended to new owner and gave free bottle of quickleen. 4. Trailer (EZ Loader): Year 10, replaced springs, hubs, tires. The replacement of the springs and hubs was just maintenance since I tow alot. Nothing was broken. |
| Barney |
As far as replacement of the outboard, the carburetors needed a lot of care to keep them operating correctly. I had installed a large external filter but that didn't help completely and green deposits were found in the carburetors. Starting the outboard could be frustrating but it never let me down. We go into the marsh sometimes where no VHF radio or cell phone would help if broken down. Jim |
| fishinchips |
The quickleen really does work for that 90hp Merc CARBURATED four stroke. Every since I put it in with gas I never had a lick of problems starting. I now have a 190 montauk. Fuel injection motor. So debating about using quickleen or ringfree plus. |
| Barney |
I started using Quickleen and things did improve. But I just wanted to move on. If I had started using Ethanol free gas sooner that would have helped the most. I have a boat partner that made the payment a lot easier. There were some other personal preferences between Mercury and Yamaha but carburation versus fuel injection was the biggest. Of course you know from your experience that the instant start is very nice too. One item we learned after the purchase was the new outboards greatly reduced time to plane with a big load which makes it much more enjoyable to operate. The prop setup is much better. |
