| Author | Topic: Scratch Removal |
| masbama |
What is the best wax and compound to get out gelcoat scratches? I over-used my pumice bar on the hull in one spot. |
Waxes generally do not contain abrasives. They probably will not smooth out scratches. Depending on the depth of the scratch in the gelcoat, you can smooth the gelcoat layer with a fine abrasive. Wet sanding with 600-grit or finer may be a good start. |
| frontier |
Try #7 white polishing compound (Ace Hardware and most auto parts places). Works great on light scratches. |
| K Albus |
I've made the same mistake in the past. See this thread: http://continuouswave.com/ubb/Forum3/HTML/011449.html |
| masbama |
Thanks to all! What great information. I'll get my 18 Dauntless looking good once again. |
