| Author | Topic: 170 Montauk with 90-HP Two-cycle |
| BYABOATBJAHNS |
What stainless propeller (4-blade) can I put on a 170 Montauk with 90-HP 2-stroke for higher speed? |
Test data from Boston Whaler factory testing is available in the Reference Section. See: http://continuouswave.com/whaler/reference/170Montauk/ At these boat speeds and horsepower an aluminum propeller often shows good performance. |
| LHG |
This rig appears to be right on a dividing line between possible Mercury props. That is probaly why so many indicate a 19" aluminum came with the engine. An aluminum will, however, give the lowest level of performance. I wouldn't use one any boat that will do over 30. Looking at Mercury's prop charts, and 18" SS Vengeance is a bit low on pitch, and a 20" Laser II a touch high. If you lift the engine up to the 3rd set of mounting holes (mandatory to run one of these), a 20" Laser should give the absolute best performance, bow lift, best ride, and top speed. With a light load, you should get near max RPM, maybe to 5300 or so. These are great props, and I run them on both of my Whalers. On a 90, the 20" model has a top speed potential of 45 mph. Another alternative would be to try an aftermarket performance prop like the Mich Wheel Rapture, or Stilleto. in 19" pitch. These are your best brands, I believe. Cabela's also sells the Rapture under their "house" brand. Forget a 4-bladed Mercury Trophy for this rig. See comments in Marketplace re: one that is for sale. |
| BYABOATBJAHNS |
Thanks for the information. I think the 20-inch is the way I'll go. The boat comes from the factory with a 21-inch Black Max aluminum propeller. I would like this boat to go 45-MPH with a light load. Thanks for the advice! |
| LHG |
Good luck and keep us posted. You should be able to find a new Laser II for $360-$400. No need to pay more than that. There are several places in FL that will ship to you in this range, and without sales tax. |
It would be a good idea to take some careful observations of boat speed versus engine speed (using a GPS with high accuracy) before and after the propeller change. Often people are happy with the results with a new propeller (especially a $350 propeller) even if the data is not exactly overwhelmingly convincing. [Nota Bene: I edited all your articles to lower case. All upper case text is very strongly discouraged.] |
| John O |
How much more performance and or speed will result from switching from the factory installed Aluminum to a stainless steel? Is it worth the risk of destroying the the lower unit if the SS hits a soilid object vs the give on the alum.? |
| fitn217 |
LHG a few quetions for you. I own a 2 stroke 90 salt water series motor on a 2003 170 Montauk. I just bought the laser II 20" pitch for my 170 Montauk. But have yet to install it. 1- Do I HAVE to raise the engine up to the third set of mounting holes?
| AQUANUT |
heres my two cents and where i got it from... after sitting thru a three hour "mercury e-skill VHS tape on the proper propping of mercury engines..."......and also viewing a similar "vhs" from yamaha...{I rig at a boston whaler dealership that is mercury/yamaha/honda all under the same roof.....} these are the basics...
I personally set my 2004 montauk 170 up 1 hole when i repowered it the day I got it in my bay...canned the 2 stroke 90....replaced it with a 115hp EFI 4 stroker... good luck on your decissions...fyi the guys I work with are great about handing out loaner props to our valued customers to try out...the elevations here range from sea level to 5500 feet...so proping varies to where you intend to operate the vessel...more so on two strokes and non-EFI fourstroke engines....if the customer doesn't trash the prop we trade...its a fair deal when offered to all. |
| BYABOATBJAHNS |
GOOD INSIGHT! HOWEVER, IS THERE ANYONE OUT THERE WHO HAS A 2003 OR 2004 170MTK WITH A 2-STROKE 90HP MERC THAT HAS PUT AN AFTER MARKET STAINLESS PROP ON? WOULD BE INTERESTED IN THE ACTUAL PERFORMANCE DIFFERENCE. THANKS.... |
| LHG |
Fitn217 - From what I understand, Merc Laser II props should be run surface piercing, about 1 1/2" high, which generally means the 3rd (center) set of mounting holes. Obviously, boat transom design can affect this. Mercury states that running a Laser II fully submerged can increase effective pitch by 2", which will reduce max PRM. Some of it's performance enhancing properties may also be lost. |
| fitn217 |
Thanks for the reply LHG. I guess I'm going to leave the motor as is, with the motor in the same mounted position that it came in. If however I see that I'm not reaching max RPM or getting the performance I should be getting than I may experiment with the mounting position. |
| trueblue |
Not sure if a thread this old can be resurrected, but here goes: I bought a 170 2 years ago that came with a 90 HP 2-stroke and an aluminum prop. I'm planning to upgrade to a Laser II (SS, 3-blade, 13.25" 20 pitch). This is my first power boat and I'm trying to feel my way along. Can anyone share some experience? Opinions are great, but I'd really love to hear from someone who has tried this prop on this boat. Are you happy with yours? Did it have a noticable effect on performance (hole shot, top end)? One last question, did you end up changing the transom mounting hole? Thanks, Chuck |
| tedious |
Chuck, can you share more information on your current prop - make, model, diameter and pitch, and what RPM and speed you now achieve? Being somewhat familiar with the 170, and just going on previous posts in this thread, it sounds like the Laser II is a full-on speed prop, designed for maximum speed. Is that your goal? Or if not, what aspect(s) of performance are you looking to improve? Tim |
| trueblue |
Tim, The current prop came with the boat and is a 12.5" x 21 pitch 3-blade Quicksilver prop. With the current prop, WOT is about 5400, but I don't often run her that hard because I don't want to stress the engine too much and ride is more important to my wife. I my Whaler mostly to motor around the river and bay here and occasionally to take the kids tubing. I'd say my most common speed is 25 - 30 kts. I've read what I can find in the forum and there's a fair amount of conflicting info, but a lot of folks seem to have liked the Laser II. I picked one up on eBay that's 13.25" x 20 pitch. My goal is to get on plane faster, fuel economy, and good top end (although that's not as important). I'm finding it difficult to gage what will give me the best mix Thank, Chuck |
| tedious |
Chuck, I have no familiarity with the Laser II - my concern was simply that the previous posters described it as a flat out speed prop which needed to be run with the motor very high, in surface-piercing mode. From that, I inferred that the Laser II might be a high-strung thoroughbred, great for top speed runs, but not so good for general use. But since you already have it, give it a try. Or maybe someone else will chime in and discuss the Laser II in more detail, relative to your usage model. I have had very good luck with the Stiletto Advantage series of props, so I would recommend them. Since you're new to this game, I'll pass on some general thoughts and opinions, stuff I've gleaned from reading this and other forums and experimenting on my 15: - almost any newer stainless prop will be better than an older aluminum model, in terms of durability, economy, and performance. Hope some of that helps... Tim |
| 64nauset |
More to think about: a few years back I posed the same question about my particular boat, a 1963 Nauset with a 1996 Evinrude 88-HP two-cycle engine. This rig would not be too different from yours when considering a propeller. I got replies back from a fellow who had my exact setup and here's what I bought: a Stiletto Advantage 13.25 x 15, purchased from Tom Clark for $250 delivered. This is a three-blade stainless steel propeleller. I had to press in the rubber adapter and clutch. No problem. The new propeller ran off and left the factory aluminum prop in the dust. Performance improved greatly. Top speed 42-MPH, no cavitation in tight turns, [engine speed] maxed out at 5200-RPM, and a hole shot to write Mom about. Better fuel economy too. The [outboard engine] was already mounted one-hole-up so I didn't have to fiddle with that. The company that makes the propeller said that speed would increase slightly if the motor was mounted two-holes-up, but cavitation would start sneaking in. Fine, the boat runs better than it ever has and 42-MPH is fast enough for that hull. I don't feel the need for two-holes-up. http://www.pbase.com/bmcelya/image/126444005 Will this propeller work as well for you? It might. Note: I allow no one near the back of the boat. That Stiletto is razor sharp, and I haven't the heart to sand it dull. |
I don't believe there is any sort of a clutch in the propeller hub insert. The insert is a typically a plastic coupling that always transmits the propeller shaft rotation to the propeller, until the coupling fails due to too much force. If it is to be called a clutch, it must be clear that it only works once. I don't think clutch is a good term for the propeller hub coupling, and I don't recall it being referred to as a clutch. Also, I don't believe the hub adaptor is rubber. Usually these newer propeller are designed to use a more or less universal plastic insert. The older propeller hub design using a rubber insert seems to have gone almost completely out of fashion. In any case, the rubber inserts are not field replaceable. They need considerable force to press them into the hub. The propeller mentioned above is probably the America Boat Propeller product called the Stilleto "D" Series SS part number D-811315. According to the application chart, it uses a hub kit model DE-503 for Evinrude engines. |
| 64nauset |
You're right Jim. I should have left out the word "clutch" in the post. |
| Tom W Clark |
I have never heard of propeller made by "American Boat Propeller" The propeller used by 64nauset is a Stiletto Advantage 4.25. It uses a field-replacable hub kit. Such hub kits are designed to provide shock protection and can be made of either plastic or rubber. |
American Boat Propellers is a dealer, not a manufacturer. They have a decent website with a listing of many propeller products, including ones called Stiletto. Unfortunately their website has a rather misleading page on which they write in the first person as if they were the manufacturers. See https://www.americanprop.biz/stiletto.cfm It might be helpful to have hyperlinks to the actual manufacturer's website for the Stiletto propeller under discussion, and to the unusual field-replaceable rubber hub kit product. Is there a manufacturer's website for "a Stiletto Advantage 4.25"? I think Stiletto-branded propeller are made by Precision Propeller Industries in Indiana, and they are a wholly-owned subsidiary of Yamaha. See: http://www.turbo-props.com/contact.php But I'll be darned if I can find a listing of propellers called "Stiletto" on that website. |
