ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Long or Short Shaft?
Author | Topic: Long or Short Shaft? |
GA76er |
posted 04-04-2004 10:52 PM ET (US)
I am repowering my '76 Montauk. It now has a 75 hp with a long shaft. Will I need to replace it with a long shaft? or is a Standard 20" ok? |
WHALERBOY 14 |
posted 04-04-2004 11:08 PM ET (US)
A long shaft is 20". the montauk requires a 20" shaft unless you have a jackplate then you can use a 25" shaft. the 20" is correct. You should check your other post http://continuouswave.com/ubb/Forum3/HTML/005878.html Joshua Walters Tightlines & Happy Whalin' |
GA76er |
posted 04-05-2004 12:06 AM ET (US)
thanks |
Sal DiMercurio |
posted 04-05-2004 12:08 AM ET (US)
15" = short shaft. 20" = long shaft. 25" = exta long shaft 30" = extra extra long shaft Sal |
